    4. Test Adapter Midea Dimstal Klimaanlagen v0.0.x
      Thomas Braun Most Active @tombox last edited by Thomas Braun
      @tombox
      Irgendwo klemmt es da wohl noch.
      Schalten kann ich über die ioBroker-Datenpunkte auch nichts. Per FB oder am Geräte geänderte Einstellungen (z. B. die Temperatur) schlagen sich auch nicht in den Datenpunkten nieder. Offenbar wird das nur einmal beim Start des Adapters eingelesen.
      2022-07-06 12:27:31.361  - info: midea.0 (697192) starting. Version 0.1.0 (non-npm: TA2k/ioBroker.midea#fd51f4b710e826e4c3025c70b7eab0d1f771f101) in /opt/iobroker/node_modules/iobroker.midea, node: v18.4.0, js-controller: 4.0.23
      2022-07-06 12:27:56.578  - info: midea.0 (697192) Login successful
      2022-07-06 12:27:56.582  - info: midea.0 (697192) Getting devices
      2022-07-06 12:28:06.220  - info: midea.0 (697192) Found 1 devices
      2022-07-06 12:28:06.240  - info: midea.0 (697192) Missing ip for GERAETE_ID device update via cloud
      2022-07-06 12:28:09.240  - error: midea.0 (697192) Error
      2022-07-06 12:28:09.241  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'appliance_state' failed:
      >                         appliance_state = await this.midea_beautiful.appliance_state$({ cloud: this.cloud, appliance_id: id, use_cloud: true });
        at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:141:43)
        at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:78:9)
      ... across the bridge ...
      > appliance.identify(cloud, use_cloud)
        at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1025)
      > self.refresh(cloud if use_cloud else None)
        at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:810)
      > responses = self._status(cmd, cloud)
        at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381)
      > responses = cloud.appliance_transparent_send(self.appliance_id, data)
        at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538)
      > response = self.api_request(
        at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526)
      > self.handle_api_error(int(payload[error_code_tag]), payload["msg"])
        at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:302)
      > handler()
        at handle_api_error (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:645)
      > raise CloudError(error, message)
        at cloud_error (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:630)
      *** JS *** midea_beautiful.exceptions.CloudError: Midea cloud API error: None (1000)
      2022-07-06 12:30:25.940  - info: switchbot-hub.0 (694063) Connected to SwitchBot API found 4 devices
      2022-07-06 12:30:28.383  - info: switchbot-hub.0 (694063) All devices and values loaded, adapter ready
      2022-07-06 12:31:08.291  - error: midea.0 (697192) Error
      2022-07-06 12:31:08.293  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'set_state' failed:
      >                 await appliance.set_state$(setState);
        at Midea.onStateChange (/opt/iobroker/node_modules/iobroker.midea/main.js:201:17)
      > self.apply(cloud)
        at set_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:827)
        at apply (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:694)
      > handler()
      2022-07-06 12:31:17.080  - error: midea.0 (697192) Error
      2022-07-06 12:31:17.081  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'set_state' failed:
      > self.apply(cloud)
      > handler()
      2022-07-06 12:31:27.084  - info: midea.0 (697192) Missing ip for GERAETE_ID device update via cloud
      2022-07-06 12:31:30.082  - error: midea.0 (697192) Error
      2022-07-06 12:31:30.083  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'appliance_state' failed:
        at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.midea/main.js:208:17)
      > handler()
      2022-07-06 12:33:09.243  - info: midea.0 (697192) Missing ip for GERAETE_ID device update via cloud
      2022-07-06 12:33:12.742  - error: midea.0 (697192) Error
      2022-07-06 12:33:12.743  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'appliance_state' failed:
      > handler()
      2022-07-06 12:38:09.244  - info: midea.0 (697192) Missing ip for GERAETE_ID device update via cloud
      2022-07-06 12:38:12.468  - error: midea.0 (697192) Error
      2022-07-06 12:38:12.469  - error: midea.0 (697192) *** PY ***  Python Error  Call to 'appliance_state' failed:
      > handler()
        tombox @Thomas Braun last edited by
        @thomas-braun Ja hatte ich auch gesehen und auch ein Ticket in dem module aufgemacht
        https://github.com/nbogojevic/midea-beautiful-air/issues/11
        um welche Geräte handelt es sich genau
        Ich würde erstmal abwarten wie der module entwickler reagiert
        TA2k created this issue in nbogojevic/midea-beautiful-air
        closed None capabilities as Error #11
          @tombox
          Das ist eine Mobile Klimaanlage
          Comfee Cool 7000-1
            baeri @tombox last edited by
            @tombox said in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
            @draexler nein 0.1.0 via github
            Wo finde ich die?
              tombox @baeri last edited by
              @baeri Im GitHub symbol oder wie in Beitrag #1 installieren
                toralt @tombox last edited by
                @tombox hab ich installiert, aber es geht bei mir immer noch nichts. muss ich den adapter zunächst komplett deinstallieren? Ich bekomme im Protokoll folgenden Fehler:
                *** PY *** Python Error Call to 'appliance_state' failed:> appliance_state = await this.midea_beautiful.appliance_state$({ at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:149:31) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:80:5)... across the bridge ...> appliance.identify(cloud, use_cloud) at appliance_state (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1041)> self.refresh(cloud if use_cloud else None) at identify (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:826)> responses = self._status(cmd, cloud) at refresh (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381)> responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538)> response = self.api_request( at appliance_transparent_send (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526)> self.handle_api_error(int(payload[error_code_tag]), payload["msg"]) at api_request (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:302)> handler() at handle_api_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:645)> raise CloudError(error, message) at cloud_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:630)*** JS *** midea_beautiful.exceptions.CloudError: Midea cloud API error: None (1000)
                  Thomas Braun Most Active @toralt last edited by
                  @toralt
                  Die Meldungen habe ich auch. Im Terminal funktioniert der Python-Code bei mir grundsätzlich und ich kann die Klimaanlage steuern. Jetzt muss 'nur noch' die Brücke zwischen dem Javascript/nodejs iobroker-Adapter zu Python geschlagen werden.
                  Ob das geht und wie aufwändig das ist? Keine Ahnung
                    ARaS last edited by
                    @tombox Ich bekomme das Plugin leider nicht über Github installiert. Bekomme folgende Fehlermeldung:
                    ERROR: Process exited with code 25
                    Hast du vielleicht einen Tipp für mich?
                    ARaS
                      tombox @ARaS last edited by tombox
                      @aras Bei der Adapterinstallation den Punkt Debug Ausgabe aktivieren
                      Bzw welches Hostsystem und Node Version
                        ARaS last edited by
                        Ok, so wie es aussieht muss ich da wohl ne andere Python Version installieren... 🤔
                        npm ERR! code 1
                        npm ERR! git dep preparation failed
                        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm ERR! > iobroker.midea@0.1.0 postinstallnpm ERR! > node ./pythonPackages.jsnpm ERR!
                        npm ERR! npm ERR! Start Python package installationnpm ERR! Python 3.5.3npm ERR! npm ERR! Python 3 foundnpm ERR! npm ERR! Please install python 3.8npm ERR! npm WARN using --force Recommended protections disabled.npm ERR! npm ERR! code 1npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneKDh0kZnpm ERR! npm ERR! command failednpm ERR! npm ERR! command sh -c node ./pythonPackages.jsnpm ERR! npm ERR! npm ERR! A complete log of this run can be found in:npm ERR! npm ERR! /home/iobroker/.npm/_logs/2022-07-25T12_34_02_885Z-debug-0.log
                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-25T12_33_48_190Z-debug-0.log
                        host.raspberrypi Cannot install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96: 1
                        T Thomas Braun 2 Replies Last reply Reply Quote 0
                          @aras Korrekt der Adapter benötigt mindestens python 3.8
                            Thomas Braun Most Active @ARaS last edited by
                            @aras
                            Aktuelle Debian-Releases kommen mit python 3.9 daher.
                            Vielleicht die Gelegenheit das sinkende Schiff deiner bisherigen Distribution zu verlassen.
                              toralt @Thomas Braun last edited by
                              Danke für die Info. Ich habe davon leider wenig Ahnung, daher verstehe ich zwar theoretisch was Du mir sagen willst, aber mir stellt sich dann wiederum die Frage, warum es jetzt nicht geht aber vorher ging? Wenn ich das richtig sehe, dann hat sich die Python Version geändert? D.h. es gab mal eine "Brücke" aber die braucht ein update?
                              Und noch eine Frage, also es ist aktuell korrekt, dass der Adapter "läuft" aber nichts aktualisiert? Oder sollte er aktualisieren aber ich hab da irgendwo einen Bock?
                              Ich hatte bzw habe meine Klimaanlagen via Yahka und diesem Adapter in Homekit, was wunderbar zu bedienen ging. Die MSmarthome App empfinde ich als mittlere Katastrophe, sehr langsam und man muss sich ständig neu anmelden.
                              Thomas Braun T 3 Replies Last reply Reply Quote 0
                                @toralt
                                Der Adapter wurde weiterentwickelt und fußt jetzt auf Python 3.8 oder neuer. Das musst du dem System zur Verfügung stellen.
                                Das aktuelle stable Release von Debian names 'Bullseye' würde das von Haus aus mitbringen. Was auch immer du da bewegst vielleicht nicht.
                                  tombox @toralt last edited by
                                  @toralt Entweder distribution updaten oder python3 oder eine
                                  alte version vom adapter nehmen
                                  Unter Adapter
                                  Expertenmodus aktivieren
                                  und dann das letzte Icon auswählen
                                    @toralt sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                                    Jein, mit der alten midea API / App funktioniert das im Moment noch, aber mit der neuen API / App muss noch eine Brücke vom ioBroker-Adapter zur python library geschlagen werden.
                                      Ahh, ok, dass ist das Problem. Ich hatte nachdem der Adapter nicht mehr funktionierte auf die neue App umgestellt.
                                      Python 3.9 läuft auf meinem Docker Image soweit ich das gesehen habe.
                                      @tombox and @thomas-braun
                                      Danke Euch beiden, jetzt hab ich das Problem verstanden. MSmarthome und der Adpater geht aktuell nicht, midea App und Adapter funktioniert nach wie vor.
                                        ARaS last edited by
                                        Ich habe nun Python 3.9 am laufen. Aber leider bekomme ich immer noch die Fehlermeldung, dass ich mind. Python 3.8 brauche, damit ich den Adapter installieren kann. Jemand ne Idee was da noch hängt? 🤷‍♂️
                                          @aras Wie ist die genaue debug ausgäbe beim installieren
                                          was kommt bei
                                          python -V
                                          python3 -V
                                          sudo su iobroker
                                          python3 -V
                                            @aras
                                            Wo/wie bist du denn da unterwegs?
                                            sudo ln -s /usr/bin/node /usr/bin/nodejs
                                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                            python --version
                                            Ist zwar eigentlich für was anderes, aber liefert auch sonst einen guten Anhaltspunkt...
                                            1.2k
                                            dimstal midea nethome nethome plus
                                            65
                                            368
                                            82857
