    4. Test Adapter Midea Dimstal Klimaanlagen v0.0.x
      tombox @baeri last edited by
      @baeri Im GitHub symbol oder wie in Beitrag #1 installieren
        toralt @tombox last edited by
        @tombox hab ich installiert, aber es geht bei mir immer noch nichts. muss ich den adapter zunächst komplett deinstallieren? Ich bekomme im Protokoll folgenden Fehler:
        *** PY *** Python Error Call to 'appliance_state' failed:> appliance_state = await this.midea_beautiful.appliance_state$({ at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:149:31) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:80:5)... across the bridge ...> appliance.identify(cloud, use_cloud) at appliance_state (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1041)> self.refresh(cloud if use_cloud else None) at identify (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:826)> responses = self._status(cmd, cloud) at refresh (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381)> responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538)> response = self.api_request( at appliance_transparent_send (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526)> self.handle_api_error(int(payload[error_code_tag]), payload["msg"]) at api_request (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:302)> handler() at handle_api_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:645)> raise CloudError(error, message) at cloud_error (/opt/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:630)*** JS *** midea_beautiful.exceptions.CloudError: Midea cloud API error: None (1000)
          Thomas Braun Most Active @toralt last edited by
          @toralt
          Die Meldungen habe ich auch. Im Terminal funktioniert der Python-Code bei mir grundsätzlich und ich kann die Klimaanlage steuern. Jetzt muss 'nur noch' die Brücke zwischen dem Javascript/nodejs iobroker-Adapter zu Python geschlagen werden.
          Ob das geht und wie aufwändig das ist? Keine Ahnung
            ARaS last edited by
            @tombox Ich bekomme das Plugin leider nicht über Github installiert. Bekomme folgende Fehlermeldung:
            ERROR: Process exited with code 25
            Hast du vielleicht einen Tipp für mich?
            ARaS
              tombox @ARaS last edited by tombox
              @aras Bei der Adapterinstallation den Punkt Debug Ausgabe aktivieren
              Bzw welches Hostsystem und Node Version
                ARaS last edited by
                Ok, so wie es aussieht muss ich da wohl ne andere Python Version installieren... 🤔
                npm ERR! code 1
                npm ERR! git dep preparation failed
                npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm ERR! > iobroker.midea@0.1.0 postinstallnpm ERR! > node ./pythonPackages.jsnpm ERR!
                npm ERR! npm ERR! Start Python package installationnpm ERR! Python 3.5.3npm ERR! npm ERR! Python 3 foundnpm ERR! npm ERR! Please install python 3.8npm ERR! npm WARN using --force Recommended protections disabled.npm ERR! npm ERR! code 1npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneKDh0kZnpm ERR! npm ERR! command failednpm ERR! npm ERR! command sh -c node ./pythonPackages.jsnpm ERR! npm ERR! npm ERR! A complete log of this run can be found in:npm ERR! npm ERR! /home/iobroker/.npm/_logs/2022-07-25T12_34_02_885Z-debug-0.log
                npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-25T12_33_48_190Z-debug-0.log
                host.raspberrypi Cannot install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96: 1
                T Thomas Braun 2 Replies Last reply Reply Quote 0
                  @aras Korrekt der Adapter benötigt mindestens python 3.8
                    Thomas Braun Most Active @ARaS last edited by
                    @aras
                    Aktuelle Debian-Releases kommen mit python 3.9 daher.
                    Vielleicht die Gelegenheit das sinkende Schiff deiner bisherigen Distribution zu verlassen.
                      toralt @Thomas Braun last edited by
                      Danke für die Info. Ich habe davon leider wenig Ahnung, daher verstehe ich zwar theoretisch was Du mir sagen willst, aber mir stellt sich dann wiederum die Frage, warum es jetzt nicht geht aber vorher ging? Wenn ich das richtig sehe, dann hat sich die Python Version geändert? D.h. es gab mal eine "Brücke" aber die braucht ein update?
                      Und noch eine Frage, also es ist aktuell korrekt, dass der Adapter "läuft" aber nichts aktualisiert? Oder sollte er aktualisieren aber ich hab da irgendwo einen Bock?
                      Ich hatte bzw habe meine Klimaanlagen via Yahka und diesem Adapter in Homekit, was wunderbar zu bedienen ging. Die MSmarthome App empfinde ich als mittlere Katastrophe, sehr langsam und man muss sich ständig neu anmelden.
                      Thomas Braun T 3 Replies Last reply Reply Quote 0
                        @toralt
                        Der Adapter wurde weiterentwickelt und fußt jetzt auf Python 3.8 oder neuer. Das musst du dem System zur Verfügung stellen.
                        Das aktuelle stable Release von Debian names 'Bullseye' würde das von Haus aus mitbringen. Was auch immer du da bewegst vielleicht nicht.
                          tombox @toralt last edited by
                          @toralt Entweder distribution updaten oder python3 oder eine
                          alte version vom adapter nehmen
                          Unter Adapter
                          Expertenmodus aktivieren
                          und dann das letzte Icon auswählen
                            @toralt sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                            Jein, mit der alten midea API / App funktioniert das im Moment noch, aber mit der neuen API / App muss noch eine Brücke vom ioBroker-Adapter zur python library geschlagen werden.
                              Ahh, ok, dass ist das Problem. Ich hatte nachdem der Adapter nicht mehr funktionierte auf die neue App umgestellt.
                              Python 3.9 läuft auf meinem Docker Image soweit ich das gesehen habe.
                              @tombox and @thomas-braun
                              Danke Euch beiden, jetzt hab ich das Problem verstanden. MSmarthome und der Adpater geht aktuell nicht, midea App und Adapter funktioniert nach wie vor.
                                ARaS last edited by
                                Ich habe nun Python 3.9 am laufen. Aber leider bekomme ich immer noch die Fehlermeldung, dass ich mind. Python 3.8 brauche, damit ich den Adapter installieren kann. Jemand ne Idee was da noch hängt? 🤷‍♂️
                                  @aras Wie ist die genaue debug ausgäbe beim installieren
                                  was kommt bei
                                  python -V
                                  python3 -V
                                  sudo su iobroker
                                  python3 -V
                                    @aras
                                    Wo/wie bist du denn da unterwegs?
                                    sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    python --version
                                    Ist zwar eigentlich für was anderes, aber liefert auch sonst einen guten Anhaltspunkt...
                                      ARaS last edited by
                                      Also unter python -V habe ich nun die neu installierte Python Version 3.9.12. Python3 hab ich da jetzt nicht mehr verknüpft.
                                      Beim installieren kommt folgende Meldung:
                                      npm ERR! code 1
                                      npm ERR! > iobroker.midea@0.1.0 postinstallnpm ERR! > node ./pythonPackages.jsnpm ERR! npm ERR! npm ERR! Start Python package installationnpm ERR! npm ERR! Python 3 not found. Please install minimum python 3.8npm ERR! npm WARN using --force Recommended protections disabled.npm ERR! /bin/sh: 1: python3: not foundnpm ERR! npm ERR! code 1npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-clonenZK3zUnpm ERR! npm ERR! command failednpm ERR! npm ERR! command sh -c node ./pythonPackages.jsnpm ERR! npm ERR! npm ERR! A complete log of this run can be found in:npm ERR! npm ERR! /home/iobroker/.npm/_logs/2022-07-25T14_49_37_774Z-debug-0.log
                                      npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-07-25T14_49_22_118Z-debug-0.log
                                        @aras die symlinks für python3 werden eigentlich automatisch angelegt. Wie hast du es genau installiert
                                          ARaS last edited by
                                          Ich hab das nach der Vorlage hier gemacht https://allurcode.com/install-latest-version-of-python-on-raspberry-pi/
                                          Da es aber erst mal nicht funktioniert hat, habe ich die Verknüpfung anstatt auf Python3 direkt auf Python gesetzt.
                                            @aras
                                            Macht man nicht so.
                                            Was hast du denn da nun für ein System?
                                            1.2k
                                            dimstal midea nethome nethome plus
                                            65
                                            368
                                            82858
