    4. Bluetooth Adapter stellt betrieb nach ein paar Minuten ein
    • AlCalzone
      AlCalzone Developer @Peter1980 last edited by
      @peter1980 Temporär aufs Beta-Repository wechseln, BLE 0.13 installieren, dann zurück auf Stable
        Thomas Braun Most Active @Peter1980 last edited by Thomas Braun
        @peter1980
        Warum in Gottesnamen immer diese Fixierung auf git?
        Damit tut man sich i.d.R. keinen Gefallen. Nimm die V 013.0 aus dem Beta-Zweig. Ich vermute aber, das dein Problem unabhängig von der Version des Adapters aus der Betriebssystemebene kommt.
        ble
        github:	0.13.0 for 19 days
        latest:	0.13.0 for 84 days
        stable:	0.12.0 for 20 months
        • AlCalzone
          AlCalzone Developer @Thomas Braun last edited by
          @thomas-braun Es könnte tatsächlich sein, dass 0.13.0 das behebt. Die bringt eine neuere Version von noble mit, die diesen Commit enthält:
          https://github.com/abandonware/noble/commit/f9854e34c3e74d7fb58cd983f8d45604f4b0eca2
          Fix out of range errors for malformed EIR data.
          0 sandoval committed to abandonware/noble
          We've sometimes encountered in the wild devices that have malformed
          EIR data structures.
          For example, we've found the device 1c:52:16:b8:6a:f2 that
          provided the `eir` buffer with data:
          `[30,3,18,162,77,46,254,20,72,142,147,210,23,60,253,2,48,128,74,92,243,232,188,150,82,60,64,0,0,0,0]`.
          This caused an out of bounds error on line 146, when
          calling function `bytes.readUInt16LE(j)`
          with `j = 28` which fails, since we're trying to read two bytes
          starting from position 28 when `bytes` has only 29 elements.
          The proposed solution respects the bounds of the `bytes` buffer when
          reading from its positions directly.
          While running scan on one device using noble, use another bluetooth-enabled linux device
          to run a service with malformed EIR data by executing these commands:
          sudo hciconfig hci0 up
          sudo hciconfig hci0 leadv 3
          sudo hcitool -i hci0 cmd 0x08 0x0008 05 04 03 02 01 00
          Co-authored-by: Filipe Carvalhedo <filipecarvalhedo@hotmail.com>
          Co-authored-by: Pedro Santana <pedrohenrique@loopkey.com.br>
            Thomas Braun Most Active @AlCalzone last edited by
            @alcalzone
            Okay, aktuellere lib kann natürlich gut sein.
            • haselchen
              haselchen Most Active @Thomas Braun last edited by
              @AlCalzone
              Hatte ich vor 23 Stunden dem TE schon geraten 😉
              (Mehrmals)
                Peter1980 @haselchen last edited by
                Also ich habe alles aktualisiert, inkl. v0.13. Jetzt bin ich noch am beobachten.
                Aber es ist auf jeden Fall besser geworden.
                Ob es wirklich stabil und fehlerfrei bleibt werde ich zurück melden.
                Hatte am WE auch kaum Zeit dafür.
                  Peter1980 @AlCalzone last edited by Peter1980
                  @alcalzone Wusste nicht das es die Funktion gibt. Jetzt hab ich Sie auch gefunden.
                  Hatte es aber schon mit dem GIT Repo link direkt aus dem Repo geupdatet.
                  Danke.
                    Peter1980 last edited by Peter1980
                    Weiterhin das gleiche Thema. Noch jemand ne gute Idee/Ratschlag?
                    • AlCalzone
                      @peter1980 Hast du noch andere Bluetooth-Hardware zum Testen? z.B. Raspberry statt externem Dongle oder umgekehrt?
                        @alcalzone aktuell nicht. Kann einen anderen externen dongel besorgen. Ich hab als Hardware einen revpi ohne Bluetooth.
                        931
