    4. Serial Port Raspberry Problem
      babl @Thomas Braun last edited by
      @thomas-braun dieses hier:
      [Fr Jul 22 08:52:18 2022] Booting Linux on physical CPU 0x0
      [Fr Jul 22 08:52:18 2022] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-                   gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for U                   buntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
      [Fr Jul 22 08:52:18 2022] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr                   =30c5383d
      [Fr Jul 22 08:52:18 2022] CPU: div instructions available: patching division cod                   e
      [Fr Jul 22 08:52:18 2022] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruct                   ion cache
      [Fr Jul 22 08:52:18 2022] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
      [Fr Jul 22 08:52:18 2022] random: fast init done
      [Fr Jul 22 08:52:18 2022] Memory policy: Data cache writealloc
      [Fr Jul 22 08:52:18 2022] Reserved memory: created CMA memory pool at 0x00000000                   1ac00000, size 320 MiB
      [Fr Jul 22 08:52:18 2022] OF: reserved mem: initialized node linux,cma, compatib                   le id shared-dma-pool
      [Fr Jul 22 08:52:18 2022] Zone ranges:
      [Fr Jul 22 08:52:18 2022]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
      [Fr Jul 22 08:52:18 2022]   Normal   empty
      [Fr Jul 22 08:52:18 2022]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
      [Fr Jul 22 08:52:18 2022] Movable zone start for each node
      [Fr Jul 22 08:52:18 2022] Early memory node ranges
      [Fr Jul 22 08:52:18 2022]   node   0: [mem 0x0000000000000000-0x000000003e5fffff                   ]
      [Fr Jul 22 08:52:18 2022]   node   0: [mem 0x0000000040000000-0x00000000fbffffff                   ]
      [Fr Jul 22 08:52:18 2022] Initmem setup node 0 [mem 0x0000000000000000-0x0000000                   0fbffffff]
      [Fr Jul 22 08:52:18 2022] On node 0 totalpages: 1025536
      [Fr Jul 22 08:52:18 2022]   DMA zone: 1728 pages used for memmap
      [Fr Jul 22 08:52:18 2022]   DMA zone: 0 pages reserved
      [Fr Jul 22 08:52:18 2022]   DMA zone: 196608 pages, LIFO batch:63
      [Fr Jul 22 08:52:18 2022]   HighMem zone: 828928 pages, LIFO batch:63
      [Fr Jul 22 08:52:18 2022] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u819                   20
      [Fr Jul 22 08:52:18 2022] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
      [Fr Jul 22 08:52:18 2022] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [Fr Jul 22 08:52:18 2022] Built 1 zonelists, mobility grouping on.  Total pages:                    1023808
      [Fr Jul 22 08:52:18 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0                    snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:                   A6:32:84:F3:CA vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=tt                   yS0,115200 console=tty1 root=PARTUUID=8dd2d595-02 rootfstype=ext4 elevator=deadl                   ine fsck.repair=yes rootwait
      [Fr Jul 22 08:52:18 2022] Kernel parameter elevator= does not have any effect an                   ymore.
                                Please use sysfs to set IO scheduler for individual de                   vices.
      [Fr Jul 22 08:52:18 2022] Dentry cache hash table entries: 131072 (order: 7, 524                   288 bytes, linear)
      [Fr Jul 22 08:52:18 2022] Inode-cache hash table entries: 65536 (order: 6, 26214                   4 bytes, linear)
      [Fr Jul 22 08:52:18 2022] mem auto-init: stack:off, heap alloc:off, heap free:of                   f
      [Fr Jul 22 08:52:18 2022] software IO TLB: mapped [mem 0x0000000014890000-0x0000                   000018890000] (64MB)
      [Fr Jul 22 08:52:18 2022] Memory: 3651872K/4102144K available (10240K kernel cod                   e, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 122592K reserved, 327680K c                   ma-reserved, 3315712K highmem)
      [Fr Jul 22 08:52:18 2022] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nod                   es=1
      [Fr Jul 22 08:52:18 2022] ftrace: allocating 34355 entries in 101 pages
      [Fr Jul 22 08:52:18 2022] ftrace: allocated 101 pages with 4 groups
      [Fr Jul 22 08:52:18 2022] rcu: Hierarchical RCU implementation.
      [Fr Jul 22 08:52:18 2022]       Rude variant of Tasks RCU enabled.
      [Fr Jul 22 08:52:18 2022]       Tracing variant of Tasks RCU enabled.
      [Fr Jul 22 08:52:18 2022] rcu: RCU calculated value of scheduler-enlistment dela                   y is 10 jiffies.
      [Fr Jul 22 08:52:18 2022] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [Fr Jul 22 08:52:18 2022] GIC: Using split EOI/Deactivate mode
      [Fr Jul 22 08:52:18 2022] random: get_random_bytes called from start_kernel+0x3c                   8/0x59c with crng_init=1
      [Fr Jul 22 08:52:18 2022] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wr                   aps every 2147483647500ns
      [Fr Jul 22 08:52:18 2022] clocksource: timer: mask: 0xffffffff max_cycles: 0xfff                   fffff, max_idle_ns: 1911260446275 ns
      [Fr Jul 22 08:52:18 2022] bcm2835: system timer (irq = 25)
      [Fr Jul 22 08:52:18 2022] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [Fr Jul 22 08:52:18 2022] clocksource: arch_sys_counter: mask: 0xffffffffffffff                    max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [Fr Jul 22 08:52:18 2022] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps                    every 4398046511102ns
      [Fr Jul 22 08:52:18 2022] Switching to timer-based delay loop, resolution 18ns
      [Fr Jul 22 08:52:18 2022] Console: colour dummy device 80x30
      [Fr Jul 22 08:52:18 2022] printk: console [tty1] enabled
      [Fr Jul 22 08:52:18 2022] Calibrating delay loop (skipped), value calculated usi                   ng timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [Fr Jul 22 08:52:18 2022] pid_max: default: 32768 minimum: 301
      [Fr Jul 22 08:52:18 2022] LSM: Security Framework initializing
      [Fr Jul 22 08:52:18 2022] Mount-cache hash table entries: 2048 (order: 1, 8192 b                   ytes, linear)
      [Fr Jul 22 08:52:18 2022] Mountpoint-cache hash table entries: 2048 (order: 1, 8                   192 bytes, linear)
      [Fr Jul 22 08:52:18 2022] cgroup: Disabling memory control group subsystem
      [Fr Jul 22 08:52:18 2022] CPU: Testing write buffer coherency: ok
      [Fr Jul 22 08:52:18 2022] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [Fr Jul 22 08:52:18 2022] Setting up static identity map for 0x200000 - 0x20003c
      [Fr Jul 22 08:52:18 2022] rcu: Hierarchical SRCU implementation.
      [Fr Jul 22 08:52:18 2022] smp: Bringing up secondary CPUs ...
      [Fr Jul 22 08:52:18 2022] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [Fr Jul 22 08:52:18 2022] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [Fr Jul 22 08:52:18 2022] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [Fr Jul 22 08:52:18 2022] smp: Brought up 1 node, 4 CPUs
      [Fr Jul 22 08:52:18 2022] SMP: Total of 4 processors activated (432.00 BogoMIPS)                   .
      [Fr Jul 22 08:52:18 2022] CPU: All CPU(s) started in HYP mode.
      [Fr Jul 22 08:52:18 2022] CPU: Virtualization extensions available.
      [Fr Jul 22 08:52:18 2022] devtmpfs: initialized
      [Fr Jul 22 08:52:18 2022] VFP support v0.3: implementor 41 architecture 3 part 4                   0 variant 8 rev 0
      [Fr Jul 22 08:52:18 2022] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xf                   fffffff, max_idle_ns: 19112604462750000 ns
      [Fr Jul 22 08:52:18 2022] futex hash table entries: 1024 (order: 4, 65536 bytes,                    linear)
      [Fr Jul 22 08:52:18 2022] pinctrl core: initialized pinctrl subsystem
      [Fr Jul 22 08:52:18 2022] NET: Registered protocol family 16
      [Fr Jul 22 08:52:18 2022] DMA: preallocated 1024 KiB pool for atomic coherent al                   locations
      [Fr Jul 22 08:52:18 2022] audit: initializing netlink subsys (disabled)
      [Fr Jul 22 08:52:18 2022] audit: type=2000 audit(0.030:1): state=initialized aud                   it_enabled=0 res=1
      [Fr Jul 22 08:52:18 2022] thermal_sys: Registered thermal governor 'step_wise'
      [Fr Jul 22 08:52:18 2022] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4                    watchpoint registers.
      [Fr Jul 22 08:52:18 2022] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [Fr Jul 22 08:52:18 2022] Serial: AMBA PL011 UART driver
      [Fr Jul 22 08:52:18 2022] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [Fr Jul 22 08:52:18 2022] raspberrypi-firmware soc:firmware: Attached to firmwar                   e from 2021-12-01T15:02:10, variant start_cd
      [Fr Jul 22 08:52:18 2022] raspberrypi-firmware soc:firmware: Firmware hash is 71                   bd3109023a0c8575585ba87cbb374d2eeb038f
      [Fr Jul 22 08:52:18 2022] Kprobes globally optimized
      [Fr Jul 22 08:52:18 2022] bcm2835-dma fe007000.dma: DMA legacy API manager, dmac                   hans=0x1
      [Fr Jul 22 08:52:18 2022] vgaarb: loaded
      [Fr Jul 22 08:52:18 2022] SCSI subsystem initialized
      [Fr Jul 22 08:52:18 2022] usbcore: registered new interface driver usbfs
      [Fr Jul 22 08:52:18 2022] usbcore: registered new interface driver hub
      [Fr Jul 22 08:52:18 2022] usbcore: registered new device driver usb
      [Fr Jul 22 08:52:18 2022] usb_phy_generic phy: supply vcc not found, using dummy                    regulator
      [Fr Jul 22 08:52:18 2022] clocksource: Switched to clocksource arch_sys_counter
      [Fr Jul 22 08:52:19 2022] VFS: Disk quotas dquot_6.6.0
      [Fr Jul 22 08:52:19 2022] VFS: Dquot-cache hash table entries: 1024 (order 0, 40                   96 bytes)
      [Fr Jul 22 08:52:19 2022] FS-Cache: Loaded
      [Fr Jul 22 08:52:19 2022] CacheFiles: Loaded
      [Fr Jul 22 08:52:19 2022] NET: Registered protocol family 2
      [Fr Jul 22 08:52:19 2022] IP idents hash table entries: 16384 (order: 5, 131072                    bytes, linear)
      [Fr Jul 22 08:52:19 2022] tcp_listen_portaddr_hash hash table entries: 512 (orde                   r: 0, 6144 bytes, linear)
      [Fr Jul 22 08:52:19 2022] TCP established hash table entries: 8192 (order: 3, 32                   768 bytes, linear)
      [Fr Jul 22 08:52:19 2022] TCP bind hash table entries: 8192 (order: 4, 65536 byt                   es, linear)
      [Fr Jul 22 08:52:19 2022] TCP: Hash tables configured (established 8192 bind 819                   2)
      [Fr Jul 22 08:52:19 2022] UDP hash table entries: 512 (order: 2, 16384 bytes, li                   near)
      [Fr Jul 22 08:52:19 2022] UDP-Lite hash table entries: 512 (order: 2, 16384 byte                   s, linear)
      [Fr Jul 22 08:52:19 2022] NET: Registered protocol family 1
      [Fr Jul 22 08:52:19 2022] RPC: Registered named UNIX socket transport module.
      [Fr Jul 22 08:52:19 2022] RPC: Registered udp transport module.
      [Fr Jul 22 08:52:19 2022] RPC: Registered tcp transport module.
      [Fr Jul 22 08:52:19 2022] RPC: Registered tcp NFSv4.1 backchannel transport modu                   le.
      [Fr Jul 22 08:52:19 2022] PCI: CLS 0 bytes, default 64
      [Fr Jul 22 08:52:19 2022] Initialise system trusted keyrings
      [Fr Jul 22 08:52:19 2022] workingset: timestamp_bits=14 max_order=20 bucket_orde                   r=6
      [Fr Jul 22 08:52:19 2022] zbud: loaded
      [Fr Jul 22 08:52:19 2022] FS-Cache: Netfs 'nfs' registered for caching
      [Fr Jul 22 08:52:19 2022] NFS: Registering the id_resolver key type
      [Fr Jul 22 08:52:19 2022] Key type id_resolver registered
      [Fr Jul 22 08:52:19 2022] Key type id_legacy registered
      [Fr Jul 22 08:52:19 2022] nfs4filelayout_init: NFSv4 File Layout Driver Register                   ing...
      [Fr Jul 22 08:52:19 2022] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver                    Registering...
      [Fr Jul 22 08:52:19 2022] Key type asymmetric registered
      [Fr Jul 22 08:52:19 2022] Asymmetric key parser 'x509' registered
      [Fr Jul 22 08:52:19 2022] bounce: pool size: 64 pages
      [Fr Jul 22 08:52:19 2022] Block layer SCSI generic (bsg) driver version 0.4 load                   ed (major 249)
      [Fr Jul 22 08:52:19 2022] io scheduler mq-deadline registered
      [Fr Jul 22 08:52:19 2022] io scheduler kyber registered
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d50000                   0 ranges:
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie:   No bus range found for /scb                   /pcie@7d500000, using [bus 00-ff]
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063f                   ffffff -> 0x00c0000000
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bf                   ffffff -> 0x0400000000
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SS                   C)
      [Fr Jul 22 08:52:19 2022] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:0                   0
      [Fr Jul 22 08:52:19 2022] pci_bus 0000:00: root bus resource [bus 00-ff]
      [Fr Jul 22 08:52:19 2022] pci_bus 0000:00: root bus resource [mem 0x600000000-0x                   63fffffff] (bus address [0xc0000000-0xffffffff])
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0: PME# supported from D0 D3hot
      [Fr Jul 22 08:52:19 2022] PCI: bus0: Fast back to back transfers disabled
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0: bridge configuration invalid ([bus 0                   0-00]), reconfiguring
      [Fr Jul 22 08:52:19 2022] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [Fr Jul 22 08:52:19 2022] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff                    64bit]
      [Fr Jul 22 08:52:19 2022] pci 0000:01:00.0: PME# supported from D0 D3cold
      [Fr Jul 22 08:52:19 2022] PCI: bus1: Fast back to back transfers disabled
      [Fr Jul 22 08:52:19 2022] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated                    to 01
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6                   000fffff]
      [Fr Jul 22 08:52:19 2022] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x6                   00000fff 64bit]
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0: PCI bridge to [bus 01]
      [Fr Jul 22 08:52:19 2022] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6                   000fffff]
      [Fr Jul 22 08:52:19 2022] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [Fr Jul 22 08:52:19 2022] pcieport 0000:00:00.0: PME: Signaling with IRQ 63
      [Fr Jul 22 08:52:19 2022] iproc-rng200 fe104000.rng: hwrng registered
      [Fr Jul 22 08:52:19 2022] vc-mem: phys_addr:0x00000000 mem_base=0x3f000000 mem_s                   ize:0x3f600000(1014 MiB)
      [Fr Jul 22 08:52:19 2022] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registe                   rs at 0xfe200000
      [Fr Jul 22 08:52:19 2022] brd: module loaded
      [Fr Jul 22 08:52:19 2022] loop: module loaded
      [Fr Jul 22 08:52:19 2022] Loading iSCSI transport class v2.0-870.
      [Fr Jul 22 08:52:19 2022] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [Fr Jul 22 08:52:19 2022] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver r8152
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver lan78xx
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver smsc95xx
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigne                   d bus number 1
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci versi                   on 0x100 quirks 0x0000060000000890
      [Fr Jul 22 08:52:19 2022] usb usb1: New USB device found, idVendor=1d6b, idProdu                   ct=0002, bcdDevice= 5.10
      [Fr Jul 22 08:52:19 2022] usb usb1: New USB device strings: Mfr=3, Product=2, Se                   rialNumber=1
      [Fr Jul 22 08:52:19 2022] usb usb1: Product: xHCI Host Controller
      [Fr Jul 22 08:52:19 2022] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
      [Fr Jul 22 08:52:19 2022] usb usb1: SerialNumber: 0000:01:00.0
      [Fr Jul 22 08:52:19 2022] hub 1-0:1.0: USB hub found
      [Fr Jul 22 08:52:19 2022] hub 1-0:1.0: 1 port detected
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: new USB bus registered, assigne                   d bus number 2
      [Fr Jul 22 08:52:19 2022] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpee                   d
      [Fr Jul 22 08:52:19 2022] usb usb2: New USB device found, idVendor=1d6b, idProdu                   ct=0003, bcdDevice= 5.10
      [Fr Jul 22 08:52:19 2022] usb usb2: New USB device strings: Mfr=3, Product=2, Se                   rialNumber=1
      [Fr Jul 22 08:52:19 2022] usb usb2: Product: xHCI Host Controller
      [Fr Jul 22 08:52:19 2022] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
      [Fr Jul 22 08:52:19 2022] usb usb2: SerialNumber: 0000:01:00.0
      [Fr Jul 22 08:52:19 2022] hub 2-0:1.0: USB hub found
      [Fr Jul 22 08:52:19 2022] hub 2-0:1.0: 4 ports detected
      [Fr Jul 22 08:52:19 2022] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [Fr Jul 22 08:52:19 2022] dwc_otg: FIQ enabled
      [Fr Jul 22 08:52:19 2022] dwc_otg: NAK holdoff enabled
      [Fr Jul 22 08:52:19 2022] dwc_otg: FIQ split-transaction FSM enabled
      [Fr Jul 22 08:52:19 2022] Module dwc_common_port init
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver uas
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver usb-storage
      [Fr Jul 22 08:52:19 2022] mousedev: PS/2 mouse device common for all mice
      [Fr Jul 22 08:52:19 2022] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog tim                   er
      [Fr Jul 22 08:52:19 2022] sdhci: Secure Digital Host Controller Interface driver
      [Fr Jul 22 08:52:19 2022] sdhci: Copyright(c) Pierre Ossman
      [Fr Jul 22 08:52:19 2022] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferri                   ng probe
      [Fr Jul 22 08:52:19 2022] sdhci-pltfm: SDHCI platform and OF driver helper
      [Fr Jul 22 08:52:19 2022] ledtrig-cpu: registered to indicate activity on CPUs
      [Fr Jul 22 08:52:19 2022] hid: raw HID events driver (C) Jiri Kosina
      [Fr Jul 22 08:52:19 2022] usbcore: registered new interface driver usbhid
      [Fr Jul 22 08:52:19 2022] usbhid: USB HID core driver
      [Fr Jul 22 08:52:19 2022] Initializing XFRM netlink socket
      [Fr Jul 22 08:52:19 2022] NET: Registered protocol family 17
      [Fr Jul 22 08:52:19 2022] Key type dns_resolver registered
      [Fr Jul 22 08:52:19 2022] Registering SWP/SWPB emulation handler
      [Fr Jul 22 08:52:19 2022] registered taskstats version 1
      [Fr Jul 22 08:52:19 2022] Loading compiled-in X.509 certificates
      [Fr Jul 22 08:52:19 2022] Key type ._fscrypt registered
      [Fr Jul 22 08:52:19 2022] Key type .fscrypt registered
      [Fr Jul 22 08:52:19 2022] Key type fscrypt-provisioning registered
      [Fr Jul 22 08:52:19 2022] uart-pl011 fe201000.serial: there is not valid maps fo                   r state default
      [Fr Jul 22 08:52:19 2022] uart-pl011 fe201000.serial: cts_event_workaround enabl                   ed
      [Fr Jul 22 08:52:19 2022] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36,                    base_baud = 0) is a PL011 rev2
      [Fr Jul 22 08:52:19 2022] bcm2835-power bcm2835-power: Broadcom BCM2835 power do                   mains driver
      [Fr Jul 22 08:52:19 2022] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [Fr Jul 22 08:52:19 2022] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [Fr Jul 22 08:52:19 2022] of_cfs_init
      [Fr Jul 22 08:52:19 2022] of_cfs_init: OK
      [Fr Jul 22 08:52:19 2022] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [Fr Jul 22 08:52:19 2022] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [Fr Jul 22 08:52:19 2022] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [Fr Jul 22 08:52:19 2022] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc]                    using ADMA
      [Fr Jul 22 08:52:19 2022] Waiting for root device PARTUUID=8dd2d595-02...
      [Fr Jul 22 08:52:19 2022] mmc1: new high speed SDIO card at address 0001
      [Fr Jul 22 08:52:19 2022] usb 1-1: new high-speed USB device number 2 using xhci                   _hcd
      [Fr Jul 22 08:52:19 2022] usb 1-1: New USB device found, idVendor=2109, idProduc                   t=3431, bcdDevice= 4.21
      [Fr Jul 22 08:52:19 2022] usb 1-1: New USB device strings: Mfr=0, Product=1, Ser                   ialNumber=0
      [Fr Jul 22 08:52:19 2022] usb 1-1: Product: USB2.0 Hub
      [Fr Jul 22 08:52:19 2022] hub 1-1:1.0: USB hub found
      [Fr Jul 22 08:52:19 2022] hub 1-1:1.0: 4 ports detected
      [Fr Jul 22 08:52:19 2022] usb 2-2: new SuperSpeed Gen 1 USB device number 2 usin                   g xhci_hcd
      [Fr Jul 22 08:52:19 2022] usb 2-2: New USB device found, idVendor=04e8, idProduc                   t=61f5, bcdDevice= 1.00
      [Fr Jul 22 08:52:19 2022] usb 2-2: New USB device strings: Mfr=2, Product=3, Ser                   ialNumber=1
      [Fr Jul 22 08:52:19 2022] usb 2-2: Product: Portable SSD T5
      [Fr Jul 22 08:52:19 2022] usb 2-2: Manufacturer: Samsung
      [Fr Jul 22 08:52:19 2022] usb 2-2: SerialNumber: 123456869C93
      [Fr Jul 22 08:52:20 2022] scsi host0: uas
      [Fr Jul 22 08:52:20 2022] scsi 0:0:0:0: Direct-Access     Samsung  Portable SSD                    T5  0    PQ: 0 ANSI: 6
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (                   500 GB/466 GiB)
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] Write Protect is off
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] Write cache: enabled, read cache: en                   abled, doesn't support DPO or FUA
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes
      [Fr Jul 22 08:52:20 2022]  sda: sda1 sda2
      [Fr Jul 22 08:52:20 2022] sd 0:0:0:0: [sda] Attached SCSI disk
      [Fr Jul 22 08:52:20 2022] EXT4-fs (sda2): mounted filesystem with ordered data m                   ode. Opts: (null)
      [Fr Jul 22 08:52:20 2022] VFS: Mounted root (ext4 filesystem) readonly on device                    8:2.
      [Fr Jul 22 08:52:20 2022] devtmpfs: mounted
      [Fr Jul 22 08:52:20 2022] Freeing unused kernel memory: 2048K
      [Fr Jul 22 08:52:20 2022] Run /sbin/init as init process
      [Fr Jul 22 08:52:20 2022]   with arguments:
      [Fr Jul 22 08:52:20 2022]     /sbin/init
      [Fr Jul 22 08:52:20 2022]   with environment:
      [Fr Jul 22 08:52:20 2022]     HOME=/
      [Fr Jul 22 08:52:20 2022]     TERM=linux
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: new full-speed USB device number 3 using xh                   ci_hcd
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: New USB device found, idVendor=1cf1, idProd                   uct=0030, bcdDevice= 1.00
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: New USB device strings: Mfr=1, Product=2, S                   erialNumber=3
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: Product: ConBee II
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: Manufacturer: dresden elektronik ingenieurt                   echnik GmbH
      [Fr Jul 22 08:52:20 2022] usb 1-1.3: SerialNumber: DE2255974
      [Fr Jul 22 08:52:20 2022] systemd[1]: System time before build time, advancing c                   lock.
      [Fr Jul 22 08:52:20 2022] NET: Registered protocol family 10
      [Fr Jul 22 08:52:20 2022] Segment Routing with IPv6
      [Fr Jul 22 08:52:20 2022] systemd[1]: systemd 241 running in system mode. (+PAM                    +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN                   UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie                   rarchy=hybrid)
      [Fr Jul 22 08:52:20 2022] systemd[1]: Detected architecture arm.
      [Fr Jul 22 08:52:20 2022] systemd[1]: Set hostname to <raspberrypi>.
      [Fr Jul 22 08:52:20 2022] usb 1-1.4: new low-speed USB device number 4 using xhc                   i_hcd
      [Fr Jul 22 08:52:21 2022] systemd[1]: /lib/systemd/system/nut-monitor.service:6:                    PIDFile= references path below legacy directory /var/run/, updating /var/run/nu                   t/upsmon.pid → /run/nut/upsmon.pid; please update the unit file accordingly.
      [Fr Jul 22 08:52:21 2022] random: systemd: uninitialized urandom read (16 bytes                    read)
      [Fr Jul 22 08:52:21 2022] systemd[1]: Set up automount Arbitrary Executable File                    Formats File System Automount Point.
      [Fr Jul 22 08:52:21 2022] systemd[1]: Created slice system-getty.slice.
      [Fr Jul 22 08:52:21 2022] systemd[1]: Listening on Journal Socket.
      [Fr Jul 22 08:52:21 2022] systemd[1]: Condition check resulted in Kernel Module                    supporting RPCSEC_GSS being skipped.
      [Fr Jul 22 08:52:21 2022] systemd[1]: Mounting Kernel Debug File System...
      [Fr Jul 22 08:52:21 2022] systemd[1]: Condition check resulted in Set Up Additio                   nal Binary Formats being skipped.
      [Fr Jul 22 08:52:21 2022] i2c /dev entries driver
      [Fr Jul 22 08:52:21 2022] snd_bcm2835: module is from the staging directory, the                    quality is unknown, you have been warned.
      [Fr Jul 22 08:52:21 2022] bcm2835_audio bcm2835_audio: card created with 8 chann                   els
      [Fr Jul 22 08:52:22 2022] EXT4-fs (sda2): re-mounted. Opts: (null)
      [Fr Jul 22 08:52:22 2022] systemd-journald[121]: Received request to flush runti                   me journal from PID 1
      [Fr Jul 22 08:52:22 2022] usb 1-1.4: New USB device found, idVendor=0463, idProd                   uct=ffff, bcdDevice= 1.00
      [Fr Jul 22 08:52:22 2022] usb 1-1.4: New USB device strings: Mfr=1, Product=2, S                   erialNumber=4
      [Fr Jul 22 08:52:22 2022] usb 1-1.4: Product: Ellipse ECO
      [Fr Jul 22 08:52:22 2022] usb 1-1.4: Manufacturer: EATON
      [Fr Jul 22 08:52:22 2022] usb 1-1.4: SerialNumber: 000000000
      [Fr Jul 22 08:52:23 2022] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initi                   alised: Registers at 0xfeb00000 length 0x00010000
      [Fr Jul 22 08:52:23 2022] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem                    initialised: Registers at 0xfeb10000 length 0x00001000
      [Fr Jul 22 08:52:23 2022] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initi                   alised: Registers at 0xfeb20000 length 0x00010000
      [Fr Jul 22 08:52:23 2022] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initial                   ised: Registers at 0xfeb30000 length 0x00010000
      [Fr Jul 22 08:52:23 2022] mc: Linux media interface: v0.10
      [Fr Jul 22 08:52:23 2022] vc_sm_cma: module is from the staging directory, the q                   uality is unknown, you have been warned.
      [Fr Jul 22 08:52:23 2022] bcm2835_vc_sm_cma_probe: Videocore shared memory drive                   r
      [Fr Jul 22 08:52:23 2022] [vc_sm_connected_init]: start
      [Fr Jul 22 08:52:23 2022] vc_sm_cma_vchi_init: failed to open VCHI service (-1)
      [Fr Jul 22 08:52:23 2022] [vc_sm_connected_init]: failed to initialize shared me                   mory service
      [Fr Jul 22 08:52:23 2022] videodev: Linux video capture interface: v2.00
      [Fr Jul 22 08:52:23 2022] bcm2835_mmal_vchiq: module is from the staging directo                   ry, the quality is unknown, you have been warned.
      [Fr Jul 22 08:52:23 2022] bcm2835_codec: module is from the staging directory, t                   he quality is unknown, you have been warned.
      [Fr Jul 22 08:52:23 2022] bcm2835_v4l2: module is from the staging directory, th                   e quality is unknown, you have been warned.
      [Fr Jul 22 08:52:23 2022] bcm2835_isp: module is from the staging directory, the                    quality is unknown, you have been warned.
      [Fr Jul 22 08:52:23 2022] bcm2835_mmal_vchiq: Failed to open VCHI service connec                   tion (status=-1)
      [Fr Jul 22 08:52:23 2022] sd 0:0:0:0: Attached scsi generic sg0 type 0
      [Fr Jul 22 08:52:23 2022] [drm] No displays found. Consider forcing hotplug if H                   DMI is attached
      [Fr Jul 22 08:52:23 2022] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_                   ops [vc4])
      [Fr Jul 22 08:52:23 2022] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor                    0
      [Fr Jul 22 08:52:23 2022] cfg80211: Loading compiled-in X.509 certificates for r                   egulatory database
      [Fr Jul 22 08:52:23 2022] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9c                   ea7'
      [Fr Jul 22 08:52:23 2022] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d                    on minor 1
      [Fr Jul 22 08:52:23 2022] brcmfmac: F1 signature read @0x18000000=0x15264345
      [Fr Jul 22 08:52:23 2022] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4                   3455-sdio for chip BCM4345/6
      [Fr Jul 22 08:52:23 2022] usbcore: registered new interface driver brcmfmac
      [Fr Jul 22 08:52:23 2022] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 w                   l0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [Fr Jul 22 08:52:25 2022] hid-generic 0003:0463:FFFF.0001: hiddev96,hidraw0: USB                    HID v10.10 Device [EATON Ellipse ECO] on usb-0000:01:00.0-1.4/input0
      [Fr Jul 22 08:52:26 2022] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
      [Fr Jul 22 08:52:26 2022] usbcore: registered new interface driver cdc_acm
      [Fr Jul 22 08:52:26 2022] cdc_acm: USB Abstract Control Model driver for USB mod                   ems and ISDN adapters
      [Fr Jul 22 08:52:26 2022] uart-pl011 fe201000.serial: no DMA platform data
      [Fr Jul 22 08:52:26 2022] random: crng init done
      [Fr Jul 22 08:52:26 2022] random: 7 urandom warning(s) missed due to ratelimitin                   g
      [Fr Jul 22 08:52:26 2022] 8021q: 802.1Q VLAN Support v1.8
      [Fr Jul 22 08:52:26 2022] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save en                   abled
      [Fr Jul 22 08:52:26 2022] Adding 2097148k swap on /var/swap.  Priority:-2 extent                   s:9 across:2768892k SSFS
      [Fr Jul 22 08:52:26 2022] bcmgenet fd580000.ethernet: configuring instance for e                   xternal RGMII (RX delay)
      [Fr Jul 22 08:52:26 2022] bcmgenet fd580000.ethernet eth0: Link is Down
      [Fr Jul 22 08:52:27 2022] tun: Universal TUN/TAP device driver, 1.6
      [Fr Jul 22 08:52:30 2022] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Fu                   ll - flow control off
      [Fr Jul 22 08:52:30 2022] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes read                   y
      [Fr Jul 22 08:52:31 2022] ICMPv6: process `dhcpcd' is using deprecated sysctl (s                   yscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_                   ms instead
      [Fr Jul 22 08:52:33 2022] Bluetooth: Core ver 2.22
      [Fr Jul 22 08:52:33 2022] NET: Registered protocol family 31
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI device and connection manager initializ                   ed
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI socket layer initialized
      [Fr Jul 22 08:52:33 2022] Bluetooth: L2CAP socket layer initialized
      [Fr Jul 22 08:52:33 2022] Bluetooth: SCO socket layer initialized
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI UART driver ver 2.3
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI UART protocol H4 registered
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI UART protocol Three-wire (H5) registere                   d
      [Fr Jul 22 08:52:33 2022] Bluetooth: HCI UART protocol Broadcom registered
      [Fr Jul 22 08:52:33 2022] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
      [Fr Jul 22 08:52:33 2022] Bluetooth: BNEP filters: protocol multicast
      [Fr Jul 22 08:52:33 2022] Bluetooth: BNEP socket layer initialized
      [Fr Jul 22 08:52:49 2022] vcc-sd: disabling
        Thomas Braun Most Active @babl last edited by
        @babl
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          @babl sagte in Serial Port Raspberry Problem:
          Das dürfte für den Trouble mit den USB-Ports verantwortlich sein. Du hast da eine SSD dran. Stromversorgung von extern oder läuft das auch über den USB-Port?
            babl @Thomas Braun last edited by babl
            @thomas-braun läuft über usb. das schon seit über 1 Jahr ohne Probleme.
            Muss ich den oberen Befehl mit dem Node ausführen und für was ist das?
            Dafür iobroker stoppen, oder?
              Dann spendier dem Ding eine eigene Spannungsversorgung.
              Musst du nicht. Hilft mir aber dein System besser kennen zu lernen und dann vielleicht noch ein paar Tips zu geben.
                @thomas-braun ok das kommt wenn ich deine befehle ausführe.
                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                pi@raspberrypi:~ $
                pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                armv7l
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.16.0
                v16.16.0
                8.11.0
                pi
                /home/pi
                OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                OK:2 https://deb.nodesource.com/node_16.x buster InRelease
                OK:3 http://archive.raspberrypi.org/debian buster InRelease
                Holen:4 https://pkgs.tailscale.com/stable/raspbian buster InRelease
                Es wurden 5.543 B in 1 s geholt (4.446 B/s).
                Alle Pakete sind aktuell.
                nodejs:
                  Installiert:           16.16.0-deb-1nodesource1
                  Installationskandidat: 16.16.0-deb-1nodesource1
                  Versionstabelle:
                 *** 16.16.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                Welchen Befehl würdest du verwenden wenn man in der Vis den Raspi rebooten will?
                ich habe jetzt
                sudo reboot
                einfach hergenommen.
                Netzteil schaue ich daß ich eins bekomme, ich habs mir schon gedacht daß es ein stromproblem sein könnte
                  sudo reboot
                  Ja, passt.
                  Die Ausgaben sind i. O., da ist nichts 'krumm'.
                  Also ich würde die Stromversorgung angehen, die USB-Geräte mit USB-Verlängerungen betreiben und die USB3-Ports (die blauen) vermeiden.
                    @thomas-braun die Festplatte hat aber nur einen USB anschluss
                    würde sowas funktionieren?
                    Amazon USB 3 Hub
                      @babl
                      Könnte sein.
                        @thomas-braun sagte in Serial Port Raspberry Problem:
                        Hallo Thomas, habe jetzt einen Hub dran, der die Festplatte mit Strom versorgt, ebenso habe ich alle USB direkt jetzt an den Hub angeschlossen. Der Hub ist nun direkt mit der Usb 2 gesteckt die USB 3 sind unbelegt.
                        Muss ich nun irgendwas mit dem vcc-sd disabled machen?
                        Danke für deine Hilfe.
                          @babl
                          Taucht es denn aktuell auf?
                          Mit
                          dmesg -T | grep -i vcc-sd
                          mal regelmäßig prüfen.
                            [Di Jul 26 15:44:36 2022] vcc-sd: disabling
                              Beobachte es mal.
                              1193
