    4. Test Adapter Energiefluss v3.6.x GitHub/Latest
      A Former User @SKB last edited by
      @skb gemacht, immer noch das gleiche... hab beide Varianten mit und ohne " ausprobiert...
      ilovegym@VMC123-iobroker /opt/iobroker $ cd node_modules/
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules $ cd iobroker.energiefluss/
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules/iobroker.energiefluss $ cd admin
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules/iobroker.energiefluss/admin $ sudo nano tab_m.html
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules/iobroker.energiefluss/admin $ ls
      energiefluss.png  i18n  index_m.html  jquery.minicolors.css  jquery.minicolors.js  jquery.minicolors.png  style.css  tab_m.html  words.js
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules/iobroker.energiefluss/admin $ ls -la
      total 236
      drwxrwxr-x+  3 iobroker iobroker  4096 Jul 27 08:19 .
      drwxrwxr-x+  5 iobroker iobroker  4096 Jul 26 19:07 ..
      -rwxrwxr-x+  1 iobroker iobroker 31386 Jul 26 19:07 energiefluss.png
      drwxrwxr-x+ 12 iobroker iobroker  4096 Jul 26 19:07 i18n
      -rw-rw-r--+  1 iobroker iobroker 16519 Jul 26 19:07 index_m.html
      -rw-rw-r--+  1 iobroker iobroker 10116 Jul 26 19:07 jquery.minicolors.css
      -rw-rw-r--+  1 iobroker iobroker 35832 Jul 26 19:07 jquery.minicolors.js
      -rw-rw-r--+  1 iobroker iobroker 68627 Jul 26 19:07 jquery.minicolors.png
      -rwxrwxr-x+  1 iobroker iobroker   675 Jul 26 19:07 style.css
      -rwxrwxr-x+  1 iobroker iobroker   364 Jul 27 08:19 tab_m.html
      -rw-rw-r--+  1 iobroker iobroker 48690 Jul 26 19:07 words.js
      ilovegym@VMC123-iobroker /opt/iobroker/node_modules/iobroker.energiefluss/admin $ cat tab_m.html
      <html>
      <head>
          <script type="text/javascript">
              let url = new URL(document.location);
              var namespace = "energiefluss.0";
              location.replace(url.protocol + "//" + url.hostname + ":" + url.port + "/energiefluss/index.html?namespace=" +
                  namespace);
          </script>
      </head>
      <body>
          Redirecting...
      </body>
      </html>
      <html>
      <head>
              location.replace(url.protocol + "//" + url.hostname + ":" + "url.port" + "/energiefluss/index.html?namespace=" +
                  namespace);
          </script>
      </head>
      <body>
          Redirecting...
      </body>
      </html>
      • SKB
        SKB Developer Most Active @Guest last edited by
        @ilovegym Hm, ok, dann muss ich da nochmal schauen.
        Kannst Du vielleicht in der Admin Konsole mal einen Rechtsklick auf den grauen Bereich machen, wo der Fehler steht, dann "This frame / Dieser frame" -> "View Frame Info / Zeige Frame Info"?
        Danke!
          @skb
          Das hier ??
          • SKB
            @ilovegym Genau. Da sieht man, das er gerne wieder auf den Port 8082 möchte, wo ja bei dir nichts läuft, richtig?
            Wo läuft denn der Admin Port? Ist das 8081? Und Web nur 81?
              @skb ja, genau, der Admin auf 8081, der Web auf 81.
              Schau hier:
              ilovegym@VMC123-iobroker /opt/iobroker $ iob list instances
              + system.adapter.admin.0                  : admin                 : VMC123-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alarm.0                  : alarm                 : Broker3                                  -  enabled
              + system.adapter.alarm.1                  : alarm                 : Broker3                                  -  enabled
              + system.adapter.alarm.2                  : alarm                 : Broker3                                  -  enabled
              + system.adapter.alarm.3                  : alarm                 : Broker3                                  -  enabled
              + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : VMC123-iobroker                          -  enabled
              + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : VMC123-iobroker                          -  enabled
              + system.adapter.alexa2.0                 : alexa2                : VMC123-iobroker                          -  enabled
                system.adapter.alias-manager.0          : alias-manager         : VMC123-iobroker                          -  enabled
              + system.adapter.amazon-dash.0            : amazon-dash           : VMC123-iobroker                          -  enabled
              + system.adapter.bluelink.0               : bluelink              : VMC123-iobroker                          -  enabled
              + system.adapter.cec2.0                   : cec2                  : Zigberry                                 -  enabled
              + system.adapter.cloud.0                  : cloud                 : VMC123-iobroker                          -  enabled
              + system.adapter.countdown.0              : countdown             : Broker2                                  -  enabled
                system.adapter.daswetter.0              : daswetter             : Broker2                                  -  enabled
                system.adapter.devices.0                : devices               : VMC123-iobroker                          -  enabled
                system.adapter.dwd.0                    : dwd                   : Broker1                                  -  enabled
              + system.adapter.echarts.0                : echarts               : VMC123-iobroker                          -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : VMC123-iobroker                          -  enabled
              + system.adapter.energiefluss.1           : energiefluss          : VMC123-iobroker                          -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : VMC123-iobroker                          -  enabled
                system.adapter.feiertage.0              : feiertage             : VMC123-iobroker                          -  enabled
                system.adapter.fitbit-api.0             : fitbit-api            : VMC123-iobroker                          -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : Broker3                                  -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : Broker2                                  -  enabled
              + system.adapter.go-e.0                   : go-e                  : Broker1                                  -  enabled
              + system.adapter.govee.0                  : govee                 : Broker1                                  -  enabled
              + system.adapter.heizoel.0                : heizoel               : VMC123-iobroker                          -  enabled
                system.adapter.ical.0                   : ical                  : VMC123-iobroker                          -  enabled
              + system.adapter.influxdb.0               : influxdb              : VMC123-iobroker                          -  enabled, port: 8086
                system.adapter.influxdb.1               : influxdb              : VMC123-iobroker                          - disabled, port: 8086
              + system.adapter.iot.0                    : iot                   : VMC123-iobroker                          -  enabled
              + system.adapter.javascript.0             : javascript            : VMC123-iobroker                          -  enabled
                system.adapter.javascript.1             : javascript            : Broker1                                  - disabled
                system.adapter.javascript.2             : javascript            : Broker2                                  - disabled
                system.adapter.javascript.3             : javascript            : Broker3                                  - disabled
              + system.adapter.lgtv.1                   : lgtv                  : VMC123-iobroker                          -  enabled
              + system.adapter.lgtv.2                   : lgtv                  : Zigberry                                 -  enabled
              + system.adapter.lgtv11.0                 : lgtv11                : VMC123-iobroker                          -  enabled, port: 8080
              + system.adapter.linux-control.0          : linux-control         : VMC123-iobroker                          -  enabled
                system.adapter.meteoalarm.0             : meteoalarm            : Broker3                                  -  enabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : VMC123-iobroker                          -  enabled, port: 54321
              + system.adapter.mihome-vacuum.1          : mihome-vacuum         : VMC123-iobroker                          -  enabled, port: 54321
              + system.adapter.mihome-vacuum.2          : mihome-vacuum         : VMC123-iobroker                          -  enabled, port: 54321
              + system.adapter.mihome-vacuum.3          : mihome-vacuum         : VMC123-iobroker                          -  enabled, port: 54321
                system.adapter.minuvis.0                : minuvis               : VMC123-iobroker                          -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : VMC123-iobroker                          -  enabled, port: 1886, bind: 0.0.0.0
              + system.adapter.mqtt.1                   : mqtt                  : VMC123-iobroker                          -  enabled, port: 1884, bind: 0.0.0.0
                system.adapter.octoprint.0              : octoprint             : VMC123-iobroker                          - disabled
                system.adapter.odl.0                    : odl                   : VMC123-iobroker                          -  enabled
                system.adapter.oilfox.0                 : oilfox                : VMC123-iobroker                          -  enabled
              + system.adapter.openligadb.0             : openligadb            : VMC123-iobroker                          -  enabled
              + system.adapter.pi-hole.0                : pi-hole               : Broker3                                  -  enabled
              + system.adapter.ping.0                   : ping                  : VMC123-iobroker                          -  enabled
              + system.adapter.proxmox.0                : proxmox               : VMC123-iobroker                          -  enabled, port: 8006
                system.adapter.rest-api.0               : rest-api              : VMC123-iobroker                          - disabled, port: 8093, bind: 0.0.0.0, run as: admin
              + system.adapter.roadtraffic.0            : roadtraffic           : VMC123-iobroker                          -  enabled
              + system.adapter.simple-api.0             : simple-api            : VMC123-iobroker                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.smartmeter.0             : smartmeter            : zeroberry                                -  enabled
              + system.adapter.snmp.0                   : snmp                  : VMC123-iobroker                          -  enabled
                system.adapter.solarmanpv.0             : solarmanpv            : VMC123-iobroker                          -  enabled
              + system.adapter.sonoff.0                 : sonoff                : VMC123-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.statistics.0             : statistics            : VMC123-iobroker                          -  enabled
              + system.adapter.synochat.0               : synochat              : VMC123-iobroker                          -  enabled
              + system.adapter.synology.0               : synology              : VMC123-iobroker                          -  enabled, port: 5001
              + system.adapter.telegram.0               : telegram              : VMC123-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : Broker3                                  -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : VMC123-iobroker                          -  enabled
              + system.adapter.tuya.0                   : tuya                  : VMC123-iobroker                          -  enabled
              + system.adapter.unifi.0                  : unifi                 : VMC123-iobroker                          -  enabled
                system.adapter.valuetrackerovertime.0   : valuetrackerovertime  : VMC123-iobroker                          - disabled
              + system.adapter.viessmannapi.0           : viessmannapi          : Broker3                                  -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : VMC123-iobroker                          -  enabled
                system.adapter.vis.0                    : vis                   : VMC123-iobroker                          -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : VMC123-iobroker                          -  enabled
              + system.adapter.web-speedy.0             : web-speedy            : Broker3                                  -  enabled
              + system.adapter.web.0                    : web                   : VMC123-iobroker                          -  enabled, port: 81, bind: 0.0.0.0, run as: admin
              + system.adapter.wifilight.0              : wifilight             : Broker1                                  -  enabled
              + system.adapter.wireguard.0              : wireguard             : VMC123-iobroker                          -  enabled
              + system.adapter.wled.0                   : wled                  : Broker1                                  -  enabled
              + system.adapter.worx.0                   : worx                  : Broker1                                  -  enabled
              + system.adapter.yahka.0                  : yahka                 : VMC123-iobroker                          -  enabled
              + system.adapter.yeelight-2.0             : yeelight-2            : VMC123-iobroker                          -  enabled
              + system.adapter.zigbee.0                 : zigbee                : VMC123-iobroker                          -  enabled, port: tcp://192.168.0.33:20108
              + instance is alive
              • Palm_Maniac
                Palm_Maniac @SKB last edited by
                @skb
                Bin erst jetzt zum updaten gekommen. Auch bei mir läuft jetzt alles, inkl. der Linienstärke. Super.
                  Maxtor62 @SKB last edited by
                  @skb
                  erst Mal ein großes Kompliment. Super Arbeit. Sowas ähnliches hatte ich mir selbst in VIS auch gebastelt. Dein Adapter ist natürlich viel besser. Daumen hoch!
                  So war meine, von SMA etwas nachgebaute Lösung.
                  Bin jetzt dabei das ganze neu zubauen. Leider habe ich noch keine Wallbox und E-Auto, aber der Boiler wird von dem SMA Sunny Home Manager gesteuert. Leider habe ich noch keinen Datenpunkt gefunden, damit ich Leistung/Verbrauch auslesen kann. Momentan mach ich das mit nem Shelly.
                  Falls jemand da ne Lösung hat, wäre das super.
                  Auch noch ein Dankeschön an Sigi234 für seine tolle Arbeit. Hab mir da was abgeschaut. Hoffe es ist okay.
                  SKB sigi234 T 3 Replies Last reply Reply Quote 1
                  • SKB
                    SKB Developer Most Active @Maxtor62 last edited by
                    @maxtor62 Danke für Deine Rückmeldung. Freut mich, wenn der Adapter auf Anhieb funktioniert.
                    Für welches "Problem" benötigst Du nun eine Lösung?
                    • SKB
                      SKB Developer Most Active last edited by SKB
                      Hallo Zusammen,
                      es wurde oben (https://forum.iobroker.net/post/833236) gewünscht, die Linien (Wege) anders zu gestalten.
                      Ist dort dann auch gewünscht, eine andere Farbe der Animation zu wählen?
                      Danke Euch 🙂
                        sigi234 Forum Testing Most Active @Maxtor62 last edited by
                        @maxtor62 sagte in Test Adapter Energiefluss v0.4.x GitHub/Latest:
                        Natürlich 😉
                          @skb sagte in Test Adapter Energiefluss v0.4.x GitHub/Latest:
                          Hallo Zusammen,
                          Yes, please 🙂
                          Uebrigens, bei mir verlaeuft die Energie immer von der PV Anlage zum Netzeinspeiser, nie zum Verbraucher.. ?
                          PV erzeugt gerade nur 60W, Netzeinspeisung sind 240, Gesamtverbrauch ist 300.
                          Laut der Animation der Linien erzeugt die PV und schickt alles ins Netz, der Verbraucher bekommt eine Animation von der PV, aber nicht vom Netz, haette er aber doch verdient.. richtig?
                            Homoran Global Moderator Administrators @Guest last edited by
                            @ilovegym sagte in Test Adapter Energiefluss v0.4.x GitHub/Latest:
                            das passt nicht, oder meinst du Netzbezug?
                            ? 1 Reply Last reply Reply Quote 1
                              jauntyjosef last edited by
                              Ich persönlich fände es bei 3 Kreisen schöner, wenn diese liegend sind. Vielleicht könnte man da auch eine Möglichkeit implimentieren, dass man dies auswählen kann. Ist aber sicherlich Geschmackssache.
                              So in dieser Art.
                                @skb
                                erst mal Danke für die schnellen Antworten.
                                Ich habe mir gedacht, wenn Dein toller Adapter auch die Wallbox darstellen kann, die ja von der PV-Steuerung geregelt wird, dann kann der Adapter vielleicht auch den Boiler abbilden. Der wird ja auch von der PV-Steuerung geregelt (Überschuss Steuerung).
                                Ich habe mit dem Modbus-Adapter den SMA Wechselrichter und den SMA Storage-Wechselrichter ausgelesen, aber ich bekomme keine brauchbaren Informationen von dem Sunny Home Manager. Vermutlich weil ich zu doof bin dazu.
                                  A Former User @Homoran last edited by
                                  Ja, Erzeugung fliesst in Netz, aber das sollte ja nur sein, wenn Ueberschuss vorhanden ist.. oder?
                                    Homoran Global Moderator Administrators @Guest last edited by Homoran
                                    ja, aber du schriebst das du 240W Netzeinspeisung hättest. Deswegen passt dies Aussage ja nicht.
                                    oder meintest du, dass das Widget dies fälschlicherweise behaupten würde?
                                      @homoran @SKB
                                      Nee, ich hab n Verbrauch von 300 W, 60W macht die Erzeugung, und Netzeinspeisung sind 240. Das ist ja richtig so.
                                      Nur die Animation fliesst von der Erzeugung direkt und nur zur Netzeinspeisung, das ist doch falsch, sollte doch NUR von der PV zum Verbraucher fliessen.
                                      Und die Animation von der Netzeinspeisung zum Verbraucher fehlt hier. Hab mal n Video gemacht, schau:
                                      Energiefluss.mp4
                                      • SKB
                                        @ilovegym Dann denke ich, musst Du nochmal in der Einstellung schauen. Dort wird unterschieden, ob der NetzBezug positiv oder negativ ist.
                                          A Former User last edited by
                                          @skb Ah, das war es, DANKE! Tja, kaum macht man es richtig, funktionierts.. 🙂
                                          • leika241265
                                            leika241265 last edited by
                                            Super Arbei
                                            cooler Adapter, super Arbeit. Ich habe mal nee Frage zu den Einstellungen für "Akku laden und entladen"?
                                            Ich nutze die Werte aus dem Sonneadapter und habe negartive Werte für chargin und positiv für discharging.
                                            Soweit auch alles ok, aber die Richtung in der Ansicht wird nicht richtig dargestellt.
                                            Im moment ladet die Batterie aber die Richtung ist von Batterie zum Verbrauch.
                                            Es solte aber sein Erzeugung zur Batterie sein.
                                            Mache ich da was falsch?
                                            energiefluss vis visualisierung visualization
                                            149
                                            2366
                                            1180206
