    4. Xbox Adapter v1.0.0 BETA
    • foxriver76
      foxriver76 Developer @Negalein last edited by
      @negalein vorher gerne mal wie dort beschrieben die Fehlermeldung extrahieren. Und evtl mal noch ein Upload vom Xbox Adapter machen.
      • Negalein
        Negalein Global Moderator @foxriver76 last edited by
        @foxriver76 sagte in Xbox Adapter v1.0.0 BETA:
        ich bekomm nur das obige als Error.
        Und unter dem Bild steht in Rot
        Cannot read properties of undefined (reading 'value')
        TypeError: Cannot read properties of undefined (reading 'value')($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.renderItem (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:150640)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.render (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:40920)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Wi (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6209)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Rs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6006)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at oa (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:44992)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ra (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39832)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Jc (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39763)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ml (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39622)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at iu (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:36004)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at bs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:34957)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Ln (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:1614)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at MessagePort.Gn (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:2007)
        Upload brachte keine Besserung
        • foxriver76
          @negalein Dann gerne damit mal bei Admin Thread melden. Bei mir klappt es mit Admin stable.
          • Negalein
            Ich bin auf euer Feedback gespannt und freue mich auf konstruktive Verbesserungsvorschläge.
            Funktioniert wieder 🙂
            beim Start kommt
            xbox.0 2022-07-29 22:04:39.057	warn	State "xbox.0.info.activeTitleImage" has no existing object, this might lead to an error in future versions
            xbox.0 2022-07-29 22:04:38.901	info	Succesfully connected to Xbox on ip 10.0.1.83
            xbox.0 2022-07-29 22:04:37.958	info	- xxxxxxxxxxxxxxx - XboxOneS - XboxOne
            xbox.0 2022-07-29 22:04:37.958	info	The following consoles are available on this account:
            xbox.0 2022-07-29 22:04:37.326	warn	Console ID not found on connected xbox account. Live ID: Nxxxxxxxx1
            xbox.0 2022-07-29 22:04:36.795	info	User is authenticated with Xbox Live
            xbox.0 2022-07-29 22:04:36.792	warn	State "xbox.0.info.authenticated" has no existing object, this might lead to an error in future versions
            xbox.0 2022-07-29 22:04:36.476	info	Successfully loaded token
            xbox.0 2022-07-29 22:04:36.359	info	starting. Version 1.0.0-beta.0 (non-npm: foxriver76/ioBroker.xbox) in /opt/iobroker/node_modules/iobroker.xbox, node: v16.15.1, js-controller: 4.0.23
            • foxriver76
              @negalein top, die Objekte fixe ich.
              • Negalein
                Launchen von Applikationen funktioniert wieder
                PS: wo finde ich die Applikationen?
                • foxriver76
                  @negalein settings.launchTitle, geht allerdings wie damals auch nur mit den IDs. Also Spiel starten, active ID extrahieren. Evtl. bekommt man es noch schöner hin. Oder man baut einen Cache ein da bin ich noch unschlüssig.
                  • Negalein
                    Ah, das ist schon soo lange her. 😉
                    Dann werd ich mir die paar Apps mal notieren.
                    Verwende die Box nur für Blue Ray, Netflix, Plex und Prime.
                    foxriver76 2 Replies Last reply Reply Quote 0
                    • foxriver76
                      @negalein mit beta.1 sollten die zwei fehlenden Objekte wieder angelegt werden.
                      • foxriver76
                        @negalein sagte in Xbox Adapter v1.0.0 BETA:
                        Ich kann probieren das mit Klarnamen in einem extra State zu implementieren. Da wird dann der Titel im Store gesucht, vom best passenden Ergebnis die ID genommen und das gestartet. Probiere ich aus sobald ich Zeit finde dafür. 😉
                        • Negalein
                          passt jetzt 🙂
                          was bedeutet Console ID not found on connected xbox account. Live ID: Nxxxxxxxx1
                          • foxriver76
                            @negalein Das heißt, die Live ID welche du in der Adapter Konfig eingetragen hast, ist nicht in dem Account mit dem du dich eingeloggt hast hinterlegt.
                            • foxriver76
                              beta.2 kommt gleich mit launchStoreTitle funktioniert für so Sachen wir Twitch, Netflix die eindeutig sind ganz gut. Für Spiele die es in Premium Edition, Gold Edition, Bundle so und so gibt, wird da eher ein Store Treffer bei rum kommen und sich der Titel im Store öffnen.
                              • foxriver76
                                foxriver76 Developer @foxriver76 last edited by
                                Eventuell kann ich das optimieren indem ich mit den installierten Apps vergleiche.
                                • foxriver76
                                  Beta.3, geht über die Store Suche (falls mehrere Treffer) findet den ersten Treffer der installiert ist und öffnet diesen, wenn nichts davon installiert, dann erster Store Treffer.
                                  Eine Heuristik die bei mir lokal sehr gut funktioniert hat.
                                  Gerne mal testen @Negalein ob es jetzt mit sprechenden Namen und dem neuen State funktioniert.
                                  • Negalein
                                    komisch
                                    die Live ID ist doch der Username neben dem Profilbild?
                                    Oder wo sonst finde ich die?
                                    • foxriver76
                                      @negalein I’m Log sollte er sagen welche Konsolen er in deinem Account gefunden hat und die live id listen. Ansonsten ist sie irgendwo in den Einstellungen deiner Xbox zu finden. Kann leider gerade nicht schauen wo genau. 😉
                                      • Negalein
                                        gerade Netflix gestartet.
                                        Name wird nicht angezeigt.
                                        • Negalein
                                          Negalein Global Moderator @foxriver76 last edited by Negalein
                                          Ahh, du meinst diese Zeichen?
                                          xbox.0 2022-07-30 14:21:58.770 info - xxxxxxxxxxxx- XboxOneS - XboxOne
                                          PS: gerade diese Meldung gesehn
                                          2022-07-30 14:34:02.735 warn Failed to get Xbox console type from Xbox API: {"status":503,"body":""}
                                          • foxriver76
                                            foxriver76 Developer @Negalein last edited by foxriver76
                                            @negalein genau das erste ist die ID der Konsole, die in die Adapter Konfig packen. Dann nochmal testen.
                                            31.7k
                                            79.8k
                                            gaming playstation spielekonsole xbox xbox adapter
                                            2582
