    4. Xbox Adapter v1.0.0 BETA
    • Negalein
      Negalein Global Moderator @foxriver76 last edited by
      @foxriver76 sagte in Xbox Adapter v1.0.0 BETA:
      vorher gerne mal wie dort beschrieben die Fehlermeldung extrahieren. Und evtl mal noch ein Upload vom Xbox Adapter machen.
      ich bekomm nur das obige als Error.
      Und unter dem Bild steht in Rot
      Cannot read properties of undefined (reading 'value')
      TypeError: Cannot read properties of undefined (reading 'value')($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.renderItem (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:150640)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at vn.render (https://10.0.1.202:8081/static/js/5710.7d75fb68.chunk.js:74:40920)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Wi (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6209)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Rs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:6006)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at oa (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:44992)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ra (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39832)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Jc (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39763)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at ml (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:39622)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at iu (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:36004)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at bs (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:16:34957)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at Ln (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:1614)($,te)=>r().createElement("div",{key:te},$,r().createElement("br",null))    at MessagePort.Gn (https://10.0.1.202:8081/static/js/3961.a98ff7ab.chunk.js:24:2007)
      Upload brachte keine Besserung
      • foxriver76
        foxriver76 Developer @Negalein last edited by
        @negalein Dann gerne damit mal bei Admin Thread melden. Bei mir klappt es mit Admin stable.
        • Negalein
          Ich bin auf euer Feedback gespannt und freue mich auf konstruktive Verbesserungsvorschläge.
          Funktioniert wieder 🙂
          beim Start kommt
          xbox.0 2022-07-29 22:04:39.057	warn	State "xbox.0.info.activeTitleImage" has no existing object, this might lead to an error in future versions
          xbox.0 2022-07-29 22:04:38.901	info	Succesfully connected to Xbox on ip 10.0.1.83
          xbox.0 2022-07-29 22:04:37.958	info	- xxxxxxxxxxxxxxx - XboxOneS - XboxOne
          xbox.0 2022-07-29 22:04:37.958	info	The following consoles are available on this account:
          xbox.0 2022-07-29 22:04:37.326	warn	Console ID not found on connected xbox account. Live ID: Nxxxxxxxx1
          xbox.0 2022-07-29 22:04:36.795	info	User is authenticated with Xbox Live
          xbox.0 2022-07-29 22:04:36.792	warn	State "xbox.0.info.authenticated" has no existing object, this might lead to an error in future versions
          xbox.0 2022-07-29 22:04:36.476	info	Successfully loaded token
          xbox.0 2022-07-29 22:04:36.359	info	starting. Version 1.0.0-beta.0 (non-npm: foxriver76/ioBroker.xbox) in /opt/iobroker/node_modules/iobroker.xbox, node: v16.15.1, js-controller: 4.0.23
          • foxriver76
            @negalein top, die Objekte fixe ich.
            • Negalein
              Launchen von Applikationen funktioniert wieder
              PS: wo finde ich die Applikationen?
              • foxriver76
                @negalein settings.launchTitle, geht allerdings wie damals auch nur mit den IDs. Also Spiel starten, active ID extrahieren. Evtl. bekommt man es noch schöner hin. Oder man baut einen Cache ein da bin ich noch unschlüssig.
                • Negalein
                  Ah, das ist schon soo lange her. 😉
                  Dann werd ich mir die paar Apps mal notieren.
                  Verwende die Box nur für Blue Ray, Netflix, Plex und Prime.
                  foxriver76 2 Replies Last reply Reply Quote 0
                  • foxriver76
                    @negalein mit beta.1 sollten die zwei fehlenden Objekte wieder angelegt werden.
                    • foxriver76
                      @negalein sagte in Xbox Adapter v1.0.0 BETA:
                      Ich kann probieren das mit Klarnamen in einem extra State zu implementieren. Da wird dann der Titel im Store gesucht, vom best passenden Ergebnis die ID genommen und das gestartet. Probiere ich aus sobald ich Zeit finde dafür. 😉
                      • Negalein
                        passt jetzt 🙂
                        was bedeutet Console ID not found on connected xbox account. Live ID: Nxxxxxxxx1
                        • foxriver76
                          @negalein Das heißt, die Live ID welche du in der Adapter Konfig eingetragen hast, ist nicht in dem Account mit dem du dich eingeloggt hast hinterlegt.
                          • foxriver76
                            beta.2 kommt gleich mit launchStoreTitle funktioniert für so Sachen wir Twitch, Netflix die eindeutig sind ganz gut. Für Spiele die es in Premium Edition, Gold Edition, Bundle so und so gibt, wird da eher ein Store Treffer bei rum kommen und sich der Titel im Store öffnen.
                            • foxriver76
                              foxriver76 Developer @foxriver76 last edited by
                              Eventuell kann ich das optimieren indem ich mit den installierten Apps vergleiche.
                              • foxriver76
                                Beta.3, geht über die Store Suche (falls mehrere Treffer) findet den ersten Treffer der installiert ist und öffnet diesen, wenn nichts davon installiert, dann erster Store Treffer.
                                Eine Heuristik die bei mir lokal sehr gut funktioniert hat.
                                Gerne mal testen @Negalein ob es jetzt mit sprechenden Namen und dem neuen State funktioniert.
                                • Negalein
                                  komisch
                                  die Live ID ist doch der Username neben dem Profilbild?
                                  Oder wo sonst finde ich die?
                                  • foxriver76
                                    @negalein I’m Log sollte er sagen welche Konsolen er in deinem Account gefunden hat und die live id listen. Ansonsten ist sie irgendwo in den Einstellungen deiner Xbox zu finden. Kann leider gerade nicht schauen wo genau. 😉
                                    • Negalein
                                      gerade Netflix gestartet.
                                      Name wird nicht angezeigt.
                                      • Negalein
                                        Negalein Global Moderator @foxriver76 last edited by Negalein
                                        Ahh, du meinst diese Zeichen?
                                        xbox.0 2022-07-30 14:21:58.770 info - xxxxxxxxxxxx- XboxOneS - XboxOne
                                        PS: gerade diese Meldung gesehn
                                        2022-07-30 14:34:02.735 warn Failed to get Xbox console type from Xbox API: {"status":503,"body":""}
                                        • foxriver76
                                          foxriver76 Developer @Negalein last edited by foxriver76
                                          @negalein genau das erste ist die ID der Konsole, die in die Adapter Konfig packen. Dann nochmal testen.
                                          • Negalein
                                            funktioniert mit der ID 🙂
                                            xbox.0 2022-07-30 14:39:08.786	info	Succesfully connected to Xbox on ip 10.0.1.83
                                            xbox.0 2022-07-30 14:39:07.031	info	User is authenticated with Xbox Live
                                            xbox.0 2022-07-30 14:39:06.758	info	Successfully loaded token
                                            xbox.0 2022-07-30 14:39:06.615	info	starting. Version 1.0.0-beta.4 in /opt/iobroker/node_modules/iobroker.xbox, node: v16.15.1, js-controller: 4.0.23
                                            31.7k
                                            79.8k
                                            gaming playstation spielekonsole xbox xbox adapter
                                            2582
