    5. Javascript stürzt immer ab bei diesem Blockly
      myssv last edited by
      Moin zusammen,
      ich habe ein Script zur Kühlschranküberwachung erstellt und das lässt Javascript immer wieder abstürzen:
      Im Log steht nur das bei Javascript:
      javascript.0
      	2022-07-30 13:13:58.438	info	script.js.common.Aqara_Sensoren.Kühlschrank_2_zu_warm: registered 1 subscription and 0 schedules
      javascript.0
      	2022-07-30 13:13:58.434	info	Start javascript script.js.common.Aqara_Sensoren.Kühlschrank_2_zu_warm
      javascript.0
      	2022-07-30 13:13:58.426	info	Stop script script.js.common.Aqara_Sensoren.Kühlschrank_2_zu_warm
      javascript.0
      	2022-07-30 13:13:48.932	info	script.js.common.Aqara_Sensoren.Kühlschrank_1_zu_warm: registered 1 subscription and 0 schedules
      javascript.0
      	2022-07-30 13:13:48.919	info	Start javascript script.js.common.Aqara_Sensoren.Kühlschrank_1_zu_warm
      javascript.0
      	2022-07-30 13:13:48.913	info	Stop script script.js.common.Aqara_Sensoren.Kühlschrank_1_zu_warm
      Hat evtl. jemand eine Idee?
      M Homoran paul53 3 Replies Last reply Reply Quote 0
        myssv @myssv last edited by myssv
        Ich habe den Fehler noch einmal reproduziert und dabei das Log beobachtet:
        rainbird.0
        	2022-07-30 13:27:30.137	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        rainbird.0
        	2022-07-30 13:27:09.768	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        rainbird.0
        	2022-07-30 13:26:50.148	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        rainbird.0
        	2022-07-30 13:26:29.778	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        rainbird.0
        	2022-07-30 13:26:10.122	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        rainbird.0
        	2022-07-30 13:25:49.789	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        email.0
        	2022-07-30 13:25:46.349	info	sent to aaa@yyy.de,bbb@yyy.de
        email.0
        	2022-07-30 13:25:45.889	info	Send email: {"html":"### Kühlschrank in der Küche ist zu warm: 8.66°C ###","to":"aaar@yyy.de,bbb@yyy.de","subject":"### Kühlschrank in der Küche ist zu warm: ","from":"ioBroker@yyy.de"}
        rainbird.0
        	2022-07-30 13:25:30.120	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        host.iobroker
        	2022-07-30 13:25:14.663	info	instance system.adapter.fitbit-api.1 terminated with code 0 (NO_ERROR)
        fitbit-api.1
        	2022-07-30 13:25:14.105	info	Terminated (NO_ERROR): Without reason
        fitbit-api.1
        	2022-07-30 13:25:12.598	error	Cannot read: Weight is not found
        fitbit-api.1
        	2022-07-30 13:25:12.115	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fitbit-api, node: v16.16.0, js-controller: 4.0.23
        host.iobroker
        	2022-07-30 13:25:10.064	info	instance system.adapter.fitbit-api.0 terminated with code 0 (NO_ERROR)
        rainbird.0
        	2022-07-30 13:25:09.750	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        fitbit-api.0
        	2022-07-30 13:25:09.496	info	Terminated (NO_ERROR): Without reason
        host.iobroker
        	2022-07-30 13:25:09.488	info	instance system.adapter.fitbit-api.1 started with pid 19283
        fitbit-api.0
        	2022-07-30 13:25:07.708	error	Cannot read: fat is not found
        fitbit-api.0
        	2022-07-30 13:25:07.278	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.fitbit-api, node: v16.16.0, js-controller: 4.0.23
        host.iobroker
        	2022-07-30 13:25:05.090	info	instance system.adapter.fitbit-api.0 started with pid 19268
        host.iobroker
        	2022-07-30 13:25:04.664	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        dwd.0
        	2022-07-30 13:25:04.138	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        dwd.0
        	2022-07-30 13:25:02.794	info	starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v16.16.0, js-controller: 4.0.23
        host.iobroker
        	2022-07-30 13:25:00.668	info	instance system.adapter.dwd.0 started with pid 19253
        rainbird.0
        	2022-07-30 13:24:50.131	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        web.0
        	2022-07-30 13:24:40.249	info	==> Connected system.user.admin from ::ffff:172.17.0.1
        web.0
        	2022-07-30 13:24:39.480	info	<== Disconnect system.user.admin from ::ffff:172.17.0.1 vis.0
        rainbird.0
        	2022-07-30 13:24:29.761	warn	Status request failed. Requested B0 but got 00: {"type":"NotAcknowledgeResponse","commandEcho":48,"NAKCode":4}
        host.iobroker
        	2022-07-30 13:24:18.912	info	instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
        Da ist kein Fehler zu sehen.
        Aber der Adapter ist danach rot
          Homoran Global Moderator Administrators @myssv last edited by
          @myssv sagte in Javascript stürzt immer ab bei diesem Blockly:
          wiederhole solange feuert im Millisekundentakt Befehle bis der Wert wieder kleiner max ist.
          das überlastet den Pi
            paul53 @myssv last edited by paul53
            @myssv sagte: jemand eine Idee?
            Die Schleife wird mehrfach ausgeführt solange die Temperatur zu hoch ist.
            Eine Schleife, die den zu prüfenden Wert pollt, ist unangebracht, wenn der Wert als Trigger dient.
            Vorschlag:
            Wert / vorheriger Wert (unter "Trigger"):
              myssv @paul53 last edited by myssv
              Ich habe das jetzt mal stumpf nachgebaut, aber nicht ganz verstanden:
              Was meinst Du mit dem Trigger?
                @myssv sagte: Ich habe das jetzt mal stumpf nachgebaut
                Hast Du nicht: Es ist wichtig, dass vorheriger Wert aus den Trigger-Blöcken ausgewertet wird, um einen Mehrfach-Timeout zu verhindern, der sich nicht mehr stoppen lässt.
                  Ja, das habe ich nicht verstanden, wie du es meinst bzw. was ich da wie ändern muss.
                    @myssv sagte: was ich da wie ändern muss.
                    Block "Objekt ID"
                    und dann vorheriger Wert auswählen.
                      Ich sehe meinen Fehler nicht ...
                        du hast den falschen Block.
                        Du musst den nehmen, den @paul53 dir gezeigt hat.
                          myssv @Homoran last edited by
                          gefunden
                            @myssv sagte: gefunden
                            ... aber falschen Vergleichs-Operator. Richtig: <=
                              Wenn der Wert<= maxTemp ist, soll nichts passieren,
                              wenn der Wert > maxTemp ist, soll eine Nachricht gesendet werden.
                              Das müsste doch so richtig sein. Irgendwie stehe ich mal wieder auf dem Schlauch
                                ist es aber nicht.
                                es muss beide male der selbe Vergleichsoperator sein, weil die zu prüfende Bedingung gegensätzlich ist
                                  @myssv sagte: wenn der Wert > maxTemp ist, soll eine Nachricht gesendet werden.
                                  sonst falls vorheriger Wert <= maxTemp
                                  entspricht
                                  Wert > maxTemp (sonst) UND vorheriger Wert <= maxTemp,
                                  also erstmaliges Überschreiten des Grenzwertes.
                                    also so:
                                      @paul53 sagte in Javascript stürzt immer ab bei diesem Blockly:
                                      Jetzt verstehe ich es.
                                      Nun ist es so, dass die Temperatur immer noch über 8° ist und ich somit keine Nachricht bekomme. Was ja korrekt ist, da die vorherige Temperatur auch schon über dem Max liegt.
                                      Da fällt der Groschen wieder mal Cent weise ...
                                      Danke Euch Beiden!
                                        Ich habe es noch etwas verändert, da ich gerne alle 5 Minuten eine Nachricht bekommen möchte, wenn die Temperatur im Kühlschrank zu hoch ist.
                                        Ist das dann so korrekt?
                                          @myssv sagte: Ist das dann so korrekt?
                                          Nein, so werden mehrere Timer gestartet, die sich nicht mehr stoppen lassen.
                                          Genau das macht diese Version. Sie sendet alle 5 Minuten bis der Timeout gestoppt wird.
                                            @paul53 ok, Danke!
                                            Ich ändere das wieder zurück und werde es dann mal beobachten und etwas damit spielen.
                                            Vielen Dank noch mal!
                                            412
