    4. Komme nicht mehr an meine Skripte ran [gelöst]
    • 15. 05. Wartungsarbeiten am ioBroker Forum
      Thomas Braun Most Active @einfachprima last edited by
      @einfachprima
      iob repo list
        einfachprima @Thomas Braun last edited by
        pi@iobroker:/opt/iobroker $ iob repo list
        Active repo(s): stable
          @einfachprima
          iob update
          iob upgrade javascript@5.7.0
            pi@iobroker:/opt/iobroker $ iob update
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "backitup"     : 2.4.9    , installed 2.4.9
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
            Adapter    "email"        : 1.1.3    , installed 1.1.3
            Adapter    "fb-checkpresence": 1.1.19, installed 1.1.19
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "influxdb"     : 3.1.7    , installed 3.1.7
            Adapter    "javascript"   : 5.7.0    , installed 6.0.0
            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
            Adapter    "linux-control": 1.1.3    , installed 1.1.3
            Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "plex"         : 0.9.1    , installed 0.9.1
            Adapter    "smartthings"  : 0.0.3    , installed 0.0.3
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "whatsapp-cmb" : 0.2.2    , installed 0.2.2
            pi@iobroker:/opt/iobroker $ iob upgrade javascript@5.7.0
            BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
            Would you like to downgrade javascript from @6.0.0 to @5.7.0 now? [(y)es, (n)o]: y
            Update javascript from @6.0.0 to @5.7.0
            NPM version: 8.11.0
            Installing iobroker.javascript@5.7.0... (System call)
            host.iobroker Cannot install iobroker.javascript@5.7.0: 217
              @einfachprima sagte in Komme nicht mehr an meine Skripte ran (tab.html not found):
              iob upgrade javascript@5.7.0 --debug
                pi@iobroker:/opt/iobroker $ iob upgrade javascript@5.7.0 --debug
                NPM version: 8.11.0
                npm WARN old lockfile
                npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                npm WARN old lockfile This is a one-time fix-up, please be patient...
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
                npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn'
                npm ERR!     /home/iobroker/.npm/_logs/2022-07-31T12_56_13_958Z-debug-0.log
                  Thomas Braun Most Active @einfachprima last edited by Thomas Braun
                  @einfachprima
                  cd /opt/iobroker/node_modules
                  for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                  EXAKTENSTESNT GENAUSO eingeben, am besten kopieren.
                    Ich hab jetzt das Löschen durchgeführt, und den Downgrade auf javascript 5.7.0 nochmal angestoßen.
                    Der Raspi reagiert gerade extrem langsam, ich warte jetzt einfach mal ab ...
                      einfachprima @einfachprima last edited by
                      Fürchte, mein Raspi 3 hat ein thermisches Problem (werde mal ein besseres Gehäuse suchen), jetzt etwas gekühlt und die Installation lief weiter:
                      pi@iobroker:/opt/iobroker/node_modules $ iob upgrade javascript@5.7.0
                      NPM version: 8.11.0
                       Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                       States database error: connect ECONNREFUSED 127.0.0.1:9000
                      added 6 packages, removed 651 packages, and changed 5 packages in 2h
                      45 packages are looking for funding
                        run `npm fund` for details
                      Cannot set system.adapter.javascript: DB closed
                       Cannot find view "system" for search "instance" : Connection is closed.
                      Cannot upgrade: Cannot find view "system"
                      Trotz Meldungen scheint der Downgrade auf 5.7.0 aber geklappt zu haben, juhu!
                      pi@iobroker:/opt/iobroker/node_modules $ iob update
                      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
                      In der Admin-GUI wird aber unter Skripte noch immer nichts angezeigt:
                      paul53 Meister Mopper 2 Replies Last reply Reply Quote 0
                        paul53 @einfachprima last edited by paul53
                        @einfachprima sagte: nichts angezeigt:
                        Prüfe mal, ob die Datei tab.html wirklich nicht vorhanden ist:
                        ls -l /opt/iobroker/node_modules/iobroker.javascript/admin
                        • Meister Mopper
                          Meister Mopper @einfachprima last edited by
                          @einfachprima
                          Wenn die Datei tatsächlich fehlt, würde ich versuchen, den admin-Adapter zu löschen und neu zu installieren?
                          iobroker del admin
                          iobroker add admin
                            einfachprima @Meister Mopper last edited by
                            pi@iobroker:/opt/iobroker/node_modules $ ls -l /opt/iobroker/node_modules/iobroker.javascript/admin
                            total 192
                            -rw-rw-r--+ 1 iobroker iobroker 34618 Jul 31 15:02 adminWords.js
                            -rw-rw-r--+ 1 iobroker iobroker  1151 Jul 31 15:02 asset-manifest.json
                            -rw-rw-r--+ 1 iobroker iobroker 90022 Jul 31 15:02 favicon.ico
                            drwxrwxr-x+ 5 iobroker iobroker  4096 Jul 31 15:02 google-blockly
                            -rw-rw-r--+ 1 iobroker iobroker 24554 Jul 31 15:02 index_m.html
                            -rw-rw-r--+ 1 iobroker iobroker  4026 Jul 31 15:02 javascript.png
                            -rw-rw-r--+ 1 iobroker iobroker   306 Jul 31 15:02 manifest.json
                            -rw-rw-r--+ 1 iobroker iobroker  1486 Jul 31 15:02 pin.png
                            drwxrwxr-x+ 2 iobroker iobroker  4096 Jul 31 15:02 plugins
                            drwxrwxr-x+ 5 iobroker iobroker  4096 Jul 31 15:02 static
                            -rw-rw-r--+ 1 iobroker iobroker 10361 Jul 31 15:02 tab.html
                            drwxrwxr-x+ 6 iobroker iobroker  4096 Jul 31 15:02 vs
                            tab.html wird mir angezeigt. Aber:
                            pi@iobroker:/opt/iobroker/node_modules $ more tab.html
                            more: cannot open tab.html: No such file or directory
                            Da ist wohl der Wurm drin, lesbar sollte sie ja für jeden sein ...
                              @einfachprima
                              Du musst schon den richtigen Pfad angeben.
                              more iobroker.javascript/admin/tab.html
                              wenn der aktuelle Pfad /opt/iobroker/node_modules ist.
                                einfachprima @paul53 last edited by
                                Oh je, schön doof von mir ...
                                tab.html ist vorhanden, lässt sich öffnen, der Inhalt sieht auch ok und vollständig aus.
                                  @einfachprima sagte: tab.html ist vorhanden, lässt sich öffnen, der Inhalt sieht auch ok und vollständig aus.
                                  Dann muss die Ursache eine andere sein. Funktionieren die anderen Tabs vom Admin?
                                    Alle anderen Tabs (Übersicht, Adapter, Instanzen, Objekte, Aufzählungen, Protokolle, Benutzer, Hosts, Dateien, Backup) funktionieren einwandfrei.
                                    Ich kann jetzt nicht mehr genau sagen, seit wann sich die Skripte nicht mehr öffnen. Es lief jetzt alles 2-3 Monate störungsfrei, gestern wollte ich die Skripte erweitern, hab davor gesehen, dass neue Adapterversionen existieren und hab die aktualisiert. Vielleicht ein Fehler.
                                    E Homoran 2 Replies Last reply Reply Quote 0
                                      Ansonsten läuft noch influxdb und Grafana.
                                      Aktive Adapter-Instanzen sind:
                                      • admin.0
                                      • backitup.0
                                      • influxdb.0
                                      • javascript.0
                                      • sonoff.0
                                      • whatsapp-cmb.0
                                        Homoran Global Moderator Administrators @einfachprima last edited by
                                        @einfachprima mal Browser Cache geleert?
                                        • Meister Mopper
                                          @einfachprima
                                          Oder anderen Browser ausprobiert?
                                            Ja, Browser Cache in Chrome gelöscht, hat leider nichts gebracht. Inkognito-Modus hilft auch nicht.
                                            Und diesen seltsamen Edge-Browser probiert, gleiches Ergebnis 😞
                                            Thomas Braun E 2 Replies Last reply Reply Quote 0
                                            31.6k
                                            79.5k
                                            958
