    4. Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update
      Thomas Braun Most Active @taba_luga last edited by
      @taba_luga
      Taucht der jetzt bei
      iobroker update -i
      auf?
        taba_luga @Thomas Braun last edited by
        nein, da steht er nicht in der Liste:
        xx@iobroker-prod:/opt/iobroker$ iobroker update -i
        Used repository: Stable (default)
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
        Adapter    "alias-manager": 1.2.4    , installed 1.2.4
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "cloud"        : 4.1.1    , installed 4.1.1
        Adapter    "devices"      : 1.0.12   , installed 1.0.12
        Adapter    "discovery"    : 3.0.3    , installed 3.0.3
        Adapter    "echarts"      : 1.0.7    , installed 1.0.7
        Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
        Adapter    "flot"         : 1.11.0   , installed 1.11.0
        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
        Adapter    "heatingcontrol": 2.8.6   , installed 2.8.6
        Adapter    "history"      : 1.11.1   , installed 1.11.1
        Adapter    "hs100"        : 2.0.7    , installed 2.0.7
        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
        Adapter    "info"         : 1.9.19   , installed 1.9.19
        Adapter    "iot"          : 1.11.4   , installed 1.11.4
        Adapter    "javascript"   : 5.7.0    , installed 5.7.0
        Adapter    "lg-thinq"     : 0.0.7    , installed 0.0.7
        Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
        Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
        Adapter    "milight"      : 0.3.6    , installed 0.3.6
        Adapter    "node-red"     : 3.3.1    , installed 3.2.0  [Updatable]
        Adapter    "ping"         : 1.5.3    , installed 1.5.3
        Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
        Adapter    "shelly"       : 5.3.2    , installed 5.3.2
        Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
        Adapter    "telegram"     : 1.13.0   , installed 1.13.0
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "vis"          : 1.4.15   , installed 1.4.15
        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
        Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "wifilight"    : 1.1.3    , installed 1.1.3
        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
        Adapter    "zwave2"       : 2.5.0    , installed 2.5.0
          paul.honka @Thomas Braun last edited by
          schau mal
          uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          armv7l
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.15.1
          v16.15.1
          8.11.0
          pi
          /opt/iobroker
          OK:1 http://archive.raspberrypi.org/debian buster InRelease
          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          OK:3 https://deb.nodesource.com/node_16.x buster InRelease
          Alle Pakete sind aktuell.
          nodejs:
            Installiert:           16.15.1-deb-1nodesource1
            Installationskandidat: 16.15.1-deb-1nodesource1
            Versionstabelle:
           *** 16.15.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u1 500
          pi@IOBroker-Sted1:/opt/iobroker $ iobroker update -i
          Adapter    "ble"          : 0.12.0   , installed 0.13.0
          Adapter    "email"        : 1.1.3    , installed 1.1.3
          Adapter    "fb-checkpresence": 1.1.14, installed 1.1.14
          Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
          Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
          Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
          Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "pushover"     : 2.1.0    , installed 2.1.0
          Adapter    "sql"          : 1.16.2   , installed 1.16.2
          Adapter    "text2command" : 2.2.1    , installed 2.2.2
          Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
          Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
          Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
          Alles gut,oder?
          Gruss paul
            Thomas Braun Most Active @paul.honka last edited by
            @paul-honka
            Ja, alles gut.
            Gegencheck:
            cd /opt/iobroker
            npm ls | grep -E 'github.com|ERR'
              hier
              ├── iobroker.gartenbewaesserung@0.0.8 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#95bf9dcd60b595c7e59e2ed87b719bf564d9ba59)
              ├── iobroker.mihome-airpurifier@0.1.8 (git+ssh://git@github.com/JoJ123/ioBroker.mihome-airpurifier.git#33aac153e52610c4362089bcf12ac40ed97d82f5)
              Was hat es mit diesen beide Adapter auf sich?
              Gruss paul
                @paul-honka
                Die sind beide nur aus GitHub installiert. Zumindest den mihome-airpurifier könnte aber auch aus dem beta-Repo bedient werden.
                Aber lass es im Moment so. Sieht gut aus.
                  apollon77 last edited by
                  Heyho alle,
                  @arteck hatbdas issue auch und bei ihm sind wie vermutet - warum auch immer - die rename ZIEL Verzeichnisse vorhanden!!!!!
                  Also bitte NICHT das rename machen was er anmeckert sondern das ZIELVerzeichnis entfernen.
                  Wir experimentieren gerade ob man es aufgeräumt bekommt.
                  arteck 1 Reply Last reply Reply Quote 1
                    arteck Developer Most Active @apollon77 last edited by arteck
                    also
                    das passiert immer wenn npm 8 auf dem weg probleme hatte
                    LÖSUNG
                    iob stop
                    alle Ordner im node_modules Ordner die mit einem . (punkt) anfangen zu löschen
                    !!!!!!!!!!!!!!ACHTUNG ausser der .bin Ordner
                    dann nochmal in die
                    rein schauen und da ebenfals die . (punkt) Ordner löschen
                      apollon77 @arteck last edited by
                      @arteck ich denke das .bin am besten nicht Weg sollte. Der ist speziell. Aber alle anderen ja
                      Ich tippe darauf das npm diese Ordner anlegt wenn es Pakete aktualisiert damit es ggf rollback machen kann. Scheinbar gibts dann aber Fälle wo npm das nicht meh me sauber aufräumt und damit die Leichen bleiben.
                      • wendy2702
                        wendy2702 @apollon77 last edited by
                        @apollon77 Habe nach Node und NPM update auch das Problem.
                        package-lock.json --> umbenannt
                        drwxrwxr-x+ 916 iobroker iobroker  36864 Aug  1 18:35 node_modules
                        -rw-rwxr--+   1 iobroker iobroker 331970 Aug  1 07:31 out2.mp4
                        -rw-rwxr--+   1 iobroker iobroker 446898 Aug  1 13:21 out3.mp4
                        -rw-rwxr--+   1 iobroker iobroker 576978 Aug  1 15:24 package-lock.json.org
                        -rw-rwxr--+   1 iobroker iobroker   3344 Aug  1 15:24 package.json
                        -rw-rwxr--+   1 iobroker iobroker   5693 Jan  4  2022 reinstall.js
                        Hat nicht geholfen, es wurde auch kein neues angelegt.
                        Dann alle Dir mit "." am Anfang gelöscht:
                        mirko@iobroker:/opt/iobroker/node_modules$ ls -la
                        total 3712
                        drwxrwxr-x+ 916 iobroker iobroker 36864 Aug  1 18:35 .
                        drwxrwxr-x+  11 iobroker iobroker  4096 Aug  1 17:58 ..
                        drwxrwxr-x+   2 iobroker iobroker  4096 Aug  1 18:35 .bin
                        drwxrwxr-x+   5 iobroker iobroker  4096 Feb 18 15:19 @alcalzone
                        drwxrwxr-x+   3 iobroker iobroker  4096 Mar 31  2020 @apollon
                        drwxrwxr-x+   5 iobroker iobroker  4096 Jan  7  2022 @babel
                        drwxrwxr-x+   3 iobroker iobroker  4096 Feb 18 15:19 @colors
                        drwxrwxr-x+   3 iobroker iobroker  4096 Feb 18 15:19 @dabh
                        drwxrwxr-x+   3 iobroker iobroker  4096 Feb  4 12:13 @datalust
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jan 31  2021 @greenlock
                        drwxrwxr-x+   3 iobroker iobroker  4096 Mar 31  2020 @harmonyhub
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jan  7  2022 @homebridge
                        drwxrwxr-x+   4 iobroker iobroker  4096 Mar 14 17:35 @influxdata
                        drwxrwxr-x+  19 iobroker iobroker  4096 Aug  1 17:49 @iobroker
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jan  7  2022 @leichtgewicht
                        drwxrwxr-x+   3 iobroker iobroker  4096 May 29 16:37 @mapbox
                        drwxrwxr-x+   5 iobroker iobroker  4096 Jan  7  2022 @nodelib
                        drwxrwxr-x+   3 iobroker iobroker  4096 Aug  1 17:49 @peter-murray
                        drwxrwxr-x+  12 iobroker iobroker  4096 Mar 31  2020 @protobufjs
                        drwxrwxr-x+  13 iobroker iobroker  4096 Dec 15  2021 @root
                        drwxrwxr-x+   3 iobroker iobroker  4096 Nov 16  2020 @samverschueren
                        drwxrwxr-x+   9 iobroker iobroker  4096 Apr 21 11:43 @sentry
                        drwxrwxr-x+  16 iobroker iobroker  4096 Mar 30 16:00 @serialport
                        drwxrwxr-x+   3 iobroker iobroker  4096 Nov 16  2020 @sindresorhus
                        drwxrwxr-x+   3 iobroker iobroker  4096 Nov 16  2020 @szmarczak
                        drwxrwxr-x+  18 iobroker iobroker  4096 Aug  1 18:35 @types
                        drwxrwxr-x+   2 iobroker iobroker  4096 Jan 20  2022 abbrev
                        drwxrwxr-x+   2 iobroker iobroker  4096 Mar 31  2020 accepts
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jan 31  2021 acme-http-01-standalone
                        drwxrwxr-x+   4 iobroker iobroker  4096 Jun  2 16:35 acorn
                        drwxrwxr-x+   3 iobroker iobroker  4096 Mar 16 10:43 acorn-walk
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jun 13 16:37 after
                        drwxrwxr-x+   5 iobroker iobroker  4096 Jan 31  2021 agent-base
                        drwxrwxr-x+   2 iobroker iobroker  4096 Nov 16  2020 aggregate-error
                        drwxrwxr-x+   5 iobroker iobroker  4096 Mar 31  2020 ajv
                        drwxrwxr-x+  15 iobroker iobroker  4096 Feb  4 12:13 alcalzone-shared
                        drwxrwxr-x+   3 iobroker iobroker  4096 Jan  7  2022 ansi-align
                        drwxrwxr-x+   2 iobroker iobroker  4096 Jan  7  2022 ansi-escapes
                        Trotzdem erhalte ich bei z.B update von Telegramm diesen Fehler:
                        $ iobroker upgrade telegram@1.14.1 --debug
                        Update telegram from @1.13.0 to @1.14.1
                        NPM version: 8.11.0Installing iobroker.telegram@1.14.1... (System call)
                        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1'npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-08-01T16_39_46_297Z-debug-0.log
                        host.iobroker Cannot install iobroker.telegram@1.14.1: 217
                        ERROR: Process exited with code 25
                        Das NPM error log:
                        mirko@iobroker:/opt/iobroker/node_modules$ cat /home/iobroker/.npm/_logs/2022-08-01T16_39_46_297Z-debug-0.log
                        0 verbose cli /usr/bin/node /usr/bin/npm
                        1 info using npm@8.11.0
                        2 info using node@v16.16.0
                        3 timing npm:load:whichnode Completed in 0ms
                        4 timing config:load:defaults Completed in 2ms
                        5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 4ms
                        6 timing config:load:builtin Completed in 4ms
                        7 timing config:load:cli Completed in 3ms
                        8 timing config:load:env Completed in 0ms
                        9 timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
                        10 timing config:load:project Completed in 6ms
                        11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                        12 timing config:load:user Completed in 0ms
                        13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                        14 timing config:load:global Completed in 1ms
                        15 timing config:load:validate Completed in 0ms
                        16 timing config:load:credentials Completed in 1ms
                        17 timing config:load:setEnvs Completed in 1ms
                        18 timing config:load Completed in 18ms
                        19 timing npm:load:configload Completed in 18ms
                        20 timing npm:load:mkdirpcache Completed in 6ms
                        21 timing npm:load:mkdirplogs Completed in 2ms
                        22 verbose title npm install iobroker.telegram@1.14.1
                        23 verbose argv "install" "--save-exact" "iobroker.telegram@1.14.1"
                        24 timing npm:load:setTitle Completed in 1ms
                        25 timing config:load:flatten Completed in 2ms
                        26 timing npm:load:display Completed in 2ms
                        27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                        28 verbose logfile /home/iobroker/.npm/_logs/2022-08-01T16_39_46_297Z-debug-0.log
                        29 timing npm:load:logFile Completed in 3ms
                        30 timing npm:load:timers Completed in 0ms
                        31 timing npm:load:configScope Completed in 0ms
                        32 timing npm:load Completed in 36ms
                        33 timing arborist:ctor Completed in 1ms
                        34 silly logfile start cleaning logs, removing 2 files
                        35 silly logfile done cleaning log files
                        36 timing arborist:ctor Completed in 1ms
                        37 timing idealTree:init Completed in 3685ms
                        38 timing idealTree:userRequests Completed in 6ms
                        39 silly idealTree buildDeps
                        40 silly fetch manifest iobroker.admin@5.4.9
                        41 http fetch GET 200 https://registry.npmjs.org/iobroker.admin 14ms (cache hit)
                        42 silly fetch manifest iobroker.enigma2@https://github.com/Matten-Matten/ioBroker.enigma2/tarball/6235d38bb549b826c7b4fc7451cc89afc0ffe2c4
                        43 http fetch GET 200 https://codeload.github.com/Matten-Matten/ioBroker.enigma2/legacy.tar.gz/6235d38bb549b826c7b4fc7451cc89afc0ffe2c4 505ms (cache revalidated)
                        44 silly fetch manifest iobroker.icons-open-icon-library-png@https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master
                        45 http fetch GET 200 https://codeload.github.com/ioBroker/ioBroker.icons-open-icon-library-png/legacy.tar.gz/refs/heads/master 1175ms (cache revalidated)
                        46 silly fetch manifest iobroker.telegram@1.14.1
                        47 http fetch GET 200 https://registry.npmjs.org/iobroker.telegram 4ms (cache hit)
                        48 silly placeDep ROOT iobroker.admin@5.4.9 REPLACE for: iobroker.inst@2.0.3 want: 5.4.9
                        49 silly placeDep ROOT iobroker.enigma2@1.3.0 REPLACE for: iobroker.inst@2.0.3 want: https://github.com/Matten-Matten/ioBroker.enigma2/tarball/6235d38bb549b826c7b4fc7451cc89afc0ffe2c4
                        50 silly placeDep ROOT iobroker.icons-open-icon-library-png@0.1.3 REPLACE for: iobroker.inst@2.0.3 want: https://github.com/ioBroker/ioBroker.icons-open-icon-library-png/tarball/master
                        51 silly placeDep ROOT iobroker.telegram@1.14.1 REPLACE for: iobroker.inst@2.0.3 want: 1.14.1
                        52 silly fetch manifest @iobroker/adapter-core@^2.6.0
                        53 silly fetch manifest passport@^0.5.2
                        54 silly fetch manifest axios@^0.27.2
                        55 silly fetch manifest node-telegram-bot-api@^0.58.0
                        56 silly fetch manifest socksv5@https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9
                        57 http fetch GET 200 https://registry.npmjs.org/passport 15ms (cache hit)
                        58 http fetch GET 200 https://registry.npmjs.org/axios 17ms (cache hit)
                        59 http fetch GET 200 https://registry.npmjs.org/node-telegram-bot-api 19ms (cache hit)
                        60 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fadapter-core 22ms (cache hit)
                        61 http fetch GET 200 https://codeload.github.com/christophgysin/socksv5/legacy.tar.gz/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9 212ms (cache revalidated)
                        62 timing idealTree:#root Completed in 3624ms
                        63 silly placeDep node_modules/@iobroker/socket-classes axios@0.27.2 OK for: @iobroker/socket-classes@0.5.0 want: ^0.27.2
                        64 silly fetch manifest form-data@^4.0.0
                        65 http fetch GET 200 https://registry.npmjs.org/form-data 3ms (cache hit)
                        66 timing idealTree:node_modules/@iobroker/socket-classes Completed in 7ms
                        67 silly fetch manifest fsevents@~2.3.2
                        68 http fetch GET 200 https://registry.npmjs.org/fsevents 4ms (cache hit)
                        69 silly placeDep node_modules/chokidar fsevents@2.3.2 OK for: chokidar@3.5.3 want: ~2.3.2
                        70 timing idealTree:node_modules/chokidar Completed in 7ms
                        71 silly fetch manifest buffer@>=6.0.3
                        72 http fetch GET 200 https://registry.npmjs.org/buffer 4ms (cache hit)
                        73 silly placeDep ROOT buffer@6.0.3 OK for: crc@4.1.0 want: >=6.0.3
                        74 silly fetch manifest ieee754@^1.2.1
                        75 http fetch GET 200 https://registry.npmjs.org/ieee754 9ms (cache hit)
                        76 timing idealTree:node_modules/crc Completed in 21ms
                        77 silly placeDep node_modules/buffer ieee754@1.2.1 OK for: buffer@6.0.3 want: ^1.2.1
                        78 timing idealTree:node_modules/buffer Completed in 2ms
                        79 silly fetch manifest depd@~2.0.0
                        80 http fetch GET 200 https://registry.npmjs.org/depd 2ms (cache hit)
                        81 silly fetch manifest safe-buffer@5.2.1
                        82 http fetch GET 200 https://registry.npmjs.org/safe-buffer 3ms (cache hit)
                        83 silly placeDep ROOT depd@2.0.0 OK for: express-session@1.17.3 want: ~2.0.0
                        84 silly placeDep node_modules/express-session safe-buffer@5.2.1 OK for: express-session@1.17.3 want: 5.2.1
                        85 timing idealTree:node_modules/express-session Completed in 10ms
                        86 timing idealTree:node_modules/depd Completed in 0ms
                        87 silly fetch manifest xmlbuilder@https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5
                        88 http fetch GET 200 https://codeload.github.com/hobbyquaker/xmlbuilder-js/legacy.tar.gz/29fe5030dc6852007dc8d1bfd5109d75f8da58d5 366ms (cache revalidated)
                        89 silly placeDep node_modules/homematic-xmlrpc xmlbuilder@0.4.2 REPLACE for: homematic-xmlrpc@1.0.2 want: https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5
                        90 timing idealTree:node_modules/homematic-xmlrpc Completed in 379ms
                        91 silly placeDep node_modules/iobroker.admin @iobroker/adapter-core@2.6.0 OK for: iobroker.admin@5.4.9 want: ^2.6.0
                        92 silly placeDep node_modules/iobroker.admin axios@0.27.2 OK for: iobroker.admin@5.4.9 want: ^0.27.2
                        93 silly placeDep node_modules/iobroker.admin passport@0.5.3 OK for: iobroker.admin@5.4.9 want: ^0.5.2
                        94 silly fetch manifest @types/iobroker@^4.0.1
                        95 http fetch GET 200 https://registry.npmjs.org/@types%2fiobroker 3ms (cache hit)
                        96 timing idealTree:node_modules/iobroker.admin Completed in 6ms
                        97 timing idealTree:node_modules/iobroker.enigma2 Completed in 0ms
                        98 timing idealTree:node_modules/iobroker.icons-open-icon-library-png Completed in 0ms
                        99 silly placeDep ROOT node-telegram-bot-api@0.58.0 OK for: iobroker.telegram@1.14.1 want: ^0.58.0
                        100 silly placeDep ROOT socksv5@0.0.6 OK for: iobroker.telegram@1.14.1 want: https://github.com/christophgysin/socksv5/tarball/7b4eba5b30ecdb6d9e656dcfede1e6884dc7c6d9
                        101 silly fetch manifest array.prototype.findindex@^2.0.2
                        102 silly fetch manifest bl@^1.2.3
                        103 silly fetch manifest debug@^3.1.0
                        104 silly fetch manifest depd@^1.1.1
                        105 silly fetch manifest eventemitter3@^3.0.0
                        106 silly fetch manifest file-type@^3.9.0
                        107 silly fetch manifest pump@^2.0.0
                        108 http fetch GET 200 https://registry.npmjs.org/bl 13ms (cache hit)
                        109 http fetch GET 200 https://registry.npmjs.org/eventemitter3 13ms (cache hit)
                        110 http fetch GET 200 https://registry.npmjs.org/array.prototype.findindex 18ms (cache hit)
                        111 http fetch GET 200 https://registry.npmjs.org/debug 18ms (cache hit)
                        112 http fetch GET 200 https://registry.npmjs.org/pump 18ms (cache hit)
                        113 http fetch GET 200 https://registry.npmjs.org/file-type 19ms (cache hit)
                        114 timing idealTree:node_modules/iobroker.telegram Completed in 28ms
                        115 silly placeDep ROOT array.prototype.findindex@2.2.0 OK for: node-telegram-bot-api@0.58.0 want: ^2.0.2
                        116 silly placeDep ROOT bl@1.2.3 OK for: node-telegram-bot-api@0.58.0 want: ^1.2.3
                        117 silly placeDep node_modules/node-telegram-bot-api debug@3.2.7 OK for: node-telegram-bot-api@0.58.0 want: ^3.1.0
                        118 silly placeDep node_modules/node-telegram-bot-api depd@1.1.2 OK for: node-telegram-bot-api@0.58.0 want: ^1.1.1
                        119 silly placeDep ROOT eventemitter3@3.1.2 OK for: node-telegram-bot-api@0.58.0 want: ^3.0.0
                        120 silly placeDep ROOT file-type@3.9.0 OK for: node-telegram-bot-api@0.58.0 want: ^3.9.0
                        121 silly placeDep ROOT pump@2.0.1 OK for: node-telegram-bot-api@0.58.0 want: ^2.0.0
                        122 silly fetch manifest call-bind@^1.0.2
                        123 silly fetch manifest es-abstract@^1.19.4
                        124 silly fetch manifest es-shim-unscopables@^1.0.0
                        125 silly fetch manifest ms@^2.1.1
                        126 http fetch GET 200 https://registry.npmjs.org/call-bind 11ms (cache hit)
                        127 http fetch GET 200 https://registry.npmjs.org/es-abstract 10ms (cache hit)
                        128 http fetch GET 200 https://registry.npmjs.org/ms 10ms (cache hit)
                        129 http fetch GET 200 https://registry.npmjs.org/es-shim-unscopables 11ms (cache hit)
                        130 timing idealTree:node_modules/node-telegram-bot-api Completed in 44ms
                        131 silly placeDep ROOT call-bind@1.0.2 REPLACE for: array.prototype.findindex@2.2.0 want: ^1.0.2
                        132 silly placeDep ROOT es-abstract@1.20.1 OK for: array.prototype.findindex@2.2.0 want: ^1.19.4
                        133 silly placeDep ROOT es-shim-unscopables@1.0.0 OK for: array.prototype.findindex@2.2.0 want: ^1.0.0
                        134 silly fetch manifest function.prototype.name@^1.1.5
                        135 silly fetch manifest get-intrinsic@^1.1.1
                        136 silly fetch manifest get-symbol-description@^1.0.0
                        137 silly fetch manifest has-property-descriptors@^1.0.0
                        138 silly fetch manifest has-symbols@^1.0.3
                        139 silly fetch manifest internal-slot@^1.0.3
                        140 silly fetch manifest is-callable@^1.2.4
                        141 silly fetch manifest is-negative-zero@^2.0.2
                        142 silly fetch manifest is-regex@^1.1.4
                        143 silly fetch manifest is-shared-array-buffer@^1.0.2
                        144 silly fetch manifest is-string@^1.0.7
                        145 silly fetch manifest is-weakref@^1.0.2
                        146 silly fetch manifest object-inspect@^1.12.0
                        147 silly fetch manifest regexp.prototype.flags@^1.4.3
                        148 silly fetch manifest string.prototype.trimend@^1.0.5
                        149 silly fetch manifest string.prototype.trimstart@^1.0.5
                        150 silly fetch manifest unbox-primitive@^1.0.2
                        151 http fetch GET 200 https://registry.npmjs.org/has-property-descriptors 52ms (cache hit)
                        152 http fetch GET 200 https://registry.npmjs.org/is-negative-zero 51ms (cache hit)
                        153 http fetch GET 200 https://registry.npmjs.org/is-callable 52ms (cache hit)
                        154 http fetch GET 200 https://registry.npmjs.org/function.prototype.name 55ms (cache hit)
                        155 http fetch GET 200 https://registry.npmjs.org/get-symbol-description 55ms (cache hit)
                        156 http fetch GET 200 https://registry.npmjs.org/object-inspect 46ms (cache hit)
                        157 http fetch GET 200 https://registry.npmjs.org/is-string 48ms (cache hit)
                        158 http fetch GET 200 https://registry.npmjs.org/internal-slot 56ms (cache hit)
                        159 http fetch GET 200 https://registry.npmjs.org/is-weakref 49ms (cache hit)
                        160 http fetch GET 200 https://registry.npmjs.org/string.prototype.trimend 47ms (cache hit)
                        161 http fetch GET 200 https://registry.npmjs.org/unbox-primitive 47ms (cache hit)
                        162 http fetch GET 200 https://registry.npmjs.org/regexp.prototype.flags 48ms (cache hit)
                        163 http fetch GET 200 https://registry.npmjs.org/string.prototype.trimstart 48ms (cache hit)
                        164 http fetch GET 200 https://registry.npmjs.org/get-intrinsic 60ms (cache hit)
                        165 http fetch GET 200 https://registry.npmjs.org/is-shared-array-buffer 53ms (cache hit)
                        166 http fetch GET 200 https://registry.npmjs.org/has-symbols 59ms (cache hit)
                        167 http fetch GET 200 https://registry.npmjs.org/is-regex 54ms (cache hit)
                        168 timing idealTree:node_modules/array.prototype.findindex Completed in 70ms
                        169 timing idealTree:node_modules/bl Completed in 0ms
                        170 timing idealTree:node_modules/call-bind Completed in 0ms
                        171 silly placeDep ROOT function.prototype.name@1.1.5 OK for: es-abstract@1.20.1 want: ^1.1.5
                        172 silly placeDep ROOT get-intrinsic@1.1.2 REPLACE for: es-abstract@1.20.1 want: ^1.1.1
                        173 silly placeDep ROOT get-symbol-description@1.0.0 OK for: es-abstract@1.20.1 want: ^1.0.0
                        174 silly placeDep ROOT has-property-descriptors@1.0.0 OK for: es-abstract@1.20.1 want: ^1.0.0
                        175 silly placeDep ROOT has-symbols@1.0.3 REPLACE for: es-abstract@1.20.1 want: ^1.0.3
                        176 silly placeDep ROOT internal-slot@1.0.3 OK for: es-abstract@1.20.1 want: ^1.0.3
                        177 silly placeDep ROOT is-callable@1.2.4 REPLACE for: es-abstract@1.20.1 want: ^1.2.4
                        178 silly placeDep ROOT is-negative-zero@2.0.2 OK for: es-abstract@1.20.1 want: ^2.0.2
                        179 silly placeDep ROOT is-regex@1.1.4 REPLACE for: es-abstract@1.20.1 want: ^1.1.4
                        180 silly placeDep ROOT is-shared-array-buffer@1.0.2 OK for: es-abstract@1.20.1 want: ^1.0.2
                        181 silly placeDep ROOT is-string@1.0.7 REPLACE for: es-abstract@1.20.1 want: ^1.0.7
                        182 silly placeDep ROOT is-weakref@1.0.2 OK for: es-abstract@1.20.1 want: ^1.0.2
                        183 silly placeDep ROOT object-inspect@1.12.2 REPLACE for: es-abstract@1.20.1 want: ^1.12.0
                        184 silly placeDep ROOT regexp.prototype.flags@1.4.3 REPLACE for: es-abstract@1.20.1 want: ^1.4.3
                        185 silly placeDep ROOT string.prototype.trimend@1.0.5 OK for: es-abstract@1.20.1 want: ^1.0.5
                        186 silly placeDep ROOT string.prototype.trimstart@1.0.5 OK for: es-abstract@1.20.1 want: ^1.0.5
                        187 silly placeDep ROOT unbox-primitive@1.0.2 OK for: es-abstract@1.20.1 want: ^1.0.2
                        188 silly fetch manifest functions-have-names@^1.2.2
                        189 silly fetch manifest has-tostringtag@^1.0.0
                        190 silly fetch manifest define-properties@^1.1.4
                        191 silly fetch manifest has-bigints@^1.0.2
                        192 http fetch GET 200 https://registry.npmjs.org/define-properties 9ms (cache hit)
                        193 http fetch GET 200 https://registry.npmjs.org/has-tostringtag 10ms (cache hit)
                        194 http fetch GET 200 https://registry.npmjs.org/has-bigints 8ms (cache hit)
                        195 http fetch GET 200 https://registry.npmjs.org/functions-have-names 12ms (cache hit)
                        196 timing idealTree:node_modules/es-abstract Completed in 55ms
                        197 timing idealTree:node_modules/es-shim-unscopables Completed in 0ms
                        198 timing idealTree:node_modules/eventemitter3 Completed in 0ms
                        199 timing idealTree:node_modules/file-type Completed in 0ms
                        200 silly placeDep ROOT functions-have-names@1.2.3 OK for: function.prototype.name@1.1.5 want: ^1.2.2
                        201 timing idealTree:node_modules/function.prototype.name Completed in 3ms
                        202 timing idealTree:node_modules/functions-have-names Completed in 0ms
                        203 timing idealTree:node_modules/get-intrinsic Completed in 1ms
                        204 timing idealTree:node_modules/get-symbol-description Completed in 0ms
                        205 timing idealTree:node_modules/has-property-descriptors Completed in 0ms
                        206 timing idealTree:node_modules/has-symbols Completed in 0ms
                        207 timing idealTree:node_modules/internal-slot Completed in 0ms
                        208 timing idealTree:node_modules/is-callable Completed in 0ms
                        209 timing idealTree:node_modules/is-negative-zero Completed in 0ms
                        210 silly placeDep ROOT has-tostringtag@1.0.0 OK for: is-regex@1.1.4 want: ^1.0.0
                        211 timing idealTree:node_modules/is-regex Completed in 2ms
                        212 timing idealTree:node_modules/has-tostringtag Completed in 0ms
                        213 timing idealTree:node_modules/is-shared-array-buffer Completed in 0ms
                        214 timing idealTree:node_modules/is-string Completed in 0ms
                        215 timing idealTree:node_modules/is-weakref Completed in 0ms
                        216 timing idealTree:node_modules/object-inspect Completed in 0ms
                        217 timing idealTree:node_modules/pump Completed in 0ms
                        218 timing idealTree:node_modules/regexp.prototype.flags Completed in 0ms
                        219 timing idealTree:node_modules/socksv5 Completed in 0ms
                        220 silly placeDep ROOT define-properties@1.1.4 REPLACE for: string.prototype.trimend@1.0.5 want: ^1.1.4
                        221 timing idealTree:node_modules/string.prototype.trimend Completed in 4ms
                        222 timing idealTree:node_modules/define-properties Completed in 0ms
                        223 timing idealTree:node_modules/string.prototype.trimstart Completed in 0ms
                        224 silly placeDep ROOT has-bigints@1.0.2 OK for: unbox-primitive@1.0.2 want: ^1.0.2
                        225 timing idealTree:node_modules/unbox-primitive Completed in 2ms
                        226 timing idealTree:node_modules/has-bigints Completed in 0ms
                        227 silly placeDep node_modules/@iobroker/socket-classes form-data@4.0.0 OK for: axios@0.27.2 want: ^4.0.0
                        228 timing idealTree:node_modules/@iobroker/socket-classes/node_modules/axios Completed in 1ms
                        229 timing idealTree:node_modules/@iobroker/socket-classes/node_modules/form-data Completed in 0ms
                        230 timing idealTree:node_modules/buffer/node_modules/ieee754 Completed in 0ms
                        231 timing idealTree:node_modules/chokidar/node_modules/fsevents Completed in 0ms
                        232 timing idealTree:node_modules/express-session/node_modules/safe-buffer Completed in 0ms
                        233 timing idealTree:node_modules/homematic-xmlrpc/node_modules/xmlbuilder Completed in 0ms
                        234 silly placeDep node_modules/iobroker.admin @types/iobroker@4.0.4 OK for: @iobroker/adapter-core@2.6.0 want: ^4.0.1
                        235 timing idealTree:node_modules/iobroker.admin/node_modules/@iobroker/adapter-core Completed in 1ms
                        236 timing idealTree:node_modules/iobroker.admin/node_modules/@types/iobroker Completed in 0ms
                        237 silly placeDep node_modules/iobroker.admin form-data@4.0.0 OK for: axios@0.27.2 want: ^4.0.0
                        238 timing idealTree:node_modules/iobroker.admin/node_modules/axios Completed in 1ms
                        239 timing idealTree:node_modules/iobroker.admin/node_modules/form-data Completed in 0ms
                        240 timing idealTree:node_modules/iobroker.admin/node_modules/passport Completed in 0ms
                        241 silly fetch manifest cpu-features@~0.0.4
                        242 http fetch GET 200 https://registry.npmjs.org/cpu-features 2ms (cache hit)
                        243 silly placeDep node_modules/iobroker.javascript cpu-features@0.0.4 OK for: ssh2@1.11.0 want: ~0.0.4
                        244 silly fetch manifest buildcheck@0.0.3
                        245 http fetch GET 200 https://registry.npmjs.org/buildcheck 4ms (cache hit)
                        246 timing idealTree:node_modules/iobroker.javascript/node_modules/ssh2 Completed in 9ms
                        247 silly placeDep ROOT buildcheck@0.0.3 OK for: cpu-features@0.0.4 want: 0.0.3
                        248 timing idealTree:node_modules/iobroker.javascript/node_modules/cpu-features Completed in 2ms
                        249 timing idealTree:node_modules/buildcheck Completed in 0ms
                        250 silly fetch manifest fsevents@^1.0.0
                        251 silly placeDep node_modules/iobroker.js2fs/node_modules/chokidar fsevents@1.2.13 OK for: chokidar@1.7.0 want: ^1.0.0
                        252 timing idealTree:node_modules/iobroker.js2fs/node_modules/chokidar Completed in 2ms
                        253 silly placeDep node_modules/node-telegram-bot-api ms@2.1.3 OK for: debug@3.2.7 want: ^2.1.1
                        254 timing idealTree:node_modules/node-telegram-bot-api/node_modules/debug Completed in 1ms
                        255 timing idealTree:node_modules/node-telegram-bot-api/node_modules/depd Completed in 0ms
                        256 timing idealTree:node_modules/node-telegram-bot-api/node_modules/ms Completed in 0ms
                        257 timing idealTree:node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents Completed in 0ms
                        258 timing idealTree:buildDeps Completed in 4286ms
                        259 timing idealTree:fixDepFlags Completed in 16ms
                        260 timing idealTree Completed in 8007ms
                        261 timing reify:loadTrees Completed in 8009ms
                        262 timing reify:diffTrees Completed in 15ms
                        263 silly reify mark retired [ '/opt/iobroker/node_modules/fsevents' ]
                        264 silly reify mark retired [
                        264 silly reify   '/opt/iobroker/node_modules/acorn',
                        264 silly reify   '/opt/iobroker/node_modules/.bin/acorn'
                        264 silly reify ]
                        265 silly reify mark retired [ '/opt/iobroker/node_modules/acorn-walk' ]
                        266 silly reify mark retired [ '/opt/iobroker/node_modules/array.prototype.findindex' ]
                        267 silly reify mark retired [ '/opt/iobroker/node_modules/bl' ]
                        268 silly reify mark retired [ '/opt/iobroker/node_modules/body-parser/node_modules/depd' ]
                        269 silly reify mark retired [ '/opt/iobroker/node_modules/call-bind' ]
                        270 silly reify mark retired [ '/opt/iobroker/node_modules/cli' ]
                        271 silly reify mark retired [ '/opt/iobroker/node_modules/cliff' ]
                        272 silly reify mark retired [ '/opt/iobroker/node_modules/coffee-compiler' ]
                        273 silly reify mark retired [
                        273 silly reify   '/opt/iobroker/node_modules/coffee-script',
                        273 silly reify   '/opt/iobroker/node_modules/.bin/coffee',
                        273 silly reify   '/opt/iobroker/node_modules/.bin/cake'
                        273 silly reify ]
                        274 silly reify mark retired [ '/opt/iobroker/node_modules/define-properties' ]
                        275 silly reify mark retired [ '/opt/iobroker/node_modules/depd' ]
                        276 silly reify mark retired [ '/opt/iobroker/node_modules/es-abstract' ]
                        277 silly reify mark retired [ '/opt/iobroker/node_modules/es-get-iterator/node_modules/call-bind' ]
                        278 silly reify mark retired [
                        278 silly reify   '/opt/iobroker/node_modules/es-get-iterator/node_modules/get-intrinsic'
                        278 silly reify ]
                        279 silly reify mark retired [ '/opt/iobroker/node_modules/es-shim-unscopables' ]
                        280 silly reify mark retired [ '/opt/iobroker/node_modules/eventemitter3' ]
                        281 silly reify mark retired [ '/opt/iobroker/node_modules/express/node_modules/depd' ]
                        282 silly reify mark retired [ '/opt/iobroker/node_modules/file-type' ]
                        283 silly reify mark retired [ '/opt/iobroker/node_modules/function.prototype.name' ]
                        284 silly reify mark retired [ '/opt/iobroker/node_modules/functions-have-names' ]
                        285 silly reify mark retired [ '/opt/iobroker/node_modules/get-intrinsic' ]
                        286 silly reify mark retired [ '/opt/iobroker/node_modules/get-symbol-description' ]
                        287 silly reify mark retired [ '/opt/iobroker/node_modules/has-bigints' ]
                        288 silly reify mark retired [ '/opt/iobroker/node_modules/has-property-descriptors' ]
                        289 silly reify mark retired [ '/opt/iobroker/node_modules/has-symbols' ]
                        290 silly reify mark retired [ '/opt/iobroker/node_modules/has-tostringtag' ]
                        291 silly reify mark retired [
                        291 silly reify   '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder'
                        291 silly reify ]
                        292 silly reify mark retired [ '/opt/iobroker/node_modules/http-errors/node_modules/depd' ]
                        293 silly reify mark retired [ '/opt/iobroker/node_modules/internal-slot' ]
                        294 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.admin' ]
                        295 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.enigma2' ]
                        296 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png' ]
                        297 silly reify mark retired [
                        297 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind'
                        297 silly reify ]
                        298 silly reify mark retired [
                        298 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties'
                        298 silly reify ]
                        299 silly reify mark retired [
                        299 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind'
                        299 silly reify ]
                        300 silly reify mark retired [
                        300 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic'
                        300 silly reify ]
                        301 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has' ]
                        302 silly reify mark retired [
                        302 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors'
                        302 silly reify ]
                        303 silly reify mark retired [
                        303 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols'
                        303 silly reify ]
                        304 silly reify mark retired [
                        304 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys'
                        304 silly reify ]
                        305 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/fsevents' ]
                        306 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.telegram' ]
                        307 silly reify mark retired [ '/opt/iobroker/node_modules/is-callable' ]
                        308 silly reify mark retired [ '/opt/iobroker/node_modules/is-negative-zero' ]
                        309 silly reify mark retired [ '/opt/iobroker/node_modules/is-regex' ]
                        310 silly reify mark retired [ '/opt/iobroker/node_modules/is-shared-array-buffer' ]
                        311 silly reify mark retired [ '/opt/iobroker/node_modules/is-string' ]
                        312 silly reify mark retired [
                        312 silly reify   '/opt/iobroker/node_modules/is-typed-array/node_modules/es-abstract'
                        312 silly reify ]
                        313 silly reify mark retired [
                        313 silly reify   '/opt/iobroker/node_modules/is-typed-array/node_modules/is-callable'
                        313 silly reify ]
                        314 silly reify mark retired [ '/opt/iobroker/node_modules/is-weakref' ]
                        315 silly reify mark retired [ '/opt/iobroker/node_modules/is-weakset/node_modules/call-bind' ]
                        316 silly reify mark retired [ '/opt/iobroker/node_modules/is-weakset/node_modules/get-intrinsic' ]
                        317 silly reify mark retired [ '/opt/iobroker/node_modules/jsonata' ]
                        318 silly reify mark retired [
                        318 silly reify   '/opt/iobroker/node_modules/node-inspect',
                        318 silly reify   '/opt/iobroker/node_modules/.bin/node-inspect'
                        318 silly reify ]
                        319 silly reify mark retired [ '/opt/iobroker/node_modules/node-telegram-bot-api' ]
                        320 silly reify mark retired [ '/opt/iobroker/node_modules/object-inspect' ]
                        321 silly reify mark retired [ '/opt/iobroker/node_modules/object-is/node_modules/call-bind' ]
                        322 silly reify mark retired [ '/opt/iobroker/node_modules/picocolors' ]
                        323 silly reify mark retired [ '/opt/iobroker/node_modules/pkginfo' ]
                        324 silly reify mark retired [ '/opt/iobroker/node_modules/pump' ]
                        325 silly reify mark retired [ '/opt/iobroker/node_modules/regexp.prototype.flags' ]
                        326 silly reify mark retired [ '/opt/iobroker/node_modules/send/node_modules/depd' ]
                        327 silly reify mark retired [ '/opt/iobroker/node_modules/setimmediate' ]
                        328 silly reify mark retired [ '/opt/iobroker/node_modules/socksv5' ]
                        329 silly reify mark retired [ '/opt/iobroker/node_modules/string.prototype.trimstart' ]
                        330 silly reify mark retired [ '/opt/iobroker/node_modules/string.prototype.trimend' ]
                        331 silly reify mark retired [
                        331 silly reify   '/opt/iobroker/node_modules/typescript',
                        331 silly reify   '/opt/iobroker/node_modules/.bin/tsc',
                        331 silly reify   '/opt/iobroker/node_modules/.bin/tsserver'
                        331 silly reify ]
                        332 silly reify mark retired [ '/opt/iobroker/node_modules/unbox-primitive' ]
                        333 silly reify mark retired [
                        333 silly reify   '/opt/iobroker/node_modules/vm2',
                        333 silly reify   '/opt/iobroker/node_modules/.bin/vm2'
                        333 silly reify ]
                        334 silly reify mark retired [ '/opt/iobroker/node_modules/virtual-tsc' ]
                        335 silly reify mark retired [
                        335 silly reify   '/opt/iobroker/node_modules/wake_on_lan',
                        335 silly reify   '/opt/iobroker/node_modules/.bin/wake'
                        335 silly reify ]
                        336 silly reify mark retired [
                        336 silly reify   '/opt/iobroker/node_modules/which-typed-array/node_modules/is-callable'
                        336 silly reify ]
                        337 silly reify mark retired [
                        337 silly reify   '/opt/iobroker/node_modules/which-typed-array/node_modules/es-abstract'
                        337 silly reify ]
                        338 silly reify mark retired [ '/opt/iobroker/node_modules/@types/caseless' ]
                        339 silly reify mark retired [ '/opt/iobroker/node_modules/@types/request' ]
                        340 silly reify mark retired [ '/opt/iobroker/node_modules/@types/tough-cookie' ]
                        341 silly reify moves {
                        341 silly reify   '/opt/iobroker/node_modules/fsevents': '/opt/iobroker/node_modules/.fsevents-yNYMVUiI',
                        341 silly reify   '/opt/iobroker/node_modules/acorn': '/opt/iobroker/node_modules/.acorn-zHERliMH',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/acorn': '/opt/iobroker/node_modules/.bin/.acorn-opeYtUKW',
                        341 silly reify   '/opt/iobroker/node_modules/acorn-walk': '/opt/iobroker/node_modules/.acorn-walk-dO1pTSLp',
                        341 silly reify   '/opt/iobroker/node_modules/array.prototype.findindex': '/opt/iobroker/node_modules/.array.prototype.findindex-JX1jwpiR',
                        341 silly reify   '/opt/iobroker/node_modules/bl': '/opt/iobroker/node_modules/.bl-gGZFUPNL',
                        341 silly reify   '/opt/iobroker/node_modules/body-parser/node_modules/depd': '/opt/iobroker/node_modules/body-parser/node_modules/.depd-VGlL2qZY',
                        341 silly reify   '/opt/iobroker/node_modules/call-bind': '/opt/iobroker/node_modules/.call-bind-wFahM582',
                        341 silly reify   '/opt/iobroker/node_modules/cli': '/opt/iobroker/node_modules/.cli-lLNyHbCb',
                        341 silly reify   '/opt/iobroker/node_modules/cliff': '/opt/iobroker/node_modules/.cliff-dLOGLVmX',
                        341 silly reify   '/opt/iobroker/node_modules/coffee-compiler': '/opt/iobroker/node_modules/.coffee-compiler-H6FiAEHY',
                        341 silly reify   '/opt/iobroker/node_modules/coffee-script': '/opt/iobroker/node_modules/.coffee-script-AWK5fAlC',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/coffee': '/opt/iobroker/node_modules/.bin/.coffee-LffDVTa7',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/cake': '/opt/iobroker/node_modules/.bin/.cake-KIpKZLZN',
                        341 silly reify   '/opt/iobroker/node_modules/define-properties': '/opt/iobroker/node_modules/.define-properties-gzFzeOn0',
                        341 silly reify   '/opt/iobroker/node_modules/depd': '/opt/iobroker/node_modules/.depd-6oV4UsPU',
                        341 silly reify   '/opt/iobroker/node_modules/es-abstract': '/opt/iobroker/node_modules/.es-abstract-bryRKUKR',
                        341 silly reify   '/opt/iobroker/node_modules/es-get-iterator/node_modules/call-bind': '/opt/iobroker/node_modules/es-get-iterator/node_modules/.call-bind-8MP8d4f3',
                        341 silly reify   '/opt/iobroker/node_modules/es-get-iterator/node_modules/get-intrinsic': '/opt/iobroker/node_modules/es-get-iterator/node_modules/.get-intrinsic-NTVg6qm6',
                        341 silly reify   '/opt/iobroker/node_modules/es-shim-unscopables': '/opt/iobroker/node_modules/.es-shim-unscopables-lNCpEqsg',
                        341 silly reify   '/opt/iobroker/node_modules/eventemitter3': '/opt/iobroker/node_modules/.eventemitter3-Ypm2PXPd',
                        341 silly reify   '/opt/iobroker/node_modules/express/node_modules/depd': '/opt/iobroker/node_modules/express/node_modules/.depd-UkXvMlmq',
                        341 silly reify   '/opt/iobroker/node_modules/file-type': '/opt/iobroker/node_modules/.file-type-5mB8rmWw',
                        341 silly reify   '/opt/iobroker/node_modules/function.prototype.name': '/opt/iobroker/node_modules/.function.prototype.name-dLvfSRnd',
                        341 silly reify   '/opt/iobroker/node_modules/functions-have-names': '/opt/iobroker/node_modules/.functions-have-names-ZNOrsTfZ',
                        341 silly reify   '/opt/iobroker/node_modules/get-intrinsic': '/opt/iobroker/node_modules/.get-intrinsic-vd5sq9SB',
                        341 silly reify   '/opt/iobroker/node_modules/get-symbol-description': '/opt/iobroker/node_modules/.get-symbol-description-t0QplcG2',
                        341 silly reify   '/opt/iobroker/node_modules/has-bigints': '/opt/iobroker/node_modules/.has-bigints-PsuMZhHG',
                        341 silly reify   '/opt/iobroker/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/.has-property-descriptors-KnJHTjkf',
                        341 silly reify   '/opt/iobroker/node_modules/has-symbols': '/opt/iobroker/node_modules/.has-symbols-NWvF0VLp',
                        341 silly reify   '/opt/iobroker/node_modules/has-tostringtag': '/opt/iobroker/node_modules/.has-tostringtag-7OKOXuU7',
                        341 silly reify   '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/xmlbuilder': '/opt/iobroker/node_modules/homematic-xmlrpc/node_modules/.xmlbuilder-UsIYEbox',
                        341 silly reify   '/opt/iobroker/node_modules/http-errors/node_modules/depd': '/opt/iobroker/node_modules/http-errors/node_modules/.depd-c1qHu8a6',
                        341 silly reify   '/opt/iobroker/node_modules/internal-slot': '/opt/iobroker/node_modules/.internal-slot-P6uKUe1y',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.admin': '/opt/iobroker/node_modules/.iobroker.admin-TtUA2igk',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.enigma2': '/opt/iobroker/node_modules/.iobroker.enigma2-GPcxIb8n',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.icons-open-icon-library-png': '/opt/iobroker/node_modules/.iobroker.icons-open-icon-library-png-dWPxt8qG',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.define-properties-6XwZYcVY',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.function-bind-xNuYoKHH',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.get-intrinsic-jaHndEV0',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-xBeCSK4w',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-property-descriptors-NgHV0bqO',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.has-symbols-BlLhZd6T',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys': '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.object-keys-L9W7bKqM',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/fsevents': '/opt/iobroker/node_modules/iobroker.js2fs/node_modules/.fsevents-pTNciYV1',
                        341 silly reify   '/opt/iobroker/node_modules/iobroker.telegram': '/opt/iobroker/node_modules/.iobroker.telegram-qJ3kkwRA',
                        341 silly reify   '/opt/iobroker/node_modules/is-callable': '/opt/iobroker/node_modules/.is-callable-ByaiUndK',
                        341 silly reify   '/opt/iobroker/node_modules/is-negative-zero': '/opt/iobroker/node_modules/.is-negative-zero-UMnvWh9m',
                        341 silly reify   '/opt/iobroker/node_modules/is-regex': '/opt/iobroker/node_modules/.is-regex-HFxgxLG7',
                        341 silly reify   '/opt/iobroker/node_modules/is-shared-array-buffer': '/opt/iobroker/node_modules/.is-shared-array-buffer-SPAEgNXE',
                        341 silly reify   '/opt/iobroker/node_modules/is-string': '/opt/iobroker/node_modules/.is-string-8L60g87m',
                        341 silly reify   '/opt/iobroker/node_modules/is-typed-array/node_modules/es-abstract': '/opt/iobroker/node_modules/is-typed-array/node_modules/.es-abstract-Y1I4ryey',
                        341 silly reify   '/opt/iobroker/node_modules/is-typed-array/node_modules/is-callable': '/opt/iobroker/node_modules/is-typed-array/node_modules/.is-callable-Px6qIVtI',
                        341 silly reify   '/opt/iobroker/node_modules/is-weakref': '/opt/iobroker/node_modules/.is-weakref-3wPDZaCU',
                        341 silly reify   '/opt/iobroker/node_modules/is-weakset/node_modules/call-bind': '/opt/iobroker/node_modules/is-weakset/node_modules/.call-bind-ZWUixpxa',
                        341 silly reify   '/opt/iobroker/node_modules/is-weakset/node_modules/get-intrinsic': '/opt/iobroker/node_modules/is-weakset/node_modules/.get-intrinsic-5MJQlNZ0',
                        341 silly reify   '/opt/iobroker/node_modules/jsonata': '/opt/iobroker/node_modules/.jsonata-ac7WxDRN',
                        341 silly reify   '/opt/iobroker/node_modules/node-inspect': '/opt/iobroker/node_modules/.node-inspect-waaOWKUA',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/node-inspect': '/opt/iobroker/node_modules/.bin/.node-inspect-PdzXFdsB',
                        341 silly reify   '/opt/iobroker/node_modules/node-telegram-bot-api': '/opt/iobroker/node_modules/.node-telegram-bot-api-1etpN2K2',
                        341 silly reify   '/opt/iobroker/node_modules/object-inspect': '/opt/iobroker/node_modules/.object-inspect-GjAk8sS0',
                        341 silly reify   '/opt/iobroker/node_modules/object-is/node_modules/call-bind': '/opt/iobroker/node_modules/object-is/node_modules/.call-bind-OTaednFR',
                        341 silly reify   '/opt/iobroker/node_modules/picocolors': '/opt/iobroker/node_modules/.picocolors-wchhkO2k',
                        341 silly reify   '/opt/iobroker/node_modules/pkginfo': '/opt/iobroker/node_modules/.pkginfo-CqIAkbx3',
                        341 silly reify   '/opt/iobroker/node_modules/pump': '/opt/iobroker/node_modules/.pump-7uzcbBxQ',
                        341 silly reify   '/opt/iobroker/node_modules/regexp.prototype.flags': '/opt/iobroker/node_modules/.regexp.prototype.flags-omxNhUlX',
                        341 silly reify   '/opt/iobroker/node_modules/send/node_modules/depd': '/opt/iobroker/node_modules/send/node_modules/.depd-DcicH4xn',
                        341 silly reify   '/opt/iobroker/node_modules/setimmediate': '/opt/iobroker/node_modules/.setimmediate-hneOl41Z',
                        341 silly reify   '/opt/iobroker/node_modules/socksv5': '/opt/iobroker/node_modules/.socksv5-3JzHnAms',
                        341 silly reify   '/opt/iobroker/node_modules/string.prototype.trimstart': '/opt/iobroker/node_modules/.string.prototype.trimstart-ocxtG8ll',
                        341 silly reify   '/opt/iobroker/node_modules/string.prototype.trimend': '/opt/iobroker/node_modules/.string.prototype.trimend-wkWXV3H1',
                        341 silly reify   '/opt/iobroker/node_modules/typescript': '/opt/iobroker/node_modules/.typescript-rKKYB1QG',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/tsc': '/opt/iobroker/node_modules/.bin/.tsc-Pyy71FfO',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/tsserver': '/opt/iobroker/node_modules/.bin/.tsserver-smqk9Vg7',
                        341 silly reify   '/opt/iobroker/node_modules/unbox-primitive': '/opt/iobroker/node_modules/.unbox-primitive-odeTH77h',
                        341 silly reify   '/opt/iobroker/node_modules/vm2': '/opt/iobroker/node_modules/.vm2-yJk3ykh3',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/vm2': '/opt/iobroker/node_modules/.bin/.vm2-C6g39egy',
                        341 silly reify   '/opt/iobroker/node_modules/virtual-tsc': '/opt/iobroker/node_modules/.virtual-tsc-7cNzXXUj',
                        341 silly reify   '/opt/iobroker/node_modules/wake_on_lan': '/opt/iobroker/node_modules/.wake_on_lan-6cMB5f0e',
                        341 silly reify   '/opt/iobroker/node_modules/.bin/wake': '/opt/iobroker/node_modules/.bin/.wake-TmFBmhSt',
                        341 silly reify   '/opt/iobroker/node_modules/which-typed-array/node_modules/is-callable': '/opt/iobroker/node_modules/which-typed-array/node_modules/.is-callable-y15J5ltr',
                        341 silly reify   '/opt/iobroker/node_modules/which-typed-array/node_modules/es-abstract': '/opt/iobroker/node_modules/which-typed-array/node_modules/.es-abstract-X4687zVr',
                        341 silly reify   '/opt/iobroker/node_modules/@types/caseless': '/opt/iobroker/node_modules/@types/.caseless-biP5OApG',
                        341 silly reify   '/opt/iobroker/node_modules/@types/request': '/opt/iobroker/node_modules/@types/.request-wwDUthdZ',
                        341 silly reify   '/opt/iobroker/node_modules/@types/tough-cookie': '/opt/iobroker/node_modules/@types/.tough-cookie-7q0ZC6AD'
                        341 silly reify }
                        342 timing reify:rollback:retireShallow Completed in 16ms
                        343 timing command:install Completed in 8073ms
                        344 verbose stack Error: ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1'
                        345 verbose cwd /opt/iobroker
                        346 verbose Linux 5.4.162-1-pve
                        347 verbose node v16.16.0
                        348 verbose npm  v8.11.0
                        349 error code ENOTEMPTY
                        350 error syscall rename
                        351 error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                        352 error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1
                        353 error errno -39
                        354 error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/.call-bind-jQ2HDLx1'
                        355 verbose exit -39
                        356 timing npm Completed in 8201ms
                        357 verbose unfinished npm timer reify 1659371986424
                        358 verbose unfinished npm timer reify:retireShallow 1659371994452
                        359 verbose code -39
                        360 error A complete log of this run can be found in:
                        360 error     /home/iobroker/.npm/_logs/2022-08-01T16_39_46_297Z-debug-0.log
                          Thomas Braun Most Active @wendy2702 last edited by Thomas Braun
                          @wendy2702
                          Stell dich in das Verzeichnis mit den vorgeschlagenen Umbenennungen und dann kopierst du da die Zeile aus meinem nodeJS-HowTo (Teil 2) ein:
                          for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
                          • wendy2702
                            wendy2702 @Thomas Braun last edited by
                            @thomas-braun Danke. Hat für Telegram geklappt.
                            Alle anderen später, jetzt erstmal Slave nach Upgrade von Buster --> Bullseye wieder beleben.
                            • X
                              xbow42 last edited by xbow42
                              Guten Abend,
                              es scheint, als habe ich einen ähnlichen Fehler.
                              Ich hatte kürzlich ein Update von node.js gemacht.
                              Heute nach dem ich den Tankerkönig hochziehen wollte, läuft der iobroker nicht mehr 😞
                              die Ordner /opt/iobroker/node_modules/.* und /opt/iobroker/node_modules/@_/._ bis auf .bin habe ich gelöscht.
                              Was muss ich tun, damit mein iobroker wieder läuft?
                              root@iobroker-nuc:/opt/iobroker# uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              x86_64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.19.0
                              v16.19.0
                              8.19.3
                              root
                              OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                              Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                              OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                              OK:4 http://ftp.de.debian.org/debian stretch Release
                              OK:5 https://deb.nodesource.com/node_16.x stretch InRelease
                              Holen:6 https://download.docker.com/linux/debian stretch InRelease [44,8 kB]
                              Es wurden 44,8 kB in 0 s geholt (95,9 kB/s).
                              nodejs:
                                Installiert:           16.19.0-1nodesource1
                                Installationskandidat: 16.19.0-1nodesource1
                                Versionstabelle:
                               *** 16.19.0-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x stretch/main amd64 Packages
                                   4.8.2~dfsg-1 500
                                      500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                              root@iobroker-nuc:/opt/iobroker# npm ls | grep ERR
                              npm ERR! code ELSPROBLEMS
                              npm ERR! extraneous: cookie@0.3.1 /opt/iobroker/node_modules/cookie
                              npm ERR! invalid: iobroker.gartenbewaesserung@ /opt/iobroker/node_modules/iobroker.gartenbewaesserung
                              npm ERR! invalid: iobroker.icons-open-icon-library-png@ /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                              npm ERR! invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                              npm ERR! invalid: iobroker.vis-materialdesign@ /opt/iobroker/node_modules/iobroker.vis-materialdesign
                              npm ERR! extraneous: moment-duration-format@2.3.2 /opt/iobroker/node_modules/moment-duration-format
                              npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
                              npm ERR!     /home/iobroker/.npm/_logs/2023-01-27T18_13_59_840Z-debug-0.log
                              root@iobroker-nuc:/opt/iobroker# iobroker status
                              node:internal/modules/cjs/loader:998
                                throw err;
                              Error: Cannot find module 'follow-redirects'
                              Require stack:
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js
                              - /opt/iobroker/node_modules/@alcalzone/pak/build/index.js
                              - /opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js
                              - /opt/iobroker/node_modules/@iobroker/js-controller-common/index.js
                              - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
                              - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                  at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                  at Module.require (node:internal/modules/cjs/loader:1067:19)
                                  at require (node:internal/modules/cjs/helpers:103:18)
                                  at Object.<anonymous> (/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js:9:18)
                                  at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                  at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                  at Module.load (node:internal/modules/cjs/loader:1043:32)
                                  at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                                  at Module.require (node:internal/modules/cjs/loader:1067:19) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/adapters/http.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/defaults.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/transformData.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/dispatchRequest.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/core/Axios.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/lib/axios.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/node_modules/axios/index.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/package-managers/npm/index.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/build/lib/pak.js',
                                  '/opt/iobroker/node_modules/@alcalzone/pak/build/index.js',
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/lib/common/tools.js',
                                  '/opt/iobroker/node_modules/@iobroker/js-controller-common/index.js',
                                  '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
                                  '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              Glasfaser DJMarc75 3 Replies Last reply Reply Quote 0
                              • Glasfaser
                                Glasfaser @xbow42 last edited by Glasfaser
                                @xbow42 sagte in Error 25 bei Adapterupdates nach Node.JS 16.15.1 Update:
                                stretch ist Tod .....
                                root@iobroker-nuc
                                root ist Tabu ! Nutze einen User
                                Aktualisiere dein System . bzw. setze es neu auf , Backup rein fertig
                                • DJMarc75
                                  DJMarc75 @xbow42 last edited by DJMarc75
                                  @xbow42 wenn man als ROOT unterwegs ist dann muss man ja wissen wie man das wieder hinbekommt....
                                  Ich selbst ziehe ja meinen Hut vor den ROOTs !
                                  Würde mich das nicht trauen, obwohl ich kein Anfänger bin.
                                  • Glasfaser
                                    und nebenbei ... du hast auch zuviel gelöscht ... von Hand ...
                                    dafür gibt es das :
                                    • X
                                      xbow42 @Glasfaser last edited by
                                      @glasfaser erst nach dem Tankerkönig-Update, kam ich nicht mehr auf die Weboberfläche.
                                      Dann werde ich mal neu aufsetzen...
                                        Thomas Braun Most Active @xbow42 last edited by
                                        @xbow42
                                        Und halte das System dieses Mal auf aktuellem Stand. Selbst der Nachfolger von deinem Stretch ist schon tot.
                                        errormeldung nodejs 16.15.1
                                        15
                                        169
                                        22042
