    3. Off Topic
    4. InfluxDB
    5. Benötige Hilfe bei Influx DB
      Altersrentner @Thomas Braun last edited by
      Danke für Deine Hilfe.
      pi@raspberrypiioBroker:~ $ wget -q https://repos.influxdata.com/influxdb.key
      pi@raspberrypiioBroker:~ $ echo '23a1c8836f0afc5ed24e0486339d7cc8f6790b83886c4c96995b88a061c5bb5d influxdb.key' | sha256sum -c && cat influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
      influxdb.key: OK
      pi@raspberrypiioBroker:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      pi@raspberrypiioBroker:~ $ sudo apt update && sudo apt install influxdb2
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 https://repos.influxdata.com/debian stable InRelease [4,645 B]
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:7 https://packages.grafana.com/oss/deb stable InRelease
      Get:8 https://repos.influxdata.com/debian stable/main armhf Packages [779 B]
      Get:9 https://repos.influxdata.com/debian stable/main arm64 Packages [1,260 B]
      Fetched 50.8 kB in 2s (26.0 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      The following additional packages will be installed:
        influxdb2-cli
      The following NEW packages will be installed:
        influxdb2 influxdb2-cli
      0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
      Need to get 94.3 MB of archives.
      After this operation, 160 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2 arm64 2.3.0-1 [89.4 MB]
      Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.3.0 [4,953 kB]
      Fetched 94.3 MB in 17s (5,603 kB/s)
      Selecting previously unselected package influxdb2.
      (Reading database ... 45845 files and directories currently installed.)
      Preparing to unpack .../influxdb2_2.3.0-1_arm64.deb ...
      Unpacking influxdb2 (2.3.0-1) ...
      Selecting previously unselected package influxdb2-cli.
      Preparing to unpack .../influxdb2-cli_2.3.0_arm64.deb ...
      Unpacking influxdb2-cli (2.3.0) ...
      Setting up influxdb2 (2.3.0-1) ...
      Created symlink /etc/systemd/system/influxd.service → /lib/systemd/system/influxdb.service.
      Created symlink /etc/systemd/system/multi-user.target.wants/influxdb.service → /lib/systemd/system/influxdb.service.
      Setting up influxdb2-cli (2.3.0) ...
      pi@raspberrypiioBroker:~ $ sudo service influxdb2 start
      Failed to start influxdb2.service: Unit influxdb2.service not found.
      pi@raspberrypiioBroker:~ $ sudo service influxdb start
      pi@raspberrypiioBroker:~ $ sudo influx
      NAME:
         influx - Influx Client
      USAGE:
         influx [command]
      COMMANDS:
         version              Print the influx CLI version
         write                Write points to InfluxDB
         bucket               Bucket management commands
         completion           Generates completion scripts
         query                Execute a Flux query
         config               Config management commands
         org, organization    Organization management commands
         delete               Delete points from InfluxDB
         user                 User management commands
         task                 Task management commands
         telegrafs            List Telegraf configuration(s). Subcommands manage Telegraf configurations.
         dashboards           List Dashboard(s).
         export               Export existing resources as a template
         secret               Secret management commands
         v1                   InfluxDB v1 management commands
         auth, authorization  Authorization management commands
         apply                Apply a template to manage resources
         stacks               List stack(s) and associated templates. Subcommands manage stacks.
         template             Summarize the provided template
         bucket-schema        Bucket schema management commands
         ping                 Check the InfluxDB /health endpoint
         setup                Setup instance with initial user, org, bucket
         backup               Backup database
         restore              Restores a backup directory to InfluxDB
         remote               Remote connection management commands
         replication          Replication stream management commands
         server-config        Display server config
         help, h              Shows a list of commands or help for one command
      GLOBAL OPTIONS:
         --help, -h  show help
      Muss ich jetzt noch Rechte einfügen? Etwa so?
      CREATE USER "admin" WITH PASSWORD '<adminpassword>' WITH ALL PRIVILEGES
      CREATE USER "user" WITH PASSWORD '<userpassword>'
      CREATE DATABASE "iobroker"
      GRANT ALL ON "iobroker" TO "user"
      Thomas Braun R 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Altersrentner last edited by
        @altersrentner
        Ich setzte kein influx ein. Wie das zu konfigurieren ist kann ich dir nicht sagen.
        • DJMarc75
          DJMarc75 @Homoran last edited by DJMarc75
          @homoran sagte in Benötige Hilfe bei Influx DB:
          wie hast du denn Grafana gesichert?
          Leider garnicht !
          @altersrentner sagte in Benötige Hilfe bei Influx DB:
          Mach langsam damit.
          Welche Anleitung hast Du genutzt ??
          EDIT:
          Du hast hoffentlich jetzt nicht influxdb2 installiert ???????????????????
            Thomas Braun Most Active @DJMarc75 last edited by
            @djmarc75
            haut influxdb2 auf die Kiste.
            Homoran DJMarc75 2 Replies Last reply Reply Quote 0
              @thomas-braun sagte in Benötige Hilfe bei Influx DB:
              @djmarc75
              aber nur mit 64bit
                Mit 32bit kann der nicht installiert werden, weil der dann gar nicht in der Auslage liegt.
                • DJMarc75
                  DJMarc75 @Thomas Braun last edited by
                  Das wollen wir eigentlich vermeiden weil ... siehe gestern 😉
                    @djmarc75
                    Altersrentner kam mit influxdb2 an. Ich hab nur das Repo gerade gerückt. Aus der Quelle kann man ja beides schöpfen. Was dann da installiert und benötigt wird muss jeder selber wissen.
                      Homoran Global Moderator Administrators @Altersrentner last edited by
                      etwa so?
                      Unable to locate package influxdb2
                      • DJMarc75
                        Jetzt hab ichs auch gesehen.... dann wird das hier wieder ein langer Thread 😩
                          etwa so?
                          Nein, nicht so. Das lag ja am nicht korrekt eingebundenen Repo. Da hätte man auch kein influx1 drüber bekommen.
                            Altersrentner @DJMarc75 last edited by Altersrentner
                            @djmarc75 sagte in Benötige Hilfe bei Influx DB:
                            Da hast Du aber eine schlechte Meinung von mir😧
                            Stand der Dinge aktuell:
                            IoBroker läuft
                            InfluxDB läuft
                            Grafana läuft
                            Soweit so gut
                            Es fehlt nur noch die Verbindung von Grafana mit der InfluxDB
                            • DJMarc75
                              DJMarc75 @Altersrentner last edited by
                              Quatsch.
                              Aber jetzt zum Thema. Welche influxdb hast Du denn nun installiert ? DIe 1er oder 2er?
                              Und welche hattest Du vorher ?
                              A 2 Replies Last reply Reply Quote 0
                                Ich denke 1
                                • DJMarc75
                                  Ich denke 1
                                  influxd version
                                    @djmarc75
                                    In der influxDB muss unter Settings Benutzer und Passwort eingestellt werden.
                                    Dort stehen jetzt noch durch das eingespielte Backup die alten Daten drin.
                                    Das Passwort habe ich aber vergessen.
                                    Da es keine Sicherung von Grafana gibt, muss ich dort unter Datenquellen/Einstellungen/influxDB
                                    ganz unten:
                                    Datenbannk: iobroker
                                    Benutzer: admin
                                    Passwort:?
                                    eingeben.
                                    Das ist doch das Passwort aus der influxDB, oder?
                                    Wenn ja, kann ich ein neues Passwort vergeben?
                                      influxd version
                                      pi@raspberrypiioBroker:~ $ influxd version
                                      InfluxDB v1.8.10 (git: 1.8 688e697c51fd)
                                      • DJMarc75
                                        Hast Du denn gestern oder heute einen Benutzer admin angelegt ?
                                          Das ist noch der Benutzer aus der alten Installation.
                                          Benutzer von Grafana jetzt ist auch admin
                                          • DJMarc75
                                            @altersrentner
                                            influx
                                            dann
                                            CREATE USER admin WITH PASSWORD '<password>' WITH ALL PRIVILEGES
                                            password durch ein eigenes ersetzen aber < und > belassen
                                            exit
                                            ich gehe davon aus dass Du die Schritte
                                            sudo systemctl unmask influxdb
                                            sudo systemctl enable influxdb
                                            sudo systemctl start influxdb
                                            auch gemacht hast ?!
                                            10208
