    4. Test Adapter renault v0.0.x für myRenault und myDacia
      tombox @JLeg last edited by
      @jleg Kannst du via github installieren ob es dann genauso ist
      JLeg 2 Replies Last reply Reply Quote 0
      • JLeg
        JLeg @tombox last edited by
        @tombox sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
        Alles klar, werde ich morgen mal testen, thx…
        • JLeg
          @tombox Ja, GIT-Version scheint's zu tun, vielen Dank.
            Hat sich wieder etwas mit dem Kamereon ApiKey getan?
            bekomme auch mit zoe2 Probleme.
            beim Renault Adapter steht im log.
            renault.0
            	2022-07-01 19:18:37.010	info	{"type":"FUNCTIONAL","messages":[{"code":"err.func.403","message":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"errors":[{"errorCode":"err.func.403","errorMessage":"{\"errors\":[{\"status\":\"403\",\"code\":\"security.access\",\"detail\":\"Access is denied for this resource\"}]}"}],"error_reference":"FUNCTIONAL"}
            renault.0
            	2022-07-01 19:18:37.010	info	Error: Request failed with status code 403
            renault.0
            	2022-07-01 19:18:37.009	info	Feature not found. Ignore res-state for updates.
            renault.0
            	2022-07-01 19:18:36.810	info	{"type":"TECHNICAL","messages":[{"code":"err.tech.502","message":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"errors":[{"errorCode":"err.tech.502","errorMessage":"{\"errors\":[{\"status\":\"502\",\"code\":\"gateway.processing\",\"title\":\"VNEXT\",\"detail\":\"an internal error occured while processing request : 403 FORBIDDEN\"}]}"}],"error_reference":"TECHNICAL"}
            renault.0
            	2022-07-01 19:18:36.810	info	Error: Request failed with status code 502
            renault.0
            	2022-07-01 19:18:36.809	info	Feature not found. Ignore lock-status for updates.
            renault.0
            	2022-07-01 19:18:32.618	info	{"type":"TECHNICAL","messages":[{"code":"err.tech.wired.kamereon-proxy","message":"Failed to forward request to remote service."}],"errors":[{"errorCode":"err.tech.wired.kamereon-proxy","errorMessage":"Failed to forward request to remote service."}],"error_reference":"TECHNICAL"}
            renault.0
            	2022-07-01 19:18:32.618	info	Error: Request failed with status code 500
            renault.0
            	2022-07-01 19:18:32.618	info	Feature not found. Ignore charge-history for updates.
            renault.0
            	2022-07-01 19:18:13.350	info	starting. Version 0.0.13 in /opt/iobroker/node_modules/iobroker.renault, node: v14.19.2, js-controller: 3.3.22
            ich hatte immer nur einen Adapter zur Zeit laufen, seit gestern abend sogar beide abgestellt.
            eben nochmal probiert, da kam das
            gestern nur der Teil mit Kamereon
              tombox @Homoran last edited by
              @homoran 500er Fehler sind mehr Fehler beim Server. Abwarten...
                Homoran Global Moderator Administrators @tombox last edited by
                @tombox Danke!
                müsste aber bei Kamereon sein, die myRenault App läuft
                • Thomas Kohb
                  Thomas Kohb @teichi last edited by
                  @teichi
                  Habe aktuell auch das Problem, dass ich das Laden remote nicht stoppen.. kann
                  Alle Werte lesen, kann der Adapter prima... gibt es da schon ne Lösung?
                    ChristophB last edited by
                    wir haben eine neue Zoe bekommen und rufe über den Renault Adapter den Ladestand ab, um beim PV Überschussladen ein Ladelimit zu realisieren. Die Voreinstellung ist ja bei einem Update Intervall von 10 Minuten. Von meinem Ioniq weiß ich, daß bei jeder Abfrage im Auto das System hochfährt und mit der Zeit die 12V Batterie leer zieht. Besteht die Gefahr bei der Zoe auch, oder wie ist das dort realisiert?
                    Gruß Christoph
                      warp-it @Thomas Kohb last edited by
                      @thomas-kohb
                      Ich vermute, Du meinst das Steuern der Ladung an einer privaten Wallbox?
                      An einer öffentlichen macht das keinen Sinn, da man dort ja das Auto nach der Beendigung des Ladens wegfährt, und damit sowieso vor Ort ist.
                      Welche Wallbox hast Du?
                      Bei meiner Easee steuere ich das über die Box, und nicht über das Fahrzeug.
                        Homoran Global Moderator Administrators @warp-it last edited by
                        @warp-it sagte in Test Adapter renault v0.0.x für myRenault und myDacia:
                        und die kennt den Ladezustand des Fahrzeugs?
                        Woher?
                          warp-it @Homoran last edited by
                          Uber den Renault Adapter: renault.0.VF1Axxxxxxxxxx.battery-status.batteryLevel
                          Ist für mich aber nicht interessant, da ich wegen des Balancings immer voll auflade.
                            und genau darauf zielt die Frage von @thomas-kohb.
                            Er möchte eine Zielladung auf x% realisieren
                              guergen @Homoran last edited by
                              Kann es sein, dass die Renault-Seite nicht mehr geht?
                              Ich kann mich nicht mehr dort einloggen und der Adapter hat auch keine Verbindung!
                                warp-it @guergen last edited by
                                @guergen said in Test Adapter renault v0.0.x für myRenault und myDacia:
                                Ich bekomme Daten:
                                  guergen @warp-it last edited by
                                  @warp-it Ich kann mich noch nicht einmal auf der Renault-Seite anmelden!
                                    akfmaster @tombox last edited by
                                    @tombox Hallo,
                                    auch mit der neuesten Version 0.0.14 läuft das Log bei mir mit Fehlermeldungen voll. Die Daten zum 'battery-status' scheinen zu passen, die 'charge-history' verblüfft mich immer wieder. Woran kann es liegen, dass so viele Fehler geworfen werden?
                                    • Humidor
                                      Humidor @tombox last edited by
                                      @tombox Hi, die History Fehler zeigen sich auch bei mir, beim alten Adapter konnte man diese denke ich deaktivieren? wäre ein Setting ev. möglich, ich brauch das auch nicht 🙂
                                      dieses dann noch:
                                        tony.blue @Humidor last edited by tony.blue
                                        Vielen Dank für den tollen Adapter 👏 . Ich verwende ihn mit einem Dacia Spring, den wir seit wenigen Tagen haben.
                                        In der myDacia-App kann ich die Klimatisierung ein- und ausschalten sowie das Aufladen anhalten. Vermute ich es richtig, dass dies über dies eigentlich über unter iobroker - Objekts - remote gesteuert werden sollen könnte? Dort haben allerdings alle Objekte den Wert "null". Bei Eingaben werden die Parameter angezeigt, haben aber keine Auswirkung (siehe charge/pause-resume und refesh).
                                        Deshalb meine Frage: Wie kann ich denn die Klimatisierung ein- und ausschalten, sowie das Aufladen beenden bzw. pausieren?
                                        In den Logs erhalte ich folgende Rückmeldungen. Hat das "Feature not found" etwas mit meinem Problem zu tun?
                                        renault.0
                                        	2022-11-01 12:29:04.644	info	Feature not found for UU1DBG009NU085390. Ignore res-state for updates.
                                        renault.0
                                        	2022-11-01 12:29:04.395	info	Feature not found for UU1DBG009NU085390. Ignore lock-status for updates.
                                        renault.0
                                        	2022-11-01 12:29:03.810	info	Feature not found for UU1DBG009NU085390. Ignore charges for updates.
                                        renault.0
                                        	2022-11-01 12:29:03.546	info	Feature not found for UU1DBG009NU085390. Ignore charge-history for updates.
                                        renault.0
                                        	2022-11-01 12:29:02.561	info	Feature not found for UU1DBG009NU085390. Ignore charging-settings for updates.
                                        renault.0
                                        	2022-11-01 12:29:02.301	info	Feature not found for UU1DBG009NU085390. Ignore hvac-settings for updates.
                                        renault.0
                                        	2022-11-01 12:29:01.186	info	Feature not found for UU1DBG009NU085390. Ignore charge-mode for updates.
                                        renault.0
                                        	2022-11-01 12:28:59.678	info	Feature not found for UU1DBG009NU085390. Ignore battery-inhibition-status for updates.
                                        renault.0
                                        	2022-11-01 12:28:57.172	info	starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.renault, node: v16.18.0, js-controller: 4.0.23
                                        renault.0
                                        	2022-11-01 12:28:57.081	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                        renault.0
                                        	2022-11-01 12:28:53.549	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        renault.0
                                        	2022-11-01 12:28:53.548	info	terminating
                                        renault.0
                                        	2022-11-01 12:28:53.548	info	Got terminate signal TERMINATE_YOURSELF
                                        renault.0
                                        	2022-11-01 12:25:57.623	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2022-11-01T11:25:57.568+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2022-11-01T11:25:57.568+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"error_reference":"FUNCTIONAL"}
                                        renault.0
                                        	2022-11-01 12:25:57.623	error	AxiosError: Request failed with status code 404
                                        renault.0
                                        	2022-11-01 12:25:35.452	error	{"type":"FUNCTIONAL","messages":[{"code":"err.func.404","message":"{\"timestamp\":\"2022-11-01T11:25:35.396+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"errors":[{"errorCode":"err.func.404","errorMessage":"{\"timestamp\":\"2022-11-01T11:25:35.396+0000\",\"status\":404,\"error\":\"Not Found\",\"message\":\"No message available\",\"path\":\"/car-adapter/v1/cars/UU1DBG009NU073290/charge/pause-resume\"}"}],"error_reference":"FUNCTIONAL"}
                                        renault.0
                                        	2022-11-01 12:25:35.452	error	AxiosError: Request failed with status code 404
                                        Es wäre echt klasse, wenn ich über den Adapter und iobroker die Möglichkeit schaffen könnte, dass der Dacia Spring nur bis 80 % lädt. Die myDacia-App kann das leider nicht.
                                        Vielen Dank!
                                        Tony
                                          tombox @tony.blue last edited by
                                          @tony-blue also wenn es nicht geht den remote state auf true oder false ohne Bestätigung zu setzen bräuchte ich nochmal ein account um zu sehen was die app anders machen
                                            tony.blue @tombox last edited by
                                            @tombox Gerne - Du hast eine Chat-Nachricht.
                                            357
                                            48863
