    • Chris76e
      Chris76e last edited by
      @sborg
      Da es ja immer Wärmer wird kannst du vieleicht beim nächsten Update der Wetterstatistik die Einteilung der Tage nach Temperatur erweitern? Wüstentag und Tropennacht finde ich intersseant.
      Siehe hier
        Rushmed Most Active last edited by Rushmed
        @SBorg
        mein WS Script 2.16 verliert seit einigen Tagen immer wieder die Verbindung zum ioBroker.
        Eine Statusabfrage bringt dieses Ergebnis:
        ● wetterstation.service - Service für ioBroker Wetterstation
             Loaded: loaded (/etc/systemd/system/wetterstation.service; enabled; vendor preset: enabled)
             Active: active (running) since Wed 2022-08-03 20:28:08 CEST; 1h 31min ago
           Main PID: 488 (wetterstation.s)
              Tasks: 2 (limit: 8985)
                CPU: 1min 27.967s
             CGroup: /system.slice/wetterstation.service
                     ├─  488 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                     └─16794 curl -s -H Content-Type: application/json -H Authorization: 90d68e964cf60c2f4508c6f0bf33479620a4749f20213fad390bdcee67026fad -d [ {"sensor":"61e95e3e494dbc001c7422d5", "value":"28.11"},{"sensor":"61e960e7494db>
        Aug 03 20:28:09 Smartazamba wetterstation.sh[580]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Network is unreachable
        Aug 03 20:29:37 Smartazamba wetterstation.sh[745]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:30:07 Smartazamba wetterstation.sh[872]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:30:37 Smartazamba wetterstation.sh[1013]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:31:07 Smartazamba wetterstation.sh[1155]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:31:37 Smartazamba wetterstation.sh[1339]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:32:07 Smartazamba wetterstation.sh[1962]: nc: connect to 192.168.178.20 port 8087 (tcp) failed: Connection refused
        Aug 03 20:32:37 Smartazamba wetterstation.sh[2067]: Connection to 192.168.178.20 8087 port [tcp/*] succeeded!
        Aug 03 20:45:09 Smartazamba wetterstation.sh[10322]: jq: error (at <stdin>:0): Cannot iterate over null (null)
        Aug 03 20:45:09 Smartazamba wetterstation.sh[10326]: jq: error (at <stdin>:0): Cannot iterate over null (null)
        woran kann das liegen?
        Manchmal läuft das Script aber trotzdem kommt im ioBroker nichts an:
        pi@Smartazamba:~ $ sudo systemctl status wetterstation
             Active: active (running) since Wed 2022-08-03 22:04:19 CEST; 10min ago
           Main PID: 22200 (wetterstation.s)
                CPU: 6.349s
                     ├─22200 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                     └─23240 curl -s -H Content-Type: application/json -H Authorization: 90d68e964cf60c2f4508c6f0bf33479620a474>
        Aug 03 22:04:19 Smartazamba systemd[1]: Started Service für ioBroker Wetterstation.
        Aug 03 22:04:19 Smartazamba wetterstation.sh[22216]: Connection to 192.168.178.20 8087 port [tcp/*] succeeded!
        lines 1-12/12 (END)
        Dann hilft ein Restart des ioBrokers.
        • Negalein
          @rushmed sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          @SBorg
          kann ich bestätigen. Ist seit 2 Tagen, dass zu unbestimmten Uhrzeiten nichts mehr übertragen wird.
          Bin gerade im Urlaub und kann daher die VM jedesmal nur neu booten (Zugangsdaten liegen daheim --> deshalb gerade ohne Putty).
          • SBorg
            SBorg Forum Testing Most Active @Chris76e last edited by
            @chris76e sagte in [Linux Shell-Skript] WLAN-Wetterstation:
            @sborg
            Siehe hier
            Ich habe es mal auf die ToDo-Liste gesetzt 🙂
            • SBorg
              SBorg Forum Testing Most Active @Rushmed last edited by
              @rushmed Bei dir sehe ich es, bei @Negalein meine ich es zu wissen, bei mir weiß ich es...
              Ihr/wir nutzen alle OSeM? Bei @Rushmed sieht man auch den "curl"-Befehl wie er da "hängt". Anscheinend hat OpenSenseMap Probleme mit seinen/m Server/n. Ich teste gerade eine Alternative die dann den hängenden curl-Befehl wieder freigibt und das Skript dann weiter läuft. Das muss aber erst mal 1-2 Tage im Test laufen.
              Aktuelle Lösung ist so lassen und eben restarten, oder temporär OSeM per conf abschalten.
                Rushmed Most Active @SBorg last edited by
                @sborg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                Gönn dir! Problem gemeldet und erkannt. Wenn eine Lösung in Aussicht is übe ich mich in Geduld.
                • SBorg
                  Sieht bis jetzt gut aus, zumindest kein Hänger und die Übertragung klappt weiterhin. Wer kann ( @Negalein 😉 ) darf gerne mal mit testen, ist in einer Minute erledigt.
                  Ich gehe mal von "nano" aus...
                  Im Installationsverzeichnis nano wetterstation.sub --> STRG + W drücken --> osem_tr eingeben und [ENTER] drücken --> nochmals STRG + W drücken, jetzt aber direkt danach [ENTER]
                  Wir landen nun bei dieser Zeile:
                  OSEM_TRANSMIT=$(curl -s -H "Content-Type: application/json" -H "Authorization: ${BOX_TOKEN}" \
                  und setzten nur einen "timeout 10" vor den curl-Befehl bzw. ändern sie derart ab:
                  OSEM_TRANSMIT=$(timeout 10 curl -s -H "Content-Type: application/json" -H "Authorization: ${BOX_TOKEN}" \
                  speichern und Service restarten, dass war es auch schon.
                  Wenn es den heutigen Tag bis morgen Früh ohne weiteren Hänger überlebt, kommt es so dann noch in die V2.17.0 mit hinein 😉
                  Der/die OSeM-Server geben offenbar sporadisch überhaupt keine Daten zurück. Normalerweise kommt ein "Erfolg" oder ein "Fehler" zurück. Aber bei "gar nichts" wartet der curl-Befehl bis zum sankt Nimmerleinstag...
                  Negalein R 2 Replies Last reply Reply Quote 1
                  • Negalein
                    Negalein Global Moderator @SBorg last edited by
                    Wer kann ( @Negalein ) darf gerne mal mit testen, ist in einer Minute erledigt.
                    leider erst am Sonntag Abend. Hab hier kein VPN. 😞
                      @sborg Habs geändert und läuft nun schon seit etwa 21 h unterbrechungsfrei. Danke.
                      SBorg 1 Reply Last reply Reply Quote 1
                      • SBorg
                        @rushmed Oftmals sind es nur die kleinen Dinge.... 🙂
                        @Negalein Ich weiß doch, deswegen auch Zwinker-Smily
                        Aber es läuft so wieder stabil. Man sieht auch noch den vorherigen Hänger und seit 1.5 Tagen ist nun Ruhe
                        • SBorg
                          Da keine offensichtlichen Fehler aufgetreten sind bzw. einer ausgemerzt (OSeM) wurde:
                          Neues Release des Wetterstation WLAN-Skriptes auf GitHub V2.17.0
                          • + durchschnittliche Windrichtung und -geschwindigkeit der letzten 10 Minuten alternativ anstelle
                            der aktuellen Werte an OpenSenseMap, windy und wetter.com senden
                          • + Temperaturtrend Aussentemperatur der letzten Stunde
                          • ~ Fix für Datenübertragung an nicht antwortenden OSeM-Server
                          Wie immer zu finden im GitHub
                          Update-Routine von Vorgängerversion:
                          • aktuellen WS-Updater nutzen (Download falls älter als V2.12.1: wget -O ws_updater.sh https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/ws_updater.sh)
                          • ./ws_updater.sh im Installationsverzeichnis ausführen
                          • Menüpunkt "4" wählen und die Fragen beantworten
                          • wetterstation.js muss ebenfalls im JavaScript-Adapter ersetzt und einmalig ausgeführt werden (neuer Datenpunkt Aussentemperatur_Trend); bei aktivierter Rest-API wird der Datenpunkt automatisch im ioB angelegt
                          Update sollte durchgeführt werden, gerade wenn man OpenSenseMap nutzt.
                          Die Release-Version ist nicht mit dem letzten Beta-Release identisch! Betatester tauschen bitte die ".sh" und ".sub" aus und restarten den Service.
                          Nashra R 2 Replies Last reply Reply Quote 2
                          • Nashra
                            Nashra Most Active Forum Testing @SBorg last edited by
                            Mußte dc installieren und läuft 👍
                              Rushmed Most Active @SBorg last edited by Rushmed
                              @sborg Hallo, habe über den Updater auf die 17 geupdated und bekomme bei Statusabfrage folgende Ausgabe.
                              pi@Smartazamba:~/Wetterstation $ systemctl status wetterstation
                                   Active: active (running) since Fri 2022-08-05 18:33:56 CEST; 6s ago
                                 Main PID: 2232017 (wetterstation.s)
                                    Tasks: 3 (limit: 8985)
                                      CPU: 6.073s
                                           ├─2232017 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                                           └─2234321 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234299]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234304]: (standard_in) 1: syntax error
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234305]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234306]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234311]: (standard_in) 1: syntax error
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234312]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234313]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234320]: (standard_in) 1: syntax error
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234321]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234322]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 18:34:02 Smartazamba wetterstation.sh[2234327]: (standard_in) 1: syntax error
                              Was hab ich falsch gemacht?
                              Was hat diese Angabe beim Ausführen des Updaters zu bedeuten:
                               Patche wetterstation.conf auf V2.17.0 ...
                              ./ws_updater.sh: line 405: [: ==: unary operator expected
                               Fertig...
                              Habs jetzt mehrmals versucht. Mit Updater und ohne. Der Fehler mit den fehlenden Kommandos bleibt und Daten kommen nicht an.
                              Beim Debug siehts ähnlich aus:
                                   Active: active (running) since Fri 2022-08-05 19:48:53 CEST; 10s ago
                                 Main PID: 527835 (wetterstation.s)
                                    Tasks: 1 (limit: 8985)
                                      CPU: 10.750s
                                           ├─527835 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                                           └─532315 date +%H
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532295]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532296]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532301]: (standard_in) 1: syntax error
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532302]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532303]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532304]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532310]: (standard_in) 1: syntax error
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532312]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532313]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532314]: /home/pi/Wetterstation/wetterstation.sh: line 326: debuging: command not found
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532319]: (standard_in) 1: syntax error
                              Aug 05 19:49:03 Smartazamba wetterstation.sh[532320]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: command not found
                              • Negalein
                                Ahh, der Zwinker ist mir am Handy garnicht aufgefallen. 😁
                                • SBorg
                                  SBorg Forum Testing Most Active @Rushmed last edited by SBorg
                                  Hast du versucht eine Beta-Version mittels des Updaters upzugraden? Das funktioniert nicht, hier muss man per Hand die Dateien kopieren.
                                  So wie es aussieht fehlt oder ist deine *.sub beschädigt. Ich würde trotzdem mal beide neu installieren. Im Installationsverzeichnis (vorher den Service stoppen):
                                  wget -O wetterstation.sh https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/wetterstation.sh
                                  wget -O wetterstation.sub https://raw.githubusercontent.com/SBorg2014/WLAN-Wetterstation/master/wetterstation.sub
                                    wget -O wetterstation.sub https://github.com/SBorg2014/WLAN-Wetterstation/blob/master/wetterstation.sub
                                    Jetzt siehts noch schlimmer aus:
                                         Active: failed (Result: exit-code) since Fri 2022-08-05 20:17:03 CEST; 1s ago
                                        Process: 977580 ExecStart=/home/pi/Wetterstation/wetterstation.sh (code=exited, status=203/EXEC)
                                       Main PID: 977580 (code=exited, status=203/EXEC)
                                            CPU: 4ms
                                    Aug 05 20:17:03 Smartazamba systemd[1]: Started Service für ioBroker Wetterstation.
                                    Aug 05 20:17:03 Smartazamba systemd[977580]: wetterstation.service: Failed to execute /home/pi/Wetterstation/wetterstat>
                                    Aug 05 20:17:03 Smartazamba systemd[977580]: wetterstation.service: Failed at step EXEC spawning /home/pi/Wetterstation>
                                    Aug 05 20:17:03 Smartazamba systemd[1]: wetterstation.service: Main process exited, code=exited, status=203/EXEC
                                    Aug 05 20:17:03 Smartazamba systemd[1]: wetterstation.service: Failed with result 'exit-code'.
                                    Ich habe nicht versucht eine Beta mit dem Updater up zu daten.
                                    • SBorg
                                      @rushmed Sieht jetzt verdächtig nach fehlenden Rechten aus.
                                      Was sagt denn ein ls -al wetterstattion*
                                      bzgl. Beta: dann weiß ich nicht was schief gelaufen ist. Pauschal scheint es zu funktionieren.
                                        @sborg Hab nochmal alles gelöscht und mit dem Updater neu installiert.
                                             Active: active (running) since Fri 2022-08-05 20:24:00 CEST; 1s ago
                                           Main PID: 978048 (wetterstation.s)
                                                CPU: 1.724s
                                                     ├─978048 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                                                     ├─978719 /bin/bash /home/pi/Wetterstation/wetterstation.sh
                                                     └─978720 [bc]
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978699]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978704]: (standard_in) 1: syntax error
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978705]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978706]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978711]: (standard_in) 1: syntax error
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978712]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978713]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978720]: (standard_in) 1: syntax error
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978721]: /home/pi/Wetterstation/wetterstation.sh: line 384: opensensemap: >
                                        Aug 05 20:24:02 Smartazamba wetterstation.sh[978722]: /home/pi/Wetterstation/wetterstation.sh: line 198: get_DATA: comm>
                                        pi@Smartazamba:~/Wetterstation $ ls -al wetterstattion*
                                        ls: cannot access 'wetterstattion*': No such file or directory
                                        pi@Smartazamba:~/Wetterstation $ sudo ls -al wetterstation*
                                        -rw-r--r-- 1 pi pi  7561 Aug  5 20:05 wetterstation.conf
                                        -rw-r--r-- 1 pi pi 21596 Jul 21 08:53 wetterstation.js
                                        -rwxr-xr-x 1 pi pi 19368 Aug  5 15:39 wetterstation.sh
                                        -rw-r--r-- 1 pi pi 77119 Aug  5 14:20 wetterstation.sub
                                        Wenn ich Opensensemap in der Conf deaktiviere taucht zumindest diese fehlende Kommando bei der Satusabfrage nicht mehr auf.
                                        • SBorg
                                          @rushmed Blöde Tippfehler... 😉
                                          Die Fehlermeldungen besagen, dass er die opensensensmap und get_data - Befehle nicht kennt. Die lädt er aus der sub nach, was fehlschlägt (wofür es keinen offensichtlichen Grund gibt).
                                          Hmm, das (meist) Allheilmittel: reboot?
                                          Boronsbruder 1 Reply Last reply Reply Quote 0
                                          • Boronsbruder
                                            Boronsbruder @SBorg last edited by
                                            @sborg
                                            mir ist beim patchen folgendes aufgefallen:
                                            ./ws_updater.sh: Zeile 405: [: ==: Einstelliger (unärer) Operator erwartet.
                                             Fertig...
                                            Ich bekomme ständig:
                                            Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: (standard_in) 1: syntax error
                                            Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 384: opensensemap: Kommando nicht gefunden.
                                            Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 392: logging: Kommando nicht gefunden.
                                            Aug  5 20:38:39 ZEROSERVER wetterstation.sh[18688]: /home/wetter/wetterstation.sh: Zeile 198: get_DATA: Kommando nicht gefunden.
                                            R SBorg 2 Replies Last reply Reply Quote 0
                                            152
                                            5661
                                            3766203
