    3. Off Topic
    4. InfluxDB
    5. Benötige Hilfe bei Influx DB
      Altersrentner @Thomas Braun last edited by
      @thomas-braun sagte in Benötige Hilfe bei Influx DB:
      Sag ich doch. Kein Repository angelegt.
      Das habe ich gemacht:
      pi@raspberrypiioBroker:~ $ sudo apt-get install -y adduser libfontconfig1
      Reading package lists... Done
      Building dependency tree... Done
      adduser is already the newest version (3.118).
      libfontconfig1 is already the newest version (2.13.1-4.2).
      libfontconfig1 set to manually installed.
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@raspberrypiioBroker:~ $ wget https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
      --2022-08-05 14:59:11--  https://dl.grafana.com/enterprise/release/grafana-enterprise_6.6.1_amd64.deb
      Resolving dl.grafana.com (dl.grafana.com)... 2a04:4e42:1b::729, 151.101.114.217
      Connecting to dl.grafana.com (dl.grafana.com)|2a04:4e42:1b::729|:443... connected.
      HTTP request sent, awaiting response... 200 OK
      Length: 63940356 (61M) [application/x-debian-package]
      Saving to: ‘grafana-enterprise_6.6.1_amd64.deb’
      grafana-enterprise_6.6.1_amd64.d 100%[=========================================================>]  60.98M  6.83MB/s    in 8.9s
      2022-08-05 14:59:20 (6.81 MB/s) - ‘grafana-enterprise_6.6.1_amd64.deb’ saved [63940356/63940356]
      pi@raspberrypiioBroker:~ $ sudo dpkg -i grafana-enterprise_6.6.1_amd64.deb
      dpkg: error processing archive grafana-enterprise_6.6.1_amd64.deb (--install):
       package architecture (amd64) does not match system (arm64)
      Errors were encountered while processing:
      pi@raspberrypiioBroker:~ $ sudo apt install grafana=6.6.1
      E: Unable to locate package grafana
      Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Altersrentner last edited by Thomas Braun
        @altersrentner
        Damit dübelst du dir 'irgendwas' am Paketmanager vorbei ins System.
        Finger weg von so einem Blödsinn.
        amd64 passt auch nicht zu deinem Raspberry Pi, der hat eine andere Prozessorarchitektur. Deswegen auch:
        • DJMarc75
          DJMarc75 @Altersrentner last edited by
          @altersrentner
          wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
          echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
          dann
          sudo apt update
            Altersrentner @DJMarc75 last edited by
            @djmarc75
            pi@raspberrypiioBroker:~ $ sudo apt update
            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://repos.influxdata.com/debian stretch InRelease
            Get:4 https://packages.grafana.com/oss/deb stable InRelease [12.1 kB]
            Get:5 https://packages.grafana.com/oss/deb stable/main arm64 Packages [26.6 kB]
            Get:6 https://packages.grafana.com/oss/deb stable/main armhf Packages [36.1 kB]
            Hit:7 http://deb.debian.org/debian bullseye InRelease
            Hit:8 http://deb.debian.org/debian bullseye-updates InRelease
            Fetched 74.9 kB in 6s (13.1 kB/s)
            All packages are up to date.
              @altersrentner
              Auch wenn ich das absolut nicht für eine gute Idee halte:
              sudo apt-mark hold grafana
              DJMarc75 A 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @Thomas Braun last edited by
                Da gibts dann halt ein H-Kennzeichen 😀
                @Altersrentner bist Du schon weitergekommen ?
                  Warum?
                  @djmarc75 sagte in Benötige Hilfe bei Influx DB:
                  Was meinst Du damit?
                  Ja, Eben das erste Board erstellt👍 👍 👍 😊 😊 😊
                  Die Version ist super einfach zu bedienen
                  Ich denke, das soll es dann gewesen sein.
                  Ich möchte mich bei alle die mir mit Engelsgeduld geholfen haben bedanken.
                  Mit freundlichen Grüßen
                  Michael
                    @altersrentner
                    Erwartest du da ernsthaft eine Antwort?
                    Schau hier rein:
                    https://grafana.com/tags/security/
                      Schau hier rein:
                      OHA!
                      Aber 😧 ich habe bei der aktuellen V keinen Lichtblick gefunden.
                      Habe doch noch eine Frage
                      Wie kann ich das zurücksetzen / aufheben?
                      MfG Michael
                      • DJMarc75
                        @altersrentner sagte in Benötige Hilfe bei Influx DB:
                        sudo atp-mark unhold grafana
                        Suchfunktionen in jeglicher Form wäre da auch mal eine super Idee - nicht hier alles OutOfTheBox erwarten !
                          @djmarc75
                          Asche auf mein Haupt😖
                          MfG Michael
                          • DJMarc75
                            Asche auf mein Haup
                            Na sooo schlimm dann auch nicht. Aber sei mal ehrlich, bissle selber suchen ist nicht grad schädlich 😉
                              Thomas Braun Most Active @DJMarc75 last edited by Thomas Braun
                              Wenn man gemein wäre:
                              man apt-mark
                              • DJMarc75
                                man apt-mark
                                Mich schreibt man mit C und nicht mit K ... aber gemein bin ich natürlich auch ! 😂
                                  @djmarc75
                                  Habe sehr viel gelesen 😧 aber komme jetzt wirklich nicht weiter.
                                  Ich möchte ein Plugin zu Grafana hinzu fügen.
                                  Installirt sollte das Discrete Plugin sein.
                                  Die Fehlermeldung sagt aber:
                                  < Paketlisten lesen... Fertig
                                  Abhängigkeitsbaum erstellen ... Fertig
                                  Zustandsinformationen lesen... Fertig
                                  E: Paket natel-discrete-panel kann nicht gefunden werden>
                                  Das habe ich bis jetzt versucht,
                                  pi@raspberrypiioBroker:~ $ sudo grafana-cli plugins install natel-discrete-panel
                                  installing natel-discrete-panel @ 0.1.1
                                  from: https://grafana.com/api/plugins/natel-discrete-panel/versions/0.1.1/download
                                  into: /var/lib/grafana/plugins
                                  ✔ Installed natel-discrete-panel successfully
                                  Restart grafana after installing plugins . <service grafana-server restart>
                                  pi@raspberrypiioBroker:~ $ sudo apt natel-discrete-panel
                                  E: Invalid operation natel-discrete-panel
                                  pi@raspberrypiioBroker:~ $ sudo apt install natel-discrete-panel
                                  E: Unable to locate package natel-discrete-panel
                                  Wie kann ich weiter kommen?
                                  Sonst, abgesehen von dem Sicherheitshinweis von Thomas Braun läuft alles prima.
                                  MfG Michael
                                  E Thomas Braun 3 Replies Last reply Reply Quote 0
                                  • DJMarc75
                                    @altersrentner Tag,
                                    die Frage ist warum Du das über die Konsole installieren willst ?
                                    Geht bei mir direkt per Grafana.
                                      Einstein67 @Altersrentner last edited by
                                      @altersrentner said in Benötige Hilfe bei Influx DB:
                                      Warum installierst du nicht einfach über die Grafana Oberfläche?
                                      Configuration --> Plugins --> ins Suchfeld Discrete eingeben --> auswählen und install
                                        @altersrentner
                                        Das Plugin ist kein Paket das man über den Paketmanager bezieht sondern offenbar direkt aus grafana heraus.
                                          @altersrentner Gerade gesehen. Das Plugin wurde richtig installiert!
                                          Funktioniert es nicht?
                                            Altersrentner @Einstein67 last edited by
                                            @einstein67 sagte in Benötige Hilfe bei Influx DB:
                                            Nein es taucht unter den Plugins nicht auf.
                                            10182
