    3. Entwicklung
    4. [Neuer Adapter] Reolink Kamera
      stefu87_CH @spanier last edited by
      @spanier ok. Bei mir läuft es unter Iobroker mit diesen Angaben.
        tritor @spanier last edited by
        @spanier
        hier mal mein funktionierendes Widget
        [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"10000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.10.152/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=XXXXXX&password=XXXXXXX","stretch":true},"style":{"left":"141px","top":"109px","width":"428px","height":"240px"},"widgetSet":"basic"}]
        Bei user und password die XXXXXX mit deinen Daten ersetzen und dann ganzen Text kopieren und in VIS Widget importieren.
          spanier @tritor last edited by
          @tritor sagte in [Neuer Adapter] Reolink Kamera:
          super danke 🙂 soweit hab ich erstmal ein standbild.. aber nach ablauf der updatezeit kommt das:
          noch eine Idee?
          T skvarel 2 Replies Last reply Reply Quote 0
            @spanier
            kannst dich mal in die Cam einloggen und die Settings unter Network/Advanced posten?
            ich nehme an unter Port settings ist alles relevante enabled, aber allemal eine Überprüfung wert.
              spanier @tritor last edited by spanier
              @tritor 30c41dc8-5d63-4604-aa46-78aa07a3809e-image.png fbf851d8-95c5-4ccd-8ca9-abcec9469d7b-image.png
              alles enabled...
              Mache jetzt alle aus und wieder an und neustart der cam...
              EDIT: Nach neustart Cam sowie Router keine Änderung bei Ablauf der Zeit...
              keine Ahnung...
                tritor @spanier last edited by tritor
                @spanier
                im Netzwerk setup auch UPnP enabled? Zumindest zum Test?
                Firmware nehme ich an ist aktuell.
                  @tritor zur sicherheits alles aktiviert... aber nichts passiert... zumindest habe ich jetzt ein standbild dauerhaft. hab den Häkchen bei addiere nichts zur url gesetzt. aber da hab ich das gefühl, dass er garnicht die zeit abläuft..
                  Portfreigabe im Router nötig? für http freigegeben.. aber keine besserung
                  ja firmware die aktuellste v3.1.0.956_22041503
                    @spanier
                    habe gerade auch ein seltsamen Effekt gehabt, bei existierenden Image Widget habe ich die Settings verändert und
                    danach hatte ich nur für 10 sec. ein Bild dann update und das Bild war weg.
                    Habe nun ein neues Widget eingefügt, link reinkopiert und altes Widget gelöscht, nun ist Bild wieder da und beleibt auch nach dem Update.
                    Also lösch mal das Image Widget bei dir und füge ein neues ein.
                      @tritor ich habe dein Link kopiert und ein neues Widget eingefügt, dann link mit meinen Daten ergänzt (IP, PW & User) danach das alte Widget gelöscht...
                      leider aber nach Ablauf der Zeit wieder das gleiche Bild 2e3fee65-08fc-43a1-9ee4-a31fec5f7b82-image.png
                        @spanier
                        Jetzt gehen mir die Ideen aus, eventuell wird in Zukunft mit dem Adapter eine zuverlässige Möglichkeit geben.
                        S T 2 Replies Last reply Reply Quote 0
                          stefu87_CH @tritor last edited by
                          @tritor Welche Einstellungen machst du beim Widget den? Hast du da mal ein Screen welche Hacken du setzt?
                            tritor @stefu87_CH last edited by
                            @stefu87_ch
                            Keine Haken:
                            S S BananaJoe 3 Replies Last reply Reply Quote 0
                              @tritor Versuche es mal somit:
                              Vielleicht bringts was
                                spanier @stefu87_CH last edited by
                                @stefu87_ch @tritor
                                Werde morgen beide Varianten probieren. Bin aber der Meinung, dass ich da auch bereits getestet hatte. Aber wie gesagt, gucke morgen nochmal.
                                Danke für eure Hilfe!! 🙂
                                  @tritor stelle ich das genauso wie bei dir mit 0 Sek UpdateZeit habe ich ein Standbild
                                  @stefu87_CH stelle ich das genauso ein wie bei dir, 180000 und die beiden Haken, habe ich von Anfang an kein Bild...
                                  Ich verstehe das nicht.. Kann es was mit meiner Kamera zu tun haben? RLC 810A...
                                  Habe den iObroker auch bereits neugestartet.
                                    @spanier Wenn du die Adresse direkt in einen Explorer eingibst, hast du den ein Bild?
                                    • BananaJoe
                                      BananaJoe Most Active @tritor last edited by BananaJoe
                                      @tritor und wenn du da eine Updatezeit einstellst? 60 Sekunden oder 600 Sekunden?
                                      Ich nutze das in diversen Ansichten als Hintergrund und habe da die Zeit drin.
                                      Mit den anderen Optionen auch mal gespielt?
                                      Aktualisiert bei mir das Bild 1x die Minute
                                      S T 2 Replies Last reply Reply Quote -1
                                        @stefu87_ch jap, habe dann ein Standbild. Sobald ich die seite aktualisiere, aktualisiert sich das Bild ensprechend
                                          spanier @BananaJoe last edited by
                                          @bananajoe auch das habe ich versucht... nach ablauf der zeit, bekomme ich dieses bild
                                            tritor @BananaJoe last edited by
                                            @bananajoe
                                            Bei mir läuft es, aber @spanier hat hier einen Issue
                                            kamera neuer adapter reolink testen
                                            157
                                            1074
                                            404015
