    4. ZigBee Adapter/TI Board steigt immer wieder mal aus
      martinschm @Asgothian last edited by martinschm
      @asgothian said in ZigBee Adapter/TI Board steigt immer wieder mal aus:
      Das hat mit deinem Problem absolut nichts zu tun. Entscheidend ist die Frage was passiert bevor der Adapter neu gestartet wird. Mehr Log Informationen sind also notwendig.
      Ich habe gerade mal den Adapter auf "Debug" gesetzt und in den Settings den herdsmann debug aktiviert und neugestartet.
      zigbee.0
      2022-08-02 11:21:53.288	debug	List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/ttyS12"},{"comName":"/dev/ttyS13"},{"comName":"/dev/ttyS14"},{"comName":"/dev/ttyS15"},{"comName":"/dev/ttyS16"},{"comName":"/dev/ttyS17"},{"comName":"/dev/ttyS18"},{"comName":"/dev/ttyS19"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS20"},{"comName":"/dev/ttyS21"},{"comName":"/dev/ttyS22"},{"comName":"/dev/ttyS23"},{"comName":"/dev/ttyS24"},{"comName":"/dev/ttyS25"},{"comName":"/dev/ttyS26"},{"comName":"/dev/ttyS27"},{"comName":"/dev/ttyS28"},{"comName":"/dev/ttyS29"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyS30"},{"comName":"/dev/ttyS31"},{"comName":"/dev/ttyS4"},{"comName":"/dev/ttyS5"},{"comName":"/dev/ttyS6"},{"comName":"/dev/ttyS7"},{"comName":"/dev/ttyS8"},{"comName":"/dev/ttyS9"}]
      zigbee.0
      2022-08-02 11:21:53.078	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      2022-08-02 11:19:45.193	error	Error herdsman start
      zigbee.0
      2022-08-02 11:19:45.193	error	Failed to start Zigbee
      zigbee.0
      2022-08-02 11:19:45.192	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      zigbee.0
      2022-08-02 11:19:45.156	debug	zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      zigbee.0
      2022-08-02 11:19:45.156	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204],"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
      zigbee.0
      2022-08-02 11:19:45.154	debug	zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
      zigbee.0
      2022-08-02 11:19:44.891	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-08-02 11:19:44.861	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-08-02 11:19:44.860	info	Starting Zigbee npm ...
      zigbee.0
      2022-08-02 11:19:44.859	info	Try to reconnect. 1 attempts left
      zigbee.0
      2022-08-02 11:19:34.857	error	Error herdsman start
      zigbee.0
      2022-08-02 11:19:34.856	error	Failed to start Zigbee
      zigbee.0
      2022-08-02 11:19:34.855	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.0
      2022-08-02 11:19:28.853	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      zigbee.0
      2022-08-02 11:19:28.852	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      zigbee.0
      2022-08-02 11:19:22.850	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      zigbee.0
      2022-08-02 11:19:22.849	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      zigbee.0
      2022-08-02 11:19:16.848	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      zigbee.0
      2022-08-02 11:19:16.846	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      zigbee.0
      2022-08-02 11:19:16.346	debug	zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
      zigbee.0
      2022-08-02 11:19:16.094	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      zigbee.0
      2022-08-02 11:19:16.092	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      zigbee.0
      2022-08-02 11:19:15.090	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
      zigbee.0
      2022-08-02 11:19:15.089	debug	zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
      zigbee.0
      2022-08-02 11:19:14.887	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_08_02-11_19_13.tar.gz success
      zigbee.0
      2022-08-02 11:19:14.846	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-08-02 11:19:14.834	debug	zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      zigbee.0
      2022-08-02 11:19:14.826	debug	zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      zigbee.0
      2022-08-02 11:19:14.813	debug	zigbee-herdsman:adapter:zStack:znp:log Serialport opened
      zigbee.0
      2022-08-02 11:19:14.773	debug	zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      zigbee.0
      2022-08-02 11:19:14.771	debug	zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204],"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
      zigbee.0
      2022-08-02 11:19:14.768	debug	zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
      zigbee.0
      2022-08-02 11:19:13.994	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-08-02 11:19:13.992	info	Starting Zigbee npm ...
      zigbee.0
      2022-08-02 11:19:13.989	info	delete old Backup files. keep only last 10
      zigbee.0
      2022-08-02 11:19:13.894	debug	Using zigbee-herdsman with settings: {"network":{"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20],"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2022-08-02 11:19:13.823	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
      zigbee.0
      2022-08-02 11:19:13.156	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      zigbee.0
      2022-08-02 11:19:13.145	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2022-08-02 11:19:05.409	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2022-08-02 11:19:05.408	debug	Plugin sentry destroyed
      zigbee.0
      2022-08-02 11:19:05.406	info	terminating
      zigbee.0
      2022-08-02 11:19:05.406	warn	Failed to stop zigbee during startup
      zigbee.0
      2022-08-02 11:19:05.393	info	Zigbee: disabling joining new devices.
      zigbee.0
      2022-08-02 11:19:05.380	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02dd9b = 0
      zigbee.0
      2022-08-02 11:19:05.378	debug	DeviceAvailability:Publish available for 0x04cd15fffe02dd9b = false
      zigbee.0
      2022-08-02 11:19:05.376	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe067cd7 = 0
      zigbee.0
      2022-08-02 11:19:05.373	debug	DeviceAvailability:Publish available for 0x04cd15fffe067cd7 = false
      zigbee.0
      2022-08-02 11:19:05.371	debug	DeviceAvailability:Publish LQ for 0x00158d0001e7a0d0 = 0
      zigbee.0
      2022-08-02 11:19:05.368	debug	DeviceAvailability:Publish available for 0x00158d0001e7a0d0 = false
      zigbee.0
      2022-08-02 11:19:05.366	debug	DeviceAvailability:Publish LQ for 0x00158d000482d34e = 0
      zigbee.0
      2022-08-02 11:19:05.365	debug	DeviceAvailability:Publish available for 0x00158d000482d34e = false
      zigbee.0
      2022-08-02 11:19:05.362	debug	DeviceAvailability:Publish LQ for 0x00158d000485f414 = 0
      zigbee.0
      2022-08-02 11:19:05.359	debug	DeviceAvailability:Publish available for 0x00158d000485f414 = false
      zigbee.0
      2022-08-02 11:19:05.358	debug	DeviceAvailability:Publish LQ for 0x842e14fffe35a210 = 0
      zigbee.0
      2022-08-02 11:19:05.355	debug	DeviceAvailability:Publish available for 0x842e14fffe35a210 = false
      zigbee.0
      2022-08-02 11:19:05.353	debug	DeviceAvailability:Publish LQ for 0x588e81fffedbcfe2 = 0
      zigbee.0
      2022-08-02 11:19:05.350	debug	DeviceAvailability:Publish available for 0x588e81fffedbcfe2 = false
      zigbee.0
      2022-08-02 11:19:05.348	debug	DeviceAvailability:Publish LQ for 0x842e14fffe1262bf = 0
      zigbee.0
      2022-08-02 11:19:05.346	debug	DeviceAvailability:Publish available for 0x842e14fffe1262bf = false
      zigbee.0
      2022-08-02 11:19:05.344	debug	DeviceAvailability:Publish LQ for 0x00158d00048605a0 = 0
      zigbee.0
      2022-08-02 11:19:05.342	debug	DeviceAvailability:Publish available for 0x00158d00048605a0 = false
      zigbee.0
      2022-08-02 11:19:05.331	debug	DeviceAvailability:Publish LQ for 0x00158d0004fd0fd7 = 0
      zigbee.0
      2022-08-02 11:19:05.329	debug	DeviceAvailability:Publish available for 0x00158d0004fd0fd7 = false
      zigbee.0
      2022-08-02 11:19:05.326	debug	DeviceAvailability:Publish LQ for 0x00158d0001ddab4c = 0
      zigbee.0
      2022-08-02 11:19:05.324	debug	DeviceAvailability:Publish available for 0x00158d0001ddab4c = false
      zigbee.0
      2022-08-02 11:19:05.322	debug	DeviceAvailability:Publish LQ for 0x00158d00033a4347 = 0
      zigbee.0
      2022-08-02 11:19:05.319	debug	DeviceAvailability:Publish available for 0x00158d00033a4347 = false
      zigbee.0
      2022-08-02 11:19:05.317	debug	DeviceAvailability:Publish LQ for 0x00158d0002f39894 = 0
      zigbee.0
      2022-08-02 11:19:05.315	debug	DeviceAvailability:Publish available for 0x00158d0002f39894 = false
      zigbee.0
      2022-08-02 11:19:05.313	debug	DeviceAvailability:Publish LQ for 0x00158d0001de72f5 = 0
      zigbee.0
      2022-08-02 11:19:05.311	debug	DeviceAvailability:Publish available for 0x00158d0001de72f5 = false
      zigbee.0
      2022-08-02 11:19:05.307	debug	DeviceAvailability:Publish LQ for 0x00158d00053fbd6f = 0
      zigbee.0
      2022-08-02 11:19:05.304	debug	DeviceAvailability:Publish available for 0x00158d00053fbd6f = false
      zigbee.0
      2022-08-02 11:19:05.301	debug	DeviceAvailability:Publish LQ for 0x00158d0002f39851 = 0
      zigbee.0
      2022-08-02 11:19:05.295	debug	DeviceAvailability:Publish available for 0x00158d0002f39851 = false
      zigbee.0
      2022-08-02 11:19:05.293	debug	DeviceAvailability:Publish LQ for 0x00158d0002f3c080 = 0
      zigbee.0
      2022-08-02 11:19:05.289	debug	DeviceAvailability:Publish available for 0x00158d0002f3c080 = false
      zigbee.0
      2022-08-02 11:19:05.287	debug	DeviceAvailability:Publish LQ for 0x00158d0002f90eff = 0
      zigbee.0
      2022-08-02 11:19:05.284	debug	DeviceAvailability:Publish available for 0x00158d0002f90eff = false
      zigbee.0
      2022-08-02 11:19:05.281	debug	DeviceAvailability:Publish LQ for 0x00158d0002271d3f = 0
      zigbee.0
      2022-08-02 11:19:05.279	debug	DeviceAvailability:Publish available for 0x00158d0002271d3f = false
      zigbee.0
      2022-08-02 11:19:05.275	debug	DeviceAvailability:Publish LQ for 0x00158d0001e42cf4 = 0
      zigbee.0
      2022-08-02 11:19:05.273	debug	DeviceAvailability:Publish available for 0x00158d0001e42cf4 = false
      zigbee.0
      2022-08-02 11:19:05.270	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02d085 = 0
      zigbee.0
      2022-08-02 11:19:05.268	debug	DeviceAvailability:Publish available for 0x04cd15fffe02d085 = false
      zigbee.0
      2022-08-02 11:19:05.265	debug	DeviceAvailability:Publish LQ for 0x00158d00041cc629 = 0
      zigbee.0
      2022-08-02 11:19:05.261	debug	DeviceAvailability:Publish available for 0x00158d00041cc629 = false
      zigbee.0
      2022-08-02 11:19:05.259	debug	DeviceAvailability:Publish LQ for 0x00158d00027051c6 = 0
      zigbee.0
      2022-08-02 11:19:05.257	debug	DeviceAvailability:Publish available for 0x00158d00027051c6 = false
      zigbee.0
      2022-08-02 11:19:05.254	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7a88a = 0
      zigbee.0
      2022-08-02 11:19:05.252	debug	DeviceAvailability:Publish available for 0x00158d0001b7a88a = false
      zigbee.0
      2022-08-02 11:19:05.248	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02d9f3 = 0
      zigbee.0
      2022-08-02 11:19:05.246	debug	DeviceAvailability:Publish available for 0x04cd15fffe02d9f3 = false
      zigbee.0
      2022-08-02 11:19:05.243	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7b481 = 0
      zigbee.0
      2022-08-02 11:19:05.241	debug	DeviceAvailability:Publish available for 0x00158d0001b7b481 = false
      zigbee.0
      2022-08-02 11:19:05.239	debug	DeviceAvailability:Publish LQ for 0x00158d0002019669 = 0
      zigbee.0
      2022-08-02 11:19:05.235	debug	DeviceAvailability:Publish available for 0x00158d0002019669 = false
      zigbee.0
      2022-08-02 11:19:05.233	debug	DeviceAvailability:Publish LQ for 0x00158d0001b9589f = 0
      zigbee.0
      2022-08-02 11:19:05.230	debug	DeviceAvailability:Publish available for 0x00158d0001b9589f = false
      zigbee.0
      2022-08-02 11:19:05.228	debug	DeviceAvailability:Publish LQ for 0x00158d0001e489c1 = 0
      zigbee.0
      2022-08-02 11:19:05.226	debug	DeviceAvailability:Publish available for 0x00158d0001e489c1 = false
      zigbee.0
      2022-08-02 11:19:05.222	debug	DeviceAvailability:Publish LQ for 0x00158d0001e48a72 = 0
      zigbee.0
      2022-08-02 11:19:05.220	debug	DeviceAvailability:Publish available for 0x00158d0001e48a72 = false
      zigbee.0
      2022-08-02 11:19:05.217	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf923 = 0
      zigbee.0
      2022-08-02 11:19:05.214	debug	DeviceAvailability:Publish available for 0x00158d0004fcf923 = false
      zigbee.0
      2022-08-02 11:19:05.211	debug	DeviceAvailability:Publish LQ for 0x00158d0001de6190 = 0
      zigbee.0
      2022-08-02 11:19:05.208	debug	DeviceAvailability:Publish available for 0x00158d0001de6190 = false
      zigbee.0
      2022-08-02 11:19:05.205	debug	DeviceAvailability:Publish LQ for 0x00158d00022cb2d5 = 0
      zigbee.0
      2022-08-02 11:19:05.203	debug	DeviceAvailability:Publish available for 0x00158d00022cb2d5 = false
      zigbee.0
      2022-08-02 11:19:05.200	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7ace5 = 0
      zigbee.0
      2022-08-02 11:19:05.197	debug	DeviceAvailability:Publish available for 0x00158d0001b7ace5 = false
      zigbee.0
      2022-08-02 11:19:05.179	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7b572 = 0
      zigbee.0
      2022-08-02 11:19:05.176	debug	DeviceAvailability:Publish available for 0x00158d0001b7b572 = false
      zigbee.0
      2022-08-02 11:19:05.174	debug	DeviceAvailability:Publish LQ for 0x00158d0001de89bc = 0
      zigbee.0
      2022-08-02 11:19:05.171	debug	DeviceAvailability:Publish available for 0x00158d0001de89bc = false
      zigbee.0
      2022-08-02 11:19:05.168	debug	DeviceAvailability:Publish LQ for 0x00158d0001fd6f2f = 0
      zigbee.0
      2022-08-02 11:19:05.164	debug	DeviceAvailability:Publish available for 0x00158d0001fd6f2f = false
      zigbee.0
      2022-08-02 11:19:05.162	debug	DeviceAvailability:Publish LQ for 0x00158d0001de8c5e = 0
      zigbee.0
      2022-08-02 11:19:05.159	debug	DeviceAvailability:Publish available for 0x00158d0001de8c5e = false
      zigbee.0
      2022-08-02 11:19:05.156	debug	DeviceAvailability:Publish LQ for 0x00158d0001e459f9 = 0
      zigbee.0
      2022-08-02 11:19:05.149	debug	DeviceAvailability:Publish available for 0x00158d0001e459f9 = false
      zigbee.0
      2022-08-02 11:19:05.145	debug	DeviceAvailability:Publish LQ for 0x00158d0002235296 = 0
      zigbee.0
      2022-08-02 11:19:05.142	debug	DeviceAvailability:Publish available for 0x00158d0002235296 = false
      zigbee.0
      2022-08-02 11:19:05.139	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7a818 = 0
      zigbee.0
      2022-08-02 11:19:05.137	debug	DeviceAvailability:Publish available for 0x00158d0001b7a818 = false
      zigbee.0
      2022-08-02 11:19:05.134	debug	DeviceAvailability:Publish LQ for 0x00158d0001fa5cab = 0
      zigbee.0
      2022-08-02 11:19:05.130	debug	DeviceAvailability:Publish available for 0x00158d0001fa5cab = false
      zigbee.0
      2022-08-02 11:19:05.126	debug	DeviceAvailability:Publish LQ for 0x00158d0001de8f8a = 0
      zigbee.0
      2022-08-02 11:19:05.123	debug	DeviceAvailability:Publish available for 0x00158d0001de8f8a = false
      zigbee.0
      2022-08-02 11:19:05.120	debug	DeviceAvailability:Publish LQ for 0x00158d00022b39fa = 0
      zigbee.0
      2022-08-02 11:19:05.118	debug	DeviceAvailability:Publish available for 0x00158d00022b39fa = false
      zigbee.0
      2022-08-02 11:19:05.114	debug	DeviceAvailability:Publish LQ for 0x00158d000201b693 = 0
      zigbee.0
      2022-08-02 11:19:05.111	debug	DeviceAvailability:Publish available for 0x00158d000201b693 = false
      zigbee.0
      2022-08-02 11:19:05.107	debug	DeviceAvailability:Publish LQ for 0x00158d0001b95a50 = 0
      zigbee.0
      2022-08-02 11:19:05.104	debug	DeviceAvailability:Publish available for 0x00158d0001b95a50 = false
      zigbee.0
      2022-08-02 11:19:05.101	debug	DeviceAvailability:Publish LQ for 0x00158d00031b35bf = 0
      zigbee.0
      2022-08-02 11:19:05.097	debug	DeviceAvailability:Publish available for 0x00158d00031b35bf = false
      zigbee.0
      2022-08-02 11:19:05.095	debug	DeviceAvailability:Publish LQ for 0x00158d00041cc7da = 0
      zigbee.0
      2022-08-02 11:19:05.092	debug	DeviceAvailability:Publish available for 0x00158d00041cc7da = false
      zigbee.0
      2022-08-02 11:19:05.088	debug	DeviceAvailability:Publish LQ for 0x14b457fffe2ea155 = 0
      zigbee.0
      2022-08-02 11:19:05.086	debug	DeviceAvailability:Publish available for 0x14b457fffe2ea155 = false
      zigbee.0
      2022-08-02 11:19:05.082	debug	DeviceAvailability:Publish LQ for 0x04cf8cdf3c7db935 = 0
      zigbee.0
      2022-08-02 11:19:05.080	debug	DeviceAvailability:Publish available for 0x04cf8cdf3c7db935 = false
      zigbee.0
      2022-08-02 11:19:05.077	debug	DeviceAvailability:Publish LQ for 0x14b457fffe72bcba = 0
      zigbee.0
      2022-08-02 11:19:05.072	debug	DeviceAvailability:Publish available for 0x14b457fffe72bcba = false
      zigbee.0
      2022-08-02 11:19:05.070	debug	DeviceAvailability:Publish LQ for 0x00158d0004fc9476 = 0
      zigbee.0
      2022-08-02 11:19:05.067	debug	DeviceAvailability:Publish available for 0x00158d0004fc9476 = false
      zigbee.0
      2022-08-02 11:19:05.064	debug	DeviceAvailability:Publish LQ for 0x00158d0004b487e0 = 0
      zigbee.0
      2022-08-02 11:19:05.062	debug	DeviceAvailability:Publish available for 0x00158d0004b487e0 = false
      zigbee.0
      2022-08-02 11:19:05.059	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf946 = 0
      zigbee.0
      2022-08-02 11:19:05.057	debug	DeviceAvailability:Publish available for 0x00158d0004fcf946 = false
      zigbee.0
      2022-08-02 11:19:05.053	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf82a = 0
      zigbee.0
      2022-08-02 11:19:05.050	debug	DeviceAvailability:Publish available for 0x00158d0004fcf82a = false
      zigbee.0
      2022-08-02 11:19:05.043	debug	DeviceAvailability:Publish LQ for 0x00158d000223a209 = 0
      zigbee.0
      2022-08-02 11:19:05.038	debug	DeviceAvailability:Publish available for 0x00158d000223a209 = false
      zigbee.0
      2022-08-02 11:19:05.023	debug	DeviceAvailability:Publish LQ for 0x00158d000420b185 = 0
      zigbee.0
      2022-08-02 11:19:05.019	debug	DeviceAvailability:Publish available for 0x00158d000420b185 = false
      zigbee.0
      2022-08-02 11:19:05.016	debug	DeviceAvailability:Publish LQ for 0x00158d0004462707 = 0
      zigbee.0
      2022-08-02 11:19:05.012	debug	DeviceAvailability:Publish available for 0x00158d0004462707 = false
      zigbee.0
      2022-08-02 11:19:05.007	debug	DeviceAvailability:Publish LQ for 0x00158d000485431c = 0
      zigbee.0
      2022-08-02 11:19:05.003	debug	DeviceAvailability:Publish available for 0x00158d000485431c = false
      zigbee.0
      2022-08-02 11:19:04.999	debug	DeviceAvailability:Publish LQ for 0x00158d0004460639 = 0
      zigbee.0
      2022-08-02 11:19:04.996	debug	DeviceAvailability:Publish available for 0x00158d0004460639 = false
      zigbee.0
      2022-08-02 11:19:04.993	debug	DeviceAvailability:Publish LQ for 0x00158d00044de796 = 0
      zigbee.0
      2022-08-02 11:19:04.988	debug	DeviceAvailability:Publish available for 0x00158d00044de796 = false
      zigbee.0
      2022-08-02 11:19:04.984	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7ba2f = 0
      zigbee.0
      2022-08-02 11:19:04.964	debug	DeviceAvailability:Publish available for 0x00158d0001b7ba2f = false
      zigbee.0
      2022-08-02 11:19:04.958	debug	DeviceAvailability:Publish LQ for 0x00158d0004465ea3 = 0
      zigbee.0
      2022-08-02 11:19:04.876	debug	DeviceAvailability:Publish available for 0x00158d0004465ea3 = false
      zigbee.0
      2022-08-02 11:19:04.870	debug	DeviceAvailability:Publish LQ for 0x00158d0004b487d4 = 0
      zigbee.0
      2022-08-02 11:19:04.864	debug	DeviceAvailability:Publish available for 0x00158d0004b487d4 = false
      zigbee.0
      2022-08-02 11:19:04.859	debug	DeviceAvailability:Publish LQ for 0x00158d00033ad77d = 0
      zigbee.0
      2022-08-02 11:19:04.853	debug	DeviceAvailability:Publish available for 0x00158d00033ad77d = false
      zigbee.0
      2022-08-02 11:19:04.839	info	cleaned everything up...
      zigbee.0
      2022-08-02 11:19:04.837	info	Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      2022-08-02 11:19:04.716	error	Error herdsman start
      zigbee.0
      2022-08-02 11:19:04.715	error	Failed to start Zigbee
      zigbee.0
      2022-08-02 11:19:04.714	error	Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
      zigbee.0
      2022-08-02 11:18:54.508	debug	List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/ttyS12"},{"comName":"/dev/ttyS13"},{"comName":"/dev/ttyS14"},{"comName":"/dev/ttyS15"},{"comName":"/dev/ttyS16"},{"comName":"/dev/ttyS17"},{"comName":"/dev/ttyS18"},{"comName":"/dev/ttyS19"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS20"},{"comName":"/dev/ttyS21"},{"comName":"/dev/ttyS22"},{"comName":"/dev/ttyS23"},{"comName":"/dev/ttyS24"},{"comName":"/dev/ttyS25"},{"comName":"/dev/ttyS26"},{"comName":"/dev/ttyS27"},{"comName":"/dev/ttyS28"},{"comName":"/dev/ttyS29"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyS30"},{"comName":"/dev/ttyS31"},{"comName":"/dev/ttyS4"},{"comName":"/dev/ttyS5"},{"comName":"/dev/ttyS6"},{"comName":"/dev/ttyS7"},{"comName":"/dev/ttyS8"},{"comName":"/dev/ttyS9"}]
      zigbee.0
      2022-08-02 11:18:54.263	error	getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
      zigbee.0
      2022-08-02 11:18:44.730	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_08_02-11_18_43.tar.gz success
      zigbee.0
      2022-08-02 11:18:44.712	info	Installed Version: iobroker.zigbee@1.7.5
      zigbee.0
      2022-08-02 11:18:43.891	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-08-02 11:18:43.889	info	Starting Zigbee npm ...
      zigbee.0
      2022-08-02 11:18:43.887	info	delete old Backup files. keep only last 10
      zigbee.0
      2022-08-02 11:18:43.803	debug	Using zigbee-herdsman with settings: {"network":{"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20],"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
      zigbee.0
      2022-08-02 11:18:43.746	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
      zigbee.0
      2022-08-02 11:18:42.750	info	Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      zigbee.0
      2022-08-02 11:18:42.726	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2022-08-02 11:17:32.329	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2022-08-02 11:17:32.328	debug	Plugin sentry destroyed
      zigbee.0
      2022-08-02 11:17:32.327	info	terminating
      zigbee.0
      2022-08-02 11:17:32.326	warn	Failed to stop zigbee during startup
      zigbee.0
      2022-08-02 11:17:32.269	info	Zigbee: disabling joining new devices.
      zigbee.0
      2022-08-02 11:17:32.207	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02dd9b = 0
      zigbee.0
      2022-08-02 11:17:32.196	debug	DeviceAvailability:Publish available for 0x04cd15fffe02dd9b = false
      zigbee.0
      2022-08-02 11:17:32.193	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe067cd7 = 0
      zigbee.0
      2022-08-02 11:17:32.177	debug	DeviceAvailability:Publish available for 0x04cd15fffe067cd7 = false
      zigbee.0
      2022-08-02 11:17:32.170	debug	DeviceAvailability:Publish LQ for 0x00158d0001e7a0d0 = 0
      zigbee.0
      2022-08-02 11:17:32.166	debug	DeviceAvailability:Publish available for 0x00158d0001e7a0d0 = false
      zigbee.0
      2022-08-02 11:17:32.132	debug	DeviceAvailability:Publish LQ for 0x00158d000482d34e = 0
      zigbee.0
      2022-08-02 11:17:32.114	debug	DeviceAvailability:Publish available for 0x00158d000482d34e = false
      zigbee.0
      2022-08-02 11:17:32.107	debug	DeviceAvailability:Publish LQ for 0x00158d000485f414 = 0
      zigbee.0
      2022-08-02 11:17:32.103	debug	DeviceAvailability:Publish available for 0x00158d000485f414 = false
      zigbee.0
      2022-08-02 11:17:32.100	debug	DeviceAvailability:Publish LQ for 0x842e14fffe35a210 = 0
      zigbee.0
      2022-08-02 11:17:32.098	debug	DeviceAvailability:Publish available for 0x842e14fffe35a210 = false
      zigbee.0
      2022-08-02 11:17:32.090	debug	DeviceAvailability:Publish LQ for 0x588e81fffedbcfe2 = 0
      zigbee.0
      2022-08-02 11:17:32.080	debug	DeviceAvailability:Publish available for 0x588e81fffedbcfe2 = false
      zigbee.0
      2022-08-02 11:17:32.077	debug	DeviceAvailability:Publish LQ for 0x842e14fffe1262bf = 0
      zigbee.0
      2022-08-02 11:17:32.073	debug	DeviceAvailability:Publish available for 0x842e14fffe1262bf = false
      zigbee.0
      2022-08-02 11:17:32.068	debug	DeviceAvailability:Publish LQ for 0x00158d00048605a0 = 0
      zigbee.0
      2022-08-02 11:17:32.063	debug	DeviceAvailability:Publish available for 0x00158d00048605a0 = false
      zigbee.0
      2022-08-02 11:17:32.059	debug	DeviceAvailability:Publish LQ for 0x00158d0004fd0fd7 = 0
      zigbee.0
      2022-08-02 11:17:32.054	debug	DeviceAvailability:Publish available for 0x00158d0004fd0fd7 = false
      zigbee.0
      2022-08-02 11:17:32.050	debug	DeviceAvailability:Publish LQ for 0x00158d0001ddab4c = 0
      zigbee.0
      2022-08-02 11:17:32.047	debug	DeviceAvailability:Publish available for 0x00158d0001ddab4c = false
      zigbee.0
      2022-08-02 11:17:32.045	debug	DeviceAvailability:Publish LQ for 0x00158d00033a4347 = 0
      zigbee.0
      2022-08-02 11:17:32.040	debug	DeviceAvailability:Publish available for 0x00158d00033a4347 = false
      zigbee.0
      2022-08-02 11:17:32.037	debug	DeviceAvailability:Publish LQ for 0x00158d0002f39894 = 0
      zigbee.0
      2022-08-02 11:17:32.034	debug	DeviceAvailability:Publish available for 0x00158d0002f39894 = false
      zigbee.0
      2022-08-02 11:17:32.030	debug	DeviceAvailability:Publish LQ for 0x00158d0001de72f5 = 0
      zigbee.0
      2022-08-02 11:17:32.026	debug	DeviceAvailability:Publish available for 0x00158d0001de72f5 = false
      zigbee.0
      2022-08-02 11:17:32.008	debug	DeviceAvailability:Publish LQ for 0x00158d00053fbd6f = 0
      zigbee.0
      2022-08-02 11:17:32.005	debug	DeviceAvailability:Publish available for 0x00158d00053fbd6f = false
      zigbee.0
      2022-08-02 11:17:32.003	debug	DeviceAvailability:Publish LQ for 0x00158d0002f39851 = 0
      zigbee.0
      2022-08-02 11:17:32.000	debug	DeviceAvailability:Publish available for 0x00158d0002f39851 = false
      zigbee.0
      2022-08-02 11:17:31.998	debug	DeviceAvailability:Publish LQ for 0x00158d0002f3c080 = 0
      zigbee.0
      2022-08-02 11:17:31.995	debug	DeviceAvailability:Publish available for 0x00158d0002f3c080 = false
      zigbee.0
      2022-08-02 11:17:31.992	debug	DeviceAvailability:Publish LQ for 0x00158d0002f90eff = 0
      zigbee.0
      2022-08-02 11:17:31.990	debug	DeviceAvailability:Publish available for 0x00158d0002f90eff = false
      zigbee.0
      2022-08-02 11:17:31.987	debug	DeviceAvailability:Publish LQ for 0x00158d0002271d3f = 0
      zigbee.0
      2022-08-02 11:17:31.985	debug	DeviceAvailability:Publish available for 0x00158d0002271d3f = false
      zigbee.0
      2022-08-02 11:17:31.981	debug	DeviceAvailability:Publish LQ for 0x00158d0001e42cf4 = 0
      zigbee.0
      2022-08-02 11:17:31.979	debug	DeviceAvailability:Publish available for 0x00158d0001e42cf4 = false
      zigbee.0
      2022-08-02 11:17:31.976	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02d085 = 0
      zigbee.0
      2022-08-02 11:17:31.974	debug	DeviceAvailability:Publish available for 0x04cd15fffe02d085 = false
      zigbee.0
      2022-08-02 11:17:31.971	debug	DeviceAvailability:Publish LQ for 0x00158d00041cc629 = 0
      zigbee.0
      2022-08-02 11:17:31.966	debug	DeviceAvailability:Publish available for 0x00158d00041cc629 = false
      zigbee.0
      2022-08-02 11:17:31.964	debug	DeviceAvailability:Publish LQ for 0x00158d00027051c6 = 0
      zigbee.0
      2022-08-02 11:17:31.961	debug	DeviceAvailability:Publish available for 0x00158d00027051c6 = false
      zigbee.0
      2022-08-02 11:17:31.958	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7a88a = 0
      zigbee.0
      2022-08-02 11:17:31.956	debug	DeviceAvailability:Publish available for 0x00158d0001b7a88a = false
      zigbee.0
      2022-08-02 11:17:31.951	debug	DeviceAvailability:Publish LQ for 0x04cd15fffe02d9f3 = 0
      zigbee.0
      2022-08-02 11:17:31.949	debug	DeviceAvailability:Publish available for 0x04cd15fffe02d9f3 = false
      zigbee.0
      2022-08-02 11:17:31.946	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7b481 = 0
      zigbee.0
      2022-08-02 11:17:31.944	debug	DeviceAvailability:Publish available for 0x00158d0001b7b481 = false
      zigbee.0
      2022-08-02 11:17:31.941	debug	DeviceAvailability:Publish LQ for 0x00158d0002019669 = 0
      zigbee.0
      2022-08-02 11:17:31.937	debug	DeviceAvailability:Publish available for 0x00158d0002019669 = false
      zigbee.0
      2022-08-02 11:17:31.935	debug	DeviceAvailability:Publish LQ for 0x00158d0001b9589f = 0
      zigbee.0
      2022-08-02 11:17:31.932	debug	DeviceAvailability:Publish available for 0x00158d0001b9589f = false
      zigbee.0
      2022-08-02 11:17:31.921	debug	DeviceAvailability:Publish LQ for 0x00158d0001e489c1 = 0
      zigbee.0
      2022-08-02 11:17:31.918	debug	DeviceAvailability:Publish available for 0x00158d0001e489c1 = false
      zigbee.0
      2022-08-02 11:17:31.913	debug	DeviceAvailability:Publish LQ for 0x00158d0001e48a72 = 0
      zigbee.0
      2022-08-02 11:17:31.911	debug	DeviceAvailability:Publish available for 0x00158d0001e48a72 = false
      zigbee.0
      2022-08-02 11:17:31.909	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf923 = 0
      zigbee.0
      2022-08-02 11:17:31.906	debug	DeviceAvailability:Publish available for 0x00158d0004fcf923 = false
      zigbee.0
      2022-08-02 11:17:31.903	debug	DeviceAvailability:Publish LQ for 0x00158d0001de6190 = 0
      zigbee.0
      2022-08-02 11:17:31.900	debug	DeviceAvailability:Publish available for 0x00158d0001de6190 = false
      zigbee.0
      2022-08-02 11:17:31.897	debug	DeviceAvailability:Publish LQ for 0x00158d00022cb2d5 = 0
      zigbee.0
      2022-08-02 11:17:31.895	debug	DeviceAvailability:Publish available for 0x00158d00022cb2d5 = false
      zigbee.0
      2022-08-02 11:17:31.892	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7ace5 = 0
      zigbee.0
      2022-08-02 11:17:31.889	debug	DeviceAvailability:Publish available for 0x00158d0001b7ace5 = false
      zigbee.0
      2022-08-02 11:17:31.886	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7b572 = 0
      zigbee.0
      2022-08-02 11:17:31.883	debug	DeviceAvailability:Publish available for 0x00158d0001b7b572 = false
      zigbee.0
      2022-08-02 11:17:31.880	debug	DeviceAvailability:Publish LQ for 0x00158d0001de89bc = 0
      zigbee.0
      2022-08-02 11:17:31.878	debug	DeviceAvailability:Publish available for 0x00158d0001de89bc = false
      zigbee.0
      2022-08-02 11:17:31.875	debug	DeviceAvailability:Publish LQ for 0x00158d0001fd6f2f = 0
      zigbee.0
      2022-08-02 11:17:31.871	debug	DeviceAvailability:Publish available for 0x00158d0001fd6f2f = false
      zigbee.0
      2022-08-02 11:17:31.868	debug	DeviceAvailability:Publish LQ for 0x00158d0001de8c5e = 0
      zigbee.0
      2022-08-02 11:17:31.864	debug	DeviceAvailability:Publish available for 0x00158d0001de8c5e = false
      zigbee.0
      2022-08-02 11:17:31.862	debug	DeviceAvailability:Publish LQ for 0x00158d0001e459f9 = 0
      zigbee.0
      2022-08-02 11:17:31.859	debug	DeviceAvailability:Publish available for 0x00158d0001e459f9 = false
      zigbee.0
      2022-08-02 11:17:31.854	debug	DeviceAvailability:Publish LQ for 0x00158d0002235296 = 0
      zigbee.0
      2022-08-02 11:17:31.850	debug	DeviceAvailability:Publish available for 0x00158d0002235296 = false
      zigbee.0
      2022-08-02 11:17:31.844	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7a818 = 0
      zigbee.0
      2022-08-02 11:17:31.839	debug	DeviceAvailability:Publish available for 0x00158d0001b7a818 = false
      zigbee.0
      2022-08-02 11:17:31.834	debug	DeviceAvailability:Publish LQ for 0x00158d0001fa5cab = 0
      zigbee.0
      2022-08-02 11:17:31.829	debug	DeviceAvailability:Publish available for 0x00158d0001fa5cab = false
      zigbee.0
      2022-08-02 11:17:31.824	debug	DeviceAvailability:Publish LQ for 0x00158d0001de8f8a = 0
      zigbee.0
      2022-08-02 11:17:31.819	debug	DeviceAvailability:Publish available for 0x00158d0001de8f8a = false
      zigbee.0
      2022-08-02 11:17:31.814	debug	DeviceAvailability:Publish LQ for 0x00158d00022b39fa = 0
      zigbee.0
      2022-08-02 11:17:31.810	debug	DeviceAvailability:Publish available for 0x00158d00022b39fa = false
      zigbee.0
      2022-08-02 11:17:31.804	debug	DeviceAvailability:Publish LQ for 0x00158d000201b693 = 0
      zigbee.0
      2022-08-02 11:17:31.802	debug	DeviceAvailability:Publish available for 0x00158d000201b693 = false
      zigbee.0
      2022-08-02 11:17:31.799	debug	DeviceAvailability:Publish LQ for 0x00158d0001b95a50 = 0
      zigbee.0
      2022-08-02 11:17:31.796	debug	DeviceAvailability:Publish available for 0x00158d0001b95a50 = false
      zigbee.0
      2022-08-02 11:17:31.794	debug	DeviceAvailability:Publish LQ for 0x00158d00031b35bf = 0
      zigbee.0
      2022-08-02 11:17:31.789	debug	DeviceAvailability:Publish available for 0x00158d00031b35bf = false
      zigbee.0
      2022-08-02 11:17:31.783	debug	DeviceAvailability:Publish LQ for 0x00158d00041cc7da = 0
      zigbee.0
      2022-08-02 11:17:31.780	debug	DeviceAvailability:Publish available for 0x00158d00041cc7da = false
      zigbee.0
      2022-08-02 11:17:31.777	debug	DeviceAvailability:Publish LQ for 0x14b457fffe2ea155 = 0
      zigbee.0
      2022-08-02 11:17:31.775	debug	DeviceAvailability:Publish available for 0x14b457fffe2ea155 = false
      zigbee.0
      2022-08-02 11:17:31.771	debug	DeviceAvailability:Publish LQ for 0x04cf8cdf3c7db935 = 0
      zigbee.0
      2022-08-02 11:17:31.769	debug	DeviceAvailability:Publish available for 0x04cf8cdf3c7db935 = false
      zigbee.0
      2022-08-02 11:17:31.766	debug	DeviceAvailability:Publish LQ for 0x14b457fffe72bcba = 0
      zigbee.0
      2022-08-02 11:17:31.763	debug	DeviceAvailability:Publish available for 0x14b457fffe72bcba = false
      zigbee.0
      2022-08-02 11:17:31.760	debug	DeviceAvailability:Publish LQ for 0x00158d0004fc9476 = 0
      zigbee.0
      2022-08-02 11:17:31.757	debug	DeviceAvailability:Publish available for 0x00158d0004fc9476 = false
      zigbee.0
      2022-08-02 11:17:31.754	debug	DeviceAvailability:Publish LQ for 0x00158d0004b487e0 = 0
      zigbee.0
      2022-08-02 11:17:31.751	debug	DeviceAvailability:Publish available for 0x00158d0004b487e0 = false
      zigbee.0
      2022-08-02 11:17:31.748	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf946 = 0
      zigbee.0
      2022-08-02 11:17:31.745	debug	DeviceAvailability:Publish available for 0x00158d0004fcf946 = false
      zigbee.0
      2022-08-02 11:17:31.742	debug	DeviceAvailability:Publish LQ for 0x00158d0004fcf82a = 0
      zigbee.0
      2022-08-02 11:17:31.739	debug	DeviceAvailability:Publish available for 0x00158d0004fcf82a = false
      zigbee.0
      2022-08-02 11:17:31.735	debug	DeviceAvailability:Publish LQ for 0x00158d000223a209 = 0
      zigbee.0
      2022-08-02 11:17:31.732	debug	DeviceAvailability:Publish available for 0x00158d000223a209 = false
      zigbee.0
      2022-08-02 11:17:31.728	debug	DeviceAvailability:Publish LQ for 0x00158d000420b185 = 0
      zigbee.0
      2022-08-02 11:17:31.722	debug	DeviceAvailability:Publish available for 0x00158d000420b185 = false
      zigbee.0
      2022-08-02 11:17:31.716	debug	DeviceAvailability:Publish LQ for 0x00158d0004462707 = 0
      zigbee.0
      2022-08-02 11:17:31.711	debug	DeviceAvailability:Publish available for 0x00158d0004462707 = false
      zigbee.0
      2022-08-02 11:17:31.708	debug	DeviceAvailability:Publish LQ for 0x00158d000485431c = 0
      zigbee.0
      2022-08-02 11:17:31.705	debug	DeviceAvailability:Publish available for 0x00158d000485431c = false
      zigbee.0
      2022-08-02 11:17:31.698	debug	DeviceAvailability:Publish LQ for 0x00158d0004460639 = 0
      zigbee.0
      2022-08-02 11:17:31.695	debug	DeviceAvailability:Publish available for 0x00158d0004460639 = false
      zigbee.0
      2022-08-02 11:17:31.690	debug	DeviceAvailability:Publish LQ for 0x00158d00044de796 = 0
      zigbee.0
      2022-08-02 11:17:31.687	debug	DeviceAvailability:Publish available for 0x00158d00044de796 = false
      zigbee.0
      2022-08-02 11:17:31.683	debug	DeviceAvailability:Publish LQ for 0x00158d0001b7ba2f = 0
      zigbee.0
      2022-08-02 11:17:31.679	debug	DeviceAvailability:Publish available for 0x00158d0001b7ba2f = false
      zigbee.0
      2022-08-02 11:17:31.675	debug	DeviceAvailability:Publish LQ for 0x00158d0004465ea3 = 0
      zigbee.0
      2022-08-02 11:17:31.671	debug	DeviceAvailability:Publish available for 0x00158d0004465ea3 = false
      zigbee.0
      2022-08-02 11:17:31.667	debug	DeviceAvailability:Publish LQ for 0x00158d0004b487d4 = 0
      zigbee.0
      2022-08-02 11:17:31.649	debug	DeviceAvailability:Publish available for 0x00158d0004b487d4 = false
      zigbee.0
      2022-08-02 11:17:31.642	debug	DeviceAvailability:Publish LQ for 0x00158d00033ad77d = 0
      zigbee.0
      2022-08-02 11:17:31.635	debug	DeviceAvailability:Publish available for 0x00158d00033ad77d = false
      zigbee.0
      2022-08-02 11:17:31.623	info	cleaned everything up...
      zigbee.0
      2022-08-02 11:17:31.621	info	Got terminate signal TERMINATE_YOURSELF
        martinschm @Thomas Braun last edited by martinschm
        @thomas-braun said in ZigBee Adapter/TI Board steigt immer wieder mal aus:
        @martinschm sagte in ZigBee Adapter/TI Board steigt immer wieder mal aus:
        /dev/ttyACM0
        Stell das auf den Link aus /dev/serial/by-id um
        Hab jetzt mal geschaut, da sind dutzende Einträge aber welchen davon muß ich nehmen?
          Thomas Braun Most Active @martinschm last edited by
          Keinen.
          Man schaut in /dev/serial/by-id nach dem Gerät und gibt dann dessen Link an.
          • Asgothian
            Asgothian Developer @martinschm last edited by
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            Die Debug Meldungen bringen an dieser Stelle nichts. Wichtig sind die debug Meldungen der letzten 2 bis 3 Minuten bevor der Adapter neu gestartet werden soll. Gegebenenfalls ist an diesen Meldungen zu erkennen warum der Neustart notwendig wurde und was genau passiert ist.
            A.
              A.
              Ah dann hab ich dich falsch verstanden. Was meinst du denn mit "bevor der Adapter neu gestartet werden soll" ?
              Der Neustart geschieht ja nicht automatisch. Irgendwann verlieren mehr und mehr Sensoren die Verbindung. Ich bekomme das mit weil ich mich über Telegram darüber informieren lasse wenn Sensoren nicht mehr erreichbar sind. Die Liste wird dann länger und länger und dann weiß ich das was nicht stimmt. Wenn ich selber einen Neustart mache kommen die Meldungen von oben.
              Bin mir nicht ganz sicher wie ich dir die debug Meldungen liefern kann die du bräuchtest.
                martinschm last edited by martinschm
                Keinen.
                Hi, sorry bin kein Linux-Experte. Hab jetzt mal nach der Seite die du gepostet hast den Befehl hier ausgeführt. Das Gerät läuft auf ttyACM0.
                martin@smarthome:~$  ls -l /dev/serial/by-id
                total 0
                lrwxrwxrwx 1 root root 13 Jul 31 13:46 usb-Texas_Instruments_XDS110__03.00.00.13                                               __Embed_with_CMSIS-DAP_L1100FA9-if00 -> ../../ttyACM0
                lrwxrwxrwx 1 root root 13 Jul 31 13:46 usb-Texas_Instruments_XDS110__03.00.00.13                                               __Embed_with_CMSIS-DAP_L1100FA9-if03 -> ../../ttyACM1
                Ich habe auch mal versucht mittels "ls -l /proc/[0-9]/fd/ |grep /dev/ttyACM0" raus zu bekommen was den Port verwendet, allerdings kommt da keinerlei Ausgabe wenn ich den Befehl ausführe. Weder in der iobroker VM noch auf dem proxmox System.
                  Thomas Braun Most Active @martinschm last edited by Thomas Braun
                  Auch. Genauer: Eines der beiden Interfaces läuft auf ttyACM0.
                  Das andere (vmtl. der Debugger) läuft auf ttyACM1
                  Das kann sich aber auch ändern, daher nimmt man den Link auf die Gerätedatei, der passt immer.
                  /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100FA9-if00
                  dann wohl.
                  • Asgothian
                    Du musst den Adapter im Debug mit laufen lassen, bis der Effekt mit den ausfallenden Sensoren auftritt. Wenn du dich entscheidest den Adapter neu zu starten kannst du nach dem Neustart das Log herunterladen und die Einträge des Zigbee-Adapters der 5 Minuten aus dem Log posten kopieren und posten.
                    Nebenbei: wenn nur einige Sensoren die Verbindung verlieren aber andere Geräte weiter funktionieren dann gibt es kein Problem mit dem USB / Seriellen Port, da ansonsten die Kommunikation zu ALLEN Sensoren abbrechen muss.
                    A.
                      A.
                      Dienstag sind wieder alle Sensoren rausgeflogen. Bin leider erst jetzt dazu gekommen den Adapter mal neu zu starten. Hier sind die Logs:
                      2022-08-06 15:15:13.121 - info: host.smarthome instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-08-06 15:15:15.331 - info: admin.0 (967) failed connection to socket.io from ::ffff:192.168.1.33:
                      2022-08-06 15:15:15.339 - error: admin.0 (967) Error: "error"
                      2022-08-06 15:18:36.848 - error: zigbee.0 (528791) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                      2022-08-06 15:18:37.164 - debug: zigbee.0 (528791) List of ports: [{"comName":"/dev/ttyACM0"},{"comName":"/dev/ttyACM1"},{"comName":"/dev/ttyS0"},{"comName":"/dev/ttyS1"},{"comName":"/dev/ttyS10"},{"comName":"/dev/ttyS11"},{"comName":"/dev/ttyS12"},{"comName":"/dev/ttyS13"},{"comName":"/dev/ttyS14"},{"comName":"/dev/ttyS15"},{"comName":"/dev/ttyS16"},{"comName":"/dev/ttyS17"},{"comName":"/dev/ttyS18"},{"comName":"/dev/ttyS19"},{"comName":"/dev/ttyS2"},{"comName":"/dev/ttyS20"},{"comName":"/dev/ttyS21"},{"comName":"/dev/ttyS22"},{"comName":"/dev/ttyS23"},{"comName":"/dev/ttyS24"},{"comName":"/dev/ttyS25"},{"comName":"/dev/ttyS26"},{"comName":"/dev/ttyS27"},{"comName":"/dev/ttyS28"},{"comName":"/dev/ttyS29"},{"comName":"/dev/ttyS3"},{"comName":"/dev/ttyS30"},{"comName":"/dev/ttyS31"},{"comName":"/dev/ttyS4"},{"comName":"/dev/ttyS5"},{"comName":"/dev/ttyS6"},{"comName":"/dev/ttyS7"},{"comName":"/dev/ttyS8"},{"comName":"/dev/ttyS9"}]
                      2022-08-06 15:18:47.804 - info: host.smarthome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2022-08-06 15:18:47.814 - info: zigbee.0 (528791) Got terminate signal TERMINATE_YOURSELF
                      2022-08-06 15:18:47.821 - info: host.smarthome stopInstance system.adapter.zigbee.0 send kill signal
                      2022-08-06 15:18:47.817 - info: zigbee.0 (528791) cleaned everything up...
                      2022-08-06 15:18:47.834 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00033ad77d = false
                      2022-08-06 15:18:47.843 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00033ad77d = 0
                      2022-08-06 15:18:47.850 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004b487d4 = false
                      2022-08-06 15:18:47.867 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004b487d4 = 0
                      2022-08-06 15:18:47.871 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004465ea3 = false
                      2022-08-06 15:18:47.874 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004465ea3 = 0
                      2022-08-06 15:18:47.878 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7ba2f = false
                      2022-08-06 15:18:47.881 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7ba2f = 0
                      2022-08-06 15:18:47.886 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00044de796 = false
                      2022-08-06 15:18:47.890 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00044de796 = 0
                      2022-08-06 15:18:47.893 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004460639 = false
                      2022-08-06 15:18:47.897 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004460639 = 0
                      2022-08-06 15:18:47.900 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000485431c = false
                      2022-08-06 15:18:47.904 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000485431c = 0
                      2022-08-06 15:18:47.907 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004462707 = false
                      2022-08-06 15:18:47.910 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004462707 = 0
                      2022-08-06 15:18:47.914 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000420b185 = false
                      2022-08-06 15:18:47.918 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000420b185 = 0
                      2022-08-06 15:18:47.922 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000223a209 = false
                      2022-08-06 15:18:47.925 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000223a209 = 0
                      2022-08-06 15:18:47.928 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004fcf82a = false
                      2022-08-06 15:18:47.932 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004fcf82a = 0
                      2022-08-06 15:18:47.935 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004fcf946 = false
                      2022-08-06 15:18:47.939 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004fcf946 = 0
                      2022-08-06 15:18:47.942 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004b487e0 = false
                      2022-08-06 15:18:47.945 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004b487e0 = 0
                      2022-08-06 15:18:47.949 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004fc9476 = false
                      2022-08-06 15:18:47.952 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004fc9476 = 0
                      2022-08-06 15:18:47.955 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x14b457fffe72bcba = false
                      2022-08-06 15:18:47.958 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x14b457fffe72bcba = 0
                      2022-08-06 15:18:47.961 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x04cf8cdf3c7db935 = false
                      2022-08-06 15:18:47.966 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7db935 = 0
                      2022-08-06 15:18:47.970 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x14b457fffe2ea155 = false
                      2022-08-06 15:18:47.973 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x14b457fffe2ea155 = 0
                      2022-08-06 15:18:47.976 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00041cc7da = false
                      2022-08-06 15:18:47.979 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00041cc7da = 0
                      2022-08-06 15:18:47.983 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00031b35bf = false
                      2022-08-06 15:18:47.985 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00031b35bf = 0
                      2022-08-06 15:18:47.988 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b95a50 = false
                      2022-08-06 15:18:47.990 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b95a50 = 0
                      2022-08-06 15:18:47.992 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000201b693 = false
                      2022-08-06 15:18:47.996 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000201b693 = 0
                      2022-08-06 15:18:47.999 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00022b39fa = false
                      2022-08-06 15:18:48.001 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00022b39fa = 0
                      2022-08-06 15:18:48.003 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001de8f8a = false
                      2022-08-06 15:18:48.005 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001de8f8a = 0
                      2022-08-06 15:18:48.010 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001fa5cab = false
                      2022-08-06 15:18:48.014 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001fa5cab = 0
                      2022-08-06 15:18:48.018 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7a818 = false
                      2022-08-06 15:18:48.021 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7a818 = 0
                      2022-08-06 15:18:48.023 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002235296 = false
                      2022-08-06 15:18:48.026 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002235296 = 0
                      2022-08-06 15:18:48.029 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001e459f9 = false
                      2022-08-06 15:18:48.031 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001e459f9 = 0
                      2022-08-06 15:18:48.033 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001de8c5e = false
                      2022-08-06 15:18:48.035 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001de8c5e = 0
                      2022-08-06 15:18:48.039 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001fd6f2f = false
                      2022-08-06 15:18:48.041 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001fd6f2f = 0
                      2022-08-06 15:18:48.044 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001de89bc = false
                      2022-08-06 15:18:48.046 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001de89bc = 0
                      2022-08-06 15:18:48.048 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7b572 = false
                      2022-08-06 15:18:48.052 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7b572 = 0
                      2022-08-06 15:18:48.054 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7ace5 = false
                      2022-08-06 15:18:48.056 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7ace5 = 0
                      2022-08-06 15:18:48.058 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00022cb2d5 = false
                      2022-08-06 15:18:48.061 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00022cb2d5 = 0
                      2022-08-06 15:18:48.064 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001de6190 = false
                      2022-08-06 15:18:48.066 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001de6190 = 0
                      2022-08-06 15:18:48.069 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004fcf923 = false
                      2022-08-06 15:18:48.071 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004fcf923 = 0
                      2022-08-06 15:18:48.073 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001e48a72 = false
                      2022-08-06 15:18:48.076 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001e48a72 = 0
                      2022-08-06 15:18:48.079 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001e489c1 = false
                      2022-08-06 15:18:48.081 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001e489c1 = 0
                      2022-08-06 15:18:48.083 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b9589f = false
                      2022-08-06 15:18:48.086 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b9589f = 0
                      2022-08-06 15:18:48.089 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002019669 = false
                      2022-08-06 15:18:48.091 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002019669 = 0
                      2022-08-06 15:18:48.093 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7b481 = false
                      2022-08-06 15:18:48.095 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7b481 = 0
                      2022-08-06 15:18:48.097 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x04cd15fffe02d9f3 = false
                      2022-08-06 15:18:48.100 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x04cd15fffe02d9f3 = 0
                      2022-08-06 15:18:48.102 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001b7a88a = false
                      2022-08-06 15:18:48.104 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001b7a88a = 0
                      2022-08-06 15:18:48.106 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00027051c6 = false
                      2022-08-06 15:18:48.108 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00027051c6 = 0
                      2022-08-06 15:18:48.111 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00041cc629 = false
                      2022-08-06 15:18:48.113 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00041cc629 = 0
                      2022-08-06 15:18:48.115 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x04cd15fffe02d085 = false
                      2022-08-06 15:18:48.117 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x04cd15fffe02d085 = 0
                      2022-08-06 15:18:48.119 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001e42cf4 = false
                      2022-08-06 15:18:48.122 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001e42cf4 = 0
                      2022-08-06 15:18:48.124 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002271d3f = false
                      2022-08-06 15:18:48.126 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002271d3f = 0
                      2022-08-06 15:18:48.128 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002f90eff = false
                      2022-08-06 15:18:48.130 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002f90eff = 0
                      2022-08-06 15:18:48.133 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002f3c080 = false
                      2022-08-06 15:18:48.135 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002f3c080 = 0
                      2022-08-06 15:18:48.137 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002f39851 = false
                      2022-08-06 15:18:48.139 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002f39851 = 0
                      2022-08-06 15:18:48.141 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00053fbd6f = false
                      2022-08-06 15:18:48.144 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00053fbd6f = 0
                      2022-08-06 15:18:48.146 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001de72f5 = false
                      2022-08-06 15:18:48.148 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001de72f5 = 0
                      2022-08-06 15:18:48.150 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0002f39894 = false
                      2022-08-06 15:18:48.152 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0002f39894 = 0
                      2022-08-06 15:18:48.155 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00033a4347 = false
                      2022-08-06 15:18:48.157 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00033a4347 = 0
                      2022-08-06 15:18:48.159 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001ddab4c = false
                      2022-08-06 15:18:48.161 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001ddab4c = 0
                      2022-08-06 15:18:48.163 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0004fd0fd7 = false
                      2022-08-06 15:18:48.166 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0004fd0fd7 = 0
                      2022-08-06 15:18:48.168 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d00048605a0 = false
                      2022-08-06 15:18:48.170 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d00048605a0 = 0
                      2022-08-06 15:18:48.172 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x842e14fffe1262bf = false
                      2022-08-06 15:18:48.174 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x842e14fffe1262bf = 0
                      2022-08-06 15:18:48.178 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x588e81fffedbcfe2 = false
                      2022-08-06 15:18:48.180 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x588e81fffedbcfe2 = 0
                      2022-08-06 15:18:48.182 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x842e14fffe35a210 = false
                      2022-08-06 15:18:48.184 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x842e14fffe35a210 = 0
                      2022-08-06 15:18:48.186 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000485f414 = false
                      2022-08-06 15:18:48.190 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000485f414 = 0
                      2022-08-06 15:18:48.192 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d000482d34e = false
                      2022-08-06 15:18:48.194 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d000482d34e = 0
                      2022-08-06 15:18:48.196 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x00158d0001e7a0d0 = false
                      2022-08-06 15:18:48.199 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x00158d0001e7a0d0 = 0
                      2022-08-06 15:18:48.203 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x04cd15fffe067cd7 = false
                      2022-08-06 15:18:48.206 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x04cd15fffe067cd7 = 0
                      2022-08-06 15:18:48.211 - debug: zigbee.0 (528791) DeviceAvailability:Publish available for 0x04cd15fffe02dd9b = false
                      2022-08-06 15:18:48.215 - debug: zigbee.0 (528791) DeviceAvailability:Publish LQ for 0x04cd15fffe02dd9b = 0
                      2022-08-06 15:18:48.254 - info: zigbee.0 (528791) Zigbee: disabling joining new devices.
                      2022-08-06 15:18:48.293 - warn: zigbee.0 (528791) Failed to stop zigbee during startup
                      2022-08-06 15:18:48.296 - info: zigbee.0 (528791) terminating
                      2022-08-06 15:18:48.301 - debug: zigbee.0 (528791) Plugin sentry destroyed
                      2022-08-06 15:18:48.303 - info: zigbee.0 (528791) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-08-06 15:18:48.824 - info: host.smarthome stopInstance system.adapter.zigbee.0 killing pid 528791
                      2022-08-06 15:18:49.258 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Red: 1 of 41
                      2022-08-06 15:18:49.357 - info: host.smarthome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-08-06 15:18:51.210 - info: host.smarthome instance system.adapter.zigbee.0 started with pid 2507142
                      2022-08-06 15:18:56.556 - debug: zigbee.0 (2507142) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2022-08-06 15:18:56.733 - debug: zigbee.0 (2507142) Objects client ready ... initialize now
                      2022-08-06 15:18:56.742 - debug: zigbee.0 (2507142) Objects create System PubSub Client
                      2022-08-06 15:18:56.744 - debug: zigbee.0 (2507142) Objects create User PubSub Client
                      2022-08-06 15:18:56.959 - debug: zigbee.0 (2507142) Objects client initialize lua scripts
                      2022-08-06 15:18:56.985 - debug: zigbee.0 (2507142) Objects connected to redis: 0.0.0.0:9001
                      2022-08-06 15:18:57.055 - debug: zigbee.0 (2507142) Redis States: Use Redis connection: 0.0.0.0:6379
                      2022-08-06 15:18:57.065 - debug: zigbee.0 (2507142) States create System PubSub Client
                      2022-08-06 15:18:57.067 - debug: zigbee.0 (2507142) States create User PubSub Client
                      2022-08-06 15:18:57.080 - debug: zigbee.0 (2507142) States connected to redis: 0.0.0.0:6379
                      2022-08-06 15:18:57.171 - debug: zigbee.0 (2507142) Plugin sentry Initialize Plugin (enabled=true)
                      2022-08-06 15:18:57.182 - info: zigbee.0 (2507142) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-08-06 15:18:57.759 - info: zigbee.0 (2507142) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                      2022-08-06 15:18:57.810 - debug: zigbee.0 (2507142) Using zigbee-herdsman with settings: {"network":{"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20],"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                      2022-08-06 15:18:57.889 - info: zigbee.0 (2507142) delete old Backup files. keep only last 10
                      2022-08-06 15:18:57.891 - info: zigbee.0 (2507142) Starting Zigbee npm ...
                      2022-08-06 15:18:57.893 - debug: zigbee.0 (2507142) Starting zigbee-herdsman...
                      2022-08-06 15:18:58.612 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
                      2022-08-06 15:18:58.616 - debug: zigbee.0 (2507142) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204],"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
                      2022-08-06 15:18:58.617 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
                      2022-08-06 15:18:58.641 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:log Serialport opened
                      2022-08-06 15:18:58.646 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
                      2022-08-06 15:18:58.650 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
                      2022-08-06 15:18:58.656 - info: zigbee.0 (2507142) Installed Version: iobroker.zigbee@1.7.5
                      2022-08-06 15:18:58.681 - debug: zigbee.0 (2507142) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_08_06-15_18_57.tar.gz success
                      2022-08-06 15:18:58.757 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Red: 0 of 41
                      2022-08-06 15:18:58.893 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Yellow: 1 of 41
                      2022-08-06 15:18:58.907 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:log Writing CC2530/CC2531 skip bootloader payload
                      2022-08-06 15:18:58.908 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
                      2022-08-06 15:18:58.948 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Green: 40 of 41
                      2022-08-06 15:18:58.968 - info: iqontrol.0 (1391) CALCULATION Adapter-Monitor Red+Yellow has changed
                      2022-08-06 15:18:58.970 - info: iqontrol.0 (1391) COMBINATION Adapter-Monitor HTML has changed
                      2022-08-06 15:18:58.973 - info: iqontrol.0 (1391) CALCULATION Adapter-Monitor Red+Yellow_LIST has changed
                      2022-08-06 15:18:58.981 - info: iqontrol.0 (1391) CALCULATION Adapter-Monitor Red+Yellow_LIST_JSON has changed
                      2022-08-06 15:18:58.987 - info: iqontrol.0 (1391) CALCULATION Adapter-Monitor Red+Yellow_NAMES_LIST has changed
                      2022-08-06 15:18:59.911 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
                      2022-08-06 15:18:59.912 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
                      2022-08-06 15:19:00.163 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:log Skip bootloader for CC2652/CC1352
                      2022-08-06 15:19:00.660 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
                      2022-08-06 15:19:00.662 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
                      2022-08-06 15:19:06.664 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
                      2022-08-06 15:19:06.665 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
                      2022-08-06 15:19:12.667 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
                      2022-08-06 15:19:12.669 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
                      2022-08-06 15:19:18.672 - error: zigbee.0 (2507142) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2022-08-06 15:19:18.673 - error: zigbee.0 (2507142) Failed to start Zigbee
                      2022-08-06 15:19:18.673 - error: zigbee.0 (2507142) Error herdsman start
                      2022-08-06 15:19:28.675 - info: zigbee.0 (2507142) Try to reconnect. 1 attempts left
                      2022-08-06 15:19:28.677 - info: zigbee.0 (2507142) Starting Zigbee npm ...
                      2022-08-06 15:19:28.678 - debug: zigbee.0 (2507142) Starting zigbee-herdsman...
                      2022-08-06 15:19:28.711 - info: zigbee.0 (2507142) Installed Version: iobroker.zigbee@1.7.5
                      2022-08-06 15:19:28.928 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
                      2022-08-06 15:19:28.929 - debug: zigbee.0 (2507142) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204],"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":false},"acceptJoiningDeviceHandler":null}'
                      2022-08-06 15:19:28.930 - debug: zigbee.0 (2507142) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
                      2022-08-06 15:19:28.984 - error: zigbee.0 (2507142) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      2022-08-06 15:19:28.985 - error: zigbee.0 (2507142) Failed to start Zigbee
                      2022-08-06 15:19:28.986 - error: zigbee.0 (2507142) Error herdsman start
                      2022-08-06 15:19:42.833 - info: web-speedy.0 (1994) Execute timer with : 1800000 Currently running : false
                      2022-08-06 15:19:42.835 - info: web-speedy.0 (1994) Run test on on Best Server found
                      2022-08-06 15:19:42.839 - info: web-speedy.0 (1994) The speed test has been started and will take at maximum 5 seconds for a single test run
                      2022-08-06 15:19:43.324 - info: web-speedy.0 (1994) Closest server found, running test
                      und hier noch die Logs von Dienstag rund um die Zeit wo die Sensoren ausgestiegen sind:
                      2022-08-02 11:12:06.517 - info: zigbee.0 (1286) Zigbee: allowing new devices to join.
                      2022-08-02 11:12:24.869 - error: zigbee.0 (1286) Failed to open the network: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms
                      at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:37:35)
                      at listOnTimeout (node:internal/timers:559:17)
                      at processTimers (node:internal/timers:502:7)
                      2022-08-02 11:12:54.560 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Red: 0 of 41
                      2022-08-02 11:12:54.711 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Yellow: 1 of 41
                      2022-08-02 11:12:54.754 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Green: 40 of 41
                      2022-08-02 11:13:15.108 - info: host.smarthome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2022-08-02 11:13:15.114 - info: zigbee.0 (1286) Got terminate signal TERMINATE_YOURSELF
                      2022-08-02 11:13:15.394 - info: host.smarthome stopInstance system.adapter.zigbee.0 send kill signal
                      2022-08-02 11:13:15.117 - info: zigbee.0 (1286) cleaned everything up...
                      2022-08-02 11:13:15.412 - info: zigbee.0 (1286) Zigbee: disabling joining new devices.
                      2022-08-02 11:13:15.619 - info: zigbee.0 (1286) terminating
                      2022-08-02 11:13:15.621 - info: zigbee.0 (1286) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-08-02 11:13:16.623 - info: zigbee.0 (1286) terminating with timeout
                      2022-08-02 11:13:17.101 - info: host.smarthome stopInstance system.adapter.zigbee.0 killing pid 1286
                      2022-08-02 11:13:18.678 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Red: 1 of 41
                      2022-08-02 11:13:18.868 - info: iqontrol.0 (1391) COUNTER Adapter-Monitor Yellow: 1 of 41
                      2022-08-02 11:13:18.902 - info: host.smarthome instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-08-02 11:13:24.435 - debug: zigbee.0 (518638) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2022-08-02 11:13:24.533 - debug: zigbee.0 (518638) Objects client ready ... initialize now
                      2022-08-02 11:13:24.536 - debug: zigbee.0 (518638) Objects create System PubSub Client
                      2022-08-02 11:13:24.538 - debug: zigbee.0 (518638) Objects create User PubSub Client
                      2022-08-02 11:13:24.657 - debug: zigbee.0 (518638) Objects client initialize lua scripts
                      2022-08-02 11:13:24.668 - debug: zigbee.0 (518638) Objects connected to redis: 0.0.0.0:9001
                      2022-08-02 11:13:24.728 - debug: zigbee.0 (518638) Redis States: Use Redis connection: 0.0.0.0:6379
                      2022-08-02 11:13:24.739 - debug: zigbee.0 (518638) States create System PubSub Client
                      2022-08-02 11:13:24.741 - debug: zigbee.0 (518638) States create User PubSub Client
                      2022-08-02 11:13:24.756 - debug: zigbee.0 (518638) States connected to redis: 0.0.0.0:6379
                      2022-08-02 11:13:24.832 - debug: zigbee.0 (518638) Plugin sentry Initialize Plugin (enabled=true)
                      2022-08-02 11:13:24.839 - info: zigbee.0 (518638) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-08-02 11:13:25.349 - info: zigbee.0 (518638) starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.16.0, js-controller: 4.0.23
                      2022-08-02 11:13:25.400 - debug: zigbee.0 (518638) Using zigbee-herdsman with settings: {"network":{"panID":6760,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20],"networkKey":[65,13,71,170,250,97,77,91,118,169,226,122,181,218,124,204]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                      2022-08-02 11:13:25.474 - info: zigbee.0 (518638) delete old Backup files. keep only last 10
                      2022-08-02 11:13:25.476 - info: zigbee.0 (518638) Starting Zigbee npm ...
                      2022-08-02 11:13:25.478 - debug: zigbee.0 (518638) Starting zigbee-herdsman...
                      2022-08-02 11:13:26.286 - info: zigbee.0 (518638) Installed Version: iobroker.zigbee@1.7.5
                      2022-08-02 11:13:26.305 - debug: zigbee.0 (518638) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_08_02-11_13_25.tar.gz success
                      2022-08-02 11:13:46.280 - error: zigbee.0 (518638) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
                      2022-08-02 11:13:46.281 - error: zigbee.0 (518638) Failed to start Zigbee
                      2022-08-02 11:13:46.282 - error: zigbee.0 (518638) Error herdsman start
                      2022-08-02 11:13:56.284 - info: zigbee.0 (518638) Try to reconnect. 1 attempts left
                      2022-08-02 11:13:56.285 - info: zigbee.0 (518638) Starting Zigbee npm ...
                      2022-08-02 11:13:56.286 - debug: zigbee.0 (518638) Starting zigbee-herdsman...
                      2022-08-02 11:13:56.323 - info: zigbee.0 (518638) Installed Version: iobroker.zigbee@1.7.5
                      2022-08-02 11:13:56.584 - error: zigbee.0 (518638) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                      2022-08-02 11:13:56.587 - error: zigbee.0 (518638) Failed to start Zigbee
                      2022-08-02 11:13:56.587 - error: zigbee.0 (518638) Error herdsman start
                      2022-08-02 11:14:00.053 - info: host.smarthome instance system.adapter.sma-speedwire.0 started with pid 519800
                      2022-08-02 11:14:02.642 - info: sma-speedwire.0 (519800) starting. Version 0.6.6 (non-npm: https://github.com/AttackStrawbery/ioBroker.sma-speedwire/tarball/b81e43b5de4409beff5ecdc1fe4be714ab4bbfbd) in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v16.16.0, js-controller: 4.0.23
                      2022-08-02 11:14:03.749 - info: host.smarthome instance system.adapter.sma-speedwire.0 terminated with code 0 (NO_ERROR)
                      2022-08-02 11:15:00.118 - info: host.smarthome instance system.adapter.daswetter.0 started with pid 521618
                      2022-08-02 11:15:02.305 - info: daswetter.0 (521618) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                      2022-08-02 11:15:02.680 - info: daswetter.0 (521618) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v16.16.0, js-controller: 4.0.23
                      2022-08-02 11:15:04.219 - info: iqontrol.0 (1391) COUNTER SABOTAGE ACTUAL: 0 of 292
                      2022-08-02 11:15:04.591 - info: iqontrol.0 (1391) COUNTER ERROR ACTUAL: 2 of 292
                      2022-08-02 11:15:12.364 - info: daswetter.0 (521618) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                      2022-08-02 11:15:12.887 - info: daswetter.0 (521618) cleaned everything up...
                      2022-08-02 11:15:12.902 - info: host.smarthome instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2022-08-02 11:16:00.068 - info: host.smarthome instance system.adapter.sma-speedwire.0 started with pid 523268
                      2022-08-02 11:16:02.594 - info: sma-speedwire.0 (523268) starting. Version 0.6.6 (non-npm: https://github.com/AttackStrawbery/ioBroker.sma-speedwire/tarball/b81e43b5de4409beff5ecdc1fe4be714ab4bbfbd) in /opt/iobroker/node_modules/iobroker.sma-speedwire, node: v16.16.0, js-controller: 4.0.23
                      2022-08-02 11:16:03.698 - info: host.smarthome instance system.adapter.sma-speedwire.0 terminated with code 0 (NO_ERROR)
                      2022-08-02 11:17:31.614 - info: host.smarthome "system.adapter.zigbee.0" disabled
                      2022-08-02 11:17:31.616 - info: host.smarthome stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      2022-08-02 11:17:31.621 - info: zigbee.0 (518638) Got terminate signal TERMINATE_YOURSELF
                      2022-08-02 11:17:31.623 - info: zigbee.0 (518638) cleaned everything up...
                      2022-08-02 11:17:31.635 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00033ad77d = false
                      2022-08-02 11:17:31.642 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00033ad77d = 0
                      2022-08-02 11:17:31.649 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004b487d4 = false
                      2022-08-02 11:17:31.667 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004b487d4 = 0
                      2022-08-02 11:17:31.671 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004465ea3 = false
                      2022-08-02 11:17:31.675 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004465ea3 = 0
                      2022-08-02 11:17:31.679 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7ba2f = false
                      2022-08-02 11:17:31.683 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7ba2f = 0
                      2022-08-02 11:17:31.687 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00044de796 = false
                      2022-08-02 11:17:31.690 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00044de796 = 0
                      2022-08-02 11:17:31.695 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004460639 = false
                      2022-08-02 11:17:31.698 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004460639 = 0
                      2022-08-02 11:17:31.705 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000485431c = false
                      2022-08-02 11:17:31.708 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000485431c = 0
                      2022-08-02 11:17:31.711 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004462707 = false
                      2022-08-02 11:17:31.716 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004462707 = 0
                      2022-08-02 11:17:31.722 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000420b185 = false
                      2022-08-02 11:17:31.728 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000420b185 = 0
                      2022-08-02 11:17:31.732 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000223a209 = false
                      2022-08-02 11:17:31.735 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000223a209 = 0
                      2022-08-02 11:17:31.739 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004fcf82a = false
                      2022-08-02 11:17:31.742 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004fcf82a = 0
                      2022-08-02 11:17:31.745 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004fcf946 = false
                      2022-08-02 11:17:31.748 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004fcf946 = 0
                      2022-08-02 11:17:31.751 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004b487e0 = false
                      2022-08-02 11:17:31.754 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004b487e0 = 0
                      2022-08-02 11:17:31.757 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004fc9476 = false
                      2022-08-02 11:17:31.760 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004fc9476 = 0
                      2022-08-02 11:17:31.763 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x14b457fffe72bcba = false
                      2022-08-02 11:17:31.766 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x14b457fffe72bcba = 0
                      2022-08-02 11:17:31.769 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x04cf8cdf3c7db935 = false
                      2022-08-02 11:17:31.771 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7db935 = 0
                      2022-08-02 11:17:31.775 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x14b457fffe2ea155 = false
                      2022-08-02 11:17:31.777 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x14b457fffe2ea155 = 0
                      2022-08-02 11:17:31.780 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00041cc7da = false
                      2022-08-02 11:17:31.783 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00041cc7da = 0
                      2022-08-02 11:17:31.789 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00031b35bf = false
                      2022-08-02 11:17:31.794 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00031b35bf = 0
                      2022-08-02 11:17:31.796 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b95a50 = false
                      2022-08-02 11:17:31.799 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b95a50 = 0
                      2022-08-02 11:17:31.802 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000201b693 = false
                      2022-08-02 11:17:31.804 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000201b693 = 0
                      2022-08-02 11:17:31.810 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00022b39fa = false
                      2022-08-02 11:17:31.814 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00022b39fa = 0
                      2022-08-02 11:17:31.819 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001de8f8a = false
                      2022-08-02 11:17:31.824 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001de8f8a = 0
                      2022-08-02 11:17:31.829 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001fa5cab = false
                      2022-08-02 11:17:31.834 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001fa5cab = 0
                      2022-08-02 11:17:31.839 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7a818 = false
                      2022-08-02 11:17:31.844 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7a818 = 0
                      2022-08-02 11:17:31.850 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002235296 = false
                      2022-08-02 11:17:31.854 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002235296 = 0
                      2022-08-02 11:17:31.859 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001e459f9 = false
                      2022-08-02 11:17:31.862 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001e459f9 = 0
                      2022-08-02 11:17:31.864 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001de8c5e = false
                      2022-08-02 11:17:31.868 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001de8c5e = 0
                      2022-08-02 11:17:31.871 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001fd6f2f = false
                      2022-08-02 11:17:31.875 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001fd6f2f = 0
                      2022-08-02 11:17:31.878 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001de89bc = false
                      2022-08-02 11:17:31.880 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001de89bc = 0
                      2022-08-02 11:17:31.883 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7b572 = false
                      2022-08-02 11:17:31.886 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7b572 = 0
                      2022-08-02 11:17:31.889 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7ace5 = false
                      2022-08-02 11:17:31.892 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7ace5 = 0
                      2022-08-02 11:17:31.895 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00022cb2d5 = false
                      2022-08-02 11:17:31.897 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00022cb2d5 = 0
                      2022-08-02 11:17:31.900 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001de6190 = false
                      2022-08-02 11:17:31.903 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001de6190 = 0
                      2022-08-02 11:17:31.906 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004fcf923 = false
                      2022-08-02 11:17:31.909 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004fcf923 = 0
                      2022-08-02 11:17:31.911 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001e48a72 = false
                      2022-08-02 11:17:31.913 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001e48a72 = 0
                      2022-08-02 11:17:31.918 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001e489c1 = false
                      2022-08-02 11:17:31.921 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001e489c1 = 0
                      2022-08-02 11:17:31.932 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b9589f = false
                      2022-08-02 11:17:31.935 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b9589f = 0
                      2022-08-02 11:17:31.937 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002019669 = false
                      2022-08-02 11:17:31.941 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002019669 = 0
                      2022-08-02 11:17:31.944 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7b481 = false
                      2022-08-02 11:17:31.946 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7b481 = 0
                      2022-08-02 11:17:31.949 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x04cd15fffe02d9f3 = false
                      2022-08-02 11:17:31.951 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x04cd15fffe02d9f3 = 0
                      2022-08-02 11:17:31.956 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001b7a88a = false
                      2022-08-02 11:17:31.958 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001b7a88a = 0
                      2022-08-02 11:17:31.961 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00027051c6 = false
                      2022-08-02 11:17:31.964 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00027051c6 = 0
                      2022-08-02 11:17:31.966 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00041cc629 = false
                      2022-08-02 11:17:31.971 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00041cc629 = 0
                      2022-08-02 11:17:31.974 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x04cd15fffe02d085 = false
                      2022-08-02 11:17:31.976 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x04cd15fffe02d085 = 0
                      2022-08-02 11:17:31.979 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001e42cf4 = false
                      2022-08-02 11:17:31.981 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001e42cf4 = 0
                      2022-08-02 11:17:31.985 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002271d3f = false
                      2022-08-02 11:17:31.987 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002271d3f = 0
                      2022-08-02 11:17:31.990 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002f90eff = false
                      2022-08-02 11:17:31.992 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002f90eff = 0
                      2022-08-02 11:17:31.995 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002f3c080 = false
                      2022-08-02 11:17:31.998 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002f3c080 = 0
                      2022-08-02 11:17:32.000 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002f39851 = false
                      2022-08-02 11:17:32.003 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002f39851 = 0
                      2022-08-02 11:17:32.005 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00053fbd6f = false
                      2022-08-02 11:17:32.008 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00053fbd6f = 0
                      2022-08-02 11:17:32.026 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001de72f5 = false
                      2022-08-02 11:17:32.030 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001de72f5 = 0
                      2022-08-02 11:17:32.034 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0002f39894 = false
                      2022-08-02 11:17:32.037 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0002f39894 = 0
                      2022-08-02 11:17:32.040 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00033a4347 = false
                      2022-08-02 11:17:32.045 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00033a4347 = 0
                      2022-08-02 11:17:32.047 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001ddab4c = false
                      2022-08-02 11:17:32.050 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001ddab4c = 0
                      2022-08-02 11:17:32.054 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0004fd0fd7 = false
                      2022-08-02 11:17:32.059 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0004fd0fd7 = 0
                      2022-08-02 11:17:32.063 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d00048605a0 = false
                      2022-08-02 11:17:32.068 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d00048605a0 = 0
                      2022-08-02 11:17:32.073 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x842e14fffe1262bf = false
                      2022-08-02 11:17:32.077 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x842e14fffe1262bf = 0
                      2022-08-02 11:17:32.080 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x588e81fffedbcfe2 = false
                      2022-08-02 11:17:32.090 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x588e81fffedbcfe2 = 0
                      2022-08-02 11:17:32.098 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x842e14fffe35a210 = false
                      2022-08-02 11:17:32.100 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x842e14fffe35a210 = 0
                      2022-08-02 11:17:32.103 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000485f414 = false
                      2022-08-02 11:17:32.107 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000485f414 = 0
                      2022-08-02 11:17:32.114 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d000482d34e = false
                      2022-08-02 11:17:32.132 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d000482d34e = 0
                      2022-08-02 11:17:32.166 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x00158d0001e7a0d0 = false
                      2022-08-02 11:17:32.170 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x00158d0001e7a0d0 = 0
                      2022-08-02 11:17:32.177 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x04cd15fffe067cd7 = false
                      2022-08-02 11:17:32.193 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x04cd15fffe067cd7 = 0
                      2022-08-02 11:17:32.196 - debug: zigbee.0 (518638) DeviceAvailability:Publish available for 0x04cd15fffe02dd9b = false
                      2022-08-02 11:17:32.207 - debug: zigbee.0 (518638) DeviceAvailability:Publish LQ for 0x04cd15fffe02dd9b = 0
                      2022-08-02 11:17:32.269 - info: zigbee.0 (518638) Zigbee: disabling joining new devices.
                      2022-08-02 11:17:32.326 - warn: zigbee.0 (518638) Failed to stop zigbee during startup
                      2022-08-02 11:17:32.327 - info: zigbee.0 (518638) terminating
                      2022-08-02 11:17:32.328 - debug: zigbee.0 (518638) Plugin sentry destroyed
                      2022-08-02 11:17:32.329 - info: zigbee.0 (518638) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2022-08-02 11:17:32.459 - info: host.smarthome stopInstance system.adapter.zigbee.0 send kill signal
                      • Asgothian
                        @martinschm Leider fehlt mal wieder das wonach ich gefragt hab. Um 11.13 wurde der Adapter neu gestartet. Ich wollte die 4 bis 5 Minuten davor sehen. Du hast aber nur ab 11.12 gepostet. Was ist davor ?
                        A.
                          martinschm @Asgothian last edited by
                          @asgothian said in ZigBee Adapter/TI Board steigt immer wieder mal aus:
                          A.
                          ich hab alles gepostet was den zigbee Adapter betrifft. In den Logs findet sich davor nichts. Da sind nur Meldungen von iQontrol, web-speedy und sma-speedwire
                          Viele Grüße
                          Martin
                            Homoran Global Moderator Administrators @martinschm last edited by
                            auch nichts vom host?
                              martinschm @Homoran last edited by
                              @homoran said in ZigBee Adapter/TI Board steigt immer wieder mal aus:
                              Auch nicht vom host.
                              Das ist alles von Mitternacht bis zu den Logs die ich oben gepostet habe.
                              iobroker log.txt
                                A.
                                Ich habe gerade mal im proxmox meine raspberrymatic VM gestoppt, die greift auch per USB auf das HM Funkmodul zu. Vor dem Stoppen ließ sich zigbee nicht Verbinden mit der Fehlermeldung von oben, nach dem Stoppen ging es sofort.
                                Vielleicht wird raspberrymatic da "übergriffig" und sperrt den anderen USB Port?
                                arteck Asgothian 2 Replies Last reply Reply Quote 0
                                  arteck Developer Most Active @martinschm last edited by
                                  @martinschm ich vermute eher das proxmox den Port nicht freigegeben hat nachdem es sich die VM den gekrallt hat..
                                    martinschm @arteck last edited by
                                    @arteck said in ZigBee Adapter/TI Board steigt immer wieder mal aus:
                                    Kann sein. Komisch ist nur, das im laufenden Betrieb auf einen anderen USB Port zu gegriffen wird.
                                    Die iobroker VM hat den einen Port mit dem Zigbee Board dran und die Raspberrymativ VM den anderen Port.
                                    Ist wohl wie bei meinen Kids, die VMs wollen immer den Usb Port den sie gerade nicht haben 🙂
                                    • Asgothian
                                      Bei den VM bin ich raus. Ich trau dem Braten nicht und nutze das nicht.
                                      A.
                                      1332
