      mane444 @s.bormann last edited by
      @s-bormann
      unter ui-block-b steht bei ::after
      ui-navbar ul:after {
          clear: both;
      .ui-navbar ul:before, .ui-navbar ul:after {
          content: "";
          display: table;
      unter ui-block-a steht bei ::after
      iQontrolToolbarLink.ui-btn-active:after {
          background-color: #dd29d0 !important;
      <style>
      .iQontrolToolbarLink.ui-btn:after {
          background-color: #cd24c1 !important;
      <style>
      .iQontrolToolbarLink.ui-btn-active:after {
      <style>
      <style>
          background-color: #2935dd !important;
          background-color: transparent !important;
      .ui-nodisc-icon.ui-btn:after, .ui-nodisc-icon .ui-btn:after {
          background-color: transparent;
      .ui-btn-icon-top:after {
          top: 0.5625em;
      .ui-btn-icon-notext:after, .ui-btn-icon-top:after, .ui-btn-icon-bottom:after {
          left: 50%;
          margin-left: -11px;
      .ui-btn-icon-left:after, .ui-btn-icon-right:after, .ui-btn-icon-top:after, .ui-btn-icon-bottom:after, .ui-btn-icon-notext:after {
          content: "";
          position: absolute;
          display: block;
          width: 22px;
          height: 22px;
          background-color: #666;
          background-color: rgba(0,0,0,.3);
          background-position: center center;
          background-repeat: no-repeat;
          -webkit-border-radius: 1em;
          border-radius: 1em;
      .ui-icon-arrow-d-l:after {
          background-image: url(data:image/svg+xml;charset=US-ASCII,%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22iso-8859-1%22%3F%3E%3C!DOCTYPE%20svg%20PUBLIC%20%22-%2F%2FW3C%2F%2FDTD%20SVG%201.1%2F%2FEN%22%20%22http%3A%2F%2Fwww.w3.org%2FGraphics%2FSVG%2F1.1%2FDTD%2Fsvg11.dtd%22%3E%3Csvg%20version%3D%221.1%22%20id%3D%22Layer_1%22%20xmlns%3D%22http%3A%2F%2Fwww.w3.org%2F2000%2Fsvg%22%20xmlns%3Axlink%3D%22http%3A%2F%2Fwww.w3.org%2F1999%2Fxlink%22%20x%3D%220px%22%20y%3D%220px%22%20%20width%3D%2214px%22%20height%3D%2214px%22%20viewBox%3D%220%200%2014%2014%22%20style%3D%22enable-background%3Anew%200%200%2014%2014%3B%22%20xml%3Aspace%3D%22preserve%22%3E%3Cpolygon%20fill%3D%22%23FFF%22%20points%3D%2214%2C3%2011%2C0%203.5%2C7.5%200%2C4%200%2C14%2010%2C14%206.5%2C10.5%20%22%2F%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3Cg%3E%3C%2Fg%3E%3C%2Fsvg%3E);
      Die Farben hab ich geändert:
      Einstellung Toolbar:
      Anzeige:
      • da_Woody
        da_Woody @mane444 last edited by da_Woody
        @mane444 also doch, wie vermutet, ein farbproblem. nach ein bißchen hirnstöbern, glaub ich, ich hatte am anfang auch das problem. darum hab ich meine selbstgeschnitzten alle auf weiß invertiert, ohne hintergrund.
        dein Wohnz.png dürfte zu groß sein. darum wird da nur der kleine bogen angezeigt von der lehne.
        meine einstellungen für die symbolleisten pics:
        66787f96-cc45-4ad9-a3b2-3083049207f9-grafik.png d01fd109-5730-4494-8881-f8e4bf170d2d-grafik.png
          mane444 @da_Woody last edited by
          @da_woody das scheint wirklich das Problem zu sein.
          Ich hab mal das Symbol Camera aus dem Adapter herauskopiert und in usersymbols hochgeladen. Es wird nun angezeigt, aber nicht wie das Original.
          7a86763b-40ff-4d92-a430-c215bcfa6f41-image.png 36711687-5fed-4c6d-b2fc-202281b7c7c5-image.png
          Ist schon etwas seltsam.
          • da_Woody
            @mane444 da hat sich anscheinend beim invertieren geändert. die originalen vom adapter funktionieren ja. wozu das also invertieren? ich mach das nur bei den eigenen.
            hab grad kurz reingelinst. das original ist ein anderes dateiformat! camera-black.svg wenn du das invertierst und in .png wandeslt, dann passiert sowas schon mal. noch dazu ist ein .svg skalierbar (original 14x14px). die kleinen tücken mit GFX. 😉
            musste am anfang auch probieren, aber so rund 100x100px haben sich als passende größe ergeben.
            meine komplette leiste
            1, 8-10 sind adapter eigene, die anderen Räume - 3D-Drucker selbst gebastelt.
              @da_woody ich glaub ich hab's gefunden. Es liegt scheinbar an der Einstellung der Icon Größe.
              Bei der Voreinstellung 14px werden die Symbole nicht richtig angezeig.
              Bei der Einstellung 15px werden alle Symbole angezeigt
                @da_woody Jetzt bin ich Happy.
                Hier das Livesystem:
                Danke für die Anregungen, ich werde trotzdem mal die Größe meiner Symbole checken.
                • da_Woody
                  @mane444 na super! 👍 ist manchmal halt schwierig, mein iQ läuft schon von anfang an. da hat man dann nicht mehr alles im kopf. viel ändert sich bei mir nicht mehr. bis auf den neuen device-watcher hab ich schon lange nichts mehr geändert.
                  da musste ich auch ne zeit rumspielen mit den automatisch erstellten widgets. 🙂
                  • s.bormann
                    s.bormann Most Active @mane444 last edited by
                    @mane444 sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                    klasse, dass es jetzt geht!
                    Kannst Du mal eines der Icons hier hochladen, dann kann ich mal schauen, ob ich den Fehler finde. Welchen Browser nutzt Du?
                    VG!
                    M da_Woody 3 Replies Last reply Reply Quote 0
                      mane444 @s.bormann last edited by mane444
                      @s-bormann
                      Hallo, ich hab hier mal die Icons zum Testen. Als Browser am PC habe ich Chrome und Edge getestet. Am Tablett und Handy Chrome.
                      Die Icons sind leider nicht sichtbar, da diese weis sind.
                      da_Woody s.bormann 2 Replies Last reply Reply Quote 0
                      • da_Woody
                        @mane444 da sind keine icons, nichtmal mit markieren. selbst wenn sie weis wären, müsste man was sehn.
                        • da_Woody
                          da_Woody @s.bormann last edited by
                          @s-bormann soweit ich das mitbekommen habe, nutzt du da .svg mit 14px.
                          siehe meinen beitrag weiter oben, 193
                            Labersack @da_Woody last edited by Labersack
                            @da_woody
                            Stell mal auf dunkle Darstelllung der Seite, dann:
                            Kannst sie auch einfach speichern, indem du auf die (unsichtbaren) Icons gehst und über rechte Maustaste die Bilder speicherst.
                            • da_Woody
                              da_Woody @s.bormann last edited by da_Woody
                              @s-bormann ich glaub, ich hab ein kleines problem gefunden. hab ein paar online status nachgetragen.
                              bei den standarticons mein grün eingefärbtes eingetragen. das wird auch brav im editor angezeigt.
                              in der view wird aber das original orangenes angezeigt.
                              siehe rechts. wenn ich den pfad dazu eintrage, wird mein grünes verwendet. siehe links.
                              ist auch reproduzierbar. pfad löschen, wieder orange.
                              S s.bormann 2 Replies Last reply Reply Quote 0
                                schweiger2 @da_Woody last edited by schweiger2
                                ich habe ein neues Icon in Größe 96x96 Pixel in das Icon-Verzeichnis /opt/iobroker/iobroker-data/files/iqontrol/images/icons eingestellt und auch die Attribute an die vorhandenen angepasst. Allerdings wird mir das Icon nicht zur Auswahl im Menü angeboten.
                                Was ist mein Fehler ? Was muss ich noch beachten ?
                                Vielen Dank für eure Hilfe.
                                [Sorry, habe versehentlich über "antworten" gearbeitet]
                                • da_Woody
                                  @schweiger2 kein problem. du darfst die icons nicht so übertragen. wie in vis mit dem dateimanager, musst du das in iQonrtol über
                                  machen.
                                    @da_woody
                                    Vielen Dank, so hat es natürlich auf Anhieb funktioniert. 👍
                                    da_Woody 1 Reply Last reply Reply Quote 1
                                    • da_Woody
                                      da_Woody @schweiger2 last edited by
                                      @schweiger2 fein, daß es geholfen hat! 🙂
                                        meerkat last edited by
                                        @s-bormann Guten Morgen.
                                        Bei den Gerätetypen gibt es ja den Typ Info-Text. Dort kann man als Größe Volle Breite, kurz einstellen. Ist es möglich diese Einstellung für Größe auch in den anderen Gerätetypen zur Verfügung zu stellen?
                                        Es gibt das ein oder andere, was ich auf dem Tablet gerne über die ganze Breite anzeigen lassen möchte, aber nicht gleich die gesamte Höhe nutzen möchte.
                                        Gruß und sonnigen Sonntag
                                        • s.bormann
                                          s.bormann Most Active @da_Woody last edited by
                                          @da_woody sagte in Test Adapter iQontrol 2.0.x Vis (Entwicklungs-Thread):
                                          Stimmt, Fehler gefunden, wird in der nächsten Version gefixed. Danke!
                                          • s.bormann
                                            @s-bormann
                                            Hab den Fehler gefunden, ein Semikolon im CSS-Code hat gefehlt. Wird in der nächsten Version gefixed.
                                            296
                                            7637
                                            6957724
