    4. Adapter "smartmeter"
      Kludi @apollon77 last edited by
      @apollon77
      OK ich habe die untere baudrate raus genommen. Leider immer noch nicht möglich.
      Log hat sich glaube ich nicht geendert.
      smartmeter.0	2022-07-30 22:41:15.672	debug	(41341) SCHEDULE NEXT RUN IN 60000s
      smartmeter.0	2022-07-30 22:41:15.671	debug	(41341) DELETE rest of data (0) because new Message start with a new Request Message
      smartmeter.0	2022-07-30 22:41:15.670	debug	(41341) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
      smartmeter.0	2022-07-30 22:41:15.669	debug	(41341) SERIALPORT REMOVE LISTENERS
      smartmeter.0	2022-07-30 22:41:15.668	debug	(41341) SERIALPORT CLOSE
      smartmeter.0	2022-07-30 22:41:15.658	debug	(41341) CLEAR MESSAGE TIMEOUT TIMER
      smartmeter.0	2022-07-30 22:41:15.658	debug	(41341) STOP
      smartmeter.0	2022-07-30 22:41:15.657	debug	(41341) Transport Reset!! Restart = true
      smartmeter.0	2022-07-30 22:41:15.656	debug	(41341) Error: No or too long answer from Serial Device after last request.
      smartmeter.0	2022-07-30 22:41:15.656	warn	(41341) No or too long answer from Serial Device after last request.
      smartmeter.0	2022-07-30 22:41:15.654	debug	(41341) Error: No or too long answer from Serial Device after last request.
      smartmeter.0	2022-07-30 22:41:15.651	debug	(41341) MESSAGE TIMEOUT TRIGGERED
      smartmeter.0	2022-07-30 22:39:15.649	debug	(41341) SET MESSAGE TIMEOUT TIMER2: 120000
      smartmeter.0	2022-07-30 22:39:15.647	debug	(41341) DONE SEND 0
      smartmeter.0	2022-07-30 22:39:15.394	debug	(41341) DONE SEND 1
      smartmeter.0	2022-07-30 22:39:15.257	debug	(41341) connected set to false
      smartmeter.0	2022-07-30 22:39:15.243	debug	(41341) TO SEND 1: /?!
      smartmeter.0	2022-07-30 22:39:15.243	debug	(41341) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
      smartmeter.0	2022-07-30 22:39:15.242	debug	(41341) TO SEND 2:
      smartmeter.0	2022-07-30 22:39:15.241	debug	(41341) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
      smartmeter.0	2022-07-30 22:39:15.240	debug	(41341) INITIAL MESSAGES TO SEND: 2
      smartmeter.0	2022-07-30 22:39:15.236	debug	(41341) SERIALPORT RESET BAUDRATE TO 300
      smartmeter.0	2022-07-30 22:39:15.221	debug	(41341) SERIALPORT OPEN
      smartmeter.0	2022-07-30 22:39:15.200	debug	(41341) CREATE SERIALPORT: 300 7 1 even
      smartmeter.0	2022-07-30 22:39:15.196	debug	(41341) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"60","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102N
      smartmeter.0	2022-07-30 22:39:15.154	info	(41341) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v14.20.0, js-controller: 4.0.23
      smartmeter.0	2022-07-30 22:39:14.393	debug	(41341) Plugin sentry Initialize Plugin (enabled=true)
        apollon77 @Kludi last edited by
        @kludi tja. Am Ende sollte da was kommen. Kopf sitzt richtig? Und richtig rum und so? Es kommt ja noch nicht mal ne fiecetstecsbtwort.
          @apollon77
          Hallo Danke für die Hilfe.
          Ich habe den Fehler gefunden.
          Das ist schon fast peinlich. Ich habe die Empfangsdiode falsch gepolt. 🙈
          Also für den Landis & Gyr E230 gehen diese einsellungen.
          Einen Schönen Sonntag noch.
            wusa last edited by
            Ich habe momentan ein Problem mit dem Smartmeter.
            smartmeter.0
            2022-08-05 08:30:08.208	warn	(COMPACT) Error while parsing SML message: Error: Wrong TL-Field 0x00 for Choice!: Message: 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
            smartmeter.0
            2022-08-05 08:28:07.208	warn	(COMPACT) Error while parsing SML message: Error: Wrong TL-Field 0xff for SmlValue!: Message: 1b1b1b1b01010101760b45535941fc4e001f43746200620072630101760104455359084553596bd243740b09014553591103bbfc4e01016337ef00760b45535941fc4e001f4375620062007263070177010b09014553591103bbfc4e080100620affff0072620165000a6bd27977078181c78203ff01010101044553590177070100000009ff010101010b09014553591103bbfc4e0177070100010800ff6400028001621e52fc5900000000275a165c0177070100020800ff6400028001621e52fc5900000000002f0ee10177070100010801ff0101621e52fc5900000000003bf6d60177070100010802ff0101621e52fc5900000000271e1f850177070100100700ff0101621b5200ff0177070100000000ff010101010f31455359313136323635313437300177078181c7f006ff010101010401010e01010163cc0a00760b76006200620072630201710163e0a9000000001b1b1b1b1a0331bd
            smartmeter.0
            2022-08-05 08:22:04.191	warn	(COMPACT) Error while parsing SML message: Error: Unknown TL-Field 0x7ce for OctetString [Offset: 44]!: Message: 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
            Das komische ist, ich habe diese Meldungen im Log, aber die Daten werden übertragen. Ich habe zwar keine Daten zu genau dieser Zeit, aber grundsätzlich scheint es zu funktionieren, nur manchmal nicht?
              klassisch Most Active @wusa last edited by
              @wusa Wenn es nur manchmal nicht funktioniert, dann mal überprüfen, ob der Lesekopf richtig sitzt.
              Es gibt mittlerweile auch Zähler, bei denen die IR LED altert und dann die Übertragung leidet und dann aussetzt.
              Welchen Lesekopf verwendets Du?
              Wenn Du das Datenabfrageintervall auf 0 setzt, bekommst Du alle Daten und kannst die Positionierung schneller überprüfen.
              Ich habe das immer mit einem (Win-) Laptop vor Ort kontrolliert.
                wusa @klassisch last edited by
                @klassisch
                Mein Zähler wurde letzte Woche getauscht. An dem kann es daher "normal" nicht liegen.
                Ich verwende einen Fototransistor BPW78A. Hatte bisher über 2 Jahre mit dem alten herstellergleichen Zähler kein Problem.
                Ich kann aber gerne nochmal die Ausrichtung kontrollieren.
                K apollon77 2 Replies Last reply Reply Quote 0
                  @wusa Beim selbstgebastelten Empfänger auch gerne die Triggerschwellen prüfen. Am besten erst mal mit alles dem Oszi.
                  Ich hatte auch mal erfolgreich die sogenannten IR Flame detectors modifiziert und testweise eingesetzt. Also Produktionslösung dann aber einen Hager Kopf eingesetzt, weil ich im Zählerschrank kein offensichtliches Gebastel haben möchte. Mehr dazu im Guide
                    apollon77 @wusa last edited by
                    @wusa Korrekt, usrichtung, ALternativ Kabelschirmung checken, ggf über aktiven USB Hub anschliessen, Kabel so "Schnell" wie es es geht so weit wie möglich vom Zähler "weg" verlegen - vllt strahlt der neue Zähle störungen anders ein.
                    Aber fang mal mit dem Sitz des Kopfes an 🙂
                    • I
                      insect @SmartHomer 0 last edited by
                      Hallo zuasmmen!
                      Ich habe auch einen USR-W610 mit EHZ001K und bekomme es nicht ans laufen.
                      Ich habe mich durch die Einstellungen in den obigen Posts durchgewühlt. Aber kein Erfolg gehabt.
                      Am WR610: Link leuchtet, RXD-Lämpchen blinkt.
                      Ich komme über WLAN auf die Weboberfläche des WR610.
                      @smarthomer-0 Du hast geschrieben, dass es mittlerweile bei Dir läuft. Könntest Du die Einstellungen des USR-W610 posten, damit ich diese vergleichen kann?
                      Wäre super. Danke.
                      Ein paar Logs:
                      info-LOG:
                      smartmeter.0
                      	2022-08-07 11:12:43.816	warn	No or too long answer from Socket after last request.
                      smartmeter.0
                      	2022-08-07 11:12:43.813	info	Error: No or too long answer from Socket after last request.
                      smartmeter.0
                      	2022-08-07 11:10:43.840	info	CONNECTED TO TCP SOCKET
                      Also wird verbunden. Aber dann verliert es sich doch.
                      Debug-Info:
                      smartmeter.0
                      	2022-08-07 11:14:37.592	debug	MATCH-RESULT MESSAGE: "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" -> null
                      smartmeter.0
                      	2022-08-07 11:14:37.589	debug	ADD NEW DATA (502 + NEW 8)
                      smartmeter.0
                      	2022-08-07 11:14:37.580	debug	MATCH-RESULT MESSAGE: "0000000001f8f8f800f8f800f8f800f8f800780078007800780080f8f878e000f8f8f8780000000000000000f8781ef88000f8008000f8008080f8781ef8f800007800780080f8f87800780078e00000000000780080f878fe8078fef800f87800807800780078e080f800781e808078fe00f8008080f8008000008080f88000f87800781ef8f8780080f878fe8078fe00007800f800f8f880f88078e00080f8f878e000f8f8f8780000000000000000f880808000f8008000f8008080f8781ef8f80000f8007800f8f8f87800f87800807800780078e080f800781e808078fe00f8008080f800800000f8007800008000f8807800f8f88080f88000f87800781ef8f8780080f878fe8078fe0000f880f8f8f8f8f80078000000f8808080780078007800780078007800000078e080f800781e808078fe7800f8f8f8f80078000000f8780000f87800780078007800f87800807800780078e080f800781e808078fe00f8008080f8008000007800f8f8f8f8007800007800000000f8781ef8f80000007800000078008000f88000808078fef80078e0f8f800000000000000008000780078007800f800f8000080000080f8f878e000f8f8f8780000000000000000f8f8808000f8008000f8008080f8781ef8f80000800078007800f87800f800f880f880f880000000f8f800f8f800f8f800f8f800" -> null
                      smartmeter.0
                      	2022-08-07 11:14:37.574	debug	ADD NEW DATA (0 + NEW 502)
                      smartmeter.0
                      	2022-08-07 11:14:36.638	debug	connected set to false
                      smartmeter.0
                      	2022-08-07 11:14:36.571	debug	SET MESSAGE TIMEOUT TIMER: 120000
                      smartmeter.0
                      	2022-08-07 11:14:36.569	debug	SOCKET RESUME
                      smartmeter.0
                      	2022-08-07 11:14:36.564	debug	SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"TCPTransport","requestInterval":"0","anotherQueryDelay":"1000","transportTcpHost":"192.168.178.40","transportTcpPort":"502","protocolSmlIgnoreInvalidCRC":false}
                      smartmeter.0
                      	2022-08-07 11:14:36.505	info	starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                      smartmeter.0
                      	2022-08-07 11:14:35.818	debug	Plugin sentry Initialize Plugin (enabled=true)
                      host.raspberrypi
                      	2022-08-07 11:14:32.322	info	instance system.adapter.smartmeter.0 started with pid 21969
                        klassisch Most Active @insect last edited by klassisch
                        @insect
                        Ich nehme an, es geht um eine "Moderne Messeinrichtung" mit optischer IR Schnittstelle? Also kein bidirektionales D0 oder sowas.
                        Daten kommen nicht an. Hast Du zwischen dem EHZ und dem USRIOT die Daten A und B gekreuzt? Das muß leider gemacht werden, weil sich Hager streng an die Norm hält und USRIOT an die Datenblätter der Chip Hersteller.
                        Vielleicht hilft Dir mein Guide . Habe auch einen Hager EHZ001K und ein USRIOT Teil im Einsatz, allerdings Eth. WLAN Modul hatte ich auch testweise im Einsatz und habe es für eine andere Applikation (RS485 Modbus-Stromzähler) auch noch im Einsatz.
                        • I
                          insect @klassisch last edited by
                          @klassisch Ja, es ist eine "Moderne Messeinrichtung" mit opticher IR Schnittstelle. Guide hatte ich auch schon vorher zu Rate gezogen. Bin erst deswegen darauf gekommen, als ich nach der Umstellung auf die moderne Messeinrichtung durch den Netzbetreiber nach dem Typ und iobroker gesucht hatte.
                          Ich kann nun Erfolg melden!
                          Was habe ich gemacht?
                          Daten A und B getauscht -> kein RXD-Blinken mehr
                          Nochmals Info-Schnittstelle geprüft. War auf "off" -> "on" gestellt. Es ging aber immer noch nicht.
                          Dann bei PIN noch auf "on" gestellt. -> Nun sehe ich an der Messeinrichtung beide Zeilen dauerhaft.
                          --> Immer noch kein Erfolg.
                          Ethernet ausgeschalten, wieder eingeschalten -> jeweils kein Erfolg
                          Data Transfer Mode auf Transparent und 9600 Baud (wieder mal) umgestellt, Ethernet ausgeschalten.
                          --> Reboot WR-610, iobroker Adapter neu gestartet ==> Juchheee! Ich habe Daten.
                          An dieser Stelle: Danke für den Guide, danke für die Hilfestellungen aus den obigen Posts.
                          @SmartHomer-0 Die Screenshots brauche ich dann jetzt nicht mehr. War dann wohl eine Kombi aus Einstellungen hin und herprobiert, ein-/ausschalten des Ethernet-Ports.
                          K A 2 Replies Last reply Reply Quote 2
                            @insect Vielen Dank für die Rückmeldung und Gratulatin zum Erfolg!
                            Die Geschichte mit PIN und der Aktivierung der Infoschnittstelle macht die Sache nicht leichter. Und nach einem Stromausfall haben die meisten Zähler das wieder vergessen und man fängt von vorne an.
                              wusa @apollon77 last edited by
                              @apollon77
                              Ich habe jetzt die Kabel etwas weiter vom Zähler weg verlegt.
                              Auch habe die restliche Kabellänger versucht so weit wie möglich weg von anderen Kabeln zu verlegen.
                              Jetzt habe ich immer 2 Messungen die funktionieren, dann 2 die nicht funktionieren.
                              Hier mal ein Screenshot:
                              Fehlermeldung ist immer wieder eine andere. Hier mal ein paar die ich schnell in den Logs gesucht habe unabhängig vom Screenshot:
                              smartmeter.0
                              2022-08-09 07:30:37.662	warn	(COMPACT) Error while parsing SML message: Error: Unknown TL-Field 0x45 for OctetString [Offset: 81]!: Message: 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
                              smartmeter.0
                              2022-08-09 07:22:33.650	warn	(COMPACT) Error while parsing SML message: Error: Wrong TL-Field (2) for Unsigned!: Message: 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
                              smartmeter.0
                              2022-08-09 07:14:29.633	warn	(COMPACT) Error while parsing SML message: Error: Wrong TL-Field 0x53 for Choice!: Message: 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
                              Kann das immer noch an den Kabel liegen oder am Lesekopf? Oder liegt hier ein anderes Problem vor?
                              apollon77 K 2 Replies Last reply Reply Quote 0
                                @wusa Aussage bleibt die gleiche. Da scheint ab und an mal ein Bit zu kippen. Gründe bleiben Die oben. Genau weil es immer wo anders ist.
                                  @wusa Poste mal eine Oszimessung und einen Schaltplan Deines Selbstbau-Empfängers. Alles andere ist blindes raten.
                                    @klassisch
                                    Oszi habe ich leider nicht.
                                    Und der Schaltplan ist relativ einfach.
                                    Das ist eine Fotodiode mit 2 Pins. Mit diesen 2 Pins gehe ich auf den Raspi und Werte alles mit dem Smartmeter Adapter aus.
                                    BPW78A
                                      @wusa Dann sehe ich folgende Möglichkeiten:
                                      • Empfohlen: Du beschaffst Dir einen fertigen Lesekopf
                                      • Du lebst mit den Aussetzern
                                      • Du frickelst noch etwas an der Position und an der Abschirmung gegen Fremdlicht. Da Du eine "Schaltung auf Hoffnung hin" ohne Schmitt-Trigger etc verwendet hast, kann Fremdlicht stören
                                      • Du verwendest ein "IR Flame detector" mit Schmitt-Trigger und Trimmer als Empfänger
                                      • Du interessierst Dich für Elektronik, arbeitest Dich ein und kaufst Dir ein Scope und baust einen Schmitt-Trigger hinter den Phototransistor. Kostet viel Zeit und Geld.
                                      Und ja, Du hattest jahrelang Glück mit Deiner alten Konfiguration und darfst Dich darüber freuen. Optimales Nutzen/Aufwand-Verhältnis. Aber das heißt nicht, daß die "auf Hoffnung hin" dimensionierte Schaltung auch bei anderen Zählern weiter funktioniert.
                                        funzel last edited by
                                        Ich habe aktuell einen itron CF 55 Fernwärmezähler als Endboss.
                                        Hat jemand eine Idee, wie ich ihn mittels Volkszähler ausgelesen bekomme bzw. ich das Problem am besten angehe?
                                        Vielen Dank!
                                        Homoran apollon77 2 Replies Last reply Reply Quote 0
                                          Homoran Global Moderator Administrators @funzel last edited by Homoran
                                          @funzel sagte in Adapter "smartmeter":
                                          Vielen Dank!
                                          was steht denn im Datenblatt oder/und bei Volkszähler?
                                          hab nur den höchst aufschlussreichen Satz gefundrn
                                          Die umfangreichen Funktionen des CF 55 liefern alle zur Abrechnung notwendigen Daten sowie Analysemöglichkeiten des Wärmenetzwerks.
                                            apollon77 @funzel last edited by
                                            Also dafür wäre das hier das falsche Forum ... Wir können nur beim "Smartmeter "adapter von ioBroker helfen
                                            3625
                                            2286750
