    4. Smartmeter Fehler "Verbunden mit Gerät oder Dienst"
      haubada @Thomas Braun last edited by haubada
      @thomas-braun said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
      Und ein Neustart des Adapters schaut wie im log aus?
      Das sieht so aus mit den Smartmeter Einstellungen vom letzten Bild:
      2022-08-07 19:26:16.212  - info: smartmeter.0 (12596) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-07 19:26:16.800  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-07 19:26:19.252  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 12612
      2022-08-07 19:26:23.300  - info: smartmeter.0 (12612) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-07 19:27:37.551  - info: admin.0 (1378) failed connection to socket.io from ::ffff:192.168.178.36:
      2022-08-07 19:27:37.570  - error: admin.0 (1378) Error: "error"
      2022-08-07 19:27:39.200  - info: admin.0 (1378) failed connection to socket.io from ::ffff:192.168.178.36:
      2022-08-07 19:27:39.211  - error: admin.0 (1378) Error: "error"
      2022-08-07 19:28:23.419  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:28:23.425  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
      2022-08-07 19:30:33.443  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:30:33.445  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
      2022-08-07 19:32:43.456  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:32:43.459  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
      2022-08-07 19:34:53.468  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:34:53.470  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
      2022-08-07 19:37:03.479  - info: smartmeter.0 (12612) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:37:03.481  - warn: smartmeter.0 (12612) No or too long answer from Serial Device after last request.
      2022-08-07 19:38:02.078  - info: smartmeter.0 (12612) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-07 19:38:24.305  - info: smartmeter.0 (12612) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-07 19:38:29.875  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2022-08-07 19:38:29.891  - info: smartmeter.0 (12612) Got terminate signal TERMINATE_YOURSELF
      2022-08-07 19:38:29.896  - info: host.raspberrypi stopInstance system.adapter.smartmeter.0 send kill signal
      2022-08-07 19:38:29.897  - info: smartmeter.0 (12612) terminating
      2022-08-07 19:38:29.901  - info: smartmeter.0 (12612) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-07 19:38:30.500  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-07 19:38:32.986  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 12850
      2022-08-07 19:38:37.120  - info: smartmeter.0 (12850) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-07 19:40:37.239  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:40:37.243  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
      2022-08-07 19:42:47.260  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:42:47.264  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
      2022-08-07 19:44:57.279  - info: smartmeter.0 (12850) Error: No or too long answer from Serial Device after last request.
      2022-08-07 19:44:57.281  - warn: smartmeter.0 (12850) No or too long answer from Serial Device after last request.
        Thomas Braun Most Active @haubada last edited by
        @haubada sagte in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
        /dev/ttyAMA0
        Stell mal auf das Gerät um. Nicht das der Kopf dort liegt.
          /dev/ttyAMA0
          Ich habe das jetzt so eingestellt:
          Allerdings bleibt das gelbe Ausrufezeichen und die Fehlermeldung "Verbunden mit Gerät oder Dienst" rot
          Homoran meinte ja:
          da passen zeile 2 und 3 schonmal nicht zusammen
          wakeup und nur lesen
          --> Soll ich da was anderes einstellen, bin aus dem link auf die Schnelle auch nicht schlau geworden
            Homoran Global Moderator Administrators @haubada last edited by Homoran
            und warum bleibt das so?
            was sagt jetzt das log beim Neustart der Instanz?
              Homoran meinte ja:
              @homoran sagte in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
              EDIT: Thread bei elv zu Ende gelesen. müsste doch passen.
                haubada @Homoran last edited by haubada
                @homoran said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
                Das ist ja mein Problem seit Beginn des Threads!
                Ich bekommt den Adapter bzw. die Instanz nicht mehr auf grün.
                Das ist mein Log nach 2x Neustarten:
                2022-08-07 20:04:01.070  - info: host.raspberrypi Restart adapter system.adapter.smartmeter.0 because enabled
                2022-08-07 20:04:02.112  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 13814
                2022-08-07 20:04:03.961  - error: smartmeter.0 (13807) smartmeter.0 invalid process id scenario 13814 vs. own ID 13807. Stopping
                2022-08-07 20:04:03.970  - info: smartmeter.0 (13807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-08-07 20:04:04.552  - error: host.raspberrypi instance system.adapter.smartmeter.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                2022-08-07 20:04:04.553  - info: host.raspberrypi Do not restart adapter system.adapter.smartmeter.0 because desired by instance
                2022-08-07 20:04:06.326  - info: smartmeter.0 (13814) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                2022-08-07 20:04:37.047  - warn: smartmeter.0 (13814) Got terminate signal. Checking desired PID: 0 vs own PID 13814
                2022-08-07 20:04:37.068  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 13834
                2022-08-07 20:04:37.413  - info: smartmeter.0 (13814) terminating
                2022-08-07 20:04:37.418  - info: smartmeter.0 (13814) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-08-07 20:04:37.428  - warn: smartmeter.0 (13814) Got terminate signal. Checking desired PID: 13834 vs own PID 13814
                2022-08-07 20:04:38.013  - error: host.raspberrypi instance system.adapter.smartmeter.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                2022-08-07 20:04:38.014  - info: host.raspberrypi Do not restart adapter system.adapter.smartmeter.0 because desired by instance
                2022-08-07 20:04:41.269  - info: smartmeter.0 (13834) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                  nö, da steht jetzt ganz was anderes drin.
                  läuft der zwei mal?
                    Das hätte ich als mein Problem geschrieben ganz oben:
                    @haubada said in Smartmeter Fehler "Verbunden mit Gerät oder Dienst":
                    Leider geht aktuell mein Smartmeter Adapter nicht mehr in den grünen Betrieb und es kommt immer die Fehlermeldung bzw. bleibt rot "Verbunden mit Gerät oder Dienst". Bei den Protokollen kommt die Warnung: No or too long answer from Serial Devie after last request.
                    äuft der zwei mal?
                    Das weiß ich ehrlich gesagt auch nicht.
                    Beim Adapter steht: Installierte Instanzen: 1
                    Es gibt nur Smartmeter.0
                      nicht instanzen
                      invalid process
                      Entweder raspi neubstartrn oder die beiden genannten Prozesse killen jnd Instanz neustarten.
                      liest du das log eigentlich?
                      davon steht jetzt nichts drin
                        Entschuldigung, dass hatte ich falsch verstanden.
                        Natürlich stand da im Log aktuell nichts drin.
                        Die Warnung bzw. Fehlermeldung kommt immer erst nach einiger Zeit.
                        Ich haben den PI jetzt neu gestartet und nun sieht das log so aus:
                        Jetzt taucht es wieder auf...
                        2022-08-07 21:16:24.396  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2022-08-07 21:16:24.427  - info: host.raspberrypi instance system.adapter.smartmeter.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2022-08-07 21:16:24.440  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                        2022-08-07 21:16:24.764  - info: host.raspberrypi stopInstance system.adapter.admin.0 killing pid 1378
                        2022-08-07 21:16:25.217  - warn: host.raspberrypi instance system.adapter.admin.0 terminated due to SIGTERM
                        2022-08-07 21:16:25.219  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code null ()
                        2022-08-07 21:16:25.220  - info: host.raspberrypi All instances are stopped.
                        2022-08-07 21:16:25.467  - info: host.raspberrypi terminated
                        2022-08-07 21:18:22.692  - info: host.raspberrypi iobroker.js-controller version 4.0.23 js-controller starting
                        2022-08-07 21:18:22.714  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                        2022-08-07 21:18:22.717  - info: host.raspberrypi hostname: raspberrypi, node: v16.16.0
                        2022-08-07 21:18:22.720  - info: host.raspberrypi ip addresses: 192.168.178.38 2003:d5:2f37:b900:1620:5c72:4ba3:3833 fe80::73c4:fe5f:4aed:5009 192.168.178.101 2003:d5:2f37:b900:1ffe:f3d9:48c6:5719 fe80::dad3:d610:3368:c745
                        2022-08-07 21:18:24.538  - info: host.raspberrypi connected to Objects and States
                        2022-08-07 21:18:24.622  - info: host.raspberrypi added notifications configuration of host
                        2022-08-07 21:18:25.931  - info: host.raspberrypi 4 instances found
                        2022-08-07 21:18:25.955  - info: host.raspberrypi starting 4 instances
                        2022-08-07 21:18:26.093  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 1281
                        2022-08-07 21:18:30.027  - info: host.raspberrypi instance system.adapter.smartmeter.0 started with pid 1464
                        2022-08-07 21:18:31.209  - info: admin.0 (1281) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
                        2022-08-07 21:18:31.333  - info: admin.0 (1281) requesting all states
                        2022-08-07 21:18:31.336  - info: admin.0 (1281) requesting all objects
                        2022-08-07 21:18:32.455  - info: admin.0 (1281) received all objects
                        2022-08-07 21:18:33.187  - info: admin.0 (1281) Request actual repository...
                        2022-08-07 21:18:33.304  - info: admin.0 (1281) http server listening on port 8081
                        2022-08-07 21:18:33.306  - info: admin.0 (1281) Use link "http://localhost:8081" to configure.
                        2022-08-07 21:18:34.029  - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2022-08-07 21:18:34.164  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 1612
                        2022-08-07 21:18:37.104  - info: admin.0 (1281) Repository received successfully.
                        2022-08-07 21:18:38.129  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1623
                        2022-08-07 21:18:38.457  - info: smartmeter.0 (1464) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                        2022-08-07 21:18:39.629  - info: discovery.0 (1612) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
                        2022-08-07 21:18:44.350  - info: backitup.0 (1623) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
                        2022-08-07 21:18:45.789  - info: backitup.0 (1623) [iobroker] backup was activated at 02:40 every 1 day(s)
                        2022-08-07 21:20:38.594  - info: smartmeter.0 (1464) Error: No or too long answer from Serial Device after last request.
                        2022-08-07 21:20:38.598  - warn: smartmeter.0 (1464) No or too long answer from Serial Device after last request.
                        2022-08-07 21:22:43.610  - info: smartmeter.0 (1464) Error: No or too long answer from Serial Device after last request.
                        2022-08-07 21:22:43.613  - warn: smartmeter.0 (1464) No or too long answer from Serial Device after last request.
                          Homoran Global Moderator Administrators @Homoran last edited by
                          hast du den Thread bei elv in meinem Link gelesen?
                            Ich habe gelesen...
                            ...dass es sein kann, dass die Schnittstelle defekt ist.
                            ...dass die richtige Konfiguration D0 Modus D; 9600 Bd; 1_7D_1P_E_1S ist (oder auch andere?!?! SML; 9600 Bd; 1_8D_0P_N_1S)
                            ...dass der Phototranisistor getauscht wurde (aber es ist ein anderes Modell?)
                            ...dass jemande den Volkszähler TTL-IR-Lesekopf nachgebaut hat
                            ...dass man die Position des Lesekopfs veränder kann (hab ich gemacht)
                            Auf was möchtest Du hinaus?
                            Soll ich mir einen anderen Lesekopf besorgen?
                            Ich bin leider kein Profi, sonst würde ich ja hier nicht um Hilfe fragen.
                            Ich weiß nur, erst ging mein Lesekopf am Logarex und jetzt geht er nicht mehr und ich kann den Grund nicht herausfinden.
                              dann hast du nicht gelesen.
                              Der Logarex scheint mit der Zeit immer schwächere Signale zu senden.
                              so dass selbst die Optimierung eines der beiden Möglichkeiten nicht mehr reicht, sondrrn beides durchgeführt werdrn muss, was irgendwann auch nicht mehr ausreichend ist.
                              Selbst ganz neu scheinen die Signale deutlich schwächer zu sein, als bei anderen Zählern. Was auch dein Foto eindrucksvoll zeigt.
                                Besten Dank für Deine Einschätzung.
                                Mir ist schon klar, dass der Logarex wahrscheinlich das Problem ist.
                                Leider habe ich aber keinen Einfluss auf meinen verbauten Stromzähler.
                                Mir fällt somit nur noch ein:
                                • anderes Lesegerät (Volkszähler, oder anderes Modell)
                                • evtl. Optimierung meiner Platine mit anderen Widerständen
                                • evtl. doch noch ein Problem mit der initialisierung der seriellen Schnittstelle ttyS0
                                  (vorher ging es ja auch immer wieder und jetzt geht gar nichts mehr, ich habe auch schon sehr viel verändert zwischenzeitlich)
                                • Info:OFF am Logarex?!?
                                Aber zu Sicherheit möchte ich BITTE nocheinmal die richtige Konfiguration für mein Smartmeter wissen?
                                D0 Modus D; 9600 Bd; 1_7D_1P_E_1S oder
                                Welche Werte sollte ich bitte hier einstellen?
                                Allgemeine Einstellungen:
                                Datenabfrageintervall
                                Datenübertragung
                                Daten-Protokoll
                                Einstellungen Datenübertragung:
                                Serielles Gerät: Name
                                Serielles Gerät: Baudrate
                                Serielles Gerät: Data-Bits
                                Serielles Gerät: Stop-Bits
                                Serielles Gerät: Parität
                                Wartezeit auf serielle Antwort
                                Homoran 3 Replies Last reply Reply Quote 0
                                  wo bist du da?
                                  warst du früher da schon einmal?
                                    den Thread bei elv wirklich gelesen?
                                    Zitat:
                                    Im Photovoltaikforum berichten einige Nutzer, dass ihr Versorger auf Anfrage bereit war den Logarex-Zähler mit defekter Schnittstelle zu ersetzen.
                                    die sind alle weitestgehend identisch
                                    wäre laut Thread bei elv wahrscheinlich nur eine vorübergehende Maßnahme, da anscheinend die Sende LED schnell altert.
                                    Den Thread wirklich gelesen?
                                    wenn du zwischendrin die Schnittstelle per Konsole blockierst durchaus noch möglich
                                    dann bekommst du nur noch die Zähletstände in kWh
                                    der Adapter regelt das üblicherweise alleine. Nur die korrekte Schnittstelle und das Protokoll eintragen
                                      @haubada ist es dieser?
                                      https://wiki.volkszaehler.org/hardware/channels/meters/power/logarex_lk13b?s[]=logarex
                                      Versuch es mal mit diesen Daten.
                                      hast du die Daten nicht von deinem Netzbetreiber bekommen?
                                      Der Link auf der Seite ist auch sehr empfehlenswert
                                      https://www.photovoltaikforum.com/thread/111153-vzlogger-liest-keine-daten-vom-logarex-zähler/
                                      Für dich jetzt direkt das Fazit
                                      Bei den Zähler sind die IR Dioden schrott die sind sehr schwach und bei geben nach kurzer Zeit den geißt auf !!!
                                        Hallo nochmals,
                                        ich habe mittlerweile einen neuen Zähler (auch wieder Logarex, aber neueres Modell) bekommen.
                                        Jetzt funktioniert es mit folgenden Einstellungen:
                                        Danke an alle!!!
                                          Super!
                                          Hoffentlich bleibt es so, weil es
                                          aber neueres Modell
                                          3161
