    4. [Javascript] Adapter-Instanzen überwachen
    • david83
      david83 last edited by david83
      @Acgua
      Hi, ich wollte das Script einmal ausprobieren und habe das npm Modul cron-parser aktiviert.
      Dann das Log kontrolliert. Folgende Meldungen:
      	2022-07-19 14:18:39.627	error	WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
      javascript.0
      2022-07-19 14:18:39.626	error	npm
      javascript.0
      2022-07-19 14:18:39.599	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.0
      2022-07-19 14:18:39.598	error	npm
      javascript.0
      2022-07-19 14:18:39.577	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
      javascript.0
      2022-07-19 14:18:39.576	error	npm
      javascript.0
      2022-07-19 14:18:39.538	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      javascript.0
      2022-07-19 14:18:39.537	error	npm
      javascript.0
      2022-07-19 14:18:39.480	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
      javascript.0
      2022-07-19 14:18:39.479	error	npm
      javascript.0
      2022-07-19 14:18:37.412	error	WARN config production Use `--omit=dev` instead.
      javascript.0
      2022-07-19 14:18:37.411	error	npm
      Ist das so richtig?
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
      david83 1 Reply Last reply Reply Quote 0
      • frana120500
        frana120500 last edited by frana120500
        ich habe auch mal die 0.0.2 ausprobiert und erhalten folgende warnings im log:
        javascript.0
        2022-07-19 14:59:32.583	warn	script.js.Sonstiges.Adapter_Instanzen_überwachen: sonoff.0.info.connection returns String "Erzeugungszähler,Waschmaschine,Bürolampe,Gosund SP112,Gosund-Heizstab,3dDrucker,FritzBox_Steckdose,Staubsauger,Gosund-USV,Stehlampe,Gosund-Treppe-ESP32,Kinderzimmerlampe,GrosseGarage,Bewässerung,TasmoShelly-BJ", but boolean expected. We assume connection is true and continue.
        javascript.0
        2022-07-19 14:59:32.582	warn	script.js.Sonstiges.Adapter_Instanzen_überwachen: mqtt.0.info.connection returns String "evcc-2142291184", but boolean expected. We assume connection is true and continue.
        • JLeg
          JLeg @Acgua last edited by
          @acgua sagte in [Javascript] Adapter-Instanzen überwachen:
          In manchen ioBroker-Umgebungen scheint die Abfrage von admin.0.info.connection (sowie bisher identifizierte Adapter mqtt und sonoff) kein Boolean zurückzugeben, sondern ein String wie etwa [2]admin, javascript. Ich kann es nicht
          nur FYI - der sonoff-Adapter z.B. enthält per Definition im besagten DP "Liste der verbundenen Geräte" - dürfte also nie "boolean" liefern... 😉
          • david83
            david83 @david83 last edited by
            @david83 sagte in [Javascript] Adapter-Instanzen überwachen:
            @Acgua
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            javascript.0
            Ist das so richtig?
            Kann zu den Ausgaben im Log jemand mit etwas mehr Hintergrundwissen was sagen?
            R Thomas Braun 2 Replies Last reply Reply Quote 0
              Rushmed Most Active @david83 last edited by
              @Acgua
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              javascript.0
              Ist das so richtig?
              Würde mich auch interessieren.
                Thomas Braun Most Active @david83 last edited by
                @david83
                Alles harmlose Hinweise auf Änderungen. Die meisten werden sich mit künftigen Updates erledigen.
                  TotalEclipse @wilbur last edited by
                  @wilbur said in [Javascript] Adapter-Instanzen überwachen:
                  Ich hab dafür ein kleines Blockly nach diesem Muster: machs-smart.de
                  Und das funktioniert bisher sehr zuverlässig.
                  Das meldet, wenn eine Instanz nicht mehr läuft.
                  Danke für die Inspirationen hier im Beitrag.
                  Ich habs auch mit der machs-smart Methode durch Blockly gelöst.
                  Bin zwar Senior Developer (allerdings nicht für JS haha), daher ist dieses grafische Programmieren mal ganz erfrischend 🙂
                  Ich nutze es für die Überwachung des ZigBee Adapters, da ich eine Art Bewegungsmelder realisiert habe und mitbekommen muss, wenn die Geräte selbst durch ausgefallenen Adapter nicht erreichbar sind.
                  • Acgua
                    Acgua @Guest last edited by
                    @ciddi89 said in [Javascript] Adapter-Instanzen überwachen:
                    @acgua danke, hab die neue Version gleich ausprobiert. 🙂 Vielen dank für die Arbeit. Das log sieht nun so aus:
                    @frana120500 said in [Javascript] Adapter-Instanzen überwachen:
                    @jleg said in [Javascript] Adapter-Instanzen überwachen:
                    Vielen Dank für eure Rückmeldungen.
                    Ich werde das Script in einen eigenen Adapter umwandeln, da kann ich einfach vieles besser handhaben im Code als über ein Script im JS-Adapter.
                    Wird aber noch etwas dauern.
                    • Acgua
                      Acgua @wilbur last edited by
                      @totaleclipse said in [Javascript] Adapter-Instanzen überwachen:
                      Sehr gut, wenn es immer zuverlässig funktioniert in diesen Use Cases ☺
                      Hier wird wohl allerdings nur der system.adapter.<Instanz>.connected Datenpunkt abgefragt. Das funktioniert erst mal auch soweit, aber halt nicht zuverlässig, da es noch weitere Datenpunkte gibt, die auch zu betrachten sind, vor allem im Fehler-Fall des Adapters. Ich habe das teils hier beschrieben: https://github.com/Acgua/ioBroker-Script-Adapter-Instances-Watcher/
                      Außerdem kann man bei Schedule-Adapter (wie: daswetter) den .connected-State nicht verwenden, der bleibt leer, auch wenn das Schedule zuverlässig läuft (oder nicht).
                        TotalEclipse @Acgua last edited by
                        @acgua said in [Javascript] Adapter-Instanzen überwachen:
                        Danke für die ausführlichen Informationen.
                        Dann werde ich mir dein Skript wohl doch mal genauer ansehen.
                        Ich wollte deine Leistung auch keinesfalls schmälern, finde wie gesagt nur die grafische Methode zu "programmieren" sehr angenehm als Abwechslung. Aber natürlich blöd, wenn das nicht alle Fälle abdeckt.
                          Kusi last edited by
                          Hallo @Acgua
                          Danke für das Skript.
                          Folgender Log-Eintrag erscheint bei mir, wenn ich eine Instanz lösche:
                          javascript.0
                          2023-09-11 02:49:27.045	error	script.js.Instanz_überprüfen.Instanz_Watcher: TypeError: Cannot read properties of undefined (reading 'name') at AdapterInstance.asyncUpdateInfoVariables (script.js.Instanz_überprüfen.Instanz_Watcher:317:44) at AdapterInstance._initAdapterInstance_StateUpdatesAsync (script.js.Instanz_überprüfen.Instanz_Watcher:298:17)
                          javascript.0
                          2023-09-11 02:49:27.045	warn	script.js.Instanz_überprüfen.Instanz_Watcher: Adapter object 'system.adapter.roomba.0' does not exist for given id 'roomba.0'.
                          Ist dies ein Fehler im Skript?
                            Kusi last edited by
                            @Acgua
                            Beim erstmaligen Start des Skripts, habe ich folgendes im Log:
                            javascript.0
                            2023-09-11 02:55:26.240	error	WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            javascript.0
                            2023-09-11 02:55:26.238	error	npm
                            javascript.0
                            2023-09-11 02:55:26.099	error	deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
                            javascript.0
                            2023-09-11 02:55:26.097	error	npm WARN
                            javascript.0
                            2023-09-11 02:55:26.010	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                            javascript.0
                            2023-09-11 02:55:26.009	error	npm
                            javascript.0
                            2023-09-11 02:55:25.738	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
                            javascript.0
                            2023-09-11 02:55:25.736	error	npm
                              michihorn last edited by michihorn
                              Hallo, ich habe mich mal an Dein Script getraut.
                              1. Frage kann das Script auch Instancen einer Multihost Umgebung überwachen?
                                EDIT: Geht wohl, es sind alle Instancen über beide Host gefunden worden. (System.INST_Check)
                              2. Anbei eine Fehlermeldung:
                              17:35:46.981	warn	javascript.1 (2941) script.js.SYSTEM.INST_Check: mqtt.0.info.connection returns String "Castrop", but boolean expected. We assume connection is true and continue.
                              17:35:46.992	warn	javascript.1 (2941) script.js.SYSTEM.INST_Check: mqtt.1.info.connection returns String "shellyuni-34945478EBFD", but boolean expected. We assume connection is true and continue.
                              17:35:46.992	warn	javascript.1 (2941) script.js.SYSTEM.INST_Check: mqtt.2.info.connection returns String "shellyuni-3494547906FF", but boolean expected. We assume connection is true and continue.
                              3.Verbesserung: Fehlermeldungen per Whatsapp oder Telegram ausgeben.
                              Michael
                                Kusi @Acgua last edited by Kusi
                                @acgua Das Skript hat bei mir über ein Jahr funktioniert, seit ein paar Wochen erhalte ich jedoch einen Fehler.
                                javascript.0	2025-03-28 23:00:54.158	error	script.js.Instanz_überprüfen.Instanz_Watcher: TypeError: CRON_PARSER.parseExpression is not a function at AdapterInstance.getPreviousCronRun (script.js.Instanz_überprüfen.Instanz_Watcher:578:42) at AdapterInstance.asyncIsInstanceFunctioning (script.js.Instanz_überprüfen.Instanz_Watcher:506:57) at AdapterInstance.asyncUpdateInfoVariables (script.js.Instanz_überprüfen.Instanz_Watcher:357:34) at AdapterInstance._initAdapterInstance_StateUpdatesAsync (script.js.Instanz_überprüfen.Instanz_Watcher:299:17)
                                Kann mir ggfs. jemand helfen, woran das liegen kann?
                                "Cron-Parser" ist bei der Javascript-Instanz vorhanden.
                                34
                                4590
