bekomme Grafana absolut nicht auf Version 8
@thomas-braun said in bekomme Grafana absolut nicht auf Version 8:
dpkg --list 'grafana*'
pi@raspberrypi:~ $ dpkg --list 'grafana*' Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==================-============-============-================================= ii grafana 9.0.6 armhf Grafana ii grafana-enterprise 7.0.0 armhf Grafana -
sudo apt remove grafana-enterprise -
sudo apt remove grafana-enterprise Reading package lists... Done Building dependency tree Reading state information... Done The following packages will be REMOVED: grafana-enterprise 0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded. After this operation, 121 MB disk space will be freed. Do you want to continue? [Y/n] y (Reading database ... 135230 files and directories currently installed.) Removing grafana-enterprise (7.0.0) ... pi@raspberrypi:~ $ dpkg --list 'grafana*' Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==================-============-============-================================= ii grafana 9.0.6 armhf Grafana rc grafana-enterprise 7.0.0 armhf GrafanaDas Ergebnis ist ich kann nicht mehr auf Grafana zugreifen
nach Reboot des Systems:
Immer noch kein zugriff auf Grafana
pi@raspberrypi:~ $ sudo apt update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://www.pivccu.de/piVCCU stable InRelease Hit:4 https://packages.grafana.com/oss/deb stable InRelease Hit:5 https://repos.influxdata.com/debian stretch InRelease Hit:6 https://deb.nodesource.com/node_16.x buster InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. pi@raspberrypi:~ $ apt policy grafana grafana: Installed: 9.0.6 Candidate: 9.0.6 Version table: *** 9.0.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 100 /var/lib/dpkg/status 9.0.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 9.0.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 9.0.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 9.0.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 9.0.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 9.0.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.10 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.9 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.5.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.10 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.4.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.10 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.3.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.2.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.8 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.1.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 8.0.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.16 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.15 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.13 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.12 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.11 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.10 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.9 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.8 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.5.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.4.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.4.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.4.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.4.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.4.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.10 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.3.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.2.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.2.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.2.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.1.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 7.0.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.7.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.6.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.6.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.6.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.5.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.5.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.5.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.5.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.4.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.7 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.3.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.2.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.6 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.1.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.0.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.0.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 6.0.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.4.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.3.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.3.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.3.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.3.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.3.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.5 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.4 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.3 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.2 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.1 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages 5.2.0 500 500 https://packages.grafana.com/oss/deb stable/main armhf Packages -
@jason sagte in bekomme Grafana absolut nicht auf Version 8:
stretch
Wie kommt ihr eigentlich immer an diese unpassenden Versionen?
Du fährst da ein Buster, also gehört auch in die influxdb.list buster rein und nicht stretch.Korrigier das!
apt policy grafana*
sorry
pi@raspberrypi:~ $ apt policy grafana* N: Unable to locate package grafana-enterprise_9.0.6_amd64.deb N: Couldn't find any package by glob 'grafana-enterprise_9.0.6_amd64.deb' N: Couldn't find any package by regex 'grafana-enterprise_9.0.6_amd64.deb'Ich hatte das mal nach einem youtube tutorial installiert.
Wenn ich das auf buster ändere passiert dann etwas mit den daten?
War mir fast klar. Gibt es bei dem Shit eigentlich auch vernünftige Anleitungen?
Frag doch mal bei dem Juhtjuber-Eggsperten.
Wenn es gescheit gemacht wird passiert an den Daten nix. Backup hat man aber ja eh.grafana-enterprise hast du auch nach irgendeinem wilden yutube-Murks installiert, stimmt's?
Ja, leider hab ich keine Ahnung mehr was das für ein Video war.. ist ja schon etwas her.
Wie geht es denn gescheit?
Welche möglichkeit hab ich denn mein Grafana wieder zum laufen zu bringen?
Erstmal bringst du deine Repos in Ordnung. Mit der influxdb.list anfangen.
echad@chet:~ $ cat /etc/apt/sources.list.d/influxdb.list deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable -
pi@raspberrypi:~ $ deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable -bash: deb: command not found -
@jason das sollst du nicht eingeben! das müsste als Ergebnis des ersten Befehls rauskommen
Die Zeile muss in deine influxdb.list rein. Ich hab die nur per cat bei mir ausgelesen, damit du siehst was da rein gehört und wo die zu finden ist.
Persudo nano /etc/apt/sources.list.d/influxdb.listkommst du da rein.
ok... ist drin
pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable -
@jason
Ich hoffe auch der key...sudo apt update -
natürlich nicht
wie bekomme ich den?Vielen Dank für Deine Geduld !!!
wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc) echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null -
Boah... es tut mir so leid
pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null pi@raspberrypi:~ $ export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc) pi@raspberrypi:~ $ echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null pi@raspberrypi:~ $ sudo apt update Hit:1 http://archive.raspberrypi.org/debian buster InRelease Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease Hit:3 https://deb.nodesource.com/node_16.x buster InRelease Hit:4 https://packages.grafana.com/oss/deb stable InRelease Hit:5 https://www.pivccu.de/piVCCU stable InRelease Ign:6 https://repos.influxdata.com/raspbian buster InRelease Err:7 https://repos.influxdata.com/raspbian buster Release 404 Not Found [IP: 143.204.89.64 443] Reading package lists... Done E: The repository 'https://repos.influxdata.com/raspbian buster Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. -
Was steht da jetzt drin?
cat /etc/apt/sources.list.d/influxdb.list[Edit:]
Ich seh schon... Mach mal ausraspbianeindebian
