    3. Off Topic
    4. Grafana
    5. bekomme Grafana absolut nicht auf Version 8
      Jason last edited by
      @thomas-braun said in bekomme Grafana absolut nicht auf Version 8:
      deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/debian buster stable
      ok... ist drin
      pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list
        Thomas Braun Most Active @Jason last edited by Thomas Braun
        @jason
        Ich hoffe auch der key...
        sudo apt update
          natürlich nicht 😞
          wie bekomme ich den?
          Vielen Dank für Deine Geduld !!!
            @jason
            wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
            export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
            echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
              Boah... es tut mir so leid
              pi@raspberrypi:~ $ wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdb.gpg > /dev/null
              pi@raspberrypi:~ $ export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
              pi@raspberrypi:~ $ echo "deb [signed-by=/etc/apt/trusted.gpg.d/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
              pi@raspberrypi:~ $ sudo apt update
              Hit:1 http://archive.raspberrypi.org/debian buster InRelease
              Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
              Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
              Hit:4 https://packages.grafana.com/oss/deb stable InRelease
              Hit:5 https://www.pivccu.de/piVCCU stable InRelease
              Ign:6 https://repos.influxdata.com/raspbian buster InRelease
              Err:7 https://repos.influxdata.com/raspbian buster Release
                404  Not Found [IP: 143.204.89.64 443]
              Reading package lists... Done
              E: The repository 'https://repos.influxdata.com/raspbian buster Release' does not have a Release file.
              N: Updating from such a repository can't be done securely, and is therefore disabled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration details.
                @jason
                Was steht da jetzt drin?
                [Edit:]
                Ich seh schon... Mach mal aus raspbian ein debian
                  Ok.. das sieht besser aus 🙂
                  Hit:1 https://packages.grafana.com/oss/deb stable InRelease
                  Hit:2 https://www.pivccu.de/piVCCU stable InRelease
                  Hit:3 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  Get:4 https://repos.influxdata.com/debian buster InRelease [4,737 B]
                  Hit:5 http://archive.raspberrypi.org/debian buster InRelease
                  Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
                  Get:7 https://repos.influxdata.com/debian buster/stable armhf Packages [939 B]
                  Fetched 5,676 B in 2s (3,032 B/s)
                  Building dependency tree
                  All packages are up to date.
                    @jason
                    Dann jetzt nochmal
                    apt policy grafana*
                      apt policy grafana*
                      pi@raspberrypi:~ $ apt policy grafana*
                      N: Unable to locate package grafana-enterprise_9.0.6_amd64.deb
                      N: Couldn't find any package by glob 'grafana-enterprise_9.0.6_amd64.deb'
                      N: Couldn't find any package by regex 'grafana-enterprise_9.0.6_amd64.deb'
                        @jason
                        dpkg -l grafana*
                          Jason last edited by Jason
                          dpkg -l grafana*
                          pi@raspberrypi:~ $ dpkg -l grafana*
                          dpkg-query: no packages found matching grafana-enterprise_9.0.6_amd64.deb
                            @jason
                            Wie kommst du eigentlich an ein amd64-Paket für dein armhf-System? Auch von der yt-Unität?
                            Ich hab keine Ahnung wie man den Mumpitz wieder loswird...
                              keine Ahnung wo das herkommt in der
                              /etc/apt/sources.list.d/grafana.list steht folgendes
                              deb https://packages.grafana.com/oss/deb stable main
                              pi@raspberrypi:/etc/apt $ dpkg --list 'grafana*'
                              Desired=Unknown/Install/Remove/Purge/Hold
                              | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
                              |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
                              ||/ Name               Version      Architecture Description
                              ii  grafana            9.0.6        armhf        Grafana
                              rc  grafana-enterprise 7.0.0        armhf        Grafana
                              wieso steht die enterprise 7.0.0 immer noch drin?
                                @jason
                                rc = removal / config
                                Heißt, das Paket ist bis auf die config-Dateien entfernt worden.
                                Dein Problem ist aber eh grafana-enterprise_9.0.6_amd64.deb
                                  @jason said in bekomme Grafana absolut nicht auf Version 8:
                                  dpkg -l grafana*
                                  jetzt steht nix mehr von amd64 drin!!
                                    @jason
                                    apt policy grafana*
                                      apt policy grafana*
                                      grafana-enterprise-rpi:
                                        Installed: (none)
                                        Candidate: 7.0.0
                                        Version table:
                                           7.0.0 500
                                              500 https://packages.grafana.com/oss/deb stable/main armhf Packages
                                      grafana-zabbix:
                                        Installed: (none)
                                        Candidate: 2.5.1-1
                                        Version table:
                                           2.5.1-1 500
                                      grafana-enterprise:
                                        Installed: (none)
                                        Candidate: 7.0.0
                                        Version table:
                                           7.0.0 500
                                              100 /var/lib/dpkg/status
                                      grafana:
                                        Installed: 9.0.6
                                        Candidate: 9.0.6
                                        Version table:
                                       *** 9.0.6 500
                                           9.0.5 500
                                           9.0.4 500
                                           9.0.3 500
                                           9.0.2 500
                                           9.0.1 500
                                           9.0.0 500
                                           8.5.10 500
                                           8.5.9 500
                                           8.5.6 500
                                           8.5.5 500
                                           8.5.4 500
                                           8.5.3 500
                                           8.5.2 500
                                           8.5.1 500
                                           8.5.0 500
                                           8.4.10 500
                                           8.4.7 500
                                           8.4.6 500
                                           8.4.5 500
                                           8.4.4 500
                                           8.4.3 500
                                           8.4.2 500
                                           8.4.1 500
                                           8.4.0 500
                                           8.3.10 500
                                           8.3.7 500
                                           8.3.6 500
                                           8.3.5 500
                                           8.3.4 500
                                           8.3.3 500
                                           8.3.2 500
                                           8.3.1 500
                                           8.3.0 500
                                           8.2.7 500
                                           8.2.6 500
                                           8.2.5 500
                                           8.2.4 500
                                           8.2.3 500
                                           8.2.2 500
                                           8.2.1 500
                                           8.2.0 500
                                           8.1.8 500
                                           8.1.7 500
                                           8.1.6 500
                                           8.1.5 500
                                           8.1.4 500
                                           8.1.3 500
                                           8.1.2 500
                                           8.1.1 500
                                           8.1.0 500
                                           8.0.7 500
                                           8.0.6 500
                                           8.0.5 500
                                           8.0.4 500
                                           8.0.3 500
                                           8.0.2 500
                                           8.0.1 500
                                           8.0.0 500
                                           7.5.16 500
                                           7.5.15 500
                                           7.5.13 500
                                           7.5.12 500
                                           7.5.11 500
                                           7.5.10 500
                                           7.5.9 500
                                           7.5.8 500
                                           7.5.7 500
                                           7.5.6 500
                                           7.5.5 500
                                           7.5.4 500
                                           7.5.3 500
                                           7.5.2 500
                                           7.5.1 500
                                           7.5.0 500
                                           7.4.5 500
                                           7.4.3 500
                                           7.4.2 500
                                           7.4.1 500
                                           7.4.0 500
                                           7.3.10 500
                                           7.3.7 500
                                           7.3.6 500
                                           7.3.5 500
                                           7.3.4 500
                                           7.3.3 500
                                           7.3.2 500
                                           7.3.1 500
                                           7.3.0 500
                                           7.2.2 500
                                           7.2.1 500
                                           7.2.0 500
                                           7.1.5 500
                                           7.1.4 500
                                           7.1.3 500
                                           7.1.2 500
                                           7.1.1 500
                                           7.1.0 500
                                           7.0.6 500
                                           7.0.5 500
                                           7.0.4 500
                                           7.0.3 500
                                           7.0.2 500
                                           7.0.1 500
                                           7.0.0 500
                                           6.7.6 500
                                           6.7.5 500
                                           6.7.4 500
                                           6.7.3 500
                                           6.7.2 500
                                           6.7.1 500
                                           6.7.0 500
                                           6.6.2 500
                                           6.6.1 500
                                           6.6.0 500
                                           6.5.3 500
                                           6.5.2 500
                                           6.5.1 500
                                           6.5.0 500
                                           6.4.5 500
                                           6.4.4 500
                                           6.4.3 500
                                           6.4.2 500
                                           6.4.1 500
                                           6.4.0 500
                                           6.3.7 500
                                           6.3.6 500
                                           6.3.5 500
                                           6.3.4 500
                                           6.3.3 500
                                           6.3.2 500
                                           6.3.1 500
                                           6.3.0 500
                                           6.2.5 500
                                           6.2.4 500
                                           6.2.3 500
                                           6.2.2 500
                                           6.2.1 500
                                           6.2.0 500
                                           6.1.6 500
                                           6.1.5 500
                                           6.1.4 500
                                           6.1.3 500
                                           6.1.2 500
                                           6.1.1 500
                                           6.1.0 500
                                           6.0.2 500
                                           6.0.1 500
                                           6.0.0 500
                                           5.4.5 500
                                           5.4.4 500
                                           5.4.3 500
                                           5.4.2 500
                                           5.4.1 500
                                           5.4.0 500
                                           5.3.4 500
                                           5.3.3 500
                                           5.3.2 500
                                           5.3.1 500
                                           5.3.0 500
                                           5.2.5 500
                                           5.2.4 500
                                           5.2.3 500
                                           5.2.2 500
                                           5.2.1 500
                                           5.2.0 500
                                      grafana-rpi:
                                        Installed: (none)
                                        Candidate: 7.4.0
                                        Version table:
                                           7.4.0 500
                                           7.3.3 500
                                           7.3.2 500
                                           7.3.1 500
                                           7.3.0 500
                                           7.2.2 500
                                           7.2.1 500
                                           7.2.0 500
                                           7.1.5 500
                                           7.1.4 500
                                           7.1.3 500
                                           7.1.2 500
                                           7.1.1 500
                                           7.1.0 500
                                           7.0.6 500
                                           7.0.5 500
                                           7.0.4 500
                                           7.0.3 500
                                           7.0.2 500
                                           7.0.1 500
                                           7.0.0 500
                                           6.7.6 500
                                           6.7.4 500
                                           6.7.3 500
                                           6.7.2 500
                                           6.7.1 500
                                           6.7.0 500
                                           6.6.2 500
                                           6.6.1 500
                                           6.6.0 500
                                           6.5.3 500
                                           6.5.2 500
                                           6.5.1 500
                                           6.5.0 500
                                           6.4.5 500
                                           6.4.4 500
                                           6.4.3 500
                                           6.4.2 500
                                           6.4.1 500
                                           6.4.0 500
                                           6.3.7 500
                                           6.3.6 500
                                           6.3.5 500
                                           6.3.4 500
                                           6.3.3 500
                                           6.3.2 500
                                           6.3.1 500
                                           6.3.0 500
                                           6.2.5 500
                                           6.2.4 500
                                           6.2.3 500
                                           6.2.2 500
                                           6.2.1 500
                                           6.2.0 500
                                           6.1.6 500
                                           6.1.5 500
                                           6.1.4 500
                                           6.1.3 500
                                           6.1.2 500
                                           6.1.1 500
                                           6.1.0 500
                                      pi@raspberrypi:~ $
                                        @jason
                                        Das müsste jetzt sauber sein.
                                          ok, wie gehts weiter? weil laufen tut es noch nicht 😞
                                            @jason sagte in bekomme Grafana absolut nicht auf Version 8:
                                            Heißt?
                                            systemctl status grafana-server
                                            1.4k
                                            5443
