    4. MieleCloudService Adapter
      Hag-En last edited by
      @Grizzelbee
      Seit gestern sieht es bei mir so aus wenn ich den Adapter neu starte:
      2022-08-09 08:33:45.004  - info: host.iobroker instance system.adapter.mielecloudservice.0 started with pid 23619
      2022-08-09 08:33:46.192  - info: mielecloudservice.0 (23619) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2022-08-09 08:33:46.271  - info: mielecloudservice.0 (23619) starting. Version 6.3.4 in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v16.16.0, js-controller: 4.0.23
      2022-08-09 08:33:46.284  - info: mielecloudservice.0 (23619) Login attempt #1 @Miele-API
      2022-08-09 08:33:46.666  - info: mielecloudservice.0 (23619) Access token expires on: 8.9.2022, 08:33:00
      2022-08-09 08:33:46.666  - info: mielecloudservice.0 (23619) Registering for all appliance events at Miele API.
      2022-08-09 08:33:46.668  - info: mielecloudservice.0 (23619) Initializing SSE watchdog.
      2022-08-09 08:33:46.760  - info: mielecloudservice.0 (23619) Server Sent Events-Connection has been established @Miele-API.
      2022-08-09 08:33:46.818  - error: mielecloudservice.0 (23619) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-08-09 08:33:46.818  - error: mielecloudservice.0 (23619) unhandled promise rejection: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.819  - error: mielecloudservice.0 (23619) Error: The id "000150727836." is invalid. Ids are not allowed to end in "."
          at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:148:23)
          at Mielecloudservice.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5743:23)
          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.mielecloudservice/source/mieleTools.js:1922:68)
          at processImmediate (node:internal/timers:468:21)
      2022-08-09 08:33:46.819  - error: mielecloudservice.0 (23619) The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.820  - error: mielecloudservice.0 (23619) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-08-09 08:33:46.820  - error: mielecloudservice.0 (23619) unhandled promise rejection: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.820  - error: mielecloudservice.0 (23619) Error: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.820  - error: mielecloudservice.0 (23619) The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.821  - error: mielecloudservice.0 (23619) Error: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.821  - error: mielecloudservice.0 (23619) The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.821  - error: mielecloudservice.0 (23619) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2022-08-09 08:33:46.821  - error: mielecloudservice.0 (23619) unhandled promise rejection: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.822  - error: mielecloudservice.0 (23619) Error: The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.822  - error: mielecloudservice.0 (23619) The id "000150727836." is invalid. Ids are not allowed to end in "."
      2022-08-09 08:33:46.826  - info: mielecloudservice.0 (23619) terminating
      2022-08-09 08:33:46.826  - warn: mielecloudservice.0 (23619) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-08-09 08:33:47.363  - error: host.iobroker instance system.adapter.mielecloudservice.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      Ich habe bereits diverse Versions-Kombinationen probiert - auch alles gelöscht und Adapter sowie Instanz neu hinzugefügt und parametrisiert. Das Login scheint ja zu funktionieren, aber irgendwo fällt er auf die Nase...
      Grizzelbee 1 Reply Last reply Reply Quote 0
        Hag-En @Gargano last edited by
        @gargano
        Da haben wir uns wohl überschnitten mit der Meldung 😉
          MarkA @Hag-En last edited by MarkA
          Moin,
          bei mir das gleiche Problem...
          mielecloudservice.0
          2022-08-09 09:52:18.215	error	Error: The id "mac-00124B000E0C6D06." is invalid. Ids are not allowed to end in "." at Utils.validateId (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/utils.js:148:23) at Mielecloudservice.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5743:23) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.mielecloudservice/source/mieleTools.js:1922:68) at processImmediate (node:internal/timers:468:21)
          mielecloudservice.0
          2022-08-09 09:52:18.211	error	unhandled promise rejection: The id "mac-00124B000E0C6D06." is invalid. Ids are not allowed to end in "."
          mielecloudservice.0
          2022-08-09 09:52:18.210	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          In dem Fall ein Gerät welches hinter einem XGW3000 Gateway hängt.
          • Grizzelbee
            Grizzelbee Developer @MarkA last edited by
            @marka , @Gargano , @Hag-En
            Ich habe hier das Selbe Problem.
            Bei so vielen gleichzeitig Betroffenen schätze ich mal das es ein Problem auf der Seite von Miele ist, oder die etwas umgestellt haben.
            Ich gucke mir das aber mal genauer an...
            • Grizzelbee
              Grizzelbee Developer @Hag-En last edited by Grizzelbee
              @marka , @Gargano , @Hag-En, @Sticks65
              Das Problem liegt wie vermutet in der Miele-API.
              Die Felder für die lokalisierten Feldnamen und -Werte werden plötzlich nicht mehr befüllt.
              Ich habe Miele eine Mail geschrieben und um Klärung gebeten ob das jetzt so bleibt, oder ob die das fixen.
              Wir müssen also erstmal abwarten.
              https://github.com/Grizzelbee/ioBroker.mielecloudservice/issues/281
                michael 1975 last edited by
                ich habe das Problem auch, dann warten wir mal was Miele sagt.
                caravandriver 1 Reply Last reply Reply Quote 0
                • caravandriver
                  caravandriver @michael 1975 last edited by
                  @michael-1975 Hier auch...
                  • Grizzelbee
                    Grizzelbee Developer @caravandriver last edited by Grizzelbee
                    @caravandriver, @michael-1975, @marka , @Gargano , @Hag-En, @Sticks65
                    Neue Erkenntnisse von heute morgen:
                    • Miele hat mir geantwortet und guckt sich das Problem gerade an.
                    • Es ist "nur" SSE betroffen -> Data-Polling funktioniert! (schon seltsam) 🙂
                    • Es scheinen alle Sprachlokalisierungen betroffen zu sein; Deutsch und Englisch habe ich selbst als fehlerhaft getestet.
                    EDIT/Update@09:27 :
                    Hallo grizzelbee,
                    nochmal Danke für Deine Mail. Unser Dev-Team hat den Bug in der SSE Lokalisierung bestätigt und arbeitet an der Abstellung.
                    Kind regards
                    Miele 3rd party API Team
                    H M 2 Replies Last reply Reply Quote 0
                      Hag-En @Grizzelbee last edited by
                      @grizzelbee
                      Läuft wieder...! Miele hat es wohl repariert 🙂
                      • O
                        oxident last edited by
                        @Grizzelbee Vielleicht wäre es eine gute Idee, diese Art von Fehler abzufangen und selbständig auf Polling umzuschalten. Wer weiß, vielleicht passiert das ja nochmal?
                          MarkA @Grizzelbee last edited by
                          @grizzelbee
                          Bei mir auch wieder in Ordnung. Danke fürs kümmern! 🙂
                          Gruß Mark
                          • Grizzelbee
                            Grizzelbee Developer @oxident last edited by
                            @oxident sagte in MieleCloudService Adapter:
                            Hmmm. 🤔
                            Weiß nicht so recht. Diesmal war Polling zufällig in Ordnung. Beim nächsten mal könnte das anders sein. Und wenn schon failover, dann in beide Richtungen. Also SSE->Polling und Polling->SSE. Aber dann hat man ganz fix eine Endlosschleife. Und das Ganze dann für alle möglichen Fehlersituationen, die Miele da so passieren könnten.
                            Das ist ein Fass ohne Boden.
                            Ich denke noch mal ein bisschen drüber nach.
                            O S 2 Replies Last reply Reply Quote 0
                            • O
                              oxident @Grizzelbee last edited by
                              @grizzelbee said in MieleCloudService Adapter:
                              Definitiv. So hatte ich das noch gar nicht gesehen 😉
                              Naja, einmal ist vielleicht auch kein Mal...
                                schweiger2 @Grizzelbee last edited by
                                @grizzelbee
                                Jetzt ist alles wieder schön und die Herzdame weiß, wann die WaMa fertig ist.
                                Vielen Dank für die Kommunikation mit Miele.
                                  deta Most Active last edited by
                                  Mh bei mir geht es immer noch nicht.
                                  Bekomme den Fehler
                                  mielecloudservice.0
                                  2022-08-10 21:21:13.399	error	Error: Unable to authenticate user! Your credentials seem to be invalid. Please double check and fix them.
                                  Was hier los? Hab gerade extra noch mal die Zugangsdaten neu eingeben.
                                  Passen.
                                  • Grizzelbee
                                    Grizzelbee Developer @deta last edited by
                                    @deta
                                    Ohne weitere Infos kann ich da nicht viel zu sagen.
                                    Versionsnummern des Adapters und Admin sind da schon Minimum.
                                    Aber der Adapter loggt in diesem Fall ja die verwendeten Credentials im Klartext aus - stimmen die denn?
                                      gyle last edited by
                                      eine Frage, da ich nicht ewig recherchieren möchte:
                                      welche Möglichkeit gäbe es auf die Cloud zu verzichten? würde das mit diesem Miele Gateway gehen?
                                      hat das jmd. im Einsatz und kann dazu berichten?
                                      • Grizzelbee
                                        Grizzelbee Developer @gyle last edited by
                                        @gyle
                                        Ich habe selbst kein Gateway - deshalb ist das hier nur das was ich aufgeschnappt habe:
                                        Ja - es gibt das XGW3000 Gateway - was nach meinem Verständnis ein Zigbee2LAN Gateway ist. Das ist dem Anschein nach in der Lage rein lokal - also ohne Cloud - zu operieren (Das macht dann der Miele-Adapter von @soef [https://github.com/soef/ioBroker.miele]). Aber eben auch nur mit den Miele-Zigbee-Geräten - nicht mit den WLAN-Geräten. Ich weiß nicht ob überhaupt noch neue Geräte für das Gateway herauskommen (also ob neue Modelle wahlweise mit WLAN oder Zigbee gebaut werden).
                                        Im wesentlichen scheint Miele aus meiner Sicht eher die Cloud Strategie zu fahren. Wobei ich durch die API da keine Probleme mit habe. Ich weiß ja welche Daten so abfließen 😉 - nämlich außer der IP und das der Nutzer ioBroker nutzt keine, die Miele nicht ohnehin schon hätte.
                                          deta Most Active @Grizzelbee last edited by
                                          @grizzelbee sagte in MieleCloudService Adapter:
                                          @deta
                                          Sorry, Aktuelle Version Installierte Version: 6.3.4
                                          Admin nstallierte Version: 6.2.14
                                            gyle @Grizzelbee last edited by gyle
                                            Danke.
                                            ich mache mir weniger Sorgen um Daten die abfließen - mir geht es darum einen stabilen Betrieb zu gewährleisten.
                                            Cloud unterliegt ja auch einem permanentem Wandel/Anpassungsbedarf usw...
                                            Und ich hatte jetzt schon mehrmals den Fall, dass dadurch meine Benachrichtigungen nicht mehr ankamen...
                                            miele mieleathome mielecloudservice
                                            90
                                            849
                                            203685
