Problem mit Adapter updates
@marcus-hamburg sagte in Problem mit Adapter updates:
Ich starte Java update
was ist das?
hier bleibt man dann stecken
und wie sieht der Konsolen in und output wirklich aus?
Was mache ich den falsch?
@homoran nach den Start des Java updates passiert nichts mehr
Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Aug 10 09:28:36 2022 from 192.168.178.5 pi@raspberrypi:~ $ sudo reboot Connection to 192.168.178.21 closed by remote host. Connection to 192.168.178.21 closed. marcus@PC-Mac-Mini ~ % 20211019_Ruck Zuck Gas Neue Pr zsh: command not found: 20211019_Ruck marcus@PC-Mac-Mini ~ % ssh pi@192.168.178.21 pi@192.168.178.21's password: Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Aug 10 09:45:28 2022 pi@raspberrypi:~ $ node -v v14.20.0 pi@raspberrypi:~ $ iob stop pi@raspberrypi:~ $ iob fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:2 http://archive.raspberrypi.org/debian buster InRelease OK:3 https://deb.nodesource.com/node_14.x buster InRelease Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@raspberrypi:~ $ iob update Used repository: stable Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.4.10 , installed 2.3.3 [Updatable] Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.5 , installed 3.0.3 [Updatable] Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "hmip" : 1.18.0 , installed 1.15.4 [Updatable] Adapter "hue" : 3.7.0 , installed 3.6.5 [Updatable] Adapter "ical" : 1.13.1 , installed 1.11.4 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.8 [Updatable] Adapter "javascript" : 5.7.0 , installed 5.2.13 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "openweathermap": 0.2.5 , installed 0.2.5 Adapter "renault" : 0.0.13 , installed 0.0.13 Adapter "ring" : 3.0.4 , installed 3.0.4 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "trashschedule": 2.0.2 , installed 1.4.1 [Updatable] Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iob upgrade This upgrade of "javascript" will at least introduce the following changes: ========================================================================== -> 5.7.0: Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage)) Lists returned by $-selector are now unified and do not contain double entries Fix subscribe multiple object ID lists in blockly -> 5.6.1: Allow to subscribe multiple object ID lists in blockly -> 5.6.0: Make state properties c(omment) and user available to scripts too make sure values of new or changed alias objects are initialized properly Enhance scheduler logic and astro events offered by wizard Respect expected value changes when determining if a value is changed Fix remembering intermediate state values when state values are subscribed fix setState logic when states are not subscribed -> 5.5.4: Tried to solve problem with the font -> 5.5.3: Fixed getObjectAsync function if object does not exist -> 5.5.2: Added new rules action block: sum two states (or minus) -> 5.5.1: Added new rules action block: sum two states (or minus) ========================================================================== Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: y Update javascript from @5.2.13 to @5.7.0 NPM version: 6.14.17 Installing iobroker.javascript@5.7.0... (System call) -
Zeige mal die Ausgabe von :
sudo ln -s /usr/bin/node /usr/bin/nodejs uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs -
@marcus-hamburg was für ein PI und wie lange gewartet?
Danke an alle. Ich hab nicht genug Geduld gehabt. Die Adapter sind am updaten. Danke
Deine Grundfrage war das ...
und die einzelnen Adapter verlangen:
Backup Node >=12
discovery Node >=14
hmip Node >=10
hue node >=10
java node >=10Was mache ich den falsch?
und jetzt :
.... denn , das wäre dann was anderes !?
Wie kommst du denn auf ... :
bei keinen Adapter aufgrund der verschiedenen NodeJS Versionen.
hast du dazu Meldungen im Log gehabt oder ... !?
@glasfaser Ja in der Admin Maske konnte ich die Aktualisierungen nicht starten, dort wurde die jeweils mit den verschiedenen Node Versionen so angezeigt. Ein update über das Terminal funktioniert jetzt, war nur nicht geduldig genug.
Gegencheck mit
uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejssagt?
@thomas-braun vielleicht ohne nodejs.
Dann siehst du aber nicht die üblichen doppel- oder gar dreifach Installationen.
@thomas-braun sagte in Problem mit Adapter updates:
Bei mir kommt
nodejs -bash: nodejs: Kommando nicht gefunden. -
@thomas-braun ok - danke für Aufklärung
pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs armv7l /usr/bin/nodejs /usr/bin/node /usr/bin/npm v14.20.0 v14.20.0 6.14.17 pi /home/pi OK:1 http://archive.raspberrypi.org/debian buster InRelease OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:3 https://deb.nodesource.com/node_14.x buster InRelease Paketlisten werden gelesen... Fertig Abhängigkeitsbaum wird aufgebaut. Statusinformationen werden eingelesen.... Fertig Aktualisierung für 110 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen. nodejs: Installiert: 14.20.0-deb-1nodesource1 Installationskandidat: 14.20.0-deb-1nodesource1 Versionstabelle: *** 14.20.0-deb-1nodesource1 500 500 https://deb.nodesource.com/node_14.x buster/main armhf Packages 100 /var/lib/dpkg/status 10.24.0~dfsg-1~deb10u1 500 500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages -
Halt dein System aktuell! Bei 110 Paketen ist das ewig nicht mehr (bzw. noch nie) gemacht worden.
iobroker stop sudo apt update sudo apt full-upgrade sudo rebootKünftig regelmäßig machen!
Und ein Upgrade auf die empfohlene nodejs@16 würde ich auch anraten.
@thomas-braun nodejs@16 installiert, Paket installiert, nur die Adapter lassen sich nicht updaten. Ich verzweifle schon wieder an mir.
Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Wed Aug 10 20:08:59 2022 pi@raspberrypi:~ $ iob stop pi@raspberrypi:~ $ iob fix library: loaded Library version=2022-06-15 ========================================================================== Welcome to the ioBroker installation fixer! Script version: 2022-06-03 You might need to enter your password a couple of times. ========================================================================== ========================================================================== Installing prerequisites (1/3) ========================================================================== OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease OK:2 http://archive.raspberrypi.org/debian buster InRelease OK:3 https://deb.nodesource.com/node_16.x buster InRelease Paketlisten werden gelesen... Fertig Installed gcc-c++ ========================================================================== Checking ioBroker user and directory permissions (2/3) ========================================================================== Created /etc/sudoers.d/iobroker Fixing directory permissions... ========================================================================== Checking autostart (3/3) ========================================================================== Enabling autostart... Autostart enabled! ========================================================================== Your installation was fixed successfully Run iobroker start to start ioBroker again! ========================================================================== pi@raspberrypi:~ $ iob update Used repository: stable Adapter "admin" : 5.3.8 , installed 5.3.8 Adapter "alexa2" : 3.11.2 , installed 3.11.2 Adapter "backitup" : 2.4.10 , installed 2.3.3 [Updatable] Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.5 , installed 3.0.3 [Updatable] Adapter "habpanel" : 0.5.0 , installed 0.5.0 Adapter "hmip" : 1.18.0 , installed 1.15.4 [Updatable] Adapter "hue" : 3.7.0 , installed 3.6.5 [Updatable] Adapter "ical" : 1.13.1 , installed 1.11.4 [Updatable] Adapter "info" : 1.9.19 , installed 1.9.8 [Updatable] Adapter "javascript" : 5.7.0 , installed 5.2.13 [Updatable] Controller "js-controller": 4.0.23 , installed 4.0.23 Adapter "mihome" : 1.4.0 , installed 1.4.0 Adapter "openweathermap": 0.2.5 , installed 0.2.5 Adapter "renault" : 0.0.13 , installed 0.0.13 Adapter "ring" : 3.0.4 , installed 3.0.4 Adapter "simple-api" : 2.7.0 , installed 2.7.0 Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "trashschedule": 2.0.2 , installed 1.4.1 [Updatable] Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iob upgrade This upgrade of "javascript" will at least introduce the following changes: ========================================================================== -> 5.7.0: Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage)) Lists returned by $-selector are now unified and do not contain double entries Fix subscribe multiple object ID lists in blockly -> 5.6.1: Allow to subscribe multiple object ID lists in blockly -> 5.6.0: Make state properties c(omment) and user available to scripts too make sure values of new or changed alias objects are initialized properly Enhance scheduler logic and astro events offered by wizard Respect expected value changes when determining if a value is changed Fix remembering intermediate state values when state values are subscribed fix setState logic when states are not subscribed -> 5.5.4: Tried to solve problem with the font -> 5.5.3: Fixed getObjectAsync function if object does not exist -> 5.5.2: Added new rules action block: sum two states (or minus) -> 5.5.1: Added new rules action block: sum two states (or minus) ========================================================================== Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: n No upgrade of "javascript" desired. This upgrade of "info" will at least introduce the following changes: ========================================================================== -> 1.9.19: Fix audio, USB, bluetooth and printer view -> 1.9.18: Fix invalid object definition to prevent errors in js-controller 4 -> 1.9.17: Design fix Update dependencies -> 1.9.16: Update dependencies Fix translations -> 1.9.15: Design fix for react-dark theme -> 1.9.10: Adjust some actions to prevent js-controller 3.3 warnings -> 1.9.9: update library to prevent some errors Adjust some actions to prevent js-controller 3.3 warnings ========================================================================== Would you like to upgrade info from @1.9.8 to @1.9.19 now? [(y)es, (n)o]: y Update info from @1.9.8 to @1.9.19 NPM version: 8.11.0 Installing iobroker.info@1.9.19... (System call) host.raspberrypi Cannot install iobroker.info@1.9.19: 217 pi@raspberrypi:~ $ -
@marcus-hamburg mach mal ein einzelupgrade nit debug
iobroker upgrade javascript --debugund wieder alles posten
pi@raspberrypi:~ $ iobroker upgrade javascript --debug This upgrade of "javascript" will at least introduce the following changes: ========================================================================== -> 5.7.0: Allow sending of messages to scripts also from adapters and CLI by sending "toScript" message (see [onMessage Documentation](https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md#onmessage)) Lists returned by $-selector are now unified and do not contain double entries Fix subscribe multiple object ID lists in blockly -> 5.6.1: Allow to subscribe multiple object ID lists in blockly -> 5.6.0: Make state properties c(omment) and user available to scripts too make sure values of new or changed alias objects are initialized properly Enhance scheduler logic and astro events offered by wizard Respect expected value changes when determining if a value is changed Fix remembering intermediate state values when state values are subscribed fix setState logic when states are not subscribed -> 5.5.4: Tried to solve problem with the font -> 5.5.3: Fixed getObjectAsync function if object does not exist -> 5.5.2: Added new rules action block: sum two states (or minus) -> 5.5.1: Added new rules action block: sum two states (or minus) ========================================================================== Would you like to upgrade javascript from @5.2.13 to @5.7.0 now? [(y)es, (n)o]: y Update javascript from @5.2.13 to @5.7.0 NPM version: 8.11.0 Installing iobroker.javascript@5.7.0... (System call) npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /opt/iobroker/node_modules/iobroker.javascript npm ERR! dest /opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript' -> '/opt/iobroker/node_modules/.iobroker.javascript-5NZ432mn' npm ERR! A complete log of this run can be found in: npm ERR! /home/iobroker/.npm/_logs/2022-08-10T18_29_21_627Z-debug-0.log host.raspberrypi Cannot install iobroker.javascript@5.7.0: 217 pi@raspberrypi:~ $ -
Du kannst das hier nutzen
https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2cd /opt/iobroker/node_modules for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; doneZitat aus dem Thread :
WICHTIG .
(Bitte Befehl KOPIEREN, nicht eintippen, ein Vertipper kann und wird da 'tödlich' sein).
oha, dazu gibt es einige Threads
lösung hier suchen
https://forum.iobroker.net/post/460759
