    4. HS100 Adapter startet alle 30 Sekunden neu
    UNSOLVED HS100 Adapter startet alle 30 Sekunden neu
      Homoran Global Moderator Administrators @frank62 last edited by
      @frank62 sagte in HS100 Adapter startet alle 30 Sekunden neu:
      Weil ich die selben Probleme habe....
      mit welcher Version?
      was steht bei dir im log?
      Hast du den Host komplett neu gestartet?
      oder hast du den doppelten Prozess sauber gekillt?
        frank62 @Homoran last edited by
        @homoran said in HS100 Adapter startet alle 30 Sekunden neu:
        Ich starte meist dann den PI neu, wo der IObroker drauf ist, oder stoppe den Adapter und starte neu.
        Beide Varianten helfen nicht auf dauer.
        raspberrypi
        Plattform: linux
        RAM: 7.5 GB
        Node.js: v14.20.0
        NPM: 6.14.17
        99+30
        Log-Größe: 30.2 KB
        PID
        Zeit
        Nachricht
        hs100.1
        	186235	2022-08-07 12:11:44.183	warn	get state error: Connection is closed.
        hs100.1
        	186235	2022-08-07 12:11:44.183	warn	Could not perform strict object check of state hs100.1.192_168_178_91.ledState: DB closed
        hs100.1
        	186235	2022-08-07 12:11:44.182	warn	get state error: Connection is closed.
        hs100.1
        	186235	2022-08-07 12:11:44.182	warn	Could not perform strict object check of state hs100.1.192_168_178_91.voltage: DB closed
        hs100.1
        	186235	2022-08-07 12:11:44.181	warn	get state error: Connection is closed.
        hs100.1
        	186235	2022-08-07 12:11:44.180	warn	Could not perform strict object check of state hs100.1.192_168_178_91.power: DB closed
        hs100.1
        	186235	2022-08-07 12:11:44.179	warn	get state error: Connection is closed.
        hs100.1
        	186235	2022-08-07 12:11:44.178	warn	Could not perform strict object check of state hs100.1.192_168_178_91.current: DB closed
        hs100.1
        	186235	2022-08-07 12:11:43.659	info	Terminated (NO_ERROR): Without reason
        hs100.1
        	186235	2022-08-07 12:11:43.657	info	terminating
        hs100.1
        	186235	2022-08-07 12:11:43.651	info	Got terminate signal TERMINATE_YOURSELF
        hs100.1
        	186235	2022-08-07 12:11:43.642	info	cleaned everything up...
        hs100.1
        	186235	2022-08-07 12:11:43.640	info	Adapter is disabled => stop
        hs100.1
        	186235	2022-08-07 12:11:43.583	info	Start with IP : 192.168.178.172
        hs100.1
        	186235	2022-08-07 12:11:43.500	info	Start with IP : 192.168.178.91
        hs100.1
        	186235	2022-08-07 12:11:43.459	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	186175	2022-08-07 12:11:39.508	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        hs100.1
        	186175	2022-08-07 12:11:39.507	info	terminating
        hs100.1
        	186175	2022-08-07 12:11:39.136	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	186175	2022-08-07 12:11:39.003	info	Got terminate signal TERMINATE_YOURSELF
        hs100.1
        	176369	2022-08-07 10:00:18.846	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	176369	2022-08-07 10:00:18.843	info	terminating
        hs100.1
        	176369	2022-08-07 10:00:18.840	info	cleaned everything up...
        hs100.1
        	176369	2022-08-07 10:00:18.835	warn	Info Message setDevice: Error: TCP Timeout after 10000ms192.168.178.172:9999 {"system":{"get_sysinfo":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	176369	2022-08-07 10:00:18.821	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	176369	2022-08-07 10:00:18.819	error	Error: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	176369	2022-08-07 10:00:18.817	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	176369	2022-08-07 10:00:18.815	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.1
        	176369	2022-08-07 09:54:58.778	info	Start with IP : 192.168.178.172
        hs100.1
        	176369	2022-08-07 09:54:58.567	info	Start with IP : 192.168.178.91
        hs100.1
        	176369	2022-08-07 09:54:58.529	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	176307	2022-08-07 09:54:26.386	warn	Info Message setDevice: Error: TCP Timeout after 10000ms192.168.178.172:9999 {"system":{"get_sysinfo":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	176307	2022-08-07 09:54:26.379	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	176307	2022-08-07 09:54:26.378	info	terminating
        hs100.1
        	176307	2022-08-07 09:54:26.376	info	cleaned everything up...
        hs100.1
        	176307	2022-08-07 09:54:26.370	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	176307	2022-08-07 09:54:26.369	error	Error: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	176307	2022-08-07 09:54:26.369	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	176307	2022-08-07 09:54:26.367	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.1
        	176307	2022-08-07 09:54:00.401	info	Start with IP : 192.168.178.172
        hs100.1
        	176307	2022-08-07 09:54:00.273	info	Start with IP : 192.168.178.91
        hs100.1
        	176307	2022-08-07 09:54:00.236	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	173698	2022-08-07 09:53:28.092	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	173698	2022-08-07 09:53:28.090	info	terminating
        hs100.1
        	173698	2022-08-07 09:53:28.088	info	cleaned everything up...
        hs100.1
        	173698	2022-08-07 09:53:28.083	warn	Info Message setDevice: Error: TCP Timeout after 10000ms192.168.178.172:9999 {"system":{"get_sysinfo":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	173698	2022-08-07 09:53:28.072	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	173698	2022-08-07 09:53:28.070	error	Error: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	173698	2022-08-07 09:53:28.069	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	173698	2022-08-07 09:53:28.066	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.1
        	173698	2022-08-07 09:35:51.709	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	173698	2022-08-07 09:29:21.692	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	173698	2022-08-07 09:17:51.658	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	173698	2022-08-07 09:17:38.540	info	Start with IP : 192.168.178.172
        hs100.1
        	173698	2022-08-07 09:17:38.330	info	Start with IP : 192.168.178.91
        hs100.1
        	173698	2022-08-07 09:17:38.279	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	145909	2022-08-07 09:17:06.039	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	145909	2022-08-07 09:17:06.037	info	terminating
        hs100.1
        	145909	2022-08-07 09:17:06.035	info	cleaned everything up...
        hs100.1
        	145909	2022-08-07 09:17:06.027	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	145909	2022-08-07 09:17:06.026	error	Error: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	145909	2022-08-07 09:17:06.024	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	145909	2022-08-07 09:17:06.022	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.1
        	145909	2022-08-07 08:58:35.037	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:53:57.592	warn	getDevice Socket connection Timeout ip: 192.168.178.91 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:53:34.516	warn	getDevice Socket connection Timeout ip: 192.168.178.91 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:45:27.555	warn	getDevice Socket connection Timeout ip: 192.168.178.91 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:45:04.490	warn	getDevice Socket connection Timeout ip: 192.168.178.91 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:28:34.448	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	145909	2022-08-07 05:28:34.444	warn	getDevice Socket connection Timeout ip: 192.168.178.91 please reconnect the Device
        hs100.1
        	145909	2022-08-07 04:31:04.282	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	145909	2022-08-07 04:30:04.284	warn	getDevice Socket connection Timeout ip: 192.168.178.172 please reconnect the Device
        hs100.1
        	145909	2022-08-07 02:12:53.731	info	Start with IP : 192.168.178.172
        hs100.1
        	145909	2022-08-07 02:12:53.536	info	Start with IP : 192.168.178.91
        hs100.1
        	145909	2022-08-07 02:12:53.498	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	145514	2022-08-07 02:12:21.329	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	145514	2022-08-07 02:12:21.326	info	terminating
        hs100.1
        	145514	2022-08-07 02:12:21.323	info	cleaned everything up...
        hs100.1
        	145514	2022-08-07 02:12:21.309	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	145514	2022-08-07 02:12:21.308	error	Error: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}} at Timeout._onTimeout (/opt/iobroker/node_modules/tplink-smarthome-api/lib/network/tcp-socket.js:59:36) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
        hs100.1
        	145514	2022-08-07 02:12:21.306	error	unhandled promise rejection: TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_realtime":{}}}
        hs100.1
        	145514	2022-08-07 02:12:21.303	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        hs100.1
        	145514	2022-08-07 02:09:39.402	info	Start with IP : 192.168.178.172
        hs100.1
        	145514	2022-08-07 02:09:39.232	info	Start with IP : 192.168.178.91
        hs100.1
        	145514	2022-08-07 02:09:39.187	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
        hs100.1
        	130883	2022-08-07 02:09:06.790	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        hs100.1
        	130883	2022-08-07 02:09:06.789	info	terminating
        hs100.1
        	130883	2022-08-07 02:09:06.787	info	cleaned everything up...
        hs100.1
        	130883	2022-08-07 02:09:06.775	error	TCP Timeout after 10000ms192.168.178.172:9999 {"emeter":{"get_daystat":{"year":2022,"month":8}}}
        Homoran F 3 Replies Last reply Reply Quote 0
          wann?
          ich sehe nichts von code7 in deinem log!
          ich kenne den Adapter nicht. ist es normal, dass da 2 verdchiedene IP Adressen im log stehen?
            frank62 @frank62 last edited by
            Jetzt nochmal neustart gemacht und abwarten.
            hs100.1
            	189455	2022-08-07 12:53:56.485	info	Start with IP : 192.168.178.172
            hs100.1
            	189455	2022-08-07 12:53:56.426	info	Start with IP : 192.168.178.91
            hs100.1
            	189455	2022-08-07 12:53:56.389	info	starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.hs100, node: v14.20.0, js-controller: 4.0.23
              Das sind 2 Steckdosen.
                und da scheint es probleme mit deinem Van zu geben
                  OK, ich schmeiß die Steckdose mal raus aus dem System und dann mal schauen.
                    @frank62 ich dachte du hättest diesen uralten Thread ausgegraben
                    dann hättest du auch error code7!
                    davon sehe ich nichts.
                      Ich habe mich darauf bezogen.
                      Sorry
                      und jetzt bin ich im Garten bis heute abend. Dann weiß ich auch mehr, ob es geholfen hat die Steckdose im Van aus dem System zu nehmen.
                        arteck Developer Most Active @Negalein last edited by arteck
                        @frank62 starte die kiste neu..wenn was hängt..
                        hs100 adapter
                        991
