    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
    • andre
      andre Developer last edited by
      @trosses:
      wie kann ich git installieren wenn ich nun den harmony adapter installieren will meckert er wegen git sei nicht vorhanden ;( `
      Eigentlich ist git dabei… Ansonsten ganz normal, wie unter Linux üblich per
      apt-get install git
      meine ich…
      MfG,
      André
      Gesendet von Unterwegs mit Tapatalk
        trosses last edited by
        iobroker 2017-06-12 19:26:33.563 info exit 13
        iobroker 2017-06-12 19:26:33.534 error host.Syndeste Cannot install harmony
        iobroker 2017-06-12 19:26:33.524 info host.Syndeste install adapter harmony
        iobroker 2017-06-12 19:26:33.491 info npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2017-06-12T17_26_33_422Z-debug.log
        iobroker 2017-06-12 19:26:33.487 info
        iobroker 2017-06-12 19:26:33.412 info npm ERR! Please check if you have git installed and in your PATH.
        iobroker 2017-06-12 19:26:33.393 info Failed using git.
        iobroker 2017-06-12 19:26:33.387 info ERR!
        iobroker 2017-06-12 19:26:33.382 info
        iobroker 2017-06-12 19:26:33.377 info npm
        iobroker 2017-06-12 19:26:33.369 info
        iobroker 2017-06-12 19:26:33.354 info ERR!
        iobroker 2017-06-12 19:26:33.349 info
        iobroker 2017-06-12 19:26:33.342 info npm
        iobroker 2017-06-12 19:26:33.336 info No git binary found in $PATH
        iobroker 2017-06-12 19:26:33.329 info ERR!
        iobroker 2017-06-12 19:26:33.324 info
        iobroker 2017-06-12 19:26:33.320 info npm
        iobroker 2017-06-12 19:26:33.309 info npm ERR! code ENOGIT
        iobroker 2017-06-12 19:26:26.634 info node-xmpp-stanza@1.1.0: use @xmpp/xml package
        iobroker 2017-06-12 19:26:26.632 info deprecated
        iobroker 2017-06-12 19:26:26.630 info WARN
        iobroker 2017-06-12 19:26:26.628 info
        iobroker 2017-06-12 19:26:26.623 info npm
        iobroker 2017-06-12 19:26:08.690 info node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:26:08.690 info node: /lib/libstdc++.so.6: no version information available (required by node)node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:26:08.676 info node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:26:08.646 info npm install iobroker.harmony --production --prefix "/volume1/opt/iobroker" (System call)
        iobroker 2017-06-12 19:26:08.425 info host.Syndeste install adapter harmony
        iobroker 2017-06-12 19:26:08.396 info /root/.npm/_logs/2017-06-12T17_26_08_306Z-debug.log
        iobroker 2017-06-12 19:26:08.385 info npm ERR! A complete log of this run can be found in:npm ERR!
        iobroker 2017-06-12 19:26:08.377 info
        iobroker 2017-06-12 19:26:08.280 info Please check if you have git installed and in your PATH.
        iobroker 2017-06-12 19:26:08.278 info ERR!
        iobroker 2017-06-12 19:26:08.275 info npm
        iobroker 2017-06-12 19:26:08.275 info npm ERR! Failed using git.
        iobroker 2017-06-12 19:26:08.275 info No git binary found in $PATHnpm ERR!
        iobroker 2017-06-12 19:26:08.261 info npm ERR!
        iobroker 2017-06-12 19:26:08.254 info code ENOGIT
        iobroker 2017-06-12 19:26:08.240 info ERR!
        iobroker 2017-06-12 19:26:08.238 info npm
        iobroker 2017-06-12 19:26:01.546 info node-xmpp-stanza@1.1.0: use @xmpp/xml package
        iobroker 2017-06-12 19:26:01.540 info deprecated
        iobroker 2017-06-12 19:26:01.538 info
        iobroker 2017-06-12 19:26:01.531 info WARN
        iobroker 2017-06-12 19:26:01.530 info
        iobroker 2017-06-12 19:26:01.522 info npm
        iobroker 2017-06-12 19:25:42.851 info node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:42.851 info node: /lib/libstdc++.so.6: no version information available (required by node)node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:42.842 info node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:42.803 info npm install iobroker.harmony --production --prefix "/volume1/opt/iobroker" (System call)
        iobroker 2017-06-12 19:25:42.551 info host.Syndeste install adapter harmony
        iobroker 2017-06-12 19:25:42.429 info npm ERR! /root/.npm/_logs/2017-06-12T17_25_42_379Z-debug.log
        iobroker 2017-06-12 19:25:42.429 info npm ERR! A complete log of this run can be found in:
        iobroker 2017-06-12 19:25:42.388 info npm ERR! Please check if you have git installed and in your PATH.
        iobroker 2017-06-12 19:25:42.388 info npm ERR! Failed using git.
        iobroker 2017-06-12 19:25:42.388 info npm ERR! No git binary found in $PATHnpm ERR!
        iobroker 2017-06-12 19:25:42.365 info npm ERR! code ENOGIT
        iobroker 2017-06-12 19:25:35.143 info npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package
        iobroker 2017-06-12 19:25:14.482 info node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:14.482 info node: /lib/libstdc++.so.6: no version information available (required by node)node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:14.404 info npm install iobroker.harmony --production --prefix "/volume1/opt/iobroker" (System call)
        iobroker 2017-06-12 19:25:10.819 error node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:10.819 error node: /lib/libstdc++.so.6: no version information available (required by node)node: /lib/libstdc++.so.6: no version information available (required by node)
        iobroker 2017-06-12 19:25:10.777 info add harmony
        so das ist das log file naja weiss auch nimmer weiter haha alles schon versucht
          Sven2013 last edited by
          Hallo Andre,
          viele Dank für deine Screens. Ich habe nun alles 100 mal durchgegangen, aber der Container startet einfach nicht. Ich habe irgendwo einen Fehler, aber wo?
          Hier mal mein Screens, vielleicht siehst du etwas:
          Vielleicht liegt es auch am Kopieren der Dateien.
          Wie hast du diese denn vom Cubie "kopiert"?
          Ich habe den Cubie als remotelaufwerk eingebunden und dann per STRG+C und STRG+V eingefügt.
          Gruß Sven
          • andre
            @trosses:
            so das ist das log file naja weiss auch nimmer weiter haha alles schon versucht `
            Ich tippe mal, dass etwas mit deiner node version nicht stimmt. Bei mir lässt sich der harmony adapter einwandfrei installieren.
            Poste mal bitte die Ausgabe von
            node -v
            und
            npm -v
            ausgeführt in der Konsole des Containers.
            Wenn die versionen nicht stimmen oder eine fehlermeldung kommt, den ordner opt/iobroker aus dem container sichern und das iobroker image im docker neu laden. Neuen Container starten und den ordner zurück spielen. Vor sichern und zurückspielen bitte immer einmal ioBroker stoppen:
            cd /opt/iobroker
            iobroker stop
            MfG,
            André
            • andre
              @Sven2013:
              Hallo Andre,
              Gruß Sven `
              Mhh, das kann natürlich am Kopieren liegen. Ich habe es über ein tar-file gemacht. Also auf dem Cubie ioBroker gestoppt und dann den kompletten ioBroker ordner in ein tar-Archiv gepackt. Dann das Archiv kopiert und über die Kommandozeile im container wieder entpackt.
              Die Fehlermeldung lässt vermuten, dass irgendwas mit dem startup.sh script nicht stimmt. Kann das aber nicht so recht deuten.
              Hast du mal versucht einen jungfräulichen, lauffähigen ioBroker Ordner aus dem Container auf die DS zu kopieren und dann zu mounten? Wenn das klappt, würde ich einfach mal versuchen den Ordner vom Cubie (ohne startup.sh) drüber zu kopieren…
              MfG,
              André
                Hallo Andre,
                danke für deine Geduld! ich glaaube nun bin ich ganz nah am Ziel. Ich habe den ordner vom cubie nochmal neu gepackt und gemaountet. Jetzt startet der Container mit deiner Startup.sh (nicht mit der modifizierten)
                Der punkt des Hostnamens ändern bringt allerdings noch eine Fehlermeldung.
                More than one host found. You must specifiy which hist must be renamed.
                Diese verstehe ich und es liegt vermutlich daran, das ich vorher ein Multihost system in Betrieb hatte.
                Aber was muss in die Kommadozeile um den Hostnamen Cubieboard in den neuen zu ändern?
                Danke Gruß Sven
                  vielen Dank an Alle und besonders an André. Ich habe es nun hinbekommen und iobroker läuft nun bei mir auch auf dem Synology Nas.
                  1000 Dank dafür und für die tolle Untestützung.
                  Gruß Sven
                    gingo79 last edited by
                    @gingo79:
                    @andre:
                    @gingo79:
                    Hallo Andre,
                    hat funktioniert, Danke.
                    Habe Deine startup.sh mit der verzögerung nun am Laufen.
                    Habe die Synology 2 x Neu gestartet und iobroker lief mit an 🙂
                    Ich werde das die nächsten Tage mal beobachten, wenn die Synology morgens nach Ihren Schlaf aufwacht.
                    gruß
                    gingo `
                    Das höre ich gern.
                    Mal hoffen dass es jetzt rennt… 🙂
                    MfG,
                    André `
                    Hallo Andre,
                    gleich am ersten Tag, klappt es natürlich wieder nicht.
                    [....] Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemonProcess 39 died: No such process; trying to remove PID file. (/var/run/avahi-daemon//pid)
                    [?25l7[1G[[32m ok [39;49m8[?12l[?25h.
                    [....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon[?25l7[1G[[32m ok [39;49m8[?12l[?25h.
                    iobroker controller daemon already running. PID: 66
                    Alle Prozesse auf 0.
                    cd /opt/iobroker
                    ./ iobroker start
                    im Terminal eingeben und iobroker läuft an.
                    Dies musste ich bei 3 Neustarts vorhin machen.
                    Frustrierend…
                    gruß
                    gingo `
                    Hallo André,
                    mein Feedback nach einer Woche, iobroker ist von 7 mal Synology erwachen, 5 mal mit gestartet.
                    Das ist ein großer Erfolg, Danke 🙂
                    Mit den paar mal, wo es schief geht, muss ich wohl leben, oder hast Du noch eine Idee, woran es liegen könnte.
                    Gingo79
                    • andre
                      @gingo79:
                      Hallo André,
                      Gingo79 `
                      Danke für das Feedback. Ich grübel auch schon was ich noch versuchen kann. Das Problem habe ich identifiziert, aber leider keine Ahnung was die Ursache ist…
                      Offensichtlich kann ioBroker manchmal nicht gestartet werden, weil der Container meint, es würde schon laufen. Was aber nicht stimmt.
                      Jetzt habe ich zwei Möglichkeiten: Entweder ich fange diese Meldung, dass ioBroker schon läuft irgendwie im Startup Script ab und reagiere darauf, oder ich identifiziere die Ursache und beseitige sie. Letzteres ist mein Favorit 😉
                      Momentan warte ich darauf, dass es bei mir wieder passiert. Allerdings startet meine DiskStation ja nicht so häufig wie bei dir. 🙂
                      Ich bleibe dran.
                      MfG,
                      André
                      Gesendet mit Tapatalk
                        tscheinik last edited by
                        Hallo bin ganz neu hier.
                        habe auf der 415+ mit docker iobroker zum laufen bekommen. da in den nächsten tagen ein z-wave usb stick kommt wollt eich schon mal den z-wave adapter installieren.
                        klappt aber nicht.
                        hat einer ahnung was der fehler ist ?
                        $ ./iobroker add zwave
                        npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call)
                        /bin/sh: 1: sudo: not found
                        /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e;
                        ! Error: Command failed: sudo apt-get install libudev-dev -y
                        ! at checkExecSyncError (child_process.js:481:13)
                        at Object.execSync (child_process.js:521:13)
                        at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15)
                        at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7)
                        at Module._compile (module.js:570:32)
                        at Object.Module._extensions..js (module.js:579:10)
                        at Module.load (module.js:487:32)
                        at tryModuleLoad (module.js:446:12)
                        at Function.Module._load (module.js:438:3)
                        at Module.runMain (module.js:604:10)
                        ! npm
                        ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"
                        npm ERR! node v6.11.0
                        npm ERR! npm v3.10.10
                        npm ERR! code ELIFECYCLE
                        ! npm ERR! iobroker.zwave@0.6.0 preinstall: node lib/preinstall.jsnpm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'.
                        npm ERR! Make sure you have the latest version of node.js and npm installed.
                        npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,
                        npm ERR! not with npm itself.
                        npm ERR! Tell the author that this fails on your system:
                        npm ERR! node lib/preinstall.js
                        npm ERR! You can get information on how to open an issue for this project with:
                        npm ERR! npm bugs iobroker.zwave
                        npm ERR! Or if that isn't available, you can get their info via:
                        npm ERR! npm owner ls iobroker.zwave
                        npm ERR! There is likely additional logging output above.
                        ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
                        ! host.DS415 install adapter zwave
                        ! npm ERR! Linux 3.10.102
                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0
                        ! npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE
                        ! npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'.
                        npm
                        ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself.
                        npm ERR!
                        You can get information on how to open an issue for this project with:npm ERR!
                        npm bugs iobroker.zwavenpm ERR! Or if that isn't available, you can get their info via:
                        ! npm ERR!
                        ! npm
                        npm
                        ERR! node v6.11.0
                        npm ERR!
                        ERROR: host.DS415 Cannot install zwave
                        ERROR: process exited with code 13</anonymous></anonymous></anonymous>
                        • andre
                          @tscheinik:
                          klappt aber nicht.
                          ! $ ./iobroker add zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0 ! npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 ! npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with:npm ERR! npm bugs iobroker.zwavenpm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) /bin/sh: 1: sudo: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: sudo apt-get install libudev-dev -y /bin/sh: 1: sudo: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:25:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.runMain (module.js:604:10) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request: npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave ERROR: host.DS415 Cannot install zwave ERROR: process exited with code 13</anonymous></anonymous></anonymous> `
                          die Lösung steht im Log:
                          Versuch mal sudo zu installieren. dazu einfach im Terminal des Containers:
                          apt-get install sudo
                          Und dann nochmal Adapterinstallation versuchen… Allerdings kann ich dir nicht helfen wenn es darum geht den USB-Stick am Container zum Laufen zu bekommen.
                          Wäre aber trotzdem nett, wenn du berichtest (auch wenn alles klappt) dann könnte ich ggf. sudo auch mit in das Image mit aufnehmen und damit die Sache für andere User erleichtern... Danke.
                          MfG,
                          André
                            hallo
                            habe es installiert. aber bekomme trotzedem einen fehler. aber wohl was anderes
                            sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog
                            debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.)
                            debconf: falling back to frontend: Readline
                            debconf: unable to initialize frontend: Readline
                            debconf: (This frontend requires a controlling tty.)
                            debconf: falling back to frontend: Teletype
                            dpkg-preconfigure: unable to re-open stdin:
                            ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed
                            ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
                            100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160
                            ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720
                            100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k
                            ! /bin/sh: 1: unzip: not found
                            ! Error: Command failed: unzip master.zip && rm master.zip
                            at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3)
                            at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3)
                            at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7)
                            ! npm
                            ERR! Linux 3.10.102
                            npm
                            ! npm
                            npm ERR!
                            npm ERR!
                            Make sure you have the latest version of node.js and npm installed.npm ERR!
                            ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
                            npm ERR!
                            100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259
                            46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k
                            100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k
                            ! npm
                            ! npm
                            npm ERR!
                            npm ERR!
                            ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave
                            100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268
                            ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k
                            100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k
                            ! npm
                            npm ERR!
                            node v6.11.0npm ERR! npm v3.10.10
                            npm ERR!
                            habe jetzt mal apt-get install unzip ins terminal eingegeben. versuche jetzt nochmal
                            edit:
                            es hat geklappt
                            • andre
                              @tscheinik:
                              hallo
                              ! $ ./iobroker add zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitteddebconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 1.) debconf: falling back to frontend: Readline debconf: unable to initialize frontend: Readline debconf: (This frontend requires a controlling tty.) debconf: falling back to frontend: Teletype dpkg-preconfigure: unable to re-open stdin: ! % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 160 0 --:--:-- --:--:-- --:--:-- 160 ! 100 40742 0 40742 0 0 23720 0 --:--:-- 0:00:01 --:--:-- 23720 100 1709k 0 1709k 0 0 678k 0 --:--:-- 0:00:02 --:--:-- 2086k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102 npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed.npm ERR! If you do, this is most likely a problem with the iobroker.zwave package,npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 259 0 --:--:-- --:--:-- --:--:-- 259 ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 46 1709k 46 787k 0 0 453k 0 0:00:03 0:00:01 0:00:02 760k 100 1709k 100 1709k 0 0 876k 0 0:00:01 0:00:01 --:--:-- 1369k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave ! npm ERR! Or if that isn't available, you can get their info via:npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave npm install iobroker.zwave --unsafe-perm --production --prefix "/opt/iobroker" (System call) sudo: unable to send audit message: Operation not permitted % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed ! 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 125 0 125 0 0 268 0 --:--:-- --:--:-- --:--:-- 268 ! 8 1709k 8 137k 0 0 104k 0 0:00:16 0:00:01 0:00:15 104k 100 1709k 100 1709k 0 0 865k 0 0:00:01 0:00:01 --:--:-- 2381k ! /bin/sh: 1: unzip: not found /opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:15 if (!suppressException) throw e; ^ ! Error: Command failed: unzip master.zip && rm master.zip /bin/sh: 1: unzip: not found ! at checkExecSyncError (child_process.js:481:13) at Object.execSync (child_process.js:521:13) at doScript (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:12:15) at installOpenZwaveFromSource (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:109:3) at installOpenZwave (/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:103:3) at Object. <anonymous>(/opt/iobroker/node_modules/.staging/iobroker.zwave-936e120a/lib/preinstall.js:26:7) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) ! npm ERR! Linux 3.10.102npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--prefix" "/opt/iobroker" npm ERR! node v6.11.0npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE ! npm ERR! iobroker.zwave@0.6.0 preinstall: `node lib/preinstall.js`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the iobroker.zwave@0.6.0 preinstall script 'node lib/preinstall.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the iobroker.zwave package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! node lib/preinstall.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs iobroker.zwave npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls iobroker.zwave npm ERR! There is likely additional logging output above. ! npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log ! host.DS415 install adapter zwave ERROR: host.DS415 Cannot install zwave ERROR: process exited with code 13</anonymous></anonymous></anonymous> `
                              Du musst das Logfile schon lesen… Oder es zumindest versuchen...
                              Nehme meinen letzte Beitrag und ersetze sudo mit unzip...
                              MfG,
                              André
                                haben uns überschnitten. darauf bin ich schon gekommen.
                                es hat jetzt geklappt.
                                • andre
                                  @tscheinik:
                                  es hat jetzt geklappt. `
                                  🙂 Du hattest jetzt nur sudo und unzip nachinstalliert, richtig?
                                  Lass es mich bitte wissen ob das Einbinden des USB sticks gelingt, dann würde ich die Pakete mit in das Image aufnehmen.
                                  MfG,
                                  André
                                    ja sobald ich den stick bekomme werde ich es testen.
                                    habe diesen stick Aeotec AEOEZW090-C Aeon Labs USB Stick
                                    ja genau einmal sudo und einmal unzip
                                      @andre:
                                      Ich bleibe dran.
                                      MfG,
                                      André
                                      Gesendet mit Tapatalk `
                                      Vielen Dank dafür!
                                      Gingo79
                                        @andre:
                                        @tscheinik:
                                        MfG,
                                        André
                                        ich habe es einmal geschafft bei z-wave einen usb port auszuwhälen. war aber kurz danach weg. ich kann nichtmal einen usb port aussuchen.
                                        bei domoticz wird der stick erkannt.
                                          Artem82 last edited by
                                          Please add to default to iob container 'cifs-utils'
                                          I want mount folder.
                                          Thx!!!
                                          • andre
                                            @tscheinik:
                                            @andre:
                                            @tscheinik:
                                            MfG,
                                            André
                                            bei domoticz wird der stick erkannt. `
                                            Versuch mal den Container mit erweiterten Berechtigungen laufen zu lassen. (https://forum.synology.com/enu/viewtopic.php?t=127019)
                                            Container stoppen, Container bearbeiten, Allgemeine Einstellungen: "Container mit hoher Priorität ausführen". Vielleicht hast du dann Zugriff auf die USB-Geräte.
                                            Falls nicht kenne ich nur den Weg wie man USB-Devices beim Start des Containers per Kommandozeile durch reicht… Habe es selbst aber noch nicht praktiziert...
                                            MfG,
                                            André
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1526566
