    4. Puppeteer: Screenshots PhantomJS Alternative
    • foxriver76
      foxriver76 Developer @Negalein last edited by
      @negalein nach der geschweiften Klammer in der Zeile über path fehlt ein Komma.
      • Negalein
        Negalein Global Moderator @foxriver76 last edited by
        @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
        leider selber Fehler
        sendTo('puppeteer.0', 'screenshot', {
            url: 'http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk',
          clip: {
            x: 0,
            y: 0,
            width: 1920,
            height: 757
            path: '../wetterstation.png' // sollte dann in /opt/iobroker/node_modules/iobroker.puppeteer/ landen
        23:07:58.219 error javascript.0 (1426) script.js.Wetter.Wetter_to_FTP compile failed: at script.js.Wetter.Wetter_to_FTP:3
        • foxriver76
          @negalein
              clip: {
                  x: 0,
                  y: 0,
                  width: 1920,
                  height: 757
          Negalein 2 Replies Last reply Reply Quote 0
          • Negalein
            @foxriver76
            Jetzt kommt keine Meldung 🙂
            Aber er speichert nichts in /opt/iobroker/node_modules/iobroker.puppeteer/
            DP sind auch leer
            • Negalein
              @foxriver76
              Edit:
              hatte den Adapter nicht gestartet 😞
              Adapter gestartet, kommt folgendes:
              puppeteer.0 2022-08-11 23:53:10.863	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              puppeteer.0 2022-08-11 23:53:10.862	info	terminating
              puppeteer.0 2022-08-11 23:53:10.858	error	Failed to launch the browser process!/opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directoryTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
              puppeteer.0 2022-08-11 23:53:10.857	error	Error: Failed to launch the browser process!/opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directoryTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at Interface.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:231:68) at Interface.emit (node:events:539:35) at Interface.close (node:readline:586:8) at Socket.onend (node:readline:277:10) at Socket.emit (node:events:539:35) at endReadableNT (node:internal/streams/readable:1345:12) at processTicksAndRejections (node:internal/process/task_queues:83:21)
              puppeteer.0 2022-08-11 23:53:10.856	error	unhandled promise rejection: Failed to launch the browser process!/opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directoryTROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
              puppeteer.0 2022-08-11 23:53:10.856	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              puppeteer.0 2022-08-11 23:53:10.787	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
              • foxriver76
                @negalein lösche mal den Adapter und installiere ihn neu bitte. Am Anfang wurden die libraries nicht mit installiert und bei update passiert das leider nicht.
                • Negalein
                  @foxriver76
                  leider selbes Ergebnis
                  puppeteer.0 2022-08-12 00:26:10.626	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                  puppeteer.0 2022-08-12 00:26:10.626	info	terminating
                  puppeteer.0 2022-08-12 00:26:10.618	error	Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                  puppeteer.0 2022-08-12 00:26:10.617	error	Error: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
                  puppeteer.0 2022-08-12 00:26:10.617	error	unhandled promise rejection: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                  puppeteer.0 2022-08-12 00:26:10.616	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  puppeteer.0 2022-08-12 00:26:10.582	info	starting. Version 0.2.1 (non-npm: foxriver76/ioBroker.puppeteer) in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                  • foxriver76
                    @negalein zeig mal log von iob del puppeteer && iob add puppeteer
                    • Negalein
                      nega@ioBroker:/opt/iobroker$ iob del puppeteer && iob add puppeteer
                      Delete adapter "puppeteer"
                      host.ioBroker Counted 1 instances of puppeteer
                      host.ioBroker Counted 1 meta of puppeteer
                      host.ioBroker Counted 1 adapter for puppeteer
                      host.ioBroker Counted 9 states of puppeteer
                      host.ioBroker Counted 14 states of system.adapter.puppeteer
                      host.ioBroker Counted 3 states (io.puppeteer.*) from states
                      host.ioBroker Counted 14 states (system.adapter.puppeteer.*) from states
                      host.ioBroker file puppeteer.admin deleted
                      host.ioBroker object puppeteer deleted
                      host.ioBroker object puppeteer.admin deleted
                      host.ioBroker Deleting 26 object(s).
                      host.ioBroker Deleting 17 state(s).
                      removed 25 packages in 3s
                      193 packages are looking for funding
                        run `npm fund` for details
                      NPM version: 8.11.0
                      Installing iobroker.puppeteer@0.2.1... (System call)
                      added 25 packages in 11s
                      host.ioBroker install adapter puppeteer
                      Cannot install "libnss3": E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nss/libnss3_3.49.1-1ubuntu1.7_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
                      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                      The following apt-get packages could not be installed: libnss3. Please install them manually.
                      upload [0] puppeteer.admin /opt/iobroker/node_modules/iobroker.puppeteer/admin/puppeteer.png puppeteer.png image/png
                      host.ioBroker object system.adapter.puppeteer created/updated
                      host.ioBroker create instance puppeteer
                      host.ioBroker object system.adapter.puppeteer.0.alive created
                      host.ioBroker object system.adapter.puppeteer.0.connected created
                      host.ioBroker object system.adapter.puppeteer.0.compactMode created
                      host.ioBroker object system.adapter.puppeteer.0.cpu created
                      host.ioBroker object system.adapter.puppeteer.0.cputime created
                      host.ioBroker object system.adapter.puppeteer.0.memHeapUsed created
                      host.ioBroker object system.adapter.puppeteer.0.memHeapTotal created
                      host.ioBroker object system.adapter.puppeteer.0.memRss created
                      host.ioBroker object system.adapter.puppeteer.0.uptime created
                      host.ioBroker object system.adapter.puppeteer.0.inputCount created
                      host.ioBroker object system.adapter.puppeteer.0.outputCount created
                      host.ioBroker object system.adapter.puppeteer.0.eventLoopLag created
                      host.ioBroker object system.adapter.puppeteer.0.sigKill created
                      host.ioBroker object system.adapter.puppeteer.0.logLevel created
                      host.ioBroker object puppeteer.0.url created
                      host.ioBroker object puppeteer.0.filename created
                      host.ioBroker object puppeteer.0.fullPage created
                      host.ioBroker object puppeteer.0.clipTop created
                      host.ioBroker object puppeteer.0.clipLeft created
                      host.ioBroker object puppeteer.0.clipWidth created
                      host.ioBroker object puppeteer.0.clipHeight created
                      host.ioBroker object puppeteer.0.renderTime created
                      host.ioBroker object puppeteer.0.waitForSelector created
                      host.ioBroker Set default value of puppeteer.0.fullPage: false
                      host.ioBroker Set default value of puppeteer.0.clipTop: 0
                      host.ioBroker Set default value of puppeteer.0.clipLeft: 0
                      host.ioBroker object system.adapter.puppeteer.0 created
                      • foxriver76
                        @negalein Und nach wie vor der Fehler beim Start?
                        • Negalein
                          Sorry, oben vergessen.
                          Ja, wieder die Fehler.
                          puppeteer.0 2022-08-12 11:05:59.293	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          puppeteer.0 2022-08-12 11:05:59.292	info	terminating
                          puppeteer.0 2022-08-12 11:05:59.287	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                          puppeteer.0 2022-08-12 11:05:59.286	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
                          puppeteer.0 2022-08-12 11:05:59.284	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
                          puppeteer.0 2022-08-12 11:05:59.284	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          puppeteer.0 2022-08-12 11:05:59.250	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                          • foxriver76
                            @negalein Zeig mal bitte Output von ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                            • Negalein
                              nega@ioBroker:~$ ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                                      libnss3.so => not found
                                      libnssutil3.so => not found
                                      libsmime3.so => not found
                              nega@ioBroker:~$
                              • foxriver76
                                @negalein sudo apt update && sudo apt install libnss3 installiert er es da. Beim install Log hat er schon gesagt, dass er es nicht findet.. mal sehen woran das liegt
                                • Negalein
                                  Danke, ist jetzt grün. 🙂
                                  Screenshot wird nicht erstellt und DP sind leer.
                                  • foxriver76
                                    @negalein DPs sind nur zur Konfiguration. Schreibt er was im Log? Evtl. auf Debug wenn du sendTo ausführst?
                                    • Negalein
                                      puppeteer.0 2022-08-12 11:33:32.075	debug	Checking path "../wetterstation.png"
                                      puppeteer.0 2022-08-12 11:33:32.075	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278577}
                                      puppeteer.0 2022-08-12 11:33:19.946	debug	Checking path "../wetterstation.png"
                                      puppeteer.0 2022-08-12 11:33:19.946	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278576}
                                      puppeteer.0 2022-08-12 11:32:57.012	info	Ready to take screenshots
                                      puppeteer.0 2022-08-12 11:32:56.815	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                                      • foxriver76
                                        @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
                                        hm gib mal als path im Skript /opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png an
                                        • Negalein
                                          puppeteer.0 2022-08-12 11:38:01.009	error	Could not take screenshot of "http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk": Screenshots cannot be stored inside a node_modules folder
                                          puppeteer.0 2022-08-12 11:38:01.009	debug	Checking path "/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"
                                          puppeteer.0 2022-08-12 11:38:01.008	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278587}
                                          hmmm, muss es woanders speichern. Was würdest du empfehlen?
                                          • foxriver76
                                            @negalein Stimmt ja, schlechter Stil wird ja vom Adapter verhindert 😄
                                            Sauber ist es im ioBroker storage, mach path weg und dafür das rein:
                                                  ioBrokerOptions: {
                                                    storagePath: 'wetterstation.png';
                                            31.7k
                                            79.8k
                                            browser headless phantomjs puppeteer screenshot screenshots website
                                            23
                                            245
                                            25550
