    4. Puppeteer: Screenshots PhantomJS Alternative
    • Negalein
      Negalein Global Moderator @foxriver76 last edited by
      @foxriver76
      leider selbes Ergebnis
      puppeteer.0 2022-08-12 00:26:10.626	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      puppeteer.0 2022-08-12 00:26:10.626	info	terminating
      puppeteer.0 2022-08-12 00:26:10.618	error	Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
      puppeteer.0 2022-08-12 00:26:10.617	error	Error: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
      puppeteer.0 2022-08-12 00:26:10.617	error	unhandled promise rejection: Failed to launch the browser process! TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
      puppeteer.0 2022-08-12 00:26:10.616	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      puppeteer.0 2022-08-12 00:26:10.582	info	starting. Version 0.2.1 (non-npm: foxriver76/ioBroker.puppeteer) in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
      • foxriver76
        foxriver76 Developer @Negalein last edited by
        @negalein zeig mal log von iob del puppeteer && iob add puppeteer
        • Negalein
          @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
          nega@ioBroker:/opt/iobroker$ iob del puppeteer && iob add puppeteer
          Delete adapter "puppeteer"
          host.ioBroker Counted 1 instances of puppeteer
          host.ioBroker Counted 1 meta of puppeteer
          host.ioBroker Counted 1 adapter for puppeteer
          host.ioBroker Counted 9 states of puppeteer
          host.ioBroker Counted 14 states of system.adapter.puppeteer
          host.ioBroker Counted 3 states (io.puppeteer.*) from states
          host.ioBroker Counted 14 states (system.adapter.puppeteer.*) from states
          host.ioBroker file puppeteer.admin deleted
          host.ioBroker object puppeteer deleted
          host.ioBroker object puppeteer.admin deleted
          host.ioBroker Deleting 26 object(s).
          host.ioBroker Deleting 17 state(s).
          removed 25 packages in 3s
          193 packages are looking for funding
            run `npm fund` for details
          NPM version: 8.11.0
          Installing iobroker.puppeteer@0.2.1... (System call)
          added 25 packages in 11s
          host.ioBroker install adapter puppeteer
          Cannot install "libnss3": E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nss/libnss3_3.49.1-1ubuntu1.7_amd64.deb  404  Not Found [IP: 185.125.190.36 80]
          E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
          The following apt-get packages could not be installed: libnss3. Please install them manually.
          upload [0] puppeteer.admin /opt/iobroker/node_modules/iobroker.puppeteer/admin/puppeteer.png puppeteer.png image/png
          host.ioBroker object system.adapter.puppeteer created/updated
          host.ioBroker create instance puppeteer
          host.ioBroker object system.adapter.puppeteer.0.alive created
          host.ioBroker object system.adapter.puppeteer.0.connected created
          host.ioBroker object system.adapter.puppeteer.0.compactMode created
          host.ioBroker object system.adapter.puppeteer.0.cpu created
          host.ioBroker object system.adapter.puppeteer.0.cputime created
          host.ioBroker object system.adapter.puppeteer.0.memHeapUsed created
          host.ioBroker object system.adapter.puppeteer.0.memHeapTotal created
          host.ioBroker object system.adapter.puppeteer.0.memRss created
          host.ioBroker object system.adapter.puppeteer.0.uptime created
          host.ioBroker object system.adapter.puppeteer.0.inputCount created
          host.ioBroker object system.adapter.puppeteer.0.outputCount created
          host.ioBroker object system.adapter.puppeteer.0.eventLoopLag created
          host.ioBroker object system.adapter.puppeteer.0.sigKill created
          host.ioBroker object system.adapter.puppeteer.0.logLevel created
          host.ioBroker object puppeteer.0.url created
          host.ioBroker object puppeteer.0.filename created
          host.ioBroker object puppeteer.0.fullPage created
          host.ioBroker object puppeteer.0.clipTop created
          host.ioBroker object puppeteer.0.clipLeft created
          host.ioBroker object puppeteer.0.clipWidth created
          host.ioBroker object puppeteer.0.clipHeight created
          host.ioBroker object puppeteer.0.renderTime created
          host.ioBroker object puppeteer.0.waitForSelector created
          host.ioBroker Set default value of puppeteer.0.fullPage: false
          host.ioBroker Set default value of puppeteer.0.clipTop: 0
          host.ioBroker Set default value of puppeteer.0.clipLeft: 0
          host.ioBroker object system.adapter.puppeteer.0 created
          • foxriver76
            @negalein Und nach wie vor der Fehler beim Start?
            • Negalein
              Sorry, oben vergessen.
              Ja, wieder die Fehler.
              puppeteer.0 2022-08-12 11:05:59.293	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
              puppeteer.0 2022-08-12 11:05:59.292	info	terminating
              puppeteer.0 2022-08-12 11:05:59.287	error	Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
              puppeteer.0 2022-08-12 11:05:59.286	error	Error: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md at onClose (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:241:20) at ChildProcess.<anonymous> (/opt/iobroker/node_modules/puppeteer/lib/cjs/puppeteer/node/BrowserRunner.js:232:79) at ChildProcess.emit (node:events:539:35) at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
              puppeteer.0 2022-08-12 11:05:59.284	error	unhandled promise rejection: Failed to launch the browser process!TROUBLESHOOTING: https://github.com/puppeteer/puppeteer/blob/main/docs/troubleshooting.md
              puppeteer.0 2022-08-12 11:05:59.284	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              puppeteer.0 2022-08-12 11:05:59.250	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
              • foxriver76
                @negalein Zeig mal bitte Output von ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                • Negalein
                  nega@ioBroker:~$ ldd /opt/iobroker/node_modules/puppeteer/.local-chromium/linux-982053/chrome-linux/chrome | grep not
                          libnss3.so => not found
                          libnssutil3.so => not found
                          libsmime3.so => not found
                  nega@ioBroker:~$
                  • foxriver76
                    @negalein sudo apt update && sudo apt install libnss3 installiert er es da. Beim install Log hat er schon gesagt, dass er es nicht findet.. mal sehen woran das liegt
                    • Negalein
                      Danke, ist jetzt grün. 🙂
                      Screenshot wird nicht erstellt und DP sind leer.
                      • foxriver76
                        @negalein DPs sind nur zur Konfiguration. Schreibt er was im Log? Evtl. auf Debug wenn du sendTo ausführst?
                        • Negalein
                          puppeteer.0 2022-08-12 11:33:32.075	debug	Checking path "../wetterstation.png"
                          puppeteer.0 2022-08-12 11:33:32.075	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278577}
                          puppeteer.0 2022-08-12 11:33:19.946	debug	Checking path "../wetterstation.png"
                          puppeteer.0 2022-08-12 11:33:19.946	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278576}
                          puppeteer.0 2022-08-12 11:32:57.012	info	Ready to take screenshots
                          puppeteer.0 2022-08-12 11:32:56.815	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
                          • foxriver76
                            @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
                            hm gib mal als path im Skript /opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png an
                            • Negalein
                              puppeteer.0 2022-08-12 11:38:01.009	error	Could not take screenshot of "http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk": Screenshots cannot be stored inside a node_modules folder
                              puppeteer.0 2022-08-12 11:38:01.009	debug	Checking path "/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"
                              puppeteer.0 2022-08-12 11:38:01.008	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278587}
                              hmmm, muss es woanders speichern. Was würdest du empfehlen?
                              • foxriver76
                                @negalein Stimmt ja, schlechter Stil wird ja vom Adapter verhindert 😄
                                Sauber ist es im ioBroker storage, mach path weg und dafür das rein:
                                      ioBrokerOptions: {
                                        storagePath: 'wetterstation.png';
                                • Negalein
                                  Negalein Global Moderator @foxriver76 last edited by Negalein
                                  was brauch ich da wieder nach }
                                  sendTo('puppeteer.0', 'screenshot', {
                                      url: 'http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk',
                                      clip: {
                                          x: 0,
                                          y: 0,
                                          width: 1920,
                                          height: 757
                                      ioBrokerOptions: {
                                  Edit:
                                  so gehts 🙂
                                      clip: {
                                          x: 0,
                                          y: 0,
                                          width: 1920,
                                          height: 757
                                      ioBrokerOptions: {
                                          storagePath: 'wetterstation.png',
                                  Edith 2:
                                  hmmm, wo speichert er jetzt?
                                  • foxriver76
                                    foxriver76 Developer @Negalein last edited by foxriver76
                                    @negalein geh mal im admin auf Dateien und dann Benutzerdaten
                                    Auf dem Filessystem ist das defaultmäßig /opt/iobroker/iobroker-data/files/0_userdata.0/
                                    • Negalein
                                      gefunden in /opt/iobroker/iobroker-data/files/0_userdata.0/ 🙂
                                      Jetzt muss ich noch an der Auflösung basteln
                                      So ist es original.
                                      Puppeteer quetscht es irgendwie.
                                      • foxriver76
                                        @negalein Mom.. ich bastel kurz was. Defaultmäßig macht Puppeteer Browser 800x600 Auflösung statt die maximal Mögliche.
                                        • foxriver76
                                          Bitte mal 0.2.4 probieren, ist in 5 Minuten auf npm
                                          • Negalein
                                            eingestellt auf 1600x800
                                            browser headless phantomjs puppeteer screenshot screenshots website
                                            23
                                            245
                                            26831
