    4. Puppeteer: Screenshots PhantomJS Alternative
    • foxriver76
      foxriver76 Developer @Negalein last edited by
      @negalein DPs sind nur zur Konfiguration. Schreibt er was im Log? Evtl. auf Debug wenn du sendTo ausführst?
      • Negalein
        Negalein Global Moderator @foxriver76 last edited by
        @foxriver76 sagte in Puppeteer: Screenshots PhantomJS Alternative:
        puppeteer.0 2022-08-12 11:33:32.075	debug	Checking path "../wetterstation.png"
        puppeteer.0 2022-08-12 11:33:32.075	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278577}
        puppeteer.0 2022-08-12 11:33:19.946	debug	Checking path "../wetterstation.png"
        puppeteer.0 2022-08-12 11:33:19.946	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"../wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278576}
        puppeteer.0 2022-08-12 11:32:57.012	info	Ready to take screenshots
        puppeteer.0 2022-08-12 11:32:56.815	info	starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.puppeteer, node: v16.15.1, js-controller: 4.0.23
        • foxriver76
          @negalein sagte in Puppeteer: Screenshots PhantomJS Alternative:
          hm gib mal als path im Skript /opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png an
          • Negalein
            puppeteer.0 2022-08-12 11:38:01.009	error	Could not take screenshot of "http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk": Screenshots cannot be stored inside a node_modules folder
            puppeteer.0 2022-08-12 11:38:01.009	debug	Checking path "/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"
            puppeteer.0 2022-08-12 11:38:01.008	debug	Message: {"command":"screenshot","message":{"url":"http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk","clip":{"x":0,"y":0,"width":1920,"height":757},"path":"/opt/iobroker/node_modules/iobroker.puppeteer/wetterstation.png"},"from":"system.adapter.javascript.0","_id":48278587}
            hmmm, muss es woanders speichern. Was würdest du empfehlen?
            • foxriver76
              @negalein Stimmt ja, schlechter Stil wird ja vom Adapter verhindert 😄
              Sauber ist es im ioBroker storage, mach path weg und dafür das rein:
                    ioBrokerOptions: {
                      storagePath: 'wetterstation.png';
              • Negalein
                Negalein Global Moderator @foxriver76 last edited by Negalein
                was brauch ich da wieder nach }
                sendTo('puppeteer.0', 'screenshot', {
                    url: 'http://10.0.1.203:3000/d/14q2Khmnz/wetterstation-copy?orgId=1&refresh=1m&kiosk',
                    clip: {
                        x: 0,
                        y: 0,
                        width: 1920,
                        height: 757
                    ioBrokerOptions: {
                Edit:
                so gehts 🙂
                    clip: {
                        x: 0,
                        y: 0,
                        width: 1920,
                        height: 757
                    ioBrokerOptions: {
                        storagePath: 'wetterstation.png',
                Edith 2:
                hmmm, wo speichert er jetzt?
                • foxriver76
                  foxriver76 Developer @Negalein last edited by foxriver76
                  @negalein geh mal im admin auf Dateien und dann Benutzerdaten
                  Auf dem Filessystem ist das defaultmäßig /opt/iobroker/iobroker-data/files/0_userdata.0/
                  • Negalein
                    gefunden in /opt/iobroker/iobroker-data/files/0_userdata.0/ 🙂
                    Jetzt muss ich noch an der Auflösung basteln
                    So ist es original.
                    Puppeteer quetscht es irgendwie.
                    • foxriver76
                      @negalein Mom.. ich bastel kurz was. Defaultmäßig macht Puppeteer Browser 800x600 Auflösung statt die maximal Mögliche.
                      • foxriver76
                        Bitte mal 0.2.4 probieren, ist in 5 Minuten auf npm
                        • Negalein
                          eingestellt auf 1600x800
                          • foxriver76
                            @negalein Schade, dann mach mal zusätzlich mit in die Message
                            viewportOptions: {
                             width: 1600,
                            height: 1000
                            Entsprechen angepasst, bin nur am Handy.
                            • Negalein
                              schon viel besser. 🙂
                              Jetzt muss ich nur noch den rechten schwarzen Rand weg bekommen.
                              • foxriver76
                                @negalein das sollte mit den Clip Optionen gehen.
                                • Negalein
                                  muss das später in Ruhe testen.
                                  Umso mehr ich mit Clip probiere, umso komischer wird es.
                                  So wie oben (trotz identen Settings) bekomm ich es nicht mehr hin.
                                  • foxriver76
                                    @negalein Gerne die exakten Settings posten, falls du noch daran hängst.
                                    • Negalein
                                      Merci
                                      Hier ein paar Beispiele.
                                      Original schaut es so aus:
                                      So wie hier (paar Beiträge weiter oben) schaff ich es nicht mehr.
                                      Das war mit exakt dem Code aus "Test 2", das jetzt allerdings anders erstellt wird (siehe Test 2).
                                          clip: {
                                              x: 0,
                                              y: 0,
                                              width: 1920,
                                              height: 757
                                          ioBrokerOptions: {
                                          viewportOptions: {
                                       width: 1200,
                                      height: 800
                                          clip: {
                                              x: 0,
                                              y: 0,
                                              width: 1920,
                                              height: 757
                                          ioBrokerOptions: {
                                          viewportOptions: {
                                       width: 1600,
                                      height: 1000
                                          clip: {
                                              x: 0,
                                              y: 0,
                                              width: 1920,
                                              height: 757
                                          ioBrokerOptions: {
                                          viewportOptions: {
                                       width: 1800,
                                      height: 1000
                                          clip: {
                                              x: 0,
                                              y: 0,
                                              width: 1000,
                                              height: 757
                                          ioBrokerOptions: {
                                          viewportOptions: {
                                       width: 1600,
                                      height: 1000
                                      • foxriver76
                                        Ah ich mache gleich eine neue Version. Ich vermute es ist schlauer den Viewport im Code zu ändern, bevor man die Seite lädt, manche Seiten kommen nicht klar wenn man die Auflösung später ändert.
                                        Bitte 0.2.5 probieren.
                                        • Negalein
                                          Perfekt! 🙂
                                          Schaut jetzt sehr gut aus.
                                          Merci
                                              clip: {
                                                  x: 0,
                                                  y: 0,
                                                  width: 1000,
                                                  height: 757
                                              ioBrokerOptions: {
                                              viewportOptions: {
                                           width: 1600,
                                          height: 1000
                                          • foxriver76
                                            @negalein Perfekt, freut mich, dass wir den Adapter verbessern konnten. 😉
                                            Negalein 2 Replies Last reply Reply Quote 1
                                            31.7k
                                            79.8k
                                            browser headless phantomjs puppeteer screenshot screenshots website
                                            23
                                            245
                                            25725
