    3. Einsteigerfragen
    4. ioBroker super langsam (oder Raspi?)
      DJ Rico last edited by DJ Rico
      @crunchip
      ich öffne es mit Fireox, wenn du das meinst
      @Homoran
      vorher ist es mir jedenfalls nicht aufgefallen, greife nur selten darauf zu.
      An Hardware wurde nichts verändert und an der Software bewusst auch nichts, außer evtl updates der adapter etc.
      @Glasfaser
      pi@raspberrypi4-iob:~ $ cd /opt/iobroker
      npm ls | grep -E 'github.com|ERR'
      iobroker update -i
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami        && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejspi        @raspberrypi4-iob:/opt/iobroker $
      pi@raspberrypi4-iob:/opt/iobroker $ npm ls | grep -E 'github.com|ERR'
      │ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      pi@raspberrypi4-iob:/opt/iobroker $ iobroker update -i
      Used repository: stable
      Adapter    "admin"        : 5.3.8    , installed 5.3.8
      Adapter    "backitup"     : 2.4.10   , installed 2.4.10
      Adapter    "ble"          : 0.13.0   , installed 0.12.0 [Updatable]
      Adapter    "blebox"       : 1.0.0    , installed 1.0.0
      Adapter    "cloud"        : 4.1.1    , installed 4.1.1
      Adapter    "deconz"       : 1.3.21   , installed 1.3.21
      Adapter    "denon"        : 1.13.4   , installed 1.13.4
      Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
      Adapter    "go-e"         : 1.0.23   , installed 1.0.23
      Adapter    "history"      : 2.2.0    , installed 1.11.1 [Updatable]
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.8   , installed 1.11.4 [Updatable]
      Adapter    "javascript"   : 5.7.0    , installed 5.7.0
      Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
      Adapter    "mpd"          : 1.0.6    , installed 1.0.6
      Adapter    "nuki-extended": 2.3.1    , installed 2.3.1
      Adapter    "ping"         : 1.5.3    , installed 1.5.3
      Adapter    "plex"         : 0.9.1    , installed 0.9.1
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "shelly"       : 6.0.0    , installed 5.3.2  [Updatable]
      Adapter    "simple-api"   : 2.7.0    , installed 2.6.5  [Updatable]
      Adapter    "synology"     : 2.1.9    , installed 2.1.7  [Updatable]
      Adapter    "telegram"     : 1.13.0   , installed 1.12.6 [Updatable]
      Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
      Adapter    "tuya"         : 3.6.15   , installed 3.6.15
      Adapter    "vis"          : 1.4.15   , installed 1.4.15
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
      Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
      pi@raspberrypi4-iob:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
      pi@raspberrypi4-iob:/opt/iobroker $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v14.20.0
      v14.20.0
      6.14.17
      pi
      /opt/iobroker
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_14.x buster InRelease
      OK:4 https://phoscon.de/apt/deconz buster InRelease
      Alle Pakete sind aktuell.
      nodejs:
        Installiert:           14.20.0-deb-1nodesource1
        Installationskandidat: 14.20.0-deb-1nodesource1
        Versionstabelle:
       *** 14.20.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
      Danke für eure Mühe
      Was mir ebend aufgefallen ist:
      Wenn ich über die Befehle
      sudo iobroker stop
      sudo iobroker update
      sudo iobroker upgrade self
      sudo iobroker start
      updaten will, erscheint folgende Meldung:
      pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker stop
      pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker update
      No connection to databases possible ...
      pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker upgrade self
      pi@raspberrypi4-iob:/opt/iobroker $ sudo iobroker start
      Ist doch auch nicht normal 😞
      Thomas Braun Glasfaser Homoran 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @DJ Rico last edited by
        @dj-rico
        Aaaaaaaaaaahhhhh.
        Iobroker never ever niemals mit sudo anpacken!
        iobroker stop
        iobroker fix
        iobroker start
        Und halt das System auf Stand. Adapter updaten, nodejs auf v16 bringen.
        • Glasfaser
          Glasfaser @DJ Rico last edited by
          @dj-rico sagte in ioBroker super langsam (oder Raspi?):
          sudo iobroker stop
          Kein sudo vor iobroker Befehle , wo hast du das her !!!!
          iobroker stop
          iobroker fix
          iobroker start
          • DJMarc75
            DJMarc75 @Glasfaser last edited by
            @glasfaser sagte in ioBroker super langsam (oder Raspi?):
            YT denke ich, wie die meisten Neueinsteiger... GottSeiDank ist er "noch nicht" über die "Bachforelle" gestolpert 😰
              OK danke für die Info, hatte das mit sudo irgendwo hier im Forum gelesen, waren aber ätere Beiträge.
              Habt ihr für mich den Befehl, damit ich ich ein Autoupdate über die Konsole machen kann für die adapter, bzw. für die aktuelle nodejs v16?
              Sorry für meine Blödheit in dem Bereich
              LG
              DJMarc75 Thomas Braun 2 Replies Last reply Reply Quote 0
              • DJMarc75
                DJMarc75 @DJ Rico last edited by
                Jetzt aber... das hat niemand behauptet und es hat jeder mal angefangen.
                Aber schau mal bei @Thomas-Braun in die Signatur, da steht alles wunderbar beschrieben!
                  @dj-rico
                  nodejs: Siehe meine Signatur
                  iobroker stop
                  iobroker update
                  iobroker upgrade
                  iobroker start
                  Vorher den fix ausführen (siehe oben).
                    DJ Rico @Thomas Braun last edited by
                    @thomas-braun said in ioBroker super langsam (oder Raspi?):
                    @dj-rico
                    iobroker stop
                    iobroker update
                    iobroker upgrade
                    iobroker start
                    leider wird wieder genau das gleiche angezeigt, anscheinend keine Verbindung möglich 😞
                    pi@raspberrypi4-iob:~ $ iobroker stop
                    pi@raspberrypi4-iob:~ $ iobroker update
                    pi@raspberrypi4-iob:~ $ iobroker upgrade self
                    pi@raspberrypi4-iob:~ $ iobroker start
                    Und wenn ich das Node JS update machen will wie in deinem Tutorial beschrieben, wird der Stammbaum bei mir so angezeigt, ganz anders als es bei dir aussieht
                    pi@raspberrypi4-iob:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                    ├─┬ iobroker.boschindego@0.9.8 (github:a1development/ioBroker.boschindego#d7fe11        9dc903f9fae51fb0fdaaea7b67419cb40a)
                    │ │ │ ├── github-from-package@0.0.0
                    ├─┬ iobroker.miio@0.0.6 (github:SchumyHao/ioBroker.miio#7967d06fdbbef9b98c7f3257        c3ae4457d06acc23)
                    │ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b        1ab5be7fe8c57d3c68b0)
                    │   ├── github-url-from-git@1.5.0
                    │   ├─┬ new-github-release-url@1.0.0
                    Hab ich vieleicht mein System zerschossen?
                      Logisch, du hast ja auch andere Adapter als ich installiert.
                      Starte das System mal komplett sauber durch:
                      iobroker stop
                      sudo reboot
                        Neugestartet hab ich heute schon öfter mit dem Befehl. 🙂
                        Brachte aber keine Veränderung.
                        Muss für heute auch erstmal Schluss machen, ich werde es in den nächsten Tagen nochmal probieren und mich mit Sicherheit nochmal melden.
                        Danke für die Hilfe bisher
                        LG
                        • DJMarc75
                          das sind 2 Befehle 😀
                            Homoran Global Moderator Administrators @DJ Rico last edited by
                            SSD an USB 3?
                            MidiComp 1 Reply Last reply Reply Quote 0
                            • MidiComp
                              MidiComp @Homoran last edited by
                              Bei mir hängt eine SATA 500gb Platte (keine SSD) als root USB 2 an RPI 3 und ich habe keine Probleme mit langsame Aufbau usw. Das Hatte ich mal als RPI an WLAN war. Seit LAN Anbindung keine Probleme mehr.
                              Homoran DJMarc75 2 Replies Last reply Reply Quote 0
                                Homoran Global Moderator Administrators @MidiComp last edited by
                                @midicomp sagte in ioBroker super langsam (oder Raspi?):
                                root USB 2 an RPI 3
                                bei raspi4 und USB3 kommt es zu massiven Störimpulsen
                                MidiComp 1 Reply Last reply Reply Quote 1
                                • MidiComp
                                  @homoran Ok das habe ich nicht gewusst, danke Dir für die Info. Ein Problem weniger falls ich mal auf RPI4 umsteige. 😉
                                  • DJMarc75
                                    DJMarc75 @MidiComp last edited by
                                    Ich hoffe nicht dass der TE das jetzt als Empfehlung auffasst 😂
                                    • MidiComp
                                      MidiComp @DJMarc75 last edited by
                                      @djmarc75 said in ioBroker super langsam (oder Raspi?):
                                      Das hoffe ich auch 😉 War rein informativ.
                                      1365
