    3. Off Topic
    4. Microcontroller
    5. erneuert nicht [wieder erledigt] Tasmo Admin / VM Problem
    • da_Woody
      da_Woody @BananaJoe last edited by
      @bananajoe sagte in Tasmo Admin Problem:
      tja, scheint gar kein php installiert zu sein:
      irre, kann das durch update auf bullseye flöten gegangen sein? mit der test.php bekomm ich jetzt eine ellenlange page.
      PHP Version 7.4.30
      System 	Linux Debian 5.10.0-16-amd64 #1 SMP Debian 5.10.127-1 (2022-06-30) x86_64
      Build Date 	Jul 7 2022 15:51:43
      Server API 	Apache 2.0 Handler
      Virtual Directory Support 	disabled
      Configuration File (php.ini) Path 	/etc/php/7.4/apache2
      Loaded Configuration File 	/etc/php/7.4/apache2/php.ini
      Scan this dir for additional .ini files 	/etc/php/7.4/apache2/conf.d
      Additional .ini files parsed 	/etc/php/7.4/apache2/conf.d/10-opcache.ini, /etc/php/7.4/apache2/conf.d/10-pdo.ini, /etc/php/7.4/apache2/conf.d/20-calendar.ini, /etc/php/7.4/apache2/conf.d/20-ctype.ini, /etc/php/7.4/apache2/conf.d/20-exif.ini, /etc/php/7.4/apache2/conf.d/20-ffi.ini, /etc/php/7.4/apache2/conf.d/20-fileinfo.ini, /etc/php/7.4/apache2/conf.d/20-ftp.ini, /etc/php/7.4/apache2/conf.d/20-gettext.ini, /etc/php/7.4/apache2/conf.d/20-iconv.ini, /etc/php/7.4/apache2/conf.d/20-json.ini, /etc/php/7.4/apache2/conf.d/20-phar.ini, /etc/php/7.4/apache2/conf.d/20-posix.ini, /etc/php/7.4/apache2/conf.d/20-readline.ini, /etc/php/7.4/apache2/conf.d/20-shmop.ini, /etc/php/7.4/apache2/conf.d/20-sockets.ini, /etc/php/7.4/apache2/conf.d/20-sysvmsg.ini, /etc/php/7.4/apache2/conf.d/20-sysvsem.ini, /etc/php/7.4/apache2/conf.d/20-sysvshm.ini, /etc/php/7.4/apache2/conf.d/20-tokenizer.ini
      PHP API 	20190902
      PHP Extension 	20190902
      Zend Extension 	320190902
      Zend Extension Build 	API320190902,NTS
      PHP Extension Build 	API20190902,NTS
      Debug Build 	no
      Thread Safety 	disabled
      Zend Signal Handling 	enabled
      Zend Memory Manager 	enabled
      Zend Multibyte Support 	disabled
      IPv6 Support 	enabled
      DTrace Support 	available, disabled
      Registered PHP Streams	https, ftps, compress.zlib, php, file, glob, data, http, ftp, phar
      Registered Stream Socket Transports	tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3
      Registered Stream Filters	zlib.*, string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, dechunk, convert.iconv.*
      der oberste teil.
      woody@Debian:~$ sudo apache2 -v
      Server version: Apache/2.4.54 (Debian)
      Server built:   2022-06-09T04:26:43
      woody@Debian:~$
      woody@Debian:~$ sudo apt -y install libapache2-mod-php
      Paketlisten werden gelesen… Fertig
      Abhängigkeitsbaum wird aufgebaut… Fertig
      Statusinformationen werden eingelesen… Fertig
      libapache2-mod-php ist schon die neueste Version (2:7.4+76).
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
      woody@Debian:~$
      haut mir dann
      woody@Debian:~$ sudo apt-get install php7.0-curl
      Paket php7.0-curl ist nicht verfügbar, wird aber von einem anderen Paket
      referenziert. Das kann heißen, dass das Paket fehlt, dass es abgelöst
      wurde oder nur aus einer anderen Quelle verfügbar ist.
      E: Für Paket »php7.0-curl« existiert kein Installationskandidat.
      woody@Debian:~$
      hmpf. ich blick da nicht durch.
      • BananaJoe
        BananaJoe Most Active @da_Woody last edited by
        @da_woody du hast PHP 7.4 installiert, versuch mal
        sudo apt install -y php7.4-curl
        crunchip da_Woody 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @BananaJoe last edited by crunchip
          @bananajoe 7.4 braucht er ja, sonst geht tasmo admin nicht, zumindest ab
          v2.0.0
          Breaking Changes
          The minimum PHP version has been set to 7.4
          @da_Woody danach noch
          service apache2 restart
          BananaJoe 1 Reply Last reply Reply Quote 1
          • BananaJoe
            BananaJoe Most Active @crunchip last edited by
            @crunchip @da_Woody Ich wollte auch nicht andeuten das dies Falsch ist - das ist ja die PHP Version des Betriebssystems bzw. der zu seiner Linux-Version passenden Quelle.
            Die Meldung auf der Webseite ist halt einerseits gut - weil Hinweis in die richtige Richtung - andererseits irreführend.
            Wenn @da_Woody da etwas länger hingeschaut hätte, wäre er auch selbst darauf gekommen 😉
            • da_Woody
              @bananajoe k, das hat mal was getutet.
              woody@Debian:~$ sudo apt install -y php7.4-curl
              Die folgenden NEUEN Pakete werden installiert:
                php7.4-curl
              0 aktualisiert, 1 neu installiert, 0 zu entfernen und 2 nicht aktualisiert.
              Es müssen 31,0 kB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 135 kB Plattenplatz zusätzlich benutzt.
              Holen:1 http://security.debian.org bullseye-security/main amd64 php7.4-curl amd64 7.4.30-1+deb11u1 [31,0 kB]
              Es wurden 31,0 kB in 0 s geholt (302 kB/s).
              Vormals nicht ausgewähltes Paket php7.4-curl wird gewählt.
              (Lese Datenbank ... 46609 Dateien und Verzeichnisse sind derzeit installiert.)
              Vorbereitung zum Entpacken von .../php7.4-curl_7.4.30-1+deb11u1_amd64.deb ...
              Entpacken von php7.4-curl (7.4.30-1+deb11u1) ...
              php7.4-curl (7.4.30-1+deb11u1) wird eingerichtet ...
              Creating config file /etc/php/7.4/mods-available/curl.ini with new version
              Trigger für libapache2-mod-php7.4 (7.4.30-1+deb11u1) werden verarbeitet ...
              Trigger für php7.4-cli (7.4.30-1+deb11u1) werden verarbeitet ...
              Prüfe Prozesse...
              Prüfe Linux-Kernel...
              Der laufende Kernel ist aktuell.
              Es müssen keine Dienste neugestartet werden.
              Es müssen keine Container neu gestartet werden.
              Es gibt keine Nutzer-Sitzungen mit veralteten Prozessen.
              woody@Debian:~$
              neue meldung:
              ERROR: PHP Zip is missing.Please install PHP Zipsudo apt-get install php7.0-zipand restart webserver
              @crunchip VM neu gestartet, nutzt nix.
              ich geh mal kalt duschen... 😉
              BananaJoe crunchip 2 Replies Last reply Reply Quote 0
              • BananaJoe
                BananaJoe Most Active @da_Woody last edited by BananaJoe
                @da_woody das gleiche in grün - nimm den Befehl von der Curl-Installation und setze da das zipand ein. Er schlägt zwar 7.0 vor, du musst aber halt immer 7.4 installieren
                  crunchip Forum Testing Most Active @da_Woody last edited by
                  @da_woody sagte in Tasmo Admin Problem:
                  also ich hab mal bei mir nachgesehen, was ich mir als Hinweise notiert hatte,
                  das x wird mit der jeweiligen Version ersetzt, in dem Fall 4, sprich (php7.4)
                  upgrade ubuntu 16 auf 18 am 14.12.20
                  apt install libcurl4
                  php -v
                  apt install apache2 libapache2-mod-php7.x php7.x php7.x-curl php7.x-zip
                  • da_Woody
                    @bananajoe & @crunchip boah! thnx!
                    da is er wieder! 🤠 der ganze kack wegen update auf bullseye? wohin ist php verschwunden? hat ja 2 jahre gefunzt.
                      @da_woody sagte in [done] Tasmo Admin Problem:
                      da is er wieder
                      na geht doch
                      wer weiss was du da angestellt hattest😁 , wobei, ein backup einer VM zurück spielen sollte allerdings sowas nicht verursachen
                      • da_Woody
                        da_Woody @crunchip last edited by
                        @crunchip sagte in [done] Tasmo Admin Problem:
                        meine rede, auch das update auf bullseye sollte sowas nich anstellen... 😵
                        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                          da wiederspreche ich, das kann schon sein, das man da manuell noch Hand anlegen muss
                          • da_Woody
                            gute nacht! 😄
                            • da_Woody
                              @crunchip hoffe, du hast das nicht falsch verstanden. So komm ich mir manchmal mit Linux vor... 😉
                                Thomas Braun Most Active @da_Woody last edited by Thomas Braun
                                Für sowas gibt es Meta-Pakete bei apt/dpkg:
                                echad@chet:~ $ apt policy php-zip php7.4-zip
                                php-zip:
                                  Installed: (none)
                                  Candidate: 2:7.4+76
                                  Version table:
                                     2:7.4+76 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        500 http://deb.debian.org/debian bullseye/main armhf Packages
                                php7.4-zip:
                                  Installed: (none)
                                  Candidate: 7.4.30-1+deb11u1
                                  Version table:
                                     7.4.30-1+deb11u1 500
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                     7.4.28-1+deb11u1 500
                                Für php-curl dann z. B.:
                                echad@chet:~ $ apt policy php-curl php7.4-curl
                                php-curl:
                                  Installed: (none)
                                  Candidate: 2:7.4+76
                                  Version table:
                                     2:7.4+76 500
                                php7.4-curl:
                                  Installed: (none)
                                  Version table:
                                Dann funktioniert auch ein Distributionsupgrade zu einer anderen php-Version.
                                • da_Woody
                                  da_Woody @Thomas Braun last edited by da_Woody
                                  @thomas-braun ja, hau ruhig drauf! 😉
                                  Ne, im ernst, bin schon froh halbwegs zurecht zu kommen. Bin ja noch lernfähig mit 58... 🙂
                                    @da_woody
                                    Hat mit daraufhauen nix zu tun. Ich will es dir nur leichter machen mit diesem 'komischen Linux' parat zu kommen und die Gartenzwerge schonen...
                                    Man installiert also nur das 'generische Meta-Paket' und der Paketmager greift dann automatisch die korrekte Version aus dem Regal.
                                    Beispiel php-curl:
                                    echad@chet:~ $ apt install php-curl
                                    Reading package lists... Done
                                    Building dependency tree... Done
                                    The following additional packages will be installed:
                                      php-common php7.4-common php7.4-curl
                                    The following NEW packages will be installed:
                                      php-common php-curl php7.4-common php7.4-curl
                                    0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
                                    Inst php-common (2:76 Debian:11.4/stable [all])
                                    Inst php7.4-common (7.4.30-1+deb11u1 Debian-Security:11/stable-security [arm64])
                                    Inst php7.4-curl (7.4.30-1+deb11u1 Debian-Security:11/stable-security [arm64])
                                    Inst php-curl (2:7.4+76 Debian:11.4/stable [all])
                                    Conf php-common (2:76 Debian:11.4/stable [all])
                                    Conf php7.4-common (7.4.30-1+deb11u1 Debian-Security:11/stable-security [arm64])
                                    Conf php7.4-curl (7.4.30-1+deb11u1 Debian-Security:11/stable-security [arm64])
                                    Conf php-curl (2:7.4+76 Debian:11.4/stable [all])
                                    php-curl schleppt also die benötigten php7.4-Pakete automatisch an, wenn man nur php-curl installiert.
                                      @da_woody
                                      Ist denn jetzt jeweils das Meta-Paket auch installiert? Sonst rennst du da immer wieder in Probleme mit den Abhängigkeiten:
                                      apt policy libapache2-mod-php php php-curl php-zip
                                        @da_woody nene, alles gut🙂
                                        • da_Woody
                                          @thomas-braun sagte in [done] Tasmo Admin Problem:
                                          sorry, heute keine zeit gehabt...
                                          woody@Debian:~$ apt policy libapache2-mod-php php php-curl php-zip
                                          libapache2-mod-php:
                                            Installiert:           2:7.4+76
                                            Installationskandidat: 2:7.4+76
                                            Versionstabelle:
                                           *** 2:7.4+76 500
                                                  500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                                                  100 /var/lib/dpkg/status
                                          php:
                                            Versionstabelle:
                                           *** 2:7.4+76 500
                                          php-curl:
                                            Installiert:           (keine)
                                            Versionstabelle:
                                               2:7.4+76 500
                                          php-zip:
                                            Versionstabelle:
                                               2:7.4+76 500
                                          woody@Debian:~$
                                          das mit draufhauen ist halt mein wiener humor. das darfst du nicht so ernst nehmen. 🙂
                                          dank dir und anderen hab ich ja schon viel gelernt. aber als DOS und WIN gelernter fehlt da noch einiges.
                                          das feine hier, man darf auch dämliche fragen stellen, ohne nieder gemacht zu werden. 👍
                                            Dann installier php-curl und php-zip noch nach und dann sollte es auch für ein upgrade auf bookworm nächstes Jahr passen. Egal welche php-Version da genau aktuell sein wird.
                                            proxmox 7 tasmoadmin
                                            5544
