    4. Test Adapter Philips-TV v0.2.x
    • Wszene
      Wszene @foxriver76 last edited by
      @foxriver76
      Danke mit ausgeschaltetem Expertenmodus sind die Button wieder da und ich kann auch wieder schalten
      die Senderwahl geht aber leider noch nicht
      Hier das Log
      philips-tv-android.0
      2022-08-08 21:21:09.877	error	Could not launch application "NITRO": undefined
      2022-08-08 21:20:59.302	error	Could not launch application "Das Erste": undefined
      2022-08-08 21:20:40.338	error	Could not launch application "ZDF HD": undefined
      2022-08-08 21:18:42.786	error	Could not launch application "MDR Sachsen HD": undefined
      • foxriver76
        foxriver76 Developer @Wszene last edited by
        @wszene Installiere mal bitte neu von GitHub, sollte nun etwas anderes als undefined loggen
        Wszene 1 Reply Last reply Reply Quote 0
        • Wszene
          @foxriver76
          Das log
          2022-08-08 21:43:34.815	error	Could not launch TV channel "ntv": {"statusCode":400,"body":"<html>\n<head>\n <title>Status page</title>\n</head>\n<body style=\"font-family: sans-serif;\">\n<p style=\"font-size: 1.2em;font-weight: bold;margin: 1em 0px;\">Bad Request</p>\n<p>The request could not be understood by the server due to malformed syntax</p>\n<p>You can get technical details <a href=\"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.1\">here</a>.<br>\nPlease continue your visit at our <a href=\"/\">home page</a>.\n</p>\n</body>\n</html>\n","headers":{"date":"Mon, 08 Aug 2022 19:43:31 GMT","accept-ranges":"bytes","server":"Restlet-Framework/2.3.12","access-control-allow-origin":"*","content-length":"456","content-type":"text/html; charset=UTF-8"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.20.200:1926","port":"1926","hostname":"192.168.20.200","hash":null,"search":null,"query":null,"pathname":"/6/activities/launch","path":"/6/activities/launch","href":"https://192.168.20.200:1926/6/activities/launch"},"method":"POST","headers":{"content-length":138,"authorization":"Digest username=\"3nfKjgd4LL885dmV\", realm=\"XTV\", nonce=\"MTY1OTk4NzgxMTY0NDo2NzRjYmY4ZTg4OGIxODA0MTY2ZjFlMjQ1Y2JhNzUzNg==\", uri=\"/6/activities/launch\", qop=auth, response=\"630e934c534d9bd014b497e4edbabc0c\", nc=00000001, cnonce=\"6dbea975523444b0ba665a83d439ff3a\", algorithm=MD5","referer":"https://192.168.20.200:1926/6/activities/launch"}}}
          • foxriver76
            @wszene Nächster Versuch bitte
            • Wszene
              @foxriver76
              Leider hat das auch nicht geklappt
              2022-08-08 22:31:49.684	error	Could not launch TV channel "NITRO": socket hang up
              2022-08-08 22:31:49.657	warn	{"channel":{"ccid":905,"preset":"1","name":"1-2-3.tv HD"},"channelList":{"id":"allcab","version":"6"}}
              2022-08-08 22:31:49.657	warn	Notify developer:
              2022-08-08 22:31:19.198	info	Starting with ip "192.168.20.200"
              2022-08-08 22:31:19.174	info	starting. Version 0.0.1 (non-npm: foxriver76/ioBroker.philips-tv-android#d9933451e224975ac76ebaa240360aa5df66cd78) in /opt/iobroker/node_modules/iobroker.philips-tv-android, node: v16.16.0, js-controller: 4.0.23
              2022-08-08 22:31:13.018	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-08-08 22:31:13.017	info	terminating
              2022-08-08 22:31:12.915	info	Got terminate signal TERMINATE_YOURSELF
              • foxriver76
                @wszene Danke fürs Posten. Next try.. jetzt sollte es gehen 😉
                Wszene 2 Replies Last reply Reply Quote 1
                • Wszene
                  @foxriver76
                  Guten Morgen,
                  Jetzt funktioniert es perfekt
                  Vielen Dank für deine Arbeit
                  Wieder 2 Geräte weg von der Harmony
                  • Wszene
                    @foxriver76
                    Hast du schon eine Idee wann deine Version des Adapters in die Repo kommt
                    • foxriver76
                      @wszene Ich möchte gerne mindestens einen Tester mit einer API Version v5/v1 haben. Und im Optimalfall, ersetzt der Adapter den von @AlCalzone falls das für ihn i. O. ist, ich möchte für diesen Fall allerdings für die User älterer APIs nichts kaputt machen. Dann können wir sehr gerne die Schritte in die Wege leiten und den Adapter auf npm schieben.
                      Es sind noch einige States hinzu gekommen zum ansteuern von Ambilight. Ebenfalls wird der Endpunkt mit den Systeminfos einmalig abgefragt, was bei mir allerdings in einen Timeout läuft, hier auch gerne Feedback geben ob das Instanzobjekt als Device angelegt wird und im native Teil die Device Informationen aufweist.
                      Wszene AlCalzone 2 Replies Last reply Reply Quote 0
                      • Wszene
                        @foxriver76
                        OK das kann ich verstehen aber mit den v5/v1 APIs kann ich dir leider nicht helfen
                        Ich hab gerade das Update gemacht
                        Ich habe nur einen DP dazu bekommen
                        "Ambilight On/Off"
                        Und was meinst du genau
                        "Ebenfalls wird der Endpunkt mit den Systeminfos einmalig abgefragt, was bei mir allerdings in einen Timeout läuft"
                        Einen TimeOut konnte ich nicht feststellen
                        • foxriver76
                          @wszene Hast du ein Stift hinter dem Objekt philips-tv-android.0? Dann zeige mal bitte das Objekt bei dir.
                          Im settings channel sind Ambilight states hinzu gekommen, falls unterstützt vom TV.
                          • Wszene
                            @foxriver76 sagte in Test Adapter Philips-TV v0.2.x:
                            Leider nicht
                            Da hat sich bei mir nichts geändert
                            • foxriver76
                              @wszene dann mach mal bitte ein debug run und Zeuge mir das Logfile.
                              • AlCalzone
                                AlCalzone Developer @foxriver76 last edited by
                                Gerne!
                                  roughestboy @AlCalzone last edited by
                                  @foxriver: vielen Dank für die Aktualisierung des Adapters, genauso natürlich auch an AlCalzone für den Vorgänger.
                                  Ich habe den Adapter nun installiert, funktioniert auch prinzipiell.
                                  Meine Frage: wie kann ich damit den TV starten ?
                                  • foxriver76
                                    foxriver76 Developer @roughestboy last edited by
                                    @roughestboy Im TV solltest du WOL aktivieren, versteckt sich in den Netzwerkeinstellungen. Dann die MAC Adresse in die Adapter Config eintragen. Hierbei wird normalerweise die WIFI Mac Adresse benötigt. Dann per settings.power DP den TV einschalten.
                                      roughestboy @foxriver76 last edited by
                                      @foxriver76 Danke, funktioniert soweit.
                                        Rushmed Most Active last edited by Rushmed
                                        Vielen Dank, hab den Adapter auch installiert und verbunden!
                                        OLED806er TV
                                          Rushmed Most Active @Rushmed last edited by Rushmed
                                          Ich habe bei mir den aktuellen Adapter sowie den Alexa Skill für meinen Philips Fernseher installiert. Leider kann ich den Fernseher mit "Alexa, schalte Fernseher ein." nicht einschalten. Ich vermute weil er über den Skill schalten will und bei dem funktioniert komischerweise das WOL trotz Aktivierung in den TV Einstellungen und in der Alexa App auf dem TV nicht. BTW mit dem Adapter funktioniert WOL. Nun möchte ich aber den TV nicht unter verschiedenen Namen anlegen und benötige dennoch den Skill weil der schon soviele sprachsteuerbare Funktionen mitbringt ohne dass ich für jede DP's anlegen muss.
                                          Hat jemand von euch die gleiche Kombi am Laufen?
                                          Edit, hat sich erledigt.
                                            chrisalex2204 last edited by
                                            ich wollte den Adapter testen, bekomme aber im Log folgende Fehlermeldung:
                                            Could not poll API: no auth mechanism defined
                                            Was mache ich falsch?
                                            philips philips tv
                                            84
                                            550
                                            130934
