    4. Bose Soundtouch steuern
    • htrecksler
      htrecksler Forum Testing last edited by
      Dann bin ich mit meinem Latein am Ende,
      bei mir funktioniert der Code. Habs gerade probiert.
      Kannst du nochmal das ganze Script hier posten?
        Awacs2000 last edited by
        createState('BoseVolume', 10);
        createState('Bose_Preset_1', {type: 'boolean'});
        createState('Bose_Preset_2', {type: 'boolean'});
        createState('Bose_Preset_3', {type: 'boolean'});
        function VolumeSetzen(pWert) {
            var BodyString = '<volume>' + pWert + '</volume>';
            var request = require('request');
            request.post({
                url:     'http://192.168.100.90:8090/volume',
                body:    BodyString
            }, function(error, response, body) {
                if (error) log(error, 'error');
        function PresetSetzen(pWert) {
            var BodyString = '<key state="release" sender="1LIVE">' + pWert + '</key>';
            request.post({
                url:     'http://192.168.100.90:8090/key',
                //body:    '<volume>20</volume>'
                body:    BodyString
        function isTimeInRange(strLower, strUpper) {
            var now = new Date();
            var lower = addTime(strLower);
            var upper = addTime(strUpper);
            var inRange = false;
            if (upper > lower) {
                // opens and closes in same day
                inRange = (now >= lower && now <= upper) ? true : false;
            } else {
                // closes in the following day
                inRange = (now >= upper && now <= lower) ? false : true;
            return inRange;
        function addTime(strTime) {
            var time = strTime.split(':');
            var d = currentDate();
            d.setHours(time[0]);
            d.setMinutes(time[1]);
            d.setSeconds(time[2]);
            return d;
        function currentDate() {
            var d = new Date();
            return new Date(d.getFullYear(), d.getMonth(), d.getDate());
        on ({id: "javascript.0.BoseVolume", change: "ne"}, function () {
            lVolume = getState("javascript.0.BoseVolume");
            VolumeSetzen(lVolume.val);
        on ({id: "javascript.0.Bose_Preset_1", val: true}, function () {
            PresetSetzen('PRESET_1');
            setState("javascript.0.Bose_Preset_1", false);
        on ({id: "javascript.0.Bose_Preset_2", val: true}, function () {
            PresetSetzen('PRESET_2');
            setState("javascript.0.Bose_Preset_2", false);
        on ({id: "javascript.0.Bose_Preset_3", val: true}, function () {
            PresetSetzen('PRESET_3');
            setState("javascript.0.Bose_Preset_3", false);
        on({id: "hm-rpc.0.MEQ0665905.1.STATE", val: true}, function(obj) {
            var lVon = "19:00:00";
            var lBis = "22:00:00";
            if (isTimeInRange(lVon, lBis)) {
              VolumeSetzen(25);
        • htrecksler
          aha, der Teil ist falsch…
              request.post({
                  body:    BodyString
          das 1LIVE darf da nicht stehen. Die Zeile muss so aussehen
          var BodyString = '<key state="release" sender="Gabbo">' + pWert + '</key>';
          sender="Gabbo" muss stehen bleiben
            Sehr geil, läuft!
            Top Arbeit von Dir! Danke tausend mal! 😄
            305_schlafzimmer_profilparameter-3profiles.txt
              gogohome last edited by
              An htrecksler danke das war echt super, funktioniert bei mir auch perfekt.
              Ich habe mir das API Dokument angeschaut, weil ich die Soundtouch Anlage auch über iobroker ausschalten will.
              Habe aber leider nicht gefunden.
              Hast du eine Idee wie man es über die API's ausschalten kann?
              • htrecksler
                Mit diesen beiden Befehlen sollte es funktionieren.
                '<key state="press" sender="Gabbo">POWER</key>'
                '<key state="release" sender="Gabbo">POWER</key>'
                Im Prinzip sagt man damit der Soundtouch:
                1. Drücke den Power Button
                2. Lasse ihn wieder los.
                Ich komme heute leider nicht dazu den kompletten Code zu testen, falls du damit so nicht klar kommst gib mir eine kurze Info, dann mache ich morgen ein komplettes Beispiel….
                Gruss Hermann
                  Hi
                  habe folgenden Code geschrieben.
                  Kann das Objekt auch in iobroker vis sehen und benutzen.
                  Leider geht die Soundtouch Anlage nicht an.
                  Ist der Code eigentlich OK.
                  createState('Bose_Power', {type: 'boolean'});
                  function PowerSetzen() {
                      var BodyString = '<key state="press" sender="Gabbo">POWER</key>';
                      request.post({
                          url:     'http://192.168.178.43:8090/key',
                          body:    BodyString
                  function PowerClear() {
                      var BodyString = '<key state="release" sender="Gabbo">POWER</key>';
                      request.post({
                          body:    BodyString
                  on ({id: "javascript.0.Bose_Power", val: true}, function () {
                      PowerSetzen;
                      PowerClear;
                      setState("javascript.0.Bose_Power", false);
                    Phantomio last edited by
                    das steuern der Soundtouch bekomme ich schon hin.
                    Hat es einer von euch schon geschafft auch etwas auszulesen:
                    z.B. was wird gerade gestream
                    oder ob die Soundtouch gerade an oder aus ist.
                    Ich habe in einem neuem Thema auch noch mal die Frage gestellt, ob eine Sprachausgabe wie bei Sonos möglich ist http://forum.iobroker.net/viewtopic.php … hilit=Bose
                    Evtl. hat ja einer von euch eine Idee.
                    Mann könnte sich zwar auch Sonos kaufen, aber die Preset Tasten von Bose sind schon cool 8-)
                    Phantomio
                      stoepselinho last edited by
                      gibt es schon einen fertigen Adapter für Bose?
                        Master77 last edited by
                        Das würde mich auch interessieren.
                        Gesendet von meinem HUAWEI NXT-L29 mit Tapatalk
                          lubeda last edited by
                          @Master77:
                          Das würde mich auch interessieren. `
                          Mich auch 😄 , ich habe eigentlich FHEM nur noch wegen diesem Adapter laufen.
                          Ich mache alle Sprachausgaben von ioBroker über FHEM. Das FHEM dazu einen Minidlna Server benötigt gefällt mir auch nicht wirklich.
                          Aber bei der Programierung bin ich raus, da kann ich nicht helfen.
                            apollon77 last edited by
                            So ein Adapter steht auf meiner Todo-Liste … aber anderes steht vorher da 🙂
                            Um einen "Mini-DLNA-Server" (auch wenn er wenn dann in ioBroker läuft) kommt man wohl auch nicht drum rum 😞
                            • N
                              Nanouk last edited by
                              Wie würde denn der Teil für Power aussehen?
                              Also quasi das Skript so erweitert das man bei VIS einen Power On/Off Widget hätte?
                              Könnte man auch beim Einschalten / Preset schalten alle Soundtouch Lautsprecher verbinden?
                              Oliver
                              • N
                                Also den Power Button habe ich jetzt auch hinbekommen.
                                createState('Bose_Preset_4', {type: 'boolean'});
                                createState('Bose_Preset_5', {type: 'boolean'});
                                createState('Bose_Preset_6', {type: 'boolean'});
                                    request.post({
                                        url:     'http://Bose IP:8090/key',
                                        body:    BodyString
                                    request.post({
                                        body:    BodyString
                                    request.post({
                                        body:    BodyString
                                    request.post({
                                        url:     'http://Bose IP:8090/volume',
                                        body:    BodyString
                                    PowerSetzen('Power');
                                on ({id: "javascript.0.Bose_Preset_4", val: true}, function () {
                                    PresetSetzen('PRESET_4');
                                    setState("javascript.0.Bose_Preset_4", false);
                                on ({id: "javascript.0.Bose_Preset_5", val: true}, function () {
                                    PresetSetzen('PRESET_5');
                                    setState("javascript.0.Bose_Preset_5", false);
                                on ({id: "javascript.0.Bose_Preset_6", val: true}, function () {
                                    PresetSetzen('PRESET_6');
                                    setState("javascript.0.Bose_Preset_6", false);
                                Leider kenne ich mich mit Javascript nicht aus und die Implementierung von /set_Zone überfordert mich. 🙂
                                Vielleicht hat das schon jemand erfolgreich laufen?
                                Gruß Oliver
                                • N
                                  @apollon77: gibts schon was neues zu dem Soundtouch Adapter?
                                  Viele Grüße
                                  Oliver
                                    Ich kam noch zu nichts …
                                    • SwedishChef
                                      SwedishChef last edited by
                                      Hallo Leute,
                                      ich bin seit ein paar Tagen dran, für die Bose SoundTouch einen Adapter zu basteln. Per JavaScript hab ich schon den code soweit beisammen, dass ich keys (z.B. 'POWER') per HTTP-push senden kann.
                                      Statusabfragen per HTTP-get (z.B. http://bosesoundtouch-ip:8090/volume) funktionieren auch und auch ein websocket, der Statusänderungen der soundbar mitbekommt und entsprechend parsed (aktuell volume, now_playing und presets) läuft.
                                      Jetzt starte ich, das ganze zu einem Adapter umzubauen, werke gerade am Aufbau einer debug-Umgebung mit VS Code. Mehr als ein leeres Adapter-Template von GitHub hab ich aber noch nicht am Laufen. Wird also noch eine Weile dauern.
                                      JavaScript hab ich erst mit diesem Projekt 'erlernt', war bisher rein auf C/C++/C# unterwegs. Brauche also für alles entsprechend Einarbeitungszeit.
                                      bis bald…
                                        Super, und danke für die Zwischeninfo. Würde dir gern dabei helfen aber ich kenne mich leider null damit aus. Danke das du dich der Sache annimmst.
                                          Du hast gesehen das es auf npm bereits Projekte gibt die das grundsätzlich machen ?! Oder baust du die ganze Kommunikation gerade selbst?
                                          • SwedishChef
                                            @apollon77:
                                            Du hast gesehen das es auf npm bereits Projekte gibt die das grundsätzlich machen ? ` Welche npm-Projekte gäbe es da?
                                            Das Grundgerüst für meinen Code stammt von https://github.com/ChrisScheffler/node-soundtouch. Ich musste hier aber einige Änderungen vornehmen, hauptsächlich beim Parsen der empfangenen Pakete. Hier dürfte sich an der API von Bose inzwischen einiges geändert haben.
                                            Ich verwende folgende npm-pakete:
                                            • request - sendet auf Port 8090 Befehle (push - Lautstärke setzen, POWER-key…) und Statusanforderungen (get - aktuelle Lautstärke, Now playing...)
                                            • ws - WebSocket, der auf port 8080 auf Updates der SoundTouch hört (Lautstärkeänderungen, Now playing…)
                                            • xml2js - parsen der empfangenen Daten
                                            • es6-promise - hab ich einfach so übernommen
                                            Hab gestern noch den ioBroker samt meinem Adapter-Template und VS-Code debug Umgebung auf meinem Windows PC grob zum Laufen gebracht. Jetzt muss ich noch meinen Script-code einpflegen. Sobald ich in den nächsten Tagen eine erste Version am Laufen hab, kann ich ihn zu Testzwecken bereitstellen. Auch hier muss ich mich erst Schlau machen, wie man da vorgeht.
                                            Bis demnächst.
                                            286
                                            65217
