    4. Synology und IR-Lesekopf für Stromzähler
      Carsten6273 @Glasfaser last edited by
      @glasfaser
      Ich habe gerade noch einmal das Log von ioBroker angesehen. Da sehe ich zwei Fehler, habe aber keine Idee was es sein könnte..
      2022-08-14 14:09:10.338 - info: host.buanet-iobroker1 iobroker.js-controller version 4.0.23 js-controller starting
      2022-08-14 14:09:10.344 - info: host.buanet-iobroker1 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-08-14 14:09:10.345 - info: host.buanet-iobroker1 hostname: buanet-iobroker1, node: v16.16.0
      2022-08-14 14:09:10.346 - info: host.buanet-iobroker1 ip addresses: 192.168.1.250 2001:16b8:1765:3100:211:32ff:fe8b:988f fe80::211:32ff:fe8b:988f
      2022-08-14 14:09:10.724 - info: host.buanet-iobroker1 connected to Objects and States
      2022-08-14 14:09:10.748 - info: host.buanet-iobroker1 Node.js version has changed from unknown to 16.16.0
      2022-08-14 14:09:10.808 - info: host.buanet-iobroker1 added notifications configuration of host
      2022-08-14 14:09:11.051 - info: host.buanet-iobroker1 3 instances found
      2022-08-14 14:09:11.060 - info: host.buanet-iobroker1 starting 3 instances
      2022-08-14 14:09:11.112 - info: host.buanet-iobroker1 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
      2022-08-14 14:09:11.152 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 1124
      2022-08-14 14:09:11.323 - info: host.buanet-iobroker1 Created UUID: 815f69c0-0883-443a-9893-4090acf8daf0
      2022-08-14 14:09:12.932 - info: admin.0 (1124) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 14:09:12.972 - info: admin.0 (1124) requesting all states
      2022-08-14 14:09:12.973 - info: admin.0 (1124) requesting all objects
      2022-08-14 14:09:13.042 - info: admin.0 (1124) received all objects
      2022-08-14 14:09:13.075 - info: admin.0 (1124) Request actual repository...
      2022-08-14 14:09:13.086 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-08-14 14:09:13.091 - info: admin.0 (1124) http server listening on port 8081
      2022-08-14 14:09:13.092 - info: admin.0 (1124) Use link "http://localhost:8081" to configure.
      2022-08-14 14:09:13.246 - warn: admin.0 (1124) Repository cannot be read: Active repo - stable
      2022-08-14 14:09:13.247 - warn: admin.0 (1124) Active repository "stable cannot be read
      2022-08-14 14:09:14.649 - info: admin.0 (1124) Repository received successfully.
      2022-08-14 14:09:15.120 - info: host.buanet-iobroker1 instance system.adapter.discovery.0 started with pid 1139
      2022-08-14 14:09:16.428 - info: discovery.0 (1139) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 14:09:19.125 - info: host.buanet-iobroker1 instance system.adapter.backitup.0 started with pid 1154
      2022-08-14 14:09:20.631 - info: backitup.0 (1154) starting. Version 2.4.9 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 14:09:20.689 - info: backitup.0 (1154) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-08-14 20:33:59.799 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-08-14 20:33:59.806 - info: admin.0 (1124) Got terminate signal TERMINATE_YOURSELF
      2022-08-14 20:33:59.810 - info: admin.0 (1124) terminating http server on port 8081
      2022-08-14 20:33:59.811 - info: admin.0 (1124) terminating
      2022-08-14 20:33:59.812 - info: admin.0 (1124) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-14 20:33:59.846 - info: host.buanet-iobroker1 stopInstance system.adapter.admin.0 send kill signal
      2022-08-14 20:34:00.358 - info: host.buanet-iobroker1 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-14 20:34:02.876 - info: host.buanet-iobroker1 instance system.adapter.admin.0 started with pid 20347
      2022-08-14 20:34:04.363 - info: admin.0 (20347) starting. Version 5.3.8 in /opt/iobroker/node_modules/iobroker.admin, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 20:34:04.401 - info: admin.0 (20347) requesting all states
      2022-08-14 20:34:04.402 - info: admin.0 (20347) requesting all objects
      2022-08-14 20:34:04.688 - info: admin.0 (20347) received all objects
      2022-08-14 20:34:05.030 - info: admin.0 (20347) Request actual repository...
      2022-08-14 20:34:05.040 - info: admin.0 (20347) http server listening on port 8081
      2022-08-14 20:34:05.041 - info: admin.0 (20347) Use link "http://localhost:8081" to configure.
      2022-08-14 20:34:05.180 - info: host.buanet-iobroker1 Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-08-14 20:34:05.446 - info: admin.0 (20347) failed connection to socket.io from ::ffff:192.168.1.66:
      2022-08-14 20:34:05.450 - error: admin.0 (20347) Error: "error"
      2022-08-14 20:34:06.824 - info: admin.0 (20347) Repository received successfully.
      2022-08-14 20:34:23.240 - info: discovery.0 (1139) Done discovering serial devices. 5 packages received
      2022-08-14 20:34:23.246 - info: discovery.0 (1139) Found 6 addresses
      2022-08-14 20:34:24.282 - warn: discovery.0 (1139) write: 10;VERSION;
      2022-08-14 20:34:24.284 - warn: discovery.0 (1139) Received: ����
      2022-08-14 20:34:24.343 - info: discovery.0 (1139) Discovery finished. Found new or modified 7 instances
      2022-08-14 20:34:24.398 - info: discovery.0 (1139) Discovery finished
      2022-08-14 20:35:04.096 - info: host.buanet-iobroker1 iobroker add smartmeter --host buanet-iobroker1
      2022-08-14 20:35:06.485 - info: host.buanet-iobroker1 iobroker NPM version: 8.11.0
      2022-08-14 20:35:06.486 - info: host.buanet-iobroker1 iobroker Installing iobroker.smartmeter@3.3.4... (System call)
      2022-08-14 20:35:12.858 - info: host.buanet-iobroker1 iobroker
      2022-08-14 20:35:12.859 - info: host.buanet-iobroker1 iobroker added 4 packages in 6s38 packages are looking for funding run `npm fund` for details
      2022-08-14 20:35:12.886 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 install adapter smartmeter
      2022-08-14 20:35:12.925 - info: host.buanet-iobroker1 iobroker upload [5] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
      2022-08-14 20:35:12.956 - info: host.buanet-iobroker1 iobroker upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
      2022-08-14 20:35:12.965 - info: host.buanet-iobroker1 iobroker upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
      2022-08-14 20:35:12.974 - info: host.buanet-iobroker1 iobroker upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
      2022-08-14 20:35:12.982 - info: host.buanet-iobroker1 iobroker upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
      2022-08-14 20:35:12.991 - info: host.buanet-iobroker1 iobroker upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/words.js words.js application/javascript
      2022-08-14 20:35:13.020 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter created/updated
      2022-08-14 20:35:13.047 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 create instance smartmeter
      2022-08-14 20:35:13.055 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.alive created
      2022-08-14 20:35:13.061 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.connected created
      2022-08-14 20:35:13.072 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.compactMode created
      2022-08-14 20:35:13.080 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.cpu created
      2022-08-14 20:35:13.086 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.cputime created
      2022-08-14 20:35:13.096 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memHeapUsed created
      2022-08-14 20:35:13.106 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memHeapTotal created
      2022-08-14 20:35:13.114 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.memRss created
      2022-08-14 20:35:13.124 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.uptime created
      2022-08-14 20:35:13.130 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.inputCount created
      2022-08-14 20:35:13.136 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.outputCount created
      2022-08-14 20:35:13.142 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.eventLoopLag created
      2022-08-14 20:35:13.148 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.sigKill created
      2022-08-14 20:35:13.154 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0.logLevel created
      2022-08-14 20:35:13.159 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object smartmeter.0.info created
      2022-08-14 20:35:13.164 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object smartmeter.0.info.connection created
      2022-08-14 20:35:13.168 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 Set default value of smartmeter.0.info.connection: false
      2022-08-14 20:35:13.180 - info: host.buanet-iobroker1 iobroker host.buanet-iobroker1 object system.adapter.smartmeter.0 created
      2022-08-14 20:35:14.200 - info: host.buanet-iobroker1 iobroker exit 0
      2022-08-14 20:35:16.209 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 started with pid 20461
      2022-08-14 20:35:18.025 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:18.113 - info: smartmeter.0 (20461) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 20:35:18.138 - error: smartmeter.0 (20461) Serial port device is undefined, check your configuration!
      2022-08-14 20:35:19.120 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:20.354 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:21.408 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:22.494 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:23.573 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:24.701 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:25.777 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:26.826 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:27.919 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:28.993 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:30.043 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:31.098 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:32.200 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:33.254 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:34.305 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:35.368 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:36.449 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:35:37.575 - info: smartmeter.0 (20461) List of port: []
      2022-08-14 20:36:57.106 - info: host.buanet-iobroker1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2022-08-14 20:36:57.111 - info: smartmeter.0 (20461) Got terminate signal TERMINATE_YOURSELF
      2022-08-14 20:36:57.113 - info: smartmeter.0 (20461) terminating
      2022-08-14 20:36:57.114 - info: smartmeter.0 (20461) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-14 20:36:57.150 - info: host.buanet-iobroker1 stopInstance system.adapter.smartmeter.0 send kill signal
      2022-08-14 20:36:57.647 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-14 20:37:00.173 - info: host.buanet-iobroker1 instance system.adapter.smartmeter.0 started with pid 20569
      2022-08-14 20:37:01.881 - info: smartmeter.0 (20569) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-14 20:37:11.933 - info: smartmeter.0 (20569) Error: No or too long answer from Serial Device after last request.
      2022-08-14 20:37:11.934 - warn: smartmeter.0 (20569) No or too long answer from Serial Device after last request.
      • Glasfaser
        Glasfaser @Carsten6273 last edited by
        @carsten6273
        Ok . Er wird sauber erkannt / durchgereicht .
        Hast du die Einstellungen so wie ich durchgeführt.
        1. ... Benutzerdefiniert ..
        2. /dev/ttyACM0
        • Glasfaser
          @carsten6273 sagte in Synology und IR-Lesekopf für Stromzähler:
            Homoran Global Moderator Administrators @Glasfaser last edited by
            @glasfaser
            deswegen
            @Carsten6273 immer zeigen und nicht erzählen
              Carsten6273 @Homoran last edited by
              So stelle ich es ein:
              klicke auf Speichern und Schliessen und beim nächsten Öffnen sehe ich wieder das
              • Glasfaser
                Glasfaser @Carsten6273 last edited by Glasfaser
                du must etwas warte ( so bei mir ) bis es alles kommt .
                dauert ca. 15-30 Sekunden ,
                erst so ...
                ... Zeit x .. danach ist es alles ausgefüllt .
                nutzt du VPN !?
                  @glasfaser
                  Du hast recht, ich war zu ungeduldig
                  Das Log sieht aber nicht viel besser aus
                  Und ansonsten kein VPN
                  • Glasfaser
                    Nimm alle Einstellungen so wie ich ... nur das bei dir /dev/ttyACM0 rein kommt
                    EDIT :
                    So wie ganz oben schon gezeigt :
                    C M 2 Replies Last reply Reply Quote 0
                      @glasfaser
                      Ich hätte jetzt
                      bekomme dann aber wieder einen Fehler zur seriellen Schnittstelle
                        Carsten6273 @Carsten6273 last edited by
                        @carsten6273
                        Wenn man es richtig macht, geht es jetzt auch
                        Glasfaser C 2 Replies Last reply Reply Quote 0
                        • Glasfaser
                          @carsten6273
                          Nicht so hektisch sein ... dann klappt es auch !!!!
                            @carsten6273
                            Ich teste gleich noch einmal weiter, aber in den Instanzen sehe ich den grünen Status.....
                            Was nutzt du zum Visualisieren der Daten?
                            • Glasfaser
                              sourceanalytix
                              Angregung ... Beispiel bei History_Wallbox
                              https://forum.iobroker.net/topic/40926/vorlage-view-visualisierung-emobility-vw-connect-audi
                                @glasfaser
                                Danke, ich werfe mal Morgen einen Blick drauf. Deine Reaktionsgeschwindigkeit war super. Und die Lösung so einfach. Viele andere Webseiten zeigen aber andere Einstellungen....
                                • Glasfaser
                                  Naja ... dazu sage ich mal nicht´s ....
                                  Das ist der Haupt-Thread , wenn du nochmal was brauchen solltest :
                                  https://forum.iobroker.net/topic/4685/adapter-smartmeter
                                  C 1 Reply Last reply Reply Quote 1
                                    @glasfaser
                                    Eine Frage ist bei mir heute noch aufgekommen:
                                    Ich habe den Stromzähler jetzt mit der Pin entsperrt und dieser zeigt dann die weiteren Infos wie Momentverbrauch usw. an. Leider kommen diese Infos jetzt nicht im iobroker an. Ich sehe weiterhin nur die Gesamtzähler. Was muss ich denn jetzt noch verändern?
                                    Glasfaser 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      Nichts ... die Datenpunkte werden dazu selbstständig erzeugt .
                                      Auch dauerhaft gespeichert ... codiert !
                                      C Glasfaser 2 Replies Last reply Reply Quote 0
                                        @glasfaser
                                        Danke für deine schnellen Antworten. Leider vermisse ich in meinen Daten noch den Momentanverbrauch. Meine Ansicht sieht so aus
                                        Eigentlich müsste ich doch noch weitere Werte sehen können oder?
                                        • Glasfaser
                                          Glasfaser @Glasfaser last edited by
                                          @Carsten6273
                                          Jipp da fehlen die freigeschalteten Werte
                                          @glasfaser sagte in Synology und IR-Lesekopf für Stromzähler:
                                          Wenn es freigeschaltet ist , dann wären auch die Datenpunkte z.b. mit Komma Werte
                                          • Glasfaser
                                            hast du auch die Schnittstelle/weiteres Datenpaket danach im Menue freigeschaltet .
                                            EDIT :
                                            Beispiel :
                                            Thomas W C 2 Replies Last reply Reply Quote 0
                                            5299
