    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Smartmeter ISKRA MT175 HICHI IR Lesekopf
      Homoran Global Moderator Administrators @JOBI59 last edited by
      @jobi59 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
      Und das Protokoll:
      bitte als text in code-tags!
      da steht was rotes
        JOBI59 @Homoran last edited by
        @homoran sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
        Und das Protokoll:
        da steht was rotes
        2022-08-15 12:10:14.187 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 872
        2022-08-15 12:10:21.895 - info: smartmeter.0 (872) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
        2022-08-15 12:10:21.992 - error: smartmeter.0 (872) Serial port device is undefined, check your configuration!
        2022-08-15 12:10:22.752 - info: smartmeter.0 (872) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        2022-08-15 12:10:27.782 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
        2022-08-15 12:10:27.802 - info: smartmeter.0 (872) Got terminate signal TERMINATE_YOURSELF
        2022-08-15 12:10:27.811 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
        2022-08-15 12:10:27.808 - info: smartmeter.0 (872) terminating
        2022-08-15 12:10:27.815 - info: smartmeter.0 (872) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-08-15 12:10:28.461 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-08-15 12:10:30.876 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 893
        2022-08-15 12:10:37.962 - info: smartmeter.0 (893) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
        2022-08-15 12:10:39.024 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        2022-08-15 12:12:38.174 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
        2022-08-15 12:12:38.180 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.
        2022-08-15 12:14:15.885 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        2022-08-15 12:17:32.014 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
        2022-08-15 12:19:38.202 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
        2022-08-15 12:19:38.204 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.```
        Ich hoffe, ich habe die richtige Passage.
          Homoran Global Moderator Administrators @JOBI59 last edited by Homoran
          nimm mal userdefined und trag manuell ein
            oder probiere den mal
              Habe ich gemacht, leider immer noch die gleiche Meldung.
              Das ist beim Protokoll dazugekommen.
              2022-08-15 12:24:03.175 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
              2022-08-15 12:24:39.369 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
              2022-08-15 12:25:01.641 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
              2022-08-15 12:25:01.658 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
              2022-08-15 12:25:01.658 - info: smartmeter.0 (893) Got terminate signal TERMINATE_YOURSELF
              2022-08-15 12:25:01.667 - info: smartmeter.0 (893) terminating
              2022-08-15 12:25:01.672 - info: smartmeter.0 (893) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2022-08-15 12:25:02.278 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2022-08-15 12:25:04.723 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1034
              2022-08-15 12:25:11.607 - info: smartmeter.0 (1034) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
              2022-08-15 12:27:11.777 - info: smartmeter.0 (1034) Error: No or too long answer from Serial Device after last request.
              2022-08-15 12:27:11.784 - warn: smartmeter.0 (1034) No or too long answer from Serial Device after last request.
                Habe ich gemacht
                Was von beiden?
                immer zeigen!
                immerhin sehe ich kein undefined mehr. Außer du hast es oben abgeschnittrn
                  Habe ich gemacht
                  Was von beiden?
                  immer zeigen!
                  Ich habe nun beides ausprobiert.
                  Einmal mit /dev/ttyS0
                  und einmal mit /dev/ttyAMA0
                  Bei beiden die gleichen Meldungen.
                  Hier das Protokoll. Einmal /dev/ttyS0 und dann /dev/ttyAMA0
                  2022-08-15 12:31:03.474 - info: smartmeter.0 (1034) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                  2022-08-15 12:31:20.343 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                  2022-08-15 12:31:20.359 - info: smartmeter.0 (1034) Got terminate signal TERMINATE_YOURSELF
                  2022-08-15 12:31:20.364 - info: smartmeter.0 (1034) terminating
                  2022-08-15 12:31:20.370 - info: smartmeter.0 (1034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-08-15 12:31:20.375 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
                  2022-08-15 12:31:20.977 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-08-15 12:31:23.440 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1054
                  2022-08-15 12:31:30.378 - info: smartmeter.0 (1054) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                  2022-08-15 12:31:38.541 - info: smartmeter.0 (1054) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                  2022-08-15 12:31:50.445 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                  2022-08-15 12:31:50.458 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
                  2022-08-15 12:31:50.460 - info: smartmeter.0 (1054) Got terminate signal TERMINATE_YOURSELF
                  2022-08-15 12:31:50.742 - info: smartmeter.0 (1054) terminating
                  2022-08-15 12:31:50.749 - info: smartmeter.0 (1054) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2022-08-15 12:31:51.359 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2022-08-15 12:31:53.514 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1070
                  2022-08-15 12:32:00.480 - info: smartmeter.0 (1070) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                  2022-08-15 12:34:00.652 - info: smartmeter.0 (1070) Error: No or too long answer from Serial Device after last request.
                  2022-08-15 12:34:00.659 - warn: smartmeter.0 (1070) No or too long answer from Serial Device after last request.
                  Homoran Ralla66 2 Replies Last reply Reply Quote 0
                    immer zeigen!
                    BITTE!
                    stell mal die Smartmeter Instanz auf debug
                    • Ralla66
                      Ralla66 Most Active @JOBI59 last edited by
                      @jobi59
                      Baudrate ?
                        Homoran Global Moderator Administrators @Ralla66 last edited by
                        @ralla66 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
                        Baudrate ?
                        sollte der Adapter mit dem Zähler aushandeln
                          immer zeigen!
                          BITTE!
                          OK, nehme ich mir zu Herzen.
                          Als nun Instanz auf folgendes eingestellt:
                          Instanz auf debug gestellt:
                          Jetzt laufen im Protokolle jede Mengen Daten auf und ich kann das LOG nich downlowden.
                          Deshalb hier mal direkt aus dem Protokoll.
                          smartmeter.0
                          	2022-08-15 12:49:58.376	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          smartmeter.0
                          	2022-08-15 12:49:58.375	debug	Plugin sentry destroyed
                          smartmeter.0
                          	2022-08-15 12:49:58.371	info	terminating
                          smartmeter.0
                          	2022-08-15 12:49:58.369	debug	SERIALPORT CLOSE
                          smartmeter.0
                          	2022-08-15 12:49:58.358	info	Got terminate signal TERMINATE_YOURSELF
                          smartmeter.0
                          	2022-08-15 12:49:58.140	debug	MATCH-RESULT MESSAGE: "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" -> null
                          smartmeter.0
                          	2022-08-15 12:49:58.138	debug	ADD NEW DATA (6510 + NEW 1)
                          Und das wiederholt sich ständig. Habe das Protokoll mit Paussieren angehalten um die anzeige zu bekommen.
                          Ich hoffe ich habe das richtig gemacht.
                            @jobi59 jetzt komme ich an meine Grenzen.
                            habe eben noch das hier gefunden
                            https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/iskraemeco_mt175
                            und bin etwas irritiert.
                            Ist das doch BIDI, also nicht "nur gelesen"?
                            J Ralla66 2 Replies Last reply Reply Quote 0
                              Es gibt von volkszähler ein Image für einen Raspberry Pi Zero W.
                              Das habe ich zum Test mal auf eine SD-Karte geschrieben und mit einem Pi Zero
                              getestet. Hier kommt im vzlogger die Daten an. Aber nur für eine kurze Zeit,
                              dann wird nichts mehr geloggt.
                              Darum bin ich auch zu iobroker und dem smartmeter Adapter gewechselt.
                              Sollte die ganzen Probleme, die ich bis jetzt habe, für mich bedeuten,
                              das ich mit meinem aktuellen Lesekopf keine daten nach iobroker bekomme.
                              So müsste ich überlegen, ob es was bringt einen HICHI Lesekopf mit WLAN zu erwerben.
                              Ich bin mittlerweile schon fast 3 Tag am Einstellen und auch am Verzweifeln.
                              • Ralla66
                                Ralla66 Most Active @Homoran last edited by Ralla66
                                mein MT175 gibt alle 5 sec über die IR die Daten preis ohne Anfrage der Daten.
                                J Homoran 2 Replies Last reply Reply Quote 1
                                  JOBI59 @Ralla66 last edited by
                                  mein MT175 gibt alle 5 sec über die IR die Daten preis.
                                  Hallo ralla66,
                                  und wie liest du die Daten?
                                    das ist natürlich jetzt eine wichtige Zusatzinformation!
                                    wenn der Kopf einen Schuss hat können wir lange spielen.
                                    Bestenfalls sitzt er nur nicht richtig und bekommt Streulicht ab.
                                    Mit der Aussage dass du mit minicom alles bekommst bin ich natürlich von einem funktionierenden System ausgegangen.
                                    Natürlich kann auch die Schnittstelle im Zähler einen Schlag weg haben. Dann nutzt auch ein neuer Kopf nichts.
                                    Grundsätzlich würde ich sagen, dass wenn minicom läuft, auch der Adapter laufen müsste (natürlich nicht parallel!)
                                      Danke!
                                      wie sind deine Einstellungen?
                                      Ralla66 J 2 Replies Last reply Reply Quote 0
                                      • Ralla66
                                        selbst Geschnitzt mit Tasmota Script
                                          Danke!
                                          Also ich versuche über iobroker mit smartmeter Adapter mit folgenden Einstellungen:
                                          Lesekopf und iobroker sind auf demselben Raspberry Pi.
                                            Danke!
                                            das ist auch in Ordnung, da Kommt ja auch was
                                            VIELLEICHT WEISS @APOLLON77 weiter
                                            6139
