    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Smartmeter ISKRA MT175 HICHI IR Lesekopf
      JOBI59 @Homoran last edited by
      @homoran sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
      @jobi59 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
      Und das Protokoll:
      bitte als text in code-tags!
      da steht was rotes
      2022-08-15 12:10:14.187 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 872
      2022-08-15 12:10:21.895 - info: smartmeter.0 (872) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-15 12:10:21.992 - error: smartmeter.0 (872) Serial port device is undefined, check your configuration!
      2022-08-15 12:10:22.752 - info: smartmeter.0 (872) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:10:27.782 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
      2022-08-15 12:10:27.802 - info: smartmeter.0 (872) Got terminate signal TERMINATE_YOURSELF
      2022-08-15 12:10:27.811 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
      2022-08-15 12:10:27.808 - info: smartmeter.0 (872) terminating
      2022-08-15 12:10:27.815 - info: smartmeter.0 (872) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-08-15 12:10:28.461 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-08-15 12:10:30.876 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 893
      2022-08-15 12:10:37.962 - info: smartmeter.0 (893) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
      2022-08-15 12:10:39.024 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:12:38.174 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
      2022-08-15 12:12:38.180 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.
      2022-08-15 12:14:15.885 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:17:32.014 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
      2022-08-15 12:19:38.202 - info: smartmeter.0 (893) Error: No or too long answer from Serial Device after last request.
      2022-08-15 12:19:38.204 - warn: smartmeter.0 (893) No or too long answer from Serial Device after last request.```
      Ich hoffe, ich habe die richtige Passage.
        Homoran Global Moderator Administrators @JOBI59 last edited by Homoran
        nimm mal userdefined und trag manuell ein
          oder probiere den mal
            Habe ich gemacht, leider immer noch die gleiche Meldung.
            Das ist beim Protokoll dazugekommen.
            2022-08-15 12:24:03.175 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
            2022-08-15 12:24:39.369 - info: smartmeter.0 (893) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
            2022-08-15 12:25:01.641 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
            2022-08-15 12:25:01.658 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
            2022-08-15 12:25:01.658 - info: smartmeter.0 (893) Got terminate signal TERMINATE_YOURSELF
            2022-08-15 12:25:01.667 - info: smartmeter.0 (893) terminating
            2022-08-15 12:25:01.672 - info: smartmeter.0 (893) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-08-15 12:25:02.278 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-08-15 12:25:04.723 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1034
            2022-08-15 12:25:11.607 - info: smartmeter.0 (1034) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
            2022-08-15 12:27:11.777 - info: smartmeter.0 (1034) Error: No or too long answer from Serial Device after last request.
            2022-08-15 12:27:11.784 - warn: smartmeter.0 (1034) No or too long answer from Serial Device after last request.
              Habe ich gemacht
              Was von beiden?
              immer zeigen!
              immerhin sehe ich kein undefined mehr. Außer du hast es oben abgeschnittrn
                Habe ich gemacht
                Was von beiden?
                immer zeigen!
                Ich habe nun beides ausprobiert.
                Einmal mit /dev/ttyS0
                und einmal mit /dev/ttyAMA0
                Bei beiden die gleichen Meldungen.
                Hier das Protokoll. Einmal /dev/ttyS0 und dann /dev/ttyAMA0
                2022-08-15 12:31:03.474 - info: smartmeter.0 (1034) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                2022-08-15 12:31:20.343 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                2022-08-15 12:31:20.359 - info: smartmeter.0 (1034) Got terminate signal TERMINATE_YOURSELF
                2022-08-15 12:31:20.364 - info: smartmeter.0 (1034) terminating
                2022-08-15 12:31:20.370 - info: smartmeter.0 (1034) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-08-15 12:31:20.375 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
                2022-08-15 12:31:20.977 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-08-15 12:31:23.440 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1054
                2022-08-15 12:31:30.378 - info: smartmeter.0 (1054) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                2022-08-15 12:31:38.541 - info: smartmeter.0 (1054) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"}]
                2022-08-15 12:31:50.445 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                2022-08-15 12:31:50.458 - info: host.JAKSioBrokerSlave stopInstance system.adapter.smartmeter.0 send kill signal
                2022-08-15 12:31:50.460 - info: smartmeter.0 (1054) Got terminate signal TERMINATE_YOURSELF
                2022-08-15 12:31:50.742 - info: smartmeter.0 (1054) terminating
                2022-08-15 12:31:50.749 - info: smartmeter.0 (1054) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2022-08-15 12:31:51.359 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2022-08-15 12:31:53.514 - info: host.JAKSioBrokerSlave instance system.adapter.smartmeter.0 started with pid 1070
                2022-08-15 12:32:00.480 - info: smartmeter.0 (1070) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v16.16.0, js-controller: 4.0.23
                2022-08-15 12:34:00.652 - info: smartmeter.0 (1070) Error: No or too long answer from Serial Device after last request.
                2022-08-15 12:34:00.659 - warn: smartmeter.0 (1070) No or too long answer from Serial Device after last request.
                Homoran Ralla66 2 Replies Last reply Reply Quote 0
                  immer zeigen!
                  BITTE!
                  stell mal die Smartmeter Instanz auf debug
                  • Ralla66
                    Ralla66 Most Active @JOBI59 last edited by
                    @jobi59
                    Baudrate ?
                      Homoran Global Moderator Administrators @Ralla66 last edited by
                      @ralla66 sagte in Smartmeter ISKRA MT175 HICHI IR Lesekopf:
                      Baudrate ?
                      sollte der Adapter mit dem Zähler aushandeln
                        immer zeigen!
                        BITTE!
                        OK, nehme ich mir zu Herzen.
                        Als nun Instanz auf folgendes eingestellt:
                        Instanz auf debug gestellt:
                        Jetzt laufen im Protokolle jede Mengen Daten auf und ich kann das LOG nich downlowden.
                        Deshalb hier mal direkt aus dem Protokoll.
                        smartmeter.0
                        	2022-08-15 12:49:58.376	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        smartmeter.0
                        	2022-08-15 12:49:58.375	debug	Plugin sentry destroyed
                        smartmeter.0
                        	2022-08-15 12:49:58.371	info	terminating
                        smartmeter.0
                        	2022-08-15 12:49:58.369	debug	SERIALPORT CLOSE
                        smartmeter.0
                        	2022-08-15 12:49:58.358	info	Got terminate signal TERMINATE_YOURSELF
                        smartmeter.0
                        	2022-08-15 12:49:58.140	debug	MATCH-RESULT MESSAGE: "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" -> null
                        smartmeter.0
                        	2022-08-15 12:49:58.138	debug	ADD NEW DATA (6510 + NEW 1)
                        Und das wiederholt sich ständig. Habe das Protokoll mit Paussieren angehalten um die anzeige zu bekommen.
                        Ich hoffe ich habe das richtig gemacht.
                          @jobi59 jetzt komme ich an meine Grenzen.
                          habe eben noch das hier gefunden
                          https://wiki.volkszaehler.org/hardware/channels/meters/power/edl-ehz/iskraemeco_mt175
                          und bin etwas irritiert.
                          Ist das doch BIDI, also nicht "nur gelesen"?
                          J Ralla66 2 Replies Last reply Reply Quote 0
                            Es gibt von volkszähler ein Image für einen Raspberry Pi Zero W.
                            Das habe ich zum Test mal auf eine SD-Karte geschrieben und mit einem Pi Zero
                            getestet. Hier kommt im vzlogger die Daten an. Aber nur für eine kurze Zeit,
                            dann wird nichts mehr geloggt.
                            Darum bin ich auch zu iobroker und dem smartmeter Adapter gewechselt.
                            Sollte die ganzen Probleme, die ich bis jetzt habe, für mich bedeuten,
                            das ich mit meinem aktuellen Lesekopf keine daten nach iobroker bekomme.
                            So müsste ich überlegen, ob es was bringt einen HICHI Lesekopf mit WLAN zu erwerben.
                            Ich bin mittlerweile schon fast 3 Tag am Einstellen und auch am Verzweifeln.
                            • Ralla66
                              Ralla66 Most Active @Homoran last edited by Ralla66
                              mein MT175 gibt alle 5 sec über die IR die Daten preis ohne Anfrage der Daten.
                              J Homoran 2 Replies Last reply Reply Quote 1
                                JOBI59 @Ralla66 last edited by
                                mein MT175 gibt alle 5 sec über die IR die Daten preis.
                                Hallo ralla66,
                                und wie liest du die Daten?
                                  das ist natürlich jetzt eine wichtige Zusatzinformation!
                                  wenn der Kopf einen Schuss hat können wir lange spielen.
                                  Bestenfalls sitzt er nur nicht richtig und bekommt Streulicht ab.
                                  Mit der Aussage dass du mit minicom alles bekommst bin ich natürlich von einem funktionierenden System ausgegangen.
                                  Natürlich kann auch die Schnittstelle im Zähler einen Schlag weg haben. Dann nutzt auch ein neuer Kopf nichts.
                                  Grundsätzlich würde ich sagen, dass wenn minicom läuft, auch der Adapter laufen müsste (natürlich nicht parallel!)
                                    Danke!
                                    wie sind deine Einstellungen?
                                    Ralla66 J 2 Replies Last reply Reply Quote 0
                                    • Ralla66
                                      selbst Geschnitzt mit Tasmota Script
                                        Danke!
                                        Also ich versuche über iobroker mit smartmeter Adapter mit folgenden Einstellungen:
                                        Lesekopf und iobroker sind auf demselben Raspberry Pi.
                                          Danke!
                                          das ist auch in Ordnung, da Kommt ja auch was
                                          VIELLEICHT WEISS @APOLLON77 weiter
                                            apollon77 @Homoran last edited by
                                            @homoran Es sind mal mindestens keine SML Daten ... Also Baudrate und ggf. Serielle settings prüfen
                                            6139
