    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by Thomas Braun
      @tiger
      What is the current situation?
      Check:
      sudo ln -s /usr/bin/node /usr/bin/nodejs
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      You are standig in the wrong directroy with the wrong command:
      npm install iobroker.js-controller
      pi@raspberrypi:/ $ npm install iobroker.js-controller
        Tiger @Thomas Braun last edited by Homoran
        This is what I've when checking :
        pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v10.24.1
        v14.20.0
        6.14.17
        pi
        /home/pi
        i'd retied in the correct folder (hoping it is the good one 😉
        with the lfollowing messages :
        pi@raspberrypi:~ $ npm install iobroker.js-controller
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        > iobroker.js-controller@4.0.23 preinstall /home/pi/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.17
        > unix-dgram@2.0.4 install /home/pi/node_modules/unix-dgram
        > node-gyp rebuild
        make: Entering directory '/home/pi/node_modules/unix-dgram/build'
          CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
        In file included from ../../nan/nan.h:60,
                         from ../src/unix_dgram.cc:5:
        /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:793:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/pi/.cache/node-gyp/14.20.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(unix_dgram, Initialize)
          SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
          COPY Release/unix_dgram.node
        make: Leaving directory '/home/pi/node_modules/unix-dgram/build'
        > ursa-optional@0.9.10 install /home/pi/node_modules/ursa-optional
        > node rebuild.js
        ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
        > diskusage@1.1.3 install /home/pi/node_modules/diskusage
        > node-gyp rebuild
        make: Entering directory '/home/pi/node_modules/diskusage/build'
          CXX(target) Release/obj.target/diskusage/src/main.o
                         from ../src/main.cpp:3:
        ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(diskusage, Init)
          CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
          SOLINK_MODULE(target) Release/obj.target/diskusage.node
          COPY Release/diskusage.node
        make: Leaving directory '/home/pi/node_modules/diskusage/build'
        > iobroker.js-controller@4.0.23 install /home/pi/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        Successfully migrated 2282 objects to Redis Sets
        object _design/system updated
          "defaultPrivate": "-----BEGIN RSA PRIVATE KEY-----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\r\nLQrsTuqtxiZzoneLoSuOcEsYGIB8TMHG1XNU6aGAJ0cI78mvbm8L\r\n-----END RSA PRIVATE KEY-----\r\n",
          "defaultPublic": "-----BEGIN CERTIFICATE-----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\r\nSYj6sP0IU2F3Gr3yMbYJAAHWsSagmHaLCViVXwwFDvQjLsZynHgBsZf0\r\n-----END CERTIFICATE-----\r\n"
        Update certificate defaultPrivate
        The object "system.certificates" was updated successfully.
        Update certificate defaultPublic
        > @root/acme@3.1.0 postinstall /home/pi/node_modules/@root/acme
        > node scripts/postinstall
        > esbuild@0.11.23 postinstall /home/pi/node_modules/esbuild
        > node install.js
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN pi@1.0.0 No description
        npm WARN pi@1.0.0 No repository field.
        + iobroker.js-controller@4.0.23
        added 312 packages from 288 contributors, removed 1 package and audited 313 packages in 85.481s
        18 packages are looking for funding
          run `npm fund` for details
        found 8 vulnerabilities (3 low, 2 moderate, 3 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        thanks
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @Tiger last edited by
          @tiger please use code-tags for the log
            @tiger sagte in Update System iobroker failed:
            /usr/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v10.24.1
            v14.20.0
            nodejs is not installed correctly.
            Can you understand German?
            Here is an extended guide on how to fix it:
            https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
            BTW: Still a wrong directory:
            You need to stand in /opt/iobroker for any operations with npm.
            Using npm is not recommended anyway. For this exakt reason.
            But first fix your nodejs-Installation.
              I do not understand german, but will try with google traductor... 🙂
              I come back after 🙂
                this command is executed in the pi's home instead of /opt/iobroker
                  in other languages f.i. french it will be worse for us
                    I'm trying to fix with your guide, but to complicate for me.
                    AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
                    I've a backup of my Sd Card.
                    If I use this backup and retry to upgrade my system,
                    do you have a guide with all steps to do?
                    When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
                    So if you've a guide, it should be more easy for a stupid guy like me
                      Tiger @Homoran last edited by
                      @homoran I completely agree, that's why I'm trying to explain in English 🙂
                        @tiger dou you have a backup of your iobroker installation?
                        done by backitup or iobroker backup?
                        then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
                        All will be built anew
                        T crunchip 2 Replies Last reply Reply Quote 0
                          Yes I've two backup in fact
                          • 1 made thanks to win32 image disc, so I've my image of yestarday
                            -1 made thanks to iobroker backup
                          My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
                            crunchip Forum Testing Most Active @Homoran last edited by
                            @homoran and install vis before backup if vis is used
                              Homoran Global Moderator Administrators @Tiger last edited by Homoran
                              win32 image disc,
                              this contains all the broken stuff.
                              not recommended!
                              what adapters did you install?
                              iobroker update -i
                                Thomas Braun Most Active @Tiger last edited by Homoran
                                @tiger
                                First action:
                                iobroker stop
                                sudo apt update
                                sudo apt full-upgrade
                                sudo reboot
                                Please post the output of
                                sudo apt update
                                  Homoran Global Moderator Administrators @crunchip last edited by
                                  @crunchip sagte in Update System iobroker failed:
                                  Restore
                                    to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                                    Adapters installed and needed was :
                                    • Siemens S7 adapter
                                    • Zigbee
                                    • Rfxcom
                                    • History
                                    iobroker update -i gives error too
                                    internal/modules/cjs/loader.js:905
                                    throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                    at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                                    at internal/main/run_main_module.js:17:47 {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: []
                                      Thomas Braun Most Active last edited by
                                      @tiger
                                      Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                                        History
                                        in the regular iobroker backup the history won't be included.
                                        You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                                          actually I'm trying your command, it's in progress.
                                          It should be better to re install everything... to have a proper installation up to date...
                                          But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                                          Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                                          regards
                                            @tiger
                                            So what is the output to
                                            sudo apt update
                                            then?
                                            update iobroker
                                            20392
