    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by Thomas Braun
      @tiger sagte in Update System iobroker failed:
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v10.24.1
      v14.20.0
      nodejs is not installed correctly.
      Can you understand German?
      Here is an extended guide on how to fix it:
      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
      BTW: Still a wrong directory:
      pi@raspberrypi:~ $ npm install iobroker.js-controller
      You need to stand in /opt/iobroker for any operations with npm.
      Using npm is not recommended anyway. For this exakt reason.
      But first fix your nodejs-Installation.
        Tiger @Thomas Braun last edited by
        I do not understand german, but will try with google traductor... 🙂
        I come back after 🙂
          Homoran Global Moderator Administrators @Tiger last edited by
          this command is executed in the pi's home instead of /opt/iobroker
            in other languages f.i. french it will be worse for us
              I'm trying to fix with your guide, but to complicate for me.
              AS I'm a newbee and so I don't understand what I'm doing, so it's difficult.
              I've a backup of my Sd Card.
              If I use this backup and retry to upgrade my system,
              do you have a guide with all steps to do?
              When try to update Iobroker.Admin, tells me that Node.JS 10 is not goof and I've to upgrade to V16, when made, I try to upgrade system, and another adapter has to be upgraded but the version of Node.JS V16 was not good for it and should be not more than V14...
              So if you've a guide, it should be more easy for a stupid guy like me
                Tiger @Homoran last edited by
                @homoran I completely agree, that's why I'm trying to explain in English 🙂
                  @tiger dou you have a backup of your iobroker installation?
                  done by backitup or iobroker backup?
                  then i would recommend to install all brandnew, best on a new SD card, so you'll still have the old one, and restore your backup to the new installation.
                  All will be built anew
                  T crunchip 2 Replies Last reply Reply Quote 0
                    Yes I've two backup in fact
                    • 1 made thanks to win32 image disc, so I've my image of yestarday
                      -1 made thanks to iobroker backup
                    My idea was to copy the imagedisc of yestarday and retry to upgrade thanks to a guide, and with the correct order of different upgrade
                      crunchip Forum Testing Most Active @Homoran last edited by
                      @homoran and install vis before backup if vis is used
                        Homoran Global Moderator Administrators @Tiger last edited by Homoran
                        win32 image disc,
                        this contains all the broken stuff.
                        not recommended!
                        what adapters did you install?
                        iobroker update -i
                          Thomas Braun Most Active @Tiger last edited by Homoran
                          @tiger
                          First action:
                          iobroker stop
                          sudo apt update
                          sudo apt full-upgrade
                          sudo reboot
                          Please post the output of
                          sudo apt update
                            Homoran Global Moderator Administrators @crunchip last edited by
                            @crunchip sagte in Update System iobroker failed:
                            Restore
                              to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
                              Adapters installed and needed was :
                              • Siemens S7 adapter
                              • Zigbee
                              • Rfxcom
                              • History
                              iobroker update -i gives error too
                              internal/modules/cjs/loader.js:905
                              throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                              at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                              at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
                              at internal/main/run_main_module.js:17:47 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                                Thomas Braun Most Active last edited by
                                @tiger
                                Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
                                  History
                                  in the regular iobroker backup the history won't be included.
                                  You have to save the directory /opt/iobroker/iobroker-data/history by yourself
                                    actually I'm trying your command, it's in progress.
                                    It should be better to re install everything... to have a proper installation up to date...
                                    But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
                                    Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
                                    regards
                                      @tiger
                                      So what is the output to
                                      sudo apt update
                                      then?
                                        command : sudo apt full-upgrade took time
                                        progress is 13% since some minutes
                                        Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                                        Progress: [ 13%] [#######...................................................]
                                          @tiger
                                          Then you never did update your system before.
                                          And you are running the Desktop-Variant. Both is a no-go.
                                            Once everything was working.. i Didn't made any update...
                                            Now It's because I would like to add some functionnality as Smappee on my Vis...
                                            I need it.
                                            or I will continue like that with old version and will continue to work as before 🙂
                                            Whatever, thanks to all for your help.
                                            progress is 48%
                                            update iobroker
                                            20392
