    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Homoran last edited by
      to be honest yestarday I tried to upgrade and was in same situation as now, so I took the imagedisc and works as before.
      Adapters installed and needed was :
      • Siemens S7 adapter
      • Zigbee
      • Rfxcom
      • History
      iobroker update -i gives error too
      internal/modules/cjs/loader.js:905
      throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
      at internal/main/run_main_module.js:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
        Thomas Braun Most Active last edited by
        @tiger
        Will you try to setup nodejs the proper way or trying around with your backups (which are most propably based on a wrong installation)
          Homoran Global Moderator Administrators @Tiger last edited by
          @tiger sagte in Update System iobroker failed:
          History
          in the regular iobroker backup the history won't be included.
          You have to save the directory /opt/iobroker/iobroker-data/history by yourself
            Tiger @Thomas Braun last edited by
            actually I'm trying your command, it's in progress.
            It should be better to re install everything... to have a proper installation up to date...
            But as you have notice, installation part is not my favorite things, I'm afroid to lost all my domotics and all i've already done with Alexa, Node red etc...
            Moreover, as I used the commande : iobroker backup, and I don't see the backup in /opt/iobroker... not sure I've the backup...
            regards
              @tiger
              So what is the output to
              sudo apt update
              then?
                command : sudo apt full-upgrade took time
                progress is 13% since some minutes
                Unpacking wolfram-engine (12.2.0+2021041101) over (12.0.1+2019062401) ...
                Progress: [ 13%] [#######...................................................]
                  Thomas Braun Most Active @Tiger last edited by
                  @tiger
                  Then you never did update your system before.
                  And you are running the Desktop-Variant. Both is a no-go.
                    Once everything was working.. i Didn't made any update...
                    Now It's because I would like to add some functionnality as Smappee on my Vis...
                    I need it.
                    or I will continue like that with old version and will continue to work as before 🙂
                    Whatever, thanks to all for your help.
                    progress is 48%
                      Homoran Global Moderator Administrators @Tiger last edited by Homoran
                      don't even think about this.
                      the day will come and you have to update an adapter you need.
                      due to the 'never change a running system' approach, now you are in trouble.
                      And then you'll be in big trouble for sure.
                      Please keep your system up to date always. for security and convenience
                        so, here the result
                        pi@raspberrypi:~ $ sudo apt update
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
                        Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                        Reading package lists... Done
                        Building dependency tree
                        All packages are up to date.
                          I'm not sure if it makes any sense to help you with that attitude...
                          Once again:
                          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            Tiger @Thomas Braun last edited by Tiger
                            I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple 😉
                            That's why I thank you for all.
                            pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            armv7l
                            /usr/bin/nodejs
                            /usr/local/bin/node
                            /usr/local/bin/npm
                            v10.24.1
                            v14.20.0
                            6.14.17
                            pi
                            /home/pi
                            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                            Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
                            nodejs:
                              Installed: 10.24.1-1nodesource1
                              Candidate: 10.24.1-1nodesource1
                              Version table:
                             *** 10.24.1-1nodesource1 500
                                    500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                    100 /var/lib/dpkg/status
                                 10.24.0~dfsg-1~deb10u1 500
                              that's a good point of view
                              so we will work on it, making you to understand it
                              that's our decision! hoping you learn something and possible give this to others
                                sudo rm /usr/local/bin/node
                                sudo rm /usr/local/bin/npm
                                curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                sudo apt install nodejs
                                sudo ln -s /usr/bin/node /usr/bin/nodejs
                                  Thanks, like to see that.
                                    @thomas-braun said in Update System iobroker failed:
                                    You'll find here after all I've done
                                    pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
                                    pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
                                    pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                                    ## Installing the NodeSource Node.js 16.x repo...
                                    ## Populating apt-get cache...
                                    + apt-get update
                                    ## Confirming "buster" is supported...
                                    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                                    ## Adding the NodeSource signing key to your keyring...
                                    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                                    gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                                    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                                    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                                    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                                    ## Running `apt-get update` for you...
                                    + apt-get update
                                    Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                                    Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
                                    Fetched 5,366 B in 1s (3,599 B/s)
                                    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                                    ## You may also need development tools to build native addons:
                                         sudo apt-get install gcc g++ make
                                    ## To install the Yarn package manager, run:
                                         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                                         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                         sudo apt-get update && sudo apt-get install yarn
                                    pi@raspberrypi:~ $ sudo apt install nodejs
                                    The following packages were automatically installed and are no longer required:
                                      gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                                      libncurses5 lxplug-volume python-colorzero
                                    Use 'sudo apt autoremove' to remove them.
                                    The following packages will be upgraded:
                                      nodejs
                                    1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    Need to get 23.6 MB of archives.
                                    After this operation, 38.8 MB of additional disk space will be used.
                                    Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
                                    Fetched 23.6 MB in 1min 14s (318 kB/s)
                                    Reading changelogs... Done
                                    (Reading database ... 167450 files and directories currently installed.)
                                    Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
                                    Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
                                    Setting up nodejs (16.16.0-deb-1nodesource1) ...
                                    Processing triggers for man-db (2.8.5-2) ...
                                    pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                                      sudo apt autoremove
                                      iobroker restart
                                      iobroker status
                                        pi@raspberrypi:~ $ sudo apt autoremove
                                        The following packages will be REMOVED:
                                        0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
                                        After this operation, 11.8 MB disk space will be freed.
                                        Do you want to continue? [Y/n] y
                                        (Reading database ... 165809 files and directories currently installed.)
                                        Removing gconf-service (3.2.6-5) ...
                                        Removing libgconf-2-4:armhf (3.2.6-5) ...
                                        Removing gconf2-common (3.2.6-5) ...
                                        Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
                                        Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
                                        Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
                                        Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
                                        Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
                                        Removing lxplug-volume (0.25) ...
                                        Removing python-colorzero (1.1) ...
                                        Processing triggers for sgml-base (1.29) ...
                                        Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
                                        pi@raspberrypi:~ $ iobroker restart
                                        pi@raspberrypi:~ $ iobroker status
                                        node:internal/modules/cjs/loader:936
                                          throw err;
                                            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                            at node:internal/main/run_main_module:17:47 {
                                          requireStack: []
                                        pi@raspberrypi:~ $
                                          juste one things more... I'd forgot to reboot ...
                                          I'd just reboot now...
                                          Sorry...
                                            @tiger
                                            Now the correct directories and commands:
                                            cd /opt/iobroker
                                            sudo -H -u iobroker npm install iobroker.js-controller
                                            iobroker stop
                                            iobroker fix
                                            iobroker start
                                            update iobroker
                                            20403
