    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger sagte in Update System iobroker failed:
      Once everything was working.. i Didn't made any update...
      I'm not sure if it makes any sense to help you with that attitude...
      Once again:
      uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        Tiger @Thomas Braun last edited by Tiger
        I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple 😉
        That's why I thank you for all.
        pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        armv7l
        /usr/bin/nodejs
        /usr/local/bin/node
        /usr/local/bin/npm
        v10.24.1
        v14.20.0
        6.14.17
        pi
        /home/pi
        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
        Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
        Reading package lists... Done
        Building dependency tree
        All packages are up to date.
        nodejs:
          Installed: 10.24.1-1nodesource1
          Candidate: 10.24.1-1nodesource1
          Version table:
         *** 10.24.1-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                100 /var/lib/dpkg/status
             10.24.0~dfsg-1~deb10u1 500
          Homoran Global Moderator Administrators @Tiger last edited by Homoran
          that's a good point of view
          so we will work on it, making you to understand it
          that's our decision! hoping you learn something and possible give this to others
            sudo rm /usr/local/bin/node
            sudo rm /usr/local/bin/npm
            curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
            sudo apt install nodejs
            sudo ln -s /usr/bin/node /usr/bin/nodejs
              Tiger @Homoran last edited by
              Thanks, like to see that.
                @thomas-braun said in Update System iobroker failed:
                You'll find here after all I've done
                pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
                pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
                pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
                ## Installing the NodeSource Node.js 16.x repo...
                ## Populating apt-get cache...
                + apt-get update
                Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
                Hit:3 http://archive.raspberrypi.org/debian buster InRelease
                ## Confirming "buster" is supported...
                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
                ## Adding the NodeSource signing key to your keyring...
                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
                + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                ## Running `apt-get update` for you...
                + apt-get update
                Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
                Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
                Fetched 5,366 B in 1s (3,599 B/s)
                ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                ## You may also need development tools to build native addons:
                     sudo apt-get install gcc g++ make
                ## To install the Yarn package manager, run:
                     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                     echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                     sudo apt-get update && sudo apt-get install yarn
                pi@raspberrypi:~ $ sudo apt install nodejs
                The following packages were automatically installed and are no longer required:
                  gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                  libncurses5 lxplug-volume python-colorzero
                Use 'sudo apt autoremove' to remove them.
                The following packages will be upgraded:
                  nodejs
                1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                Need to get 23.6 MB of archives.
                After this operation, 38.8 MB of additional disk space will be used.
                Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
                Fetched 23.6 MB in 1min 14s (318 kB/s)
                Reading changelogs... Done
                (Reading database ... 167450 files and directories currently installed.)
                Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
                Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
                Setting up nodejs (16.16.0-deb-1nodesource1) ...
                Processing triggers for man-db (2.8.5-2) ...
                pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                  sudo apt autoremove
                  iobroker restart
                  iobroker status
                    pi@raspberrypi:~ $ sudo apt autoremove
                    The following packages will be REMOVED:
                    0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
                    After this operation, 11.8 MB disk space will be freed.
                    Do you want to continue? [Y/n] y
                    (Reading database ... 165809 files and directories currently installed.)
                    Removing gconf-service (3.2.6-5) ...
                    Removing libgconf-2-4:armhf (3.2.6-5) ...
                    Removing gconf2-common (3.2.6-5) ...
                    Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
                    Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
                    Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
                    Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
                    Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
                    Removing lxplug-volume (0.25) ...
                    Removing python-colorzero (1.1) ...
                    Processing triggers for sgml-base (1.29) ...
                    Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
                    pi@raspberrypi:~ $ iobroker restart
                    pi@raspberrypi:~ $ iobroker status
                    node:internal/modules/cjs/loader:936
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                        at node:internal/main/run_main_module:17:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    pi@raspberrypi:~ $
                      juste one things more... I'd forgot to reboot ...
                      I'd just reboot now...
                      Sorry...
                        @tiger
                        Now the correct directories and commands:
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                        iobroker stop
                        iobroker fix
                        iobroker start
                          Problem with command
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                          npm WARN old lockfile
                          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                          npm WARN old lockfile This is a one-time fix-up, please be patient...
                          npm ERR! code 24
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR! command failed
                          npm ERR! command sh -c node iobroker.js setup first
                          npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
                          I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
                            ok!
                            delete it and try again.
                            if you are afraid of deleting, rename it
                              I rename directly in the folder /opt/iobroker the file
                              and remade the operation
                              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                              npm ERR! code 32
                              npm ERR! Successfully migrated 2282 objects to Redis Sets
                              npm ERR! object _design/system updated
                              npm ERR! host.raspberrypi install adapter backitup
                              npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                              npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                              npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                              npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                              npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                              npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                              npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                              npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                              npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                              npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                              npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                              npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                              npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                              log file 2022-08-15T14_47_08_695Z-debug-0.log
                              mikeal created this issue in request/request
                              open Request’s Past, Present and Future #3142
                                @tiger looks fine!
                                npm works correctly now
                                  @tiger
                                  iobroker list adapters
                                  iobroker list instances
                                    pi@raspberrypi:~ $ iobroker list adapters
                                      throw err;
                                      requireStack: []
                                      @tiger
                                      cd /opt/iobroker
                                      sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                        npm ERR! code E404
                                        npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                                        npm ERR! 404
                                        npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                                        npm ERR! 404 This package name is not valid, because
                                        npm ERR! 404  1. name can no longer contain capital letters
                                        npm ERR! 404
                                        npm ERR! 404 Note that you can also install from a
                                        npm ERR! 404 tarball, folder, http url, or git url.
                                        npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                                        log file2022-08-15T15_04_08_107Z-debug-0.log
                                          Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                          @tiger
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install admin@5.3.8
                                          sudo -H -u iobroker npm install js-controller
                                            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                            @thomas-braun sagte in Update System iobroker failed:
                                            @tiger
                                            cd /opt/iobroker
                                            sudo -H -u iobroker npm install .js-controller
                                            no
                                            why 404?
                                            iobroker.admin 5.3.8 is stable
                                            update iobroker
                                            20400
