    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by Tiger
      I understand you, but I would like to be up to date and continue, it's just because i dont like to not understand everything and take time of other poeple 😉
      That's why I thank you for all.
      pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      armv7l
      /usr/bin/nodejs
      /usr/local/bin/node
      /usr/local/bin/npm
      v10.24.1
      v14.20.0
      6.14.17
      pi
      /home/pi
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Hit:3 https://deb.nodesource.com/node_10.x buster InRelease
      Reading package lists... Done
      Building dependency tree
      All packages are up to date.
      nodejs:
        Installed: 10.24.1-1nodesource1
        Candidate: 10.24.1-1nodesource1
        Version table:
       *** 10.24.1-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.24.0~dfsg-1~deb10u1 500
        Homoran Global Moderator Administrators @Tiger last edited by Homoran
        @tiger sagte in Update System iobroker failed:
        that's a good point of view
        so we will work on it, making you to understand it
        that's our decision! hoping you learn something and possible give this to others
          Thomas Braun Most Active @Tiger last edited by
          sudo rm /usr/local/bin/node
          sudo rm /usr/local/bin/npm
          curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
          sudo apt install nodejs
          sudo ln -s /usr/bin/node /usr/bin/nodejs
            Tiger @Homoran last edited by
            Thanks, like to see that.
              @thomas-braun said in Update System iobroker failed:
              You'll find here after all I've done
              pi@raspberrypi:~ $ sudo rm /usr/local/bin/node
              pi@raspberrypi:~ $ sudo rm /usr/local/bin/npm
              pi@raspberrypi:~ $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
              ## Installing the NodeSource Node.js 16.x repo...
              ## Populating apt-get cache...
              + apt-get update
              Hit:2 https://deb.nodesource.com/node_10.x buster InRelease
              Hit:3 http://archive.raspberrypi.org/debian buster InRelease
              ## Confirming "buster" is supported...
              + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/buster/Release'
              ## Adding the NodeSource signing key to your keyring...
              + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
              gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
              ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
              + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' > /etc/apt/sources.list.d/nodesource.list
              + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x buster main' >> /etc/apt/sources.list.d/nodesource.list
              ## Running `apt-get update` for you...
              + apt-get update
              Get:3 https://deb.nodesource.com/node_16.x buster InRelease [4,584 B]
              Get:4 https://deb.nodesource.com/node_16.x buster/main armhf Packages [782 B]
              Fetched 5,366 B in 1s (3,599 B/s)
              ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
              ## You may also need development tools to build native addons:
                   sudo apt-get install gcc g++ make
              ## To install the Yarn package manager, run:
                   curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                   echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                   sudo apt-get update && sudo apt-get install yarn
              pi@raspberrypi:~ $ sudo apt install nodejs
              The following packages were automatically installed and are no longer required:
                gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
                libncurses5 lxplug-volume python-colorzero
              Use 'sudo apt autoremove' to remove them.
              The following packages will be upgraded:
                nodejs
              1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 23.6 MB of archives.
              After this operation, 38.8 MB of additional disk space will be used.
              Get:1 https://deb.nodesource.com/node_16.x buster/main armhf nodejs armhf 16.16.0-deb-1nodesource1 [23.6 MB]
              Fetched 23.6 MB in 1min 14s (318 kB/s)
              Reading changelogs... Done
              (Reading database ... 167450 files and directories currently installed.)
              Preparing to unpack .../nodejs_16.16.0-deb-1nodesource1_armhf.deb ...
              Unpacking nodejs (16.16.0-deb-1nodesource1) over (10.24.1-1nodesource1) ...
              Setting up nodejs (16.16.0-deb-1nodesource1) ...
              Processing triggers for man-db (2.8.5-2) ...
              pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
              ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                sudo apt autoremove
                iobroker restart
                iobroker status
                  pi@raspberrypi:~ $ sudo apt autoremove
                  The following packages will be REMOVED:
                  0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
                  After this operation, 11.8 MB disk space will be freed.
                  Do you want to continue? [Y/n] y
                  (Reading database ... 165809 files and directories currently installed.)
                  Removing gconf-service (3.2.6-5) ...
                  Removing libgconf-2-4:armhf (3.2.6-5) ...
                  Removing gconf2-common (3.2.6-5) ...
                  Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
                  Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
                  Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
                  Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
                  Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
                  Removing lxplug-volume (0.25) ...
                  Removing python-colorzero (1.1) ...
                  Processing triggers for sgml-base (1.29) ...
                  Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
                  pi@raspberrypi:~ $ iobroker restart
                  pi@raspberrypi:~ $ iobroker status
                  node:internal/modules/cjs/loader:936
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                      at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                      at node:internal/main/run_main_module:17:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  pi@raspberrypi:~ $
                    juste one things more... I'd forgot to reboot ...
                    I'd just reboot now...
                    Sorry...
                      @tiger
                      Now the correct directories and commands:
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.js-controller
                      iobroker stop
                      iobroker fix
                      iobroker start
                        Problem with command
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                        npm WARN old lockfile
                        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                        npm WARN old lockfile This is a one-time fix-up, please be patient...
                        npm ERR! code 24
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
                        I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
                          ok!
                          delete it and try again.
                          if you are afraid of deleting, rename it
                            I rename directly in the folder /opt/iobroker the file
                            and remade the operation
                            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                            npm ERR! code 32
                            npm ERR! Successfully migrated 2282 objects to Redis Sets
                            npm ERR! object _design/system updated
                            npm ERR! host.raspberrypi install adapter backitup
                            npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                            npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                            npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                            npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                            npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                            npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                            npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                            npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                            npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                            npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                            npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                            npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                            npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                            log file 2022-08-15T14_47_08_695Z-debug-0.log
                            mikeal created this issue in request/request
                            open Request’s Past, Present and Future #3142
                              @tiger looks fine!
                              npm works correctly now
                                @tiger
                                iobroker list adapters
                                iobroker list instances
                                  pi@raspberrypi:~ $ iobroker list adapters
                                    throw err;
                                    requireStack: []
                                    @tiger
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                                      npm ERR! code E404
                                      npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                                      npm ERR! 404
                                      npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                                      npm ERR! 404 This package name is not valid, because
                                      npm ERR! 404  1. name can no longer contain capital letters
                                      npm ERR! 404
                                      npm ERR! 404 Note that you can also install from a
                                      npm ERR! 404 tarball, folder, http url, or git url.
                                      npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                                      log file2022-08-15T15_04_08_107Z-debug-0.log
                                        Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                        @tiger
                                        cd /opt/iobroker
                                        sudo -H -u iobroker npm install admin@5.3.8
                                        sudo -H -u iobroker npm install js-controller
                                          Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                          @thomas-braun sagte in Update System iobroker failed:
                                          @tiger
                                          cd /opt/iobroker
                                          sudo -H -u iobroker npm install .js-controller
                                          no
                                          why 404?
                                          iobroker.admin 5.3.8 is stable
                                            Tiger @Homoran last edited by Tiger
                                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                            npm ERR! code ETARGET
                                            npm ERR! notarget No matching version found for admin@5.3.8.
                                            npm ERR! notarget In most cases you or one of your dependencies are requesting
                                            npm ERR! notarget a package version that doesn't exist.
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                            log 2022-08-15T15_11_04_483Z-debug-0.log
                                            update iobroker
                                            20400
