    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger sagte in Update System iobroker failed:
      sudo apt autoremove
      iobroker restart
      iobroker status
        Tiger @Thomas Braun last edited by
        pi@raspberrypi:~ $ sudo apt autoremove
        Reading package lists... Done
        Building dependency tree
        The following packages will be REMOVED:
          gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
          libncurses5 lxplug-volume python-colorzero
        0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
        After this operation, 11.8 MB disk space will be freed.
        Do you want to continue? [Y/n] y
        (Reading database ... 165809 files and directories currently installed.)
        Removing gconf-service (3.2.6-5) ...
        Removing libgconf-2-4:armhf (3.2.6-5) ...
        Removing gconf2-common (3.2.6-5) ...
        Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
        Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
        Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
        Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
        Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
        Removing lxplug-volume (0.25) ...
        Removing python-colorzero (1.1) ...
        Processing triggers for sgml-base (1.29) ...
        Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
        pi@raspberrypi:~ $ iobroker restart
        pi@raspberrypi:~ $ iobroker status
        node:internal/modules/cjs/loader:936
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
            at node:internal/main/run_main_module:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        pi@raspberrypi:~ $
          juste one things more... I'd forgot to reboot ...
          I'd just reboot now...
          Sorry...
            @tiger
            Now the correct directories and commands:
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.js-controller
            iobroker stop
            iobroker fix
            iobroker start
              Problem with command
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
              npm WARN old lockfile
              npm WARN old lockfile The package-lock.json file was created with an old version of npm,
              npm WARN old lockfile so supplemental metadata must be fetched from the registry.
              npm WARN old lockfile This is a one-time fix-up, please be patient...
              npm ERR! code 24
              npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
              npm ERR! command failed
              npm ERR! command sh -c node iobroker.js setup first
              npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
              I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
                Homoran Global Moderator Administrators @Tiger last edited by Homoran
                ok!
                delete it and try again.
                if you are afraid of deleting, rename it
                  Tiger @Homoran last edited by
                  I rename directly in the folder /opt/iobroker the file
                  and remade the operation
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  npm ERR! code 32
                  npm ERR! Successfully migrated 2282 objects to Redis Sets
                  npm ERR! object _design/system updated
                  npm ERR! host.raspberrypi install adapter backitup
                  npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                  npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                  log file 2022-08-15T14_47_08_695Z-debug-0.log
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                    @tiger looks fine!
                    npm works correctly now
                      @tiger
                      iobroker list adapters
                      iobroker list instances
                        pi@raspberrypi:~ $ iobroker list adapters
                          throw err;
                          requireStack: []
                          @tiger
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                            npm ERR! code E404
                            npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                            npm ERR! 404
                            npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                            npm ERR! 404 This package name is not valid, because
                            npm ERR! 404  1. name can no longer contain capital letters
                            npm ERR! 404
                            npm ERR! 404 Note that you can also install from a
                            npm ERR! 404 tarball, folder, http url, or git url.
                            npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                            log file2022-08-15T15_04_08_107Z-debug-0.log
                              Thomas Braun Most Active @Tiger last edited by Thomas Braun
                              @tiger
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install admin@5.3.8
                              sudo -H -u iobroker npm install js-controller
                                Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                                @thomas-braun sagte in Update System iobroker failed:
                                @tiger
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install .js-controller
                                no
                                why 404?
                                iobroker.admin 5.3.8 is stable
                                  Tiger @Homoran last edited by Tiger
                                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                  npm ERR! code ETARGET
                                  npm ERR! notarget No matching version found for admin@5.3.8.
                                  npm ERR! notarget In most cases you or one of your dependencies are requesting
                                  npm ERR! notarget a package version that doesn't exist.
                                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                  log 2022-08-15T15_11_04_483Z-debug-0.log
                                    expected it
                                    there seems to be a typo.
                                    i just saw!
                                    iobroker.admin not ioBroker.admin
                                    messing around on my mobile. didn't see at once. sorry!
                                      @tiger
                                      cd /opt/iobroker
                                      sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                        npm ERR! code ENOENT
                                        npm ERR! syscall chmod
                                        npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                        npm ERR! errno -2
                                        npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                        log 2022-08-15T15_15_37_253Z-debug-0.log
                                          @tiger
                                          cd /opt/iobroker
                                            @thomas-braun said in Update System iobroker failed:
                                            Sorry I made step by step, and if I see some errors I prefer to wait
                                            here the result
                                            npm ERR! code 32
                                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                            log2022-08-15T15_27_12_327Z-debug-0.log
                                            update iobroker
                                            20404
