    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      pi@raspberrypi:~ $ sudo apt autoremove
      Reading package lists... Done
      Building dependency tree
      The following packages will be REMOVED:
        gconf-service gconf2-common libbluetooth3 libexiv2-14 libgconf-2-4 libgfortran3 libgmime-2.6-0
        libncurses5 lxplug-volume python-colorzero
      0 upgraded, 0 newly installed, 10 to remove and 0 not upgraded.
      After this operation, 11.8 MB disk space will be freed.
      Do you want to continue? [Y/n] y
      (Reading database ... 165809 files and directories currently installed.)
      Removing gconf-service (3.2.6-5) ...
      Removing libgconf-2-4:armhf (3.2.6-5) ...
      Removing gconf2-common (3.2.6-5) ...
      Removing libbluetooth3:armhf (5.50-1.2~deb10u2+rpt1) ...
      Removing libexiv2-14:armhf (0.25-4+deb10u2) ...
      Removing libgfortran3:armhf (6.5.0-1+rpi1+b1) ...
      Removing libgmime-2.6-0:armhf (2.6.23+dfsg1-4) ...
      Removing libncurses5:armhf (6.1+20181013-2+deb10u2) ...
      Removing lxplug-volume (0.25) ...
      Removing python-colorzero (1.1) ...
      Processing triggers for sgml-base (1.29) ...
      Processing triggers for libc-bin (2.28-10+rpt2+rpi1+deb10u1) ...
      pi@raspberrypi:~ $ iobroker restart
      pi@raspberrypi:~ $ iobroker status
      node:internal/modules/cjs/loader:936
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
          at node:internal/main/run_main_module:17:47 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      pi@raspberrypi:~ $
        juste one things more... I'd forgot to reboot ...
        I'd just reboot now...
        Sorry...
          Thomas Braun Most Active @Tiger last edited by
          @tiger
          Now the correct directories and commands:
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          iobroker stop
          iobroker fix
          iobroker start
            Problem with command
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm WARN old lockfile
            npm WARN old lockfile The package-lock.json file was created with an old version of npm,
            npm WARN old lockfile so supplemental metadata must be fetched from the registry.
            npm WARN old lockfile This is a one-time fix-up, please be patient...
            npm ERR! code 24
            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
            npm ERR! command failed
            npm ERR! command sh -c node iobroker.js setup first
            npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
            I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
              Homoran Global Moderator Administrators @Tiger last edited by Homoran
              @tiger sagte in Update System iobroker failed:
              ok!
              delete it and try again.
              if you are afraid of deleting, rename it
                Tiger @Homoran last edited by
                I rename directly in the folder /opt/iobroker the file
                and remade the operation
                npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                npm ERR! code 32
                npm ERR! Successfully migrated 2282 objects to Redis Sets
                npm ERR! object _design/system updated
                npm ERR! host.raspberrypi install adapter backitup
                npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
                log file 2022-08-15T14_47_08_695Z-debug-0.log
                mikeal created this issue in request/request
                open Request’s Past, Present and Future #3142
                  @tiger looks fine!
                  npm works correctly now
                    @tiger
                    iobroker list adapters
                    iobroker list instances
                      pi@raspberrypi:~ $ iobroker list adapters
                        throw err;
                        requireStack: []
                        @tiger
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                          npm ERR! code E404
                          npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                          npm ERR! 404
                          npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                          npm ERR! 404 This package name is not valid, because
                          npm ERR! 404  1. name can no longer contain capital letters
                          npm ERR! 404
                          npm ERR! 404 Note that you can also install from a
                          npm ERR! 404 tarball, folder, http url, or git url.
                          npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                          log file2022-08-15T15_04_08_107Z-debug-0.log
                            Thomas Braun Most Active @Tiger last edited by Thomas Braun
                            @tiger
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install admin@5.3.8
                            sudo -H -u iobroker npm install js-controller
                              Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                              @thomas-braun sagte in Update System iobroker failed:
                              @tiger
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install .js-controller
                              no
                              why 404?
                              iobroker.admin 5.3.8 is stable
                                Tiger @Homoran last edited by Tiger
                                pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                                npm ERR! code ETARGET
                                npm ERR! notarget No matching version found for admin@5.3.8.
                                npm ERR! notarget In most cases you or one of your dependencies are requesting
                                npm ERR! notarget a package version that doesn't exist.
                                npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                                log 2022-08-15T15_11_04_483Z-debug-0.log
                                  expected it
                                  there seems to be a typo.
                                  i just saw!
                                  iobroker.admin not ioBroker.admin
                                  messing around on my mobile. didn't see at once. sorry!
                                    @tiger
                                    cd /opt/iobroker
                                    sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                      npm ERR! code ENOENT
                                      npm ERR! syscall chmod
                                      npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                      npm ERR! errno -2
                                      npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                      npm ERR! enoent This is related to npm not being able to find a file.
                                      npm ERR! enoent
                                      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                      log 2022-08-15T15_15_37_253Z-debug-0.log
                                        @tiger
                                        cd /opt/iobroker
                                          @thomas-braun said in Update System iobroker failed:
                                          Sorry I made step by step, and if I see some errors I prefer to wait
                                          here the result
                                          npm ERR! code 32
                                          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                          log2022-08-15T15_27_12_327Z-debug-0.log
                                            thats ok!
                                            but I'm confused.
                                            you twice installed 5.3.8 but it seems still not to be installed
                                            update iobroker
                                            20405
