    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      juste one things more... I'd forgot to reboot ...
      I'd just reboot now...
      Sorry...
        Thomas Braun Most Active @Tiger last edited by
        @tiger
        Now the correct directories and commands:
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker stop
        iobroker fix
        iobroker start
          Problem with command
          pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN old lockfile
          npm WARN old lockfile The package-lock.json file was created with an old version of npm,
          npm WARN old lockfile so supplemental metadata must be fetched from the registry.
          npm WARN old lockfile This is a one-time fix-up, please be patient...
          npm ERR! code 24
          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
          npm ERR! command failed
          npm ERR! command sh -c node iobroker.js setup first
          npm ERR! Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
          npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_39_15_503Z-debug-0.log
          I attached Log file2022-08-15T14_39_15_503Z-debug-0.log
            Homoran Global Moderator Administrators @Tiger last edited by Homoran
            @tiger sagte in Update System iobroker failed:
            ok!
            delete it and try again.
            if you are afraid of deleting, rename it
              Tiger @Homoran last edited by
              I rename directly in the folder /opt/iobroker the file
              and remade the operation
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm ERR! code 32
              npm ERR! Successfully migrated 2282 objects to Redis Sets
              npm ERR! object _design/system updated
              npm ERR! host.raspberrypi install adapter backitup
              npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
              npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
              npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
              npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
              npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
              npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
              npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
              npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
              npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
              npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
              npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
              npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
              npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T14_47_08_695Z-debug-0.log
              log file 2022-08-15T14_47_08_695Z-debug-0.log
              mikeal created this issue in request/request
              open Request’s Past, Present and Future #3142
                @tiger looks fine!
                npm works correctly now
                  @tiger
                  iobroker list adapters
                  iobroker list instances
                    pi@raspberrypi:~ $ iobroker list adapters
                    node:internal/modules/cjs/loader:936
                      throw err;
                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                        at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                        at node:internal/main/run_main_module:17:47 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                      @tiger
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
                        npm ERR! code E404
                        npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
                        npm ERR! 404
                        npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
                        npm ERR! 404 This package name is not valid, because
                        npm ERR! 404  1. name can no longer contain capital letters
                        npm ERR! 404
                        npm ERR! 404 Note that you can also install from a
                        npm ERR! 404 tarball, folder, http url, or git url.
                        npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
                        log file2022-08-15T15_04_08_107Z-debug-0.log
                          Thomas Braun Most Active @Tiger last edited by Thomas Braun
                          @tiger
                          cd /opt/iobroker
                          sudo -H -u iobroker npm install admin@5.3.8
                          sudo -H -u iobroker npm install js-controller
                            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                            @thomas-braun sagte in Update System iobroker failed:
                            @tiger
                            cd /opt/iobroker
                            sudo -H -u iobroker npm install .js-controller
                            no
                            why 404?
                            iobroker.admin 5.3.8 is stable
                              Tiger @Homoran last edited by Tiger
                              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                              npm ERR! code ETARGET
                              npm ERR! notarget No matching version found for admin@5.3.8.
                              npm ERR! notarget In most cases you or one of your dependencies are requesting
                              npm ERR! notarget a package version that doesn't exist.
                              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                              log 2022-08-15T15_11_04_483Z-debug-0.log
                                expected it
                                there seems to be a typo.
                                i just saw!
                                iobroker.admin not ioBroker.admin
                                messing around on my mobile. didn't see at once. sorry!
                                  @tiger
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                                    npm ERR! code ENOENT
                                    npm ERR! syscall chmod
                                    npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                                    npm ERR! errno -2
                                    npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                                    npm ERR! enoent This is related to npm not being able to find a file.
                                    npm ERR! enoent
                                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                                    log 2022-08-15T15_15_37_253Z-debug-0.log
                                      @tiger
                                      cd /opt/iobroker
                                        @thomas-braun said in Update System iobroker failed:
                                        Sorry I made step by step, and if I see some errors I prefer to wait
                                        here the result
                                        npm ERR! code 32
                                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                                        log2022-08-15T15_27_12_327Z-debug-0.log
                                          thats ok!
                                          but I'm confused.
                                          you twice installed 5.3.8 but it seems still not to be installed
                                            @tiger
                                            curl -fsL https://iobroker.net/fix.sh | bash -
                                            if that fails:
                                            curl -sLf https://iobroker.net/install.sh | bash -
                                            T Homoran 3 Replies Last reply Reply Quote 0
                                            update iobroker
                                            20405
