    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      iobroker list adapters
      iobroker list instances
        Tiger @Thomas Braun last edited by
        pi@raspberrypi:~ $ iobroker list adapters
        node:internal/modules/cjs/loader:936
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
            at node:internal/main/run_main_module:17:47 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
          @tiger
          cd /opt/iobroker
          sudo -H -u iobroker npm install ioBroker.admin@5.3.8
          sudo -H -u iobroker npm install iobroker.js-controller
            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
            npm ERR! code E404
            npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
            npm ERR! 404
            npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
            npm ERR! 404 This package name is not valid, because
            npm ERR! 404  1. name can no longer contain capital letters
            npm ERR! 404
            npm ERR! 404 Note that you can also install from a
            npm ERR! 404 tarball, folder, http url, or git url.
            npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
            log file2022-08-15T15_04_08_107Z-debug-0.log
              Thomas Braun Most Active @Tiger last edited by Thomas Braun
              @tiger
              cd /opt/iobroker
              sudo -H -u iobroker npm install admin@5.3.8
              sudo -H -u iobroker npm install js-controller
                Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
                @thomas-braun sagte in Update System iobroker failed:
                @tiger
                cd /opt/iobroker
                sudo -H -u iobroker npm install .js-controller
                no
                why 404?
                iobroker.admin 5.3.8 is stable
                  Tiger @Homoran last edited by Tiger
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
                  npm ERR! code ETARGET
                  npm ERR! notarget No matching version found for admin@5.3.8.
                  npm ERR! notarget In most cases you or one of your dependencies are requesting
                  npm ERR! notarget a package version that doesn't exist.
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
                  log 2022-08-15T15_11_04_483Z-debug-0.log
                    Homoran Global Moderator Administrators @Tiger last edited by Homoran
                    @tiger sagte in Update System iobroker failed:
                    expected it
                    there seems to be a typo.
                    i just saw!
                    iobroker.admin not ioBroker.admin
                    messing around on my mobile. didn't see at once. sorry!
                      @tiger
                      cd /opt/iobroker
                      sudo -H -u iobroker npm install iobroker.admin@5.3.8
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        npm ERR! code ENOENT
                        npm ERR! syscall chmod
                        npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                        npm ERR! errno -2
                        npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                        npm ERR! enoent This is related to npm not being able to find a file.
                        npm ERR! enoent
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                        log 2022-08-15T15_15_37_253Z-debug-0.log
                        mikeal created this issue in request/request
                        open Request’s Past, Present and Future #3142
                          @tiger
                          cd /opt/iobroker
                            @thomas-braun said in Update System iobroker failed:
                            Sorry I made step by step, and if I see some errors I prefer to wait
                            here the result
                            pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                            npm ERR! code 32
                            npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                            npm ERR! command failed
                            npm ERR! command sh -c node iobroker.js setup first
                            npm ERR! Successfully migrated 2282 objects to Redis Sets
                            npm ERR! object _design/system updated
                            npm ERR! host.raspberrypi install adapter backitup
                            npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                            npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                            npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                            npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                            npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                            npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                            npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                            npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                            npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                            npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                            npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                            npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                            npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                            npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                            log2022-08-15T15_27_12_327Z-debug-0.log
                              thats ok!
                              but I'm confused.
                              you twice installed 5.3.8 but it seems still not to be installed
                                @tiger
                                curl -fsL https://iobroker.net/fix.sh | bash -
                                if that fails:
                                curl -sLf https://iobroker.net/install.sh | bash -
                                T Homoran 3 Replies Last reply Reply Quote 0
                                  already in /opt/iobriker?
                                    @thomas-braun may there be another installation in an unappropriate directory?
                                      yes, but broker 😄
                                        first failed... and strange, as you said... seems not to be installed
                                        pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                        library: loaded
                                        Library version=2022-06-15
                                        ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                        Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                          The password is for your linux user, more specific for the root (or root entiteled) user.
                                            @thomas-braun that what I said.. I don't remember I'd one...
                                            As the raspberry was only for iobroker
                                            update iobroker
                                            20409
