    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      cd /opt/iobroker
      sudo -H -u iobroker npm install ioBroker.admin@5.3.8
      sudo -H -u iobroker npm install iobroker.js-controller
        Tiger @Thomas Braun last edited by
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker.admin@5.3.8
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/ioBroker.admin - Not found
        npm ERR! 404
        npm ERR! 404  'ioBroker.admin@5.3.8' is not in this registry.
        npm ERR! 404 This package name is not valid, because
        npm ERR! 404  1. name can no longer contain capital letters
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR!     [2022-08-15T15_04_08_107Z-debug-0.log
        log file2022-08-15T15_04_08_107Z-debug-0.log
          Thomas Braun Most Active @Tiger last edited by Thomas Braun
          @tiger
          cd /opt/iobroker
          sudo -H -u iobroker npm install admin@5.3.8
          sudo -H -u iobroker npm install js-controller
            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
            @thomas-braun sagte in Update System iobroker failed:
            @tiger
            cd /opt/iobroker
            sudo -H -u iobroker npm install .js-controller
            no
            why 404?
            iobroker.admin 5.3.8 is stable
              Tiger @Homoran last edited by Tiger
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
              npm ERR! code ETARGET
              npm ERR! notarget No matching version found for admin@5.3.8.
              npm ERR! notarget In most cases you or one of your dependencies are requesting
              npm ERR! notarget a package version that doesn't exist.
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
              log 2022-08-15T15_11_04_483Z-debug-0.log
                Homoran Global Moderator Administrators @Tiger last edited by Homoran
                @tiger sagte in Update System iobroker failed:
                expected it
                there seems to be a typo.
                i just saw!
                iobroker.admin not ioBroker.admin
                messing around on my mobile. didn't see at once. sorry!
                  @tiger
                  cd /opt/iobroker
                  sudo -H -u iobroker npm install iobroker.admin@5.3.8
                    pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    npm ERR! code ENOENT
                    npm ERR! syscall chmod
                    npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
                    npm ERR! errno -2
                    npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
                    npm ERR! enoent This is related to npm not being able to find a file.
                    npm ERR! enoent
                    npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
                    log 2022-08-15T15_15_37_253Z-debug-0.log
                    mikeal created this issue in request/request
                    open Request’s Past, Present and Future #3142
                      @tiger
                      cd /opt/iobroker
                        @thomas-braun said in Update System iobroker failed:
                        Sorry I made step by step, and if I see some errors I prefer to wait
                        here the result
                        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                        npm ERR! code 32
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! Successfully migrated 2282 objects to Redis Sets
                        npm ERR! object _design/system updated
                        npm ERR! host.raspberrypi install adapter backitup
                        npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                        npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                        npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                        npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                        npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                        npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                        npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                        npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                        npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                        npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                        npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                        log2022-08-15T15_27_12_327Z-debug-0.log
                          thats ok!
                          but I'm confused.
                          you twice installed 5.3.8 but it seems still not to be installed
                            @tiger
                            curl -fsL https://iobroker.net/fix.sh | bash -
                            if that fails:
                            curl -sLf https://iobroker.net/install.sh | bash -
                            T Homoran 3 Replies Last reply Reply Quote 0
                              already in /opt/iobriker?
                                @thomas-braun may there be another installation in an unappropriate directory?
                                  yes, but broker 😄
                                    first failed... and strange, as you said... seems not to be installed
                                    pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                                    library: loaded
                                    Library version=2022-06-15
                                    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                                    Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                      The password is for your linux user, more specific for the root (or root entiteled) user.
                                        @thomas-braun that what I said.. I don't remember I'd one...
                                        As the raspberry was only for iobroker
                                          @tiger
                                          The user 'pi' has a password.
                                            security issue if you didn't change it raspberry
                                            update iobroker
                                            20409
