    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
      @thomas-braun sagte in Update System iobroker failed:
      @tiger
      cd /opt/iobroker
      sudo -H -u iobroker npm install admin@5.3.8
      sudo -H -u iobroker npm install .js-controller
      no
      why 404?
      iobroker.admin 5.3.8 is stable
        Tiger @Homoran last edited by Tiger
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install admin@5.3.8
        npm ERR! code ETARGET
        npm ERR! notarget No matching version found for admin@5.3.8.
        npm ERR! notarget In most cases you or one of your dependencies are requesting
        npm ERR! notarget a package version that doesn't exist.
        npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_11_04_483Z-debug-0.log
        log 2022-08-15T15_11_04_483Z-debug-0.log
          Homoran Global Moderator Administrators @Tiger last edited by Homoran
          @tiger sagte in Update System iobroker failed:
          expected it
          there seems to be a typo.
          i just saw!
          iobroker.admin not ioBroker.admin
          messing around on my mobile. didn't see at once. sorry!
            Thomas Braun Most Active @Tiger last edited by
            @tiger
            cd /opt/iobroker
            sudo -H -u iobroker npm install iobroker.admin@5.3.8
            sudo -H -u iobroker npm install iobroker.js-controller
              Tiger @Thomas Braun last edited by
              pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.admin@5.3.8
              npm WARN deprecated har-validator@5.1.5: this library is no longer supported
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
              npm ERR! code ENOENT
              npm ERR! syscall chmod
              npm ERR! path /opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid
              npm ERR! errno -2
              npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/request/node_modules/uuid/bin/uuid'
              npm ERR! enoent This is related to npm not being able to find a file.
              npm ERR! enoent
              npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_15_37_253Z-debug-0.log
              log 2022-08-15T15_15_37_253Z-debug-0.log
              mikeal created this issue in request/request
              open Request’s Past, Present and Future #3142
                @tiger
                cd /opt/iobroker
                  @thomas-braun said in Update System iobroker failed:
                  Sorry I made step by step, and if I see some errors I prefer to wait
                  here the result
                  pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                  npm ERR! code 32
                  npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                  npm ERR! command failed
                  npm ERR! command sh -c node iobroker.js setup first
                  npm ERR! Successfully migrated 2282 objects to Redis Sets
                  npm ERR! object _design/system updated
                  npm ERR! host.raspberrypi install adapter backitup
                  npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                  npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                  npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                  npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                  npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                  npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                  npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                  npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                  npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                  npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                  npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                  npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                  npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                  npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
                  log2022-08-15T15_27_12_327Z-debug-0.log
                    thats ok!
                    but I'm confused.
                    you twice installed 5.3.8 but it seems still not to be installed
                      @tiger
                      curl -fsL https://iobroker.net/fix.sh | bash -
                      if that fails:
                      curl -sLf https://iobroker.net/install.sh | bash -
                      T Homoran 3 Replies Last reply Reply Quote 0
                        already in /opt/iobriker?
                          @thomas-braun may there be another installation in an unappropriate directory?
                            yes, but broker 😄
                              first failed... and strange, as you said... seems not to be installed
                              pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                              library: loaded
                              Library version=2022-06-15
                              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                              Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                                Thomas Braun Most Active @Tiger last edited by Thomas Braun
                                The password is for your linux user, more specific for the root (or root entiteled) user.
                                  @thomas-braun that what I said.. I don't remember I'd one...
                                  As the raspberry was only for iobroker
                                    @tiger
                                    The user 'pi' has a password.
                                      security issue if you didn't change it raspberry
                                        pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                                        library: loaded
                                            Welcome to the ioBroker installer!
                                            Installer version: 2022-06-03
                                            You might need to enter your password a couple of times.
                                            Installing prerequisites (1/4)
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                                        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                        Reading package lists... Done
                                        Changing npm registry to https://registry.npmjs.org
                                        Installed gcc-c++
                                            Creating ioBroker user and directory (2/4)
                                        Created /etc/sudoers.d/iobroker
                                        Directory /opt/iobroker created
                                            Installing ioBroker (3/4)
                                        npm ERR! code 32
                                        npm ERR! Successfully migrated 2308 objects to Redis Sets
                                        npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                                            Finalizing installation (4/4)
                                        Enabling autostart...
                                        Autostart enabled!
                                        Fixing directory permissions...
                                            ioBroker was installed successfully
                                            Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                                        You need to re-login before doing anything else on the console!
                                        log 2022-08-15T15_38_44_496Z-debug-0.log
                                        how to re-login?
                                          two different Subnets for LAN and WLAN?
                                            yes, both was connected, I tryed but
                                            This site can’t be reached
                                            localhost refused to connect.
                                            update iobroker
                                            20410
