    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Tiger @Thomas Braun last edited by
      @thomas-braun said in Update System iobroker failed:
      sudo -H -u iobroker npm install iobroker.js-controller
      Sorry I made step by step, and if I see some errors I prefer to wait
      here the result
      pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm WARN deprecated har-validator@5.1.5: this library is no longer supported
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm ERR! code 32
      npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
      npm ERR! command failed
      npm ERR! command sh -c node iobroker.js setup first
      npm ERR! Successfully migrated 2282 objects to Redis Sets
      npm ERR! object _design/system updated
      npm ERR! host.raspberrypi install adapter backitup
      npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
      npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
      npm ERR!     /home/iobroker/.npm/_logs/2022-08-15T15_27_12_327Z-debug-0.log
      log2022-08-15T15_27_12_327Z-debug-0.log
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Homoran Global Moderator Administrators @Tiger last edited by
        @tiger sagte in Update System iobroker failed:
        thats ok!
        but I'm confused.
        you twice installed 5.3.8 but it seems still not to be installed
          Thomas Braun Most Active @Tiger last edited by
          @tiger
          curl -fsL https://iobroker.net/fix.sh | bash -
          if that fails:
          curl -sLf https://iobroker.net/install.sh | bash -
          T Homoran 3 Replies Last reply Reply Quote 0
            already in /opt/iobriker?
              @thomas-braun may there be another installation in an unappropriate directory?
                yes, but broker 😄
                  first failed... and strange, as you said... seems not to be installed
                  pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                  library: loaded
                  Library version=2022-06-15
                  ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                  Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                    Thomas Braun Most Active @Tiger last edited by Thomas Braun
                    The password is for your linux user, more specific for the root (or root entiteled) user.
                      @thomas-braun that what I said.. I don't remember I'd one...
                      As the raspberry was only for iobroker
                        @tiger
                        The user 'pi' has a password.
                          security issue if you didn't change it raspberry
                            pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                            library: loaded
                                Welcome to the ioBroker installer!
                                Installer version: 2022-06-03
                                You might need to enter your password a couple of times.
                                Installing prerequisites (1/4)
                            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                            Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                            Reading package lists... Done
                            Changing npm registry to https://registry.npmjs.org
                            Installed gcc-c++
                                Creating ioBroker user and directory (2/4)
                            Created /etc/sudoers.d/iobroker
                            Directory /opt/iobroker created
                                Installing ioBroker (3/4)
                            npm ERR! code 32
                            npm ERR! Successfully migrated 2308 objects to Redis Sets
                            npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                                Finalizing installation (4/4)
                            Enabling autostart...
                            Autostart enabled!
                            Fixing directory permissions...
                                ioBroker was installed successfully
                                Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                            You need to re-login before doing anything else on the console!
                            log 2022-08-15T15_38_44_496Z-debug-0.log
                            how to re-login?
                              two different Subnets for LAN and WLAN?
                                Tiger @Homoran last edited by Tiger
                                yes, both was connected, I tryed but
                                This site can’t be reached
                                localhost refused to connect.
                                  Homoran Global Moderator Administrators @Tiger last edited by Homoran
                                  try with IP
                                  otherwise we have to proceed with the console
                                    already tryied
                                    same issue
                                    192.168.1.16 refused to connect.
                                      @Thomas-Braun
                                      npm ERR! code 32
                                      Did you see?
                                        did you call ip:8081?
                                        if yes, does iobroker list instances work this time?
                                          Of course I did...this is what I written : http://192.168.1.16:8081/
                                          but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                                          pi@raspberrypi:~ $ iobroker list instances
                                          node:internal/modules/cjs/loader:936
                                            throw err;
                                          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                              at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                              at node:internal/main/run_main_module:17:47 {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: []
                                            @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                            update iobroker
                                            20416
