    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Homoran Global Moderator Administrators @Tiger last edited by
      @tiger sagte in Update System iobroker failed:
      Sorry I made step by step, and if I see some errors I prefer to wait
      thats ok!
      but I'm confused.
      you twice installed 5.3.8 but it seems still not to be installed
        Thomas Braun Most Active @Tiger last edited by
        @tiger
        curl -fsL https://iobroker.net/fix.sh | bash -
        if that fails:
        curl -sLf https://iobroker.net/install.sh | bash -
        T Homoran 3 Replies Last reply Reply Quote 0
          Tiger @Thomas Braun last edited by
          @thomas-braun said in Update System iobroker failed:
          already in /opt/iobriker?
            @thomas-braun may there be another installation in an unappropriate directory?
              yes, but broker 😄
                first failed... and strange, as you said... seems not to be installed
                pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
                library: loaded
                Library version=2022-06-15
                ioBroker is not installed in /opt/iobroker! Cannot fix anything...
                Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                  Thomas Braun Most Active @Tiger last edited by Thomas Braun
                  The password is for your linux user, more specific for the root (or root entiteled) user.
                    @thomas-braun that what I said.. I don't remember I'd one...
                    As the raspberry was only for iobroker
                      @tiger
                      The user 'pi' has a password.
                        security issue if you didn't change it raspberry
                          pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                          library: loaded
                              Welcome to the ioBroker installer!
                              Installer version: 2022-06-03
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/4)
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                          Reading package lists... Done
                          Changing npm registry to https://registry.npmjs.org
                          Installed gcc-c++
                              Creating ioBroker user and directory (2/4)
                          Created /etc/sudoers.d/iobroker
                          Directory /opt/iobroker created
                              Installing ioBroker (3/4)
                          npm ERR! code 32
                          npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                          npm ERR! command failed
                          npm ERR! command sh -c node iobroker.js setup first
                          npm ERR! Successfully migrated 2308 objects to Redis Sets
                          npm ERR! object _design/system updated
                          npm ERR! host.raspberrypi install adapter backitup
                          npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                          npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                          npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                          npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                          npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                          npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                          npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                          npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                          npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                          npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                          npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                          npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                          npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                          npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                              Finalizing installation (4/4)
                          Enabling autostart...
                          Autostart enabled!
                          Fixing directory permissions...
                              ioBroker was installed successfully
                              Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                          You need to re-login before doing anything else on the console!
                          log 2022-08-15T15_38_44_496Z-debug-0.log
                          how to re-login?
                            two different Subnets for LAN and WLAN?
                              Tiger @Homoran last edited by Tiger
                              yes, both was connected, I tryed but
                              This site can’t be reached
                              localhost refused to connect.
                                Homoran Global Moderator Administrators @Tiger last edited by Homoran
                                try with IP
                                otherwise we have to proceed with the console
                                  already tryied
                                  same issue
                                  192.168.1.16 refused to connect.
                                    @Thomas-Braun
                                    npm ERR! code 32
                                    Did you see?
                                      did you call ip:8081?
                                      if yes, does iobroker list instances work this time?
                                        Of course I did...this is what I written : http://192.168.1.16:8081/
                                        but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                                        pi@raspberrypi:~ $ iobroker list instances
                                        node:internal/modules/cjs/loader:936
                                          throw err;
                                        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                            at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                            at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                            at node:internal/main/run_main_module:17:47 {
                                          code: 'MODULE_NOT_FOUND',
                                          requireStack: []
                                          @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                            for information, I found in directory the backup of this morning 😉 if it can help to restart from there...
                                            1.0k
                                            update iobroker
                                            20416
