    2. English
    3. ioBroker general
    4. Update System iobroker failed
      Thomas Braun Most Active @Tiger last edited by
      @tiger
      curl -fsL https://iobroker.net/fix.sh | bash -
      if that fails:
      curl -sLf https://iobroker.net/install.sh | bash -
      T Homoran 3 Replies Last reply Reply Quote 0
        Tiger @Thomas Braun last edited by
        @thomas-braun said in Update System iobroker failed:
        already in /opt/iobriker?
          @thomas-braun may there be another installation in an unappropriate directory?
            Homoran Global Moderator Administrators @Tiger last edited by
            @tiger sagte in Update System iobroker failed:
            yes, but broker 😄
              first failed... and strange, as you said... seems not to be installed
              pi@raspberrypi:/opt/iobroker $ curl -fsL https://iobroker.net/fix.sh | bash -
              library: loaded
              Library version=2022-06-15
              ioBroker is not installed in /opt/iobroker! Cannot fix anything...
              Second is on the road... but tell me that password will be asked few time... don't remember that I'had a password .. hum hum
                Thomas Braun Most Active @Tiger last edited by Thomas Braun
                The password is for your linux user, more specific for the root (or root entiteled) user.
                  @thomas-braun that what I said.. I don't remember I'd one...
                  As the raspberry was only for iobroker
                    @tiger
                    The user 'pi' has a password.
                      security issue if you didn't change it raspberry
                        pi@raspberrypi:/opt/iobroker $ curl -sLf https://iobroker.net/install.sh | bash -
                        library: loaded
                            Welcome to the ioBroker installer!
                            Installer version: 2022-06-03
                            You might need to enter your password a couple of times.
                            Installing prerequisites (1/4)
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 http://archive.raspberrypi.org/debian buster InRelease
                        Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                        Reading package lists... Done
                        Changing npm registry to https://registry.npmjs.org
                        Installed gcc-c++
                            Creating ioBroker user and directory (2/4)
                        Created /etc/sudoers.d/iobroker
                        Directory /opt/iobroker created
                            Installing ioBroker (3/4)
                        npm ERR! code 32
                        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
                        npm ERR! command failed
                        npm ERR! command sh -c node iobroker.js setup first
                        npm ERR! Successfully migrated 2308 objects to Redis Sets
                        npm ERR! object _design/system updated
                        npm ERR! host.raspberrypi install adapter backitup
                        npm ERR! These apt-get packages were already installed: cifs-utils, nfs-common
                        npm ERR! upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                        npm ERR! upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                        npm ERR! upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                        npm ERR! upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                        npm ERR! upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                        npm ERR! upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                        npm ERR! upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                        npm ERR! upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                        npm ERR! upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                        npm ERR! upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                        npm ERR! upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                        npm ERR! host.raspberrypi Invalid version of "admin". Installed "4.0.10", required ">=5.2.0"
                        npm ERR!     /home/pi/.npm/_logs/2022-08-15T15_38_44_496Z-debug-0.log
                            Finalizing installation (4/4)
                        Enabling autostart...
                        Autostart enabled!
                        Fixing directory permissions...
                            ioBroker was installed successfully
                            Open http://192.168.0.100 192.168.1.16:8081 in a browser and start configuring!
                        You need to re-login before doing anything else on the console!
                        log 2022-08-15T15_38_44_496Z-debug-0.log
                        how to re-login?
                          two different Subnets for LAN and WLAN?
                            Tiger @Homoran last edited by Tiger
                            yes, both was connected, I tryed but
                            This site can’t be reached
                            localhost refused to connect.
                              Homoran Global Moderator Administrators @Tiger last edited by Homoran
                              try with IP
                              otherwise we have to proceed with the console
                                already tryied
                                same issue
                                192.168.1.16 refused to connect.
                                  @Thomas-Braun
                                  npm ERR! code 32
                                  Did you see?
                                    did you call ip:8081?
                                    if yes, does iobroker list instances work this time?
                                      Of course I did...this is what I written : http://192.168.1.16:8081/
                                      but iobroker list instances has same result as before... (I tryied in directory /opt/iobroker and in the directory show here after)
                                      pi@raspberrypi:~ $ iobroker list instances
                                      node:internal/modules/cjs/loader:936
                                        throw err;
                                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:778:27)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:77:12)
                                          at node:internal/main/run_main_module:17:47 {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: []
                                        @tiger Sorry, I don't have any clue. we have to wait for @Thomas-Braun
                                          for information, I found in directory the backup of this morning 😉 if it can help to restart from there...
                                            if you want listen to my advice from earlier this day:
                                            take a new SD card, install the latest RaspberryOS lite and iobroker by curl -sLf https://iobroker.net/install.sh | bash - and restore it there.
                                            and don"t vorget to save your history folder
                                            1.0k
                                            update iobroker
                                            20416
